Staro 03.06.2010., 10:50   #4561
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
Good CenterLock
Rotors are always centered around the hub
Stripping a bolt and rendering the hub useless is eliminated
Rotors are more difficult to bend due to the reinforced inner spider ring
Easy rotor removal for shipping or transport
Hub weight can be less than ISO 6-bolt due to reduction of reinforced side area
Bad CenterLock
Compatibility issues have resulted in funky adapters
Lack of mass-market adoption and options from high-end hub makers Chris King, Industry Nine, etc.
Really only compatible with Shimano brakes, but their brakes are solid performers
Oddball 180mm diameter rotor vs. 185mm from other manufacturers
Rotors are slightly heavier and can cost twice as much
Need to buy a Centerlock wrench
Good 6-bolt
Rotors and adapters are readily available
Plethora of brake options
Lots of hub choices
Rotors can be half the price of CenterLock designs
Bad 6-bolt
Can install rotors off-center
Removal for shipping is cumbersome
Risk of stripping a bolt
Multiple points of failure (6 bolts)
izvor
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 03.06.2010., 12:32   #4562
murina
murina's Avatar
Postovi: 494
Vuco, SamFischerove pedale su sodomizirale Catkillerove i neželjena posljedica su te koje su ti ostavili u kutiji prekrivene novinama.
Staro 03.06.2010., 13:59   #4563
CatKiller
al se nekad dobro jelo...
CatKiller's Avatar
Postovi: 3,312
Autor Vuco Pregled postova
. Dobro, onda imam doma Shimano SPD M505 brijem pedale.
Moje su, ali sam ti ostavio da poklonis nekom jer:
a) nemam cleateve za njih
b) malo skripe
pa mi ih se ne da prodavati za 30 kn
Staro 03.06.2010., 16:58   #4564
murina
murina's Avatar
Postovi: 494
Postoji li kakva zaštita za ramu od bužira? Sve mi satralo (opet uglancan, pa bode u oči)
Staro 03.06.2010., 17:12   #4565
Red Dwarf
Bajker s AMD-om na dresu
Red Dwarf's Avatar
Postovi: 960
fiksiraj bužir...ili ramu prevuci zračnicom/neoprenskom zaštitom
donirajte spd distojreru da mu je manja investicija za šuze
i murina : nu ga đava odnija kad ćemo na savicu da me provozaš malo
aleluja...da bi promijenio gumu trebalo mi je ravno 58 minuta...supeeeer...ali eto sad makar imam oba dvije za blato pa će bajk malo bolje držati po sljemenu naravno pošto se nema para ukrao sam bratu stražnjeg bulldoga i uvalio mu ovu connection trail neće ni skužiti
prokleti obruči...
bome sutra ja lagano ujutro pravac sljeme ako bude vrijeme kao i sad...zaje*i ti subotu i nedjelju...taman lijepo sutra malo noge razgibam a navečer par pivkana strusim u medvedgradu...a i u subotu nemogu jer imam nekog "posla" ^^
sve u svemu 4-5 vrećica najlonskih za stvari ukoliko po putu počne kiša i lagano tura trg-tunel-lugarnica-pilana-tkalča, sladoled u ivice i marice , tkalča idalje i lagano doma...
Zadnje izmijenjeno od: Red Dwarf. 03.06.2010. u 19:40.
Red Dwarf je offline   Reply With Quote
Staro 03.06.2010., 21:26   #4566
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Evo, za subotu spremna još 2 moja frenda uz Salvareza koji nam dolazi u goste iz Ruda. Teško da će odvesti Lojstek u komadu, no idemo polagano, tempo 3h . Ja sam im svima rekao oko 9 otprilike na trgu, znači do 12 smo gore .
Staro 03.06.2010., 21:30   #4567
Željac
sto da napisem ?!
Željac's Avatar
Postovi: 880
i ja sam poprilicno siguran za subotu.
nista definitivno, ali je velika sansa !
