		#4561 |
			 In the ghetto
					Postovi: 1,943
		 Good CenterLock Rotors are always centered around the hub Stripping a bolt and rendering the hub useless is eliminated Rotors are more difficult to bend due to the reinforced inner spider ring Easy rotor removal for shipping or transport Hub weight can be less than ISO 6-bolt due to reduction of reinforced side area Bad CenterLock Compatibility issues have resulted in funky adapters Lack of mass-market adoption and options from high-end hub makers Chris King, Industry Nine, etc. Really only compatible with Shimano brakes, but their brakes are solid performers Oddball 180mm diameter rotor vs. 185mm from other manufacturers Rotors are slightly heavier and can cost twice as much Need to buy a Centerlock wrench Good 6-bolt Rotors and adapters are readily available Plethora of brake options Lots of hub choices Rotors can be half the price of CenterLock designs Bad 6-bolt Can install rotors off-center Removal for shipping is cumbersome Risk of stripping a bolt Multiple points of failure (6 bolts) izvor
	AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor  |
		#4563 |
			 al se nekad dobro jelo...
					Postovi: 3,312
	Zenfone 9 | Zephyrus M16 | HP Chromebook X2 | Tesla Model Y LR  |
		#4565 |
			 Bajker s AMD-om na dresu
					Postovi: 960
		 fiksiraj bužir...ili ramu prevuci zračnicom/neoprenskom zaštitom donirajte spd distojreru   da mu je manja investicija za šuzei murina : nu ga đava odnija kad ćemo na savicu da me provozaš malo ![]() aleluja...da bi promijenio gumu trebalo mi je ravno 58 minuta...supeeeer...ali eto sad makar imam oba dvije za blato pa će bajk malo bolje držati po sljemenu   naravno pošto se nema para ukrao sam bratu stražnjeg bulldoga i uvalio mu ovu connection trail   neće ni skužiti ![]() prokleti obruči... bome sutra ja lagano ujutro pravac sljeme ako bude vrijeme kao i sad...zaje*i ti subotu i nedjelju...taman lijepo sutra malo noge razgibam a navečer par pivkana strusim u medvedgradu...a i u subotu nemogu jer imam nekog "posla" ^^ ![]() sve u svemu 4-5 vrećica najlonskih za stvari ukoliko po putu počne kiša i lagano tura trg-tunel-lugarnica-pilana-tkalča, sladoled u ivice i marice  , tkalča idalje i lagano doma...Zadnje izmijenjeno od: Red Dwarf. 03.06.2010. u 19:40.  |
		#4566 |
				Lokacija: Zagreb, Tresnjevka
					Postovi: 9,505
		 Evo, za subotu spremna još 2 moja frenda uz Salvareza koji nam dolazi u goste iz Ruda. Teško da će odvesti Lojstek u komadu, no idemo polagano, tempo 3h   . Ja sam im svima rekao oko 9 otprilike na trgu, znači do 12 smo gore  .
	"Everything with a heartbeat can knock you down"  |
		#4567 |
			 sto da napisem ?!
					Postovi: 880
		 i ja sam poprilicno siguran za subotu. nista definitivno, ali je velika sansa ! ![]()  |
		#4568 |
			 Too much busy
					Postovi: 1,540
	It's nice to be important, but it's more important to be nice!  |
		#4570 |
			 no fear
				Lokacija: ZAGREB
					Postovi: 894
		#4571 |
					Postovi: 9,505
		#4572 |
					Postovi: 960
		 e pa seksam vas u zdrav mozak    znači subota i termin u 9 ujutro i tempo 3 sata dogore?e onda i mene računajte... e jbmu onda moram zvati frenda da sutra pješačimo dogore...jbga...obećao nekim ljudima mms-ove sutra pa moram ispuniti obećanje...  |
		#4573 |
			Datum registracije: May 2009
				Lokacija: Otok, Osijek
					Postovi: 5
		 vozim fuji tahoe sl, i s..bo sam fuji nabu zadnju i pogon zasada na njemu! i mislim da mi se vise isplati dati sada 500kn pa sam miran duze, ako ne i zauvijek nego se svako malo s popravcima zamarati, nemam iskustva s previse djelova ali imam iskustva s kidanjem!  |
		#4575 |
					Postovi: 494
		#4576 |
			 Avocado
					Postovi: 7,856
		 Vuco, imaš neku stazicu posebno pripremljenu za dole onda sutra?  ![]() Sutra se onda gore dogovorimo tko će uzet pakne ![]() EDIT: I ako netko ima pumpicu za shock nek pliz ponese, kao da mi malo treba shock nadrukat.
