Staro 25.05.2015., 19:41   #241
iggi
Lokacija: qǝɹƃɐz
Postovi: 441
Ako su Quiet Edition dižem ruku...
iggi je offline   Reply With Quote
Staro 25.05.2015., 19:59   #242
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 919
Staro 26.05.2015., 00:42   #243
O9g1
Bee-do Bee-do Bee-do, TUP
O9g1's Avatar
Datum registracije: Aug 2009
Postovi: 323
i tata bi neki ventić sine, i tata bi...
Eh, da, maestralna pobjeda, čestitke i od mene i sretno sa workshopom! Držim fige!
Najljepše je kad čovjek radi ono što voli u životu i kad si još od toga može priuštiti pristojnu egzistenciju... kud ćeš bolje?!
(plan)
CPU: Intel i5 2500k (BX80623I52500K) cooled by Scythe Ninja3 (SCNJ-3000)
MBO: Asus P8Z68-V PRO/GEN3
RAM: 2x4GB Kingston 1600MHz, DDR3, XMP (KHX1600C9D3K2/8G)
GPU: GIGABYTE Radeon R9 290 4GB Windforce 3x (GV-R929OC-4GD)
SSD: Samsung 840 EVO 120GB (MZ-7TE120BW) - System
HDD1: WD Caviar Black 500GB (WD5001AALS) - Storage
HDD2: WD 250GB (WD2500JS-22MHB0 ) - Backup
ODD: Samsung 22/8/8/48/32x (SH-S222AB)
PSU: XFX XXX Edition P1-650X-CAG9 650W
CASE: Fractal Design Arc midi
FAN CONTROL: Scythe KAZE MASTER 5.25″ Bay Fan Controller (KM01-BK)
FAN: 2x Fractal Design Dynamic GP-14, 140 mm intake+2X Scythe S-flex 120mm (SFF21E) exhaust
OS: W10 x64
LCD:MASTER: LG 29UM57-P Ultra širok đubar, jooooj što ga volem... , SLAVE: Dell 17"
KEYBOARD: Logitech UltraX keyboard (Y-BL49)
MOUSE: Logitech G400
SOUND: Creative Sound Blaster X-Fi XtremeMusic
HEADSET: Steelseries Siberia v2
RALLYING GEAR: Logitech G25+homemade cokpit+handbrake (modani Genius MaxFighter F-16U)
IF IN DOUBT, FLAT OUT!!!
Don't touch it! It is mine! It's all miiiiineeee!!!
Lenovo Essential B580
CPU: Intel Celeron Dual Core B820 1.70GHz (2MB cache)
LCD: 15.6" HD LED 1366 x 768
GPU: Intel HD Graphics 3000
RAM: 4GB DDR3 1600MHz
HDD: 320GB SATA
ODD: DVDRW DL
PSU: Up to 4hours (Li-Ion 6 cell)
ETHERNET: Yes (Gb LAN)
COMM: Yes (802.11b/g/n)
BLUETOOTH: Yes
AUDIO IN/OUT: Yes
VGA OUT: Yes
HDMI: Yes
CASE: Lenovo
CARD READER: Yes
FINGERPRINT READER: Yes
CAMERA: Yes
OS: Windows 7 Profesional
Lenovo ThinkPad E560
CPU: Intel Core i7-6500U 2.5 GHz
LCD: 15.6 inch 16:9, 1920x1080, IPS-Panel, LED-Backlight, glossy: no
Extern LCD:Lenovo X24a, 24 inch 16:10, 1920x1200, IPS-Panel, LED-Backlight
GPU: AMD Radeon R7 M370 2 GB GDDR5
RAM: 16GB, 2 x 8 GB DDR3L-1600
HDD: 250GB SSD
ODD: DVD+/-RW
PSU: 48 Wh (6 cell)
ETHERNET: Gigabit Ethernet
COMM: 802.11ac, Bluetooth, Intel Dual Band Wireless-AC 8260 - M.2 Card
CONNECTIONS: 3 x USB 3.0, HDMI, VGA, OneLink connector, LAN, Headphone/microphone combo jack
CARD READER: 4 in 1 ( SD Card, MultiMediaCard, SDHC Card, SDXC Card )
CAMERA: Yes
OS: Windows 10 64x
Poštena, dobra i odgovorna trgovina +još jedna...
Straight roads are for fast cars, turns are for fast drivers!