Staro 03.06.2010., 21:37   #4568
borny
Too much busy
borny's Avatar
Postovi: 1,540
Dakle subota:
Dwarf
De5tr0yer
Vuco
Ja ću u 9 ići jer mi je prerano u 7 ustat nakon radnog dana.
Dakle subota:
Dwarf
De5tr0yer
Vuco
borny
9h kod konja?
Staro 03.06.2010., 21:43   #4569
Vuco
Vuco's Avatar
Postovi: 9,505
Dečki, di kupiti u Zagrebu silikonsku mast ? Spominje se Molydon, a jel netko zna osim njega gdje tražiti ?
Staro 03.06.2010., 22:18   #4570
MIK
no fear
MIK's Avatar
Lokacija: ZAGREB
Postovi: 894
Navodno u scuba dućanima: npr. sraga sub - Prilaz Gjure Deželića 40 - bočica 40kn.
MIK je offline   Reply With Quote
Staro 03.06.2010., 23:00   #4571
Vuco
Vuco's Avatar
Postovi: 9,505
Autor MIK Pregled postova
Odlično! Ja sam našao samo web shopove. Hvala puno MIK
Staro 03.06.2010., 23:24   #4572
Red Dwarf
Red Dwarf's Avatar
Postovi: 960
e pa seksam vas u zdrav mozak znači subota i termin u 9 ujutro i tempo 3 sata dogore?
e onda i mene računajte...
e jbmu onda moram zvati frenda da sutra pješačimo dogore...jbga...obećao nekim ljudima mms-ove sutra pa moram ispuniti obećanje...
Staro 04.06.2010., 01:03   #4573
tomiotok
Datum registracije: May 2009
Lokacija: Otok, Osijek
Postovi: 5
Što će ti uopće tak skupi pogoni? Uzmi deore jer ti je očito dovoljan, možda i previše
Koji bajk uopće voziš, ovako mi ne liči da si neki opasni bajker
vozim fuji tahoe sl, i s..bo sam fuji nabu zadnju i pogon zasada na njemu! i mislim da mi se vise isplati dati sada 500kn pa sam miran duze, ako ne i zauvijek nego se svako malo s popravcima zamarati, nemam iskustva s previse djelova ali imam iskustva s kidanjem!
tomiotok je offline   Reply With Quote
Staro 04.06.2010., 08:54   #4574
srale7
srale7's Avatar
Postovi: 5,782
Ako mi bike bude gotov do sutra, i ako se u petak ne zdevastiram, racunajte na mene za sljeme, jer vidim tempo ce biti lagan, tak da necu valjda stalno biti zadnji :P
srale7 je online   Reply With Quote
Staro 04.06.2010., 11:24   #4575
murina
murina's Avatar
Postovi: 494
Autor Red Dwarf Pregled postova
a kad đubre lije jbga. Prognoza mi kaže sutra veeeeliko sunce i 27 stupnjeva ali trenutno ne izgleda tako. Ja na žalost ne mogu sutra s vama.
Staro 04.06.2010., 11:30   #4576
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Vuco, imaš neku stazicu posebno pripremljenu za dole onda sutra?
Sutra se onda gore dogovorimo tko će uzet pakne
EDIT: I ako netko ima pumpicu za shock nek pliz ponese, kao da mi malo treba shock nadrukat.
Spoiler alert!
Zadnje izmijenjeno od: De5tr0yer. 04.06.2010. u 11:45.
Staro 04.06.2010., 12:01   #4577
murina
murina's Avatar
Postovi: 494
Sigurno je 20-ka zanimljiva nakon ove kiše
Računajte i na mene šta se tiče pakni pa javite šta ste dogovorili
Staro 04.06.2010., 14:31   #4578
Red Dwarf
Red Dwarf's Avatar
Postovi: 960
Sljeme (preliminary) report #5
Ovu turu bi nazvao : Jebem te živote ilitiga odoh ispucati frustracije na sljeme
Uvertira : Evo bio sam vam ja danas na sljemenu jutros...iskreno ja sutra i u nedjelju neidem. Zajebi ti to...obukao sam 100% kožne adidaske koje su mi promočile (one vojne s čepićima), grip je nikakav, svuda blato poprilične dubine, gore na kamenom dijelu su jezerca i skoro sam postao pokojnik na tom šugavom kamenju...
Sve u svemu vama svaka čast koji će te ići ali meni je danas bilo dosta. A i ako sam se ja uspio zaprljati što sam samo po lojsteku išao mogu misliti kako će te se tek vi
Opis ukratko :
Dakle ponjeo sa sobom litru ipo vode i 5dl medice i do gore lagano ipod u uši i udri po brijama tipa prodigy, safri duo, tiesto, armin itd... i uglavnom došao nekako do gore pritom strusivši samo pola litre vode i dec rakije (da me ugrije)jer je gore malo hladnije.
A dolje dolje sam putem cuclao onih ostalih 3 deci i naravno kako se prema dolje sve više zatopljavalo onda sam lijepo do dolje morao jednostavno skinuti majicu jer bi se i skuhao hvala bogu nije bilo ni žive duše na sljemenu. Ali na putu do dolje puštao se rock i naravno pjevalo se na sav glas uf prave karaoke su bile do dolje...queen, pink floydi, deep purple, the who...uf...pravi mali koncert je bio do tunela praktički
A najbolje je bilo kad sam došao do onog dijela gdje je ono ogromno blato i taman malo prije ipod prebaci na wish you were here...i idem ja onako polako i taman kad počne stih "So, so you think you can tell Heaven from Hell,
blue skies from pain." ugledam prokleto blato
Uf...definitivno mi je ovo bilo jedno od boljih sljemena jer sam lijepo laganica po rakijici, karaoke i mokra priroda
Staza :
ukratko očajna : staza do adolfovca vam je prvo sa skliskim kamenjem pa blatom i potočićima (od vuče stabala), onda od adolfovca do ceste je najgori dio : gnjecavo blato...čak sam se i skliznuo par puta iako su mi čizmice bile samo s čepićima dolje...po cijelom džonu... i onda inad ceste je bio sklisko kamenje i mini-vodopadi, naravno od lugarnice pa do tomislavovog doma sam bio na cesti
Što se nosilo : 4
para čarapa, dvije majice, jakna, dugi rukavi, ona moja AMD majica, 1.5lvode i pola litre rakije (medice). Naravno da su mi šugave kožne čizme promočile pa da sam imao 6 pari bilo bi taman Naravno netrebam ni govoriti da je gore hladno i sparno a nema zraaaaka...nikako...i još mi glupi kišobran bio prokišnjavao pa sam u tunelu morao osušiti kosu i cijelog sebe prije povratka u civilizaciju pošto sam bio ful mokar.
Uglavnom gore je bilo sparno i hladno i morao si se znojiti ful puno, a dolje da ga jbš nisi mogao biti u ičemu a kamo li majici...i onda vraćam se lojstekom nazad i taman dolje na početku idem prema žičari kad ono vidiš ide policija dangubiti prema gore...a ja u biciklističkoj majici ful otkopčanoj, na ipodu svira smoke on the water, ja u "hrvatska traži zvijezdu" elementu i u ruci medica
Al eto...i još zanimljivije je samo bilo da sam bio jedini u cijelom gradu u kratkim rukavima...i blatnjavim čizmama/potkoljenicama
E da evo vam par slikica...gore kod izvora i kod table tomislavov dom sam slikao svoju festinu tour de france (ja mislim da jedini imam narančastu) tako da nebi bilo da sam slike povukao s interneta
Dakle ovo je bilo na izvoru
A ovo kod vrha 1006metara nadmorske visine
A ovako vam izgleda 60% staze...ostatak je čisto blato
I ovo je mala životinjica 1 2 koju sam vidio prvi put u životu uživo u prirodi
Društvo :
Sigurno se mislite ko bi lud išao po ovoj kiši dogore...e pa vjerovali ili ne nsiam bio sam glasovi u glavi su mi pravili društvo ma trebao sam ići s jednim frendom koji je odustao a ja sam morao nekako odvrnuti sigurnosni frustracijski ventil pa eto otišao malo do gore i tako
Zadnje izmijenjeno od: Red Dwarf. 04.06.2010. u 14:36.