O9g1 je offline   Reply With Quote
Staro 26.05.2015., 08:58   #244
V.I.P
Istrian Lifestyle
V.I.P's Avatar
Datum registracije: Jul 2009
Lokacija: Medulin
Postovi: 1,384
Nismo jedini forum koji smo mu pomogli tako da ce biti malo ventova da zadovolji sve nas
V.I.P je offline   Reply With Quote
Staro 26.05.2015., 09:44   #245
perich
I hate mondays..........
perich's Avatar
Datum registracije: Nov 2002
Lokacija: Zagreb - Zaprešić
Postovi: 1,541
ja samo da pohvalim Build, svaka cast.
Ventove podjeli ekipi, meni nije trenutno potrebno!
perich je offline   Reply With Quote
Staro 26.05.2015., 11:23   #246
arrow
arrow's Avatar
Datum registracije: Nov 2014
Lokacija: Zd
Postovi: 609
da se nadovezem, pratim ovaj build od pocetka
cestitke na pobjedi,stvarno si si dao truda
e sad pitanje, kako podnosi EK D5 pumpa tj. muci li se da cirkulira vodu kroz taj monster radijator? koliko ima Wata ?
pitam zato, sto vez duze vrijeme razmisljam o velikom radijatoru jer jednostavno nemam srece u potrazi za 240mm ili 360mm radijatoru na domacem trzistu
te trebam misljenje, hoce li moci atman pumpa 220v 25w 1300l/h pogurati kroz cijeli sistem? namjera mi je i cpu i gpu pod vodu
arrow je offline   Reply With Quote
Staro 26.05.2015., 12:27   #247
gaggo
Postovi: 528
Ne znam dal je bilo u posljednjim postovima, ali me zanima kolliko te kostao taj cijeli pothvat?
I jel oni kristalni kljucevi na kucistu imaju jos neku funkciju osim da budu ukrasni? Bilo bi fora, da se komp ne pali kad njih nema
gaggo je offline   Reply With Quote
Staro 26.05.2015., 12:51   #248
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 919
Autor arrow Pregled postova
Kod mene su d5 na nekom minimalnom protoku. Baš ništa se ne čuje dok rade i sve hladno. Ne znam za te 220V pumpe ali znam one za grijanje od nekih 50e u oglasima, da razbijaju. Uslov je da imaš mjesta, guraju i do 40m, sa malim pritiskom, rukom zaustaviš protok. Sa druge strane, iz Ljubljane sve stiže za 48h.
@gaggo: pleksi "kristali" su više dekoracija. Ipak Superman ne ide bez njih. Odrastao sam na Christopher Reeve verzijama. Bilo je raznih ideja ali i ženica koristi moj komp, pa nisam htio komplicirati.
Staro 26.05.2015., 13:54   #249
arrow
arrow's Avatar
Lokacija: Zd
Postovi: 609
pumpa atman mi je vec bila u sistemu sa manjim hladnjakom i odlicno je gonila ali sam je izbacio jer je bila prebucna, kad bih je dodatno izolirao mozda bih uspio pregusiti zvuk
te pumpe za centralno grijanje su ipak malo pre glomazne i nisu od plastike
kazes da ti d5 radi na minimalnom protoku? na koliko odprilike?
ovako mi je nesto u planu samo sa puno manje ventilatora,sliku sam nasao na netu
http://www.pohrani.com/?2M/R7/4jHOsPo/cool.jpg
btw isprike sto trpam svoje planove nevezano za tvoju temu ali mi se cinilo prikladno mjesto za pitat par savjeta
Staro 26.05.2015., 13:57   #250
Laszlo
Laszlo's Avatar
Postovi: 321
Autor MegaSkot Pregled postova
Jao, pa razlog vise da se ne moze upaliti bez njih!
Laszlo je offline   Reply With Quote
Staro 26.05.2015., 14:15   #251
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 919
@arrow: meni je pumpa od 500L/h išla kroz cpu, dvije grafe i dva 360 radijatora, bez problema. Sve će to raditi.