Staro 04.06.2010., 14:42   #4579
murina
murina's Avatar
Postovi: 494
Pa zašto pješke pobogu?
Staro 04.06.2010., 14:44   #4580
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Nenijeuopćeblatoijezera Kralj!
Čuj, čim se kiša smiri, ta voda oteče jako brzo.
Ako cijelu noć ne bude padalo ne bi trebalo bit strašno ujutro. Al dolje će bit legendarno blato sigurno
Šta si išo sam, mogo si sutra s nama taj užitak podijelit.
Svaka čast na daždevnjaku, vrlo su rijetki, ja i frend smo ih tražili par godina na vrapčaku gore na brdu i vidjeli smo ih svega 5-6...
Vidim da ti nije bježao pa si ga mogao fotkat. Inače, ako netko ne zna, ne ga dirat golim rukama, ove narančaste fleke imaju žlijezde iz kojih ispušta otrov, ne bi trebao biti ubojit ali izaziva svrbež i jako peče.
Spoiler alert!
Staro 04.06.2010., 14:44   #4581
Red Dwarf
Red Dwarf's Avatar
Postovi: 960
zato jer da sam išao s biciklom bi još i njega morao gurati...tamo da mi je bilo jednostavnije pješke
e,e...ovaj je bio miroljubi...ali šugavi mobitel radi šit slike pa je i daždevnjak ispao malo šit...to sam ga susreo kod onog slomljenog stabla (na onoj uskoj cestici koja ima onaj glupi uspon visok 2 metra i dug 1m [prije klupica])
Staro 04.06.2010., 14:45   #4582
Željac
sto da napisem ?!
Željac's Avatar
Postovi: 880
vidim, bit ce lijepo sutra...
moram putnu torbu spremit sa suhom odjecom
Staro 04.06.2010., 14:48   #4583
murina
murina's Avatar
Postovi: 494
poalaaa moram i ja nekako sutra gore, sigurno će bit fešta nizbrdo!!
Staro 04.06.2010., 14:53   #4584
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Ne znam kak vama, al meni navire adrenalin čim pomislim na spust
Spoiler alert!
Staro 04.06.2010., 14:57   #4585
murina
murina's Avatar
Postovi: 494
Prije par dana sam sanjao spust
Staro 04.06.2010., 15:04   #4586
Red Dwarf
Red Dwarf's Avatar
Postovi: 960
vjeruj mi murina ja bi na tvom mjestu ostao doma s onim gumama ako ih još imaš...te gume će ti biti zakurac i gore i dolje
Staro 04.06.2010., 15:06   #4587
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Autor murina Pregled postova
To mi je vrlo poznato, ja sam sanjao u više navrata, jednom da sam se raspičko tak jako da sam rebra polomio.
Jedna najavica, reba sl je bezecirana, stiže spd and I CAN'T WAIT!!!
EDIT: dwarf je pica.
EDIT2: za bornya, da, 9hundred konjska muda, tek sad vidio xD
Spoiler alert!
Staro 04.06.2010., 15:19   #4588
murina
murina's Avatar
Postovi: 494
Sljedeći tjedan kupujem one King Jim, a ako odem još s ovima gore dok je mokro onda pomozibože Ma da se sve proć. Najveći problem je zavoj desno, a pad terena lijevo (i obratno) pa treba iskombinirat kotrljanje i klizanje Ala gušta
Staro 04.06.2010., 15:24   #4589
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Imam bolje gume od tebe al svejedno patim od istih problema, to mi je valjda najveći strah
Sutra će stvarno bit veselo, moram šparat zadnju kočnicu jer su pakne pri kraju, a blato je i spust je.
Spoiler alert!
Staro 04.06.2010., 15:29   #4590
Nik
Nik's Avatar
Postovi: 454
Pametnije je da si kupis ili posudis kacigu.