Radijator sa slike ima alu cijevi ako se ne varam i izbjegavaj. Imao sam prilike vidjeti šta bakar uradi aluminijumu kroz godinu-dvije. Izgrize ga kao miš. Kod mene u ovom modu je izmjenjivač toplote iz vanjskog dijela kućne klime, eto ti ideje. Ima ih po oglasima za smiješne novce. Meni je lik prodao dvije za 30e. Ubacivao sam mesing cijevi i svaku cijev vario i to je mnogo komplikovano. U Novom Sadu sam našao firmu koja pravi te izmjenjivače i jedan budući mod će biti tako urađen. Mnogo ljepše i jednostavnije a računica se na kraju svede na isto.
@Laszlo: sve znam ali...kad se oženiš, ne pitaš se ništa. Call me papuchar...
Staro 26.05.2015., 14:49   #252
D1viry
D1viry's Avatar
Lokacija: Slavonija
Postovi: 2,066
A, ne ne ne. Kupiš joj neki laptop i gotova stvar. Tako sam si ja riješio problem.
On topic: super si odradio build. Svaka ti dala.
Pošten trgovac: 1,2,3,4,5,6
Staro 05.07.2015., 05:04   #253
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 919
Što se tiče Bit-tech foruma:
Staro 05.07.2015., 11:59   #254
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Znaci prave se ludi? Smecari...
Staro 13.09.2015., 23:26   #255
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 919
Uskoro novi mod, bude li zainteresiranih za ovaj, nek mi se jave na PM.
Staro 30.11.2015., 04:10   #256
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 919
Tek sad vidim da sam ostao dužan fotke Vulture case-a.
Njega radim poslije Ivy.
Name:	vulture case 1.jpg‎
ID:	15644   Click image for larger version
Name:	vulture case 3.jpg‎
ID:	15645   Click image for larger version
Name:	vulture case 4.jpg‎
ID:	15646   Click image for larger version
Name:	vulture case 5.jpg‎
Staro 03.12.2015., 20:52   #257
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,330
Dobre fotke i foto lokacija za slikati na otvorenom .
P.S. Nego Jel citas ti PM-ove ?
Lewis je online   Reply With Quote
Staro 04.12.2015., 17:36   #258
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 919
Done.
Jurcam, ne znam gdje mi je glava od posla.
Staro 25.12.2015., 12:22   #259
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 919
Mod je izabran za jedan od dvanaest najboljih u 2015. godini, na bit-tech. Glasovanje u toku.
http://www.bit-tech.net/modding/2015...e-year-2015/26
Zadnje izmijenjeno od: MegaSkot. 25.12.2015. u 13:29.
Staro 25.12.2015., 17:53   #260
Prki
Prki's Avatar
Postovi: 1,317
Ne kužim zašto moraš glasati za tri moda.Ali onaj revenge si je bogami dao truda(samo da mu ne dođe do požara kakvog)
Prki je online   Reply With Quote
Staro 25.12.2015., 18:05   #261
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,291
Dobio si moj glas
Staro 28.12.2015., 11:39   #262
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,077
i moj
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 28.12.2015., 16:15   #263
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 919
Autor Prki Pregled postova
Ima 6 nagrada a realno, teško je izabrati samo jedan.
Hvala svima.
Staro 31.12.2015., 11:33   #264
turbojc
turbojc's Avatar
Datum registracije: Sep 2014
Lokacija: Slavonski Brod.
Postovi: 162
I moj glas si dobio!
Ali malo je to zeznuto kada moraš i konkurenciju gurati, but okej.
turbojc je offline   Reply With Quote
Staro 07.01.2016., 13:55   #265
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 919
Staro 07.01.2016., 16:02   #266
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,291
kako bi se reklo - zlatna sredina
Staro 13.01.2016., 14:05   #267
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 919
Chieftec, Stvarno su me oduševili, hvala im!
http://www.chieftec.eu/de/gehaeuse/m...nd/sj-06b.html
Staro 14.01.2016., 12:34   #268
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 919
Hvala svima koji su glasovali!!
3. mjesto!!!
http://www.bit-tech.net/modding/2016...-the-winners/1
Staro 14.01.2016., 12:45   #269
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,291
Daj me nemoj klat. Kako su te pokrali
Jesu ti se bar javili?
Staro 14.01.2016., 13:14   #270
Sphere
Datum registracije: Mar 2015
Postovi: 1,254
I Alienware area 51 izgleda slicno tom Chieftecu, tj razlika je prakticki u tome sta Chif ima prozor i prakticki je samo kontra okrenut po izgledu od Alienware-a.
Sphere je offline   Reply With Quote