			Spoiler alert! Zadnje izmijenjeno od: De5tr0yer. 04.06.2010. u 11:45.  |
		#4578 |
					Postovi: 960
		 Sljeme (preliminary) report #5 Ovu turu bi nazvao : Jebem te živote ilitiga odoh ispucati frustracije na sljeme Uvertira : Evo bio sam vam ja danas na sljemenu jutros...iskreno ja sutra i u nedjelju neidem. Zajebi ti to...obukao sam 100% kožne adidaske koje su mi promočile (one vojne s čepićima), grip je nikakav, svuda blato poprilične dubine, gore na kamenom dijelu su jezerca i skoro sam postao pokojnik na tom šugavom kamenju... Sve u svemu vama svaka čast koji će te ići ali meni je danas bilo dosta. A i ako sam se ja uspio zaprljati što sam samo po lojsteku išao mogu misliti kako će te se tek vi ![]() Opis ukratko : Dakle ponjeo sa sobom litru ipo vode i 5dl medice   i do gore lagano ipod u uši i udri po brijama tipa prodigy, safri duo, tiesto, armin itd... i uglavnom došao nekako do gore pritom strusivši samo pola litre vode i dec rakije (da me ugrije)jer je gore malo hladnije.A dolje   dolje sam putem cuclao onih ostalih 3 deci i naravno kako se prema dolje sve više zatopljavalo onda sam lijepo do dolje morao jednostavno skinuti majicu jer bi se i skuhao   hvala bogu nije bilo ni žive duše na sljemenu. Ali na putu do dolje puštao se rock i naravno pjevalo se na sav glas   uf prave karaoke su bile do dolje...queen, pink floydi, deep purple, the who...uf...pravi mali koncert je bio do tunela praktički ![]() A najbolje je bilo kad sam došao do onog dijela gdje je ono ogromno blato   i taman malo prije ipod prebaci na wish you were here...i idem ja onako polako i taman kad počne stih "So, so you think you can tell Heaven from  Hell,blue skies from pain." ugledam prokleto blato ![]() Uf...definitivno mi je ovo bilo jedno od boljih sljemena jer sam lijepo laganica po rakijici, karaoke i mokra priroda ![]() Staza : ukratko očajna : staza do adolfovca vam je prvo sa skliskim kamenjem pa blatom i potočićima (od vuče stabala), onda od adolfovca do ceste je najgori dio : gnjecavo blato...čak sam se i skliznuo par puta iako su mi čizmice bile samo s čepićima dolje...po cijelom džonu... i onda inad ceste je bio sklisko kamenje i mini-vodopadi, naravno od lugarnice pa do tomislavovog doma sam bio na cesti Što se nosilo : 4 para čarapa, dvije majice, jakna, dugi rukavi, ona moja AMD majica, 1.5lvode i pola litre rakije (medice). Naravno da su mi šugave kožne čizme promočile pa da sam imao 6 pari bilo bi taman   Naravno netrebam ni govoriti da je gore hladno i sparno   a nema zraaaaka...nikako...i još mi glupi kišobran bio prokišnjavao pa sam u tunelu morao osušiti kosu i cijelog sebe prije povratka u civilizaciju pošto sam bio ful mokar.Uglavnom gore je bilo sparno i hladno i morao si se znojiti ful puno, a dolje da ga jbš nisi mogao biti u ičemu a kamo li majici...i onda vraćam se lojstekom nazad i taman dolje na početku idem prema žičari kad ono vidiš ide policija dangubiti prema gore...a ja u biciklističkoj majici ful otkopčanoj, na ipodu svira smoke on the water, ja u "hrvatska traži zvijezdu" elementu i u ruci medica ![]() Al eto...i još zanimljivije je samo bilo da sam bio jedini u cijelom gradu u kratkim rukavima...i blatnjavim čizmama/potkoljenicama E da evo vam par slikica...gore kod izvora i kod table tomislavov dom sam slikao svoju festinu tour de france (ja mislim da jedini imam narančastu) tako da nebi bilo da sam slike povukao s interneta Dakle ovo je bilo na izvoru A ovo kod vrha   1006metara nadmorske visineA ovako vam izgleda 60% staze...ostatak je čisto blato ![]() I ovo je mala životinjica 1 2 koju sam vidio prvi put u životu uživo u prirodi Društvo : Sigurno se mislite ko bi lud išao po ovoj kiši dogore...e pa vjerovali ili ne nsiam bio sam   glasovi u glavi su mi pravili društvo       ma trebao sam ići s jednim frendom koji je odustao a ja sam morao nekako odvrnuti sigurnosni frustracijski ventil pa eto otišao malo do gore i takoZadnje izmijenjeno od: Red Dwarf. 04.06.2010. u 14:36.  |
		#4580 |
			 Avocado
					Postovi: 7,856
		 Nenijeuopćeblatoijezera    Kralj!![]() Čuj, čim se kiša smiri, ta voda oteče jako brzo. ![]() Ako cijelu noć ne bude padalo ne bi trebalo bit strašno ujutro. Al dolje će bit legendarno blato sigurno ![]() Šta si išo sam, mogo si sutra s nama taj užitak podijelit. Svaka čast na daždevnjaku, vrlo su rijetki, ja i frend smo ih tražili par godina na vrapčaku gore na brdu i vidjeli smo ih svega 5-6... ![]() Vidim da ti nije bježao pa si ga mogao fotkat. Inače, ako netko ne zna, ne ga dirat golim rukama, ove narančaste fleke imaju žlijezde iz kojih ispušta otrov, ne bi trebao biti ubojit ali izaziva svrbež i jako peče.
	Spoiler alert!  |
		#4581 |
					Postovi: 960
		 zato jer da sam išao s biciklom bi još i njega morao gurati...tamo da mi je bilo jednostavnije pješke e,e...ovaj je bio miroljubi...ali šugavi mobitel radi šit slike pa je i daždevnjak ispao malo šit...to sam ga susreo kod onog slomljenog stabla (na onoj uskoj cestici koja ima onaj glupi uspon visok 2 metra i dug 1m [prije klupica])  |
		#4582 |
			 sto da napisem ?!
					Postovi: 880
		 vidim, bit ce lijepo sutra...     ![]() moram putnu torbu spremit sa suhom odjecom   ![]()  |
		#4587 |
			 Avocado
					Postovi: 7,856
		 To mi je vrlo poznato, ja sam sanjao u više navrata, jednom da sam se raspičko tak jako da sam rebra polomio. Jedna najavica, reba sl je bezecirana, stiže spd and I CAN'T WAIT!!! ![]() EDIT: dwarf je pica. EDIT2: za bornya, da, 9hundred konjska muda, tek sad vidio xD
	Spoiler alert!  |
		#4588 |
					Postovi: 494
		 Sljedeći tjedan kupujem one King Jim, a ako odem još s ovima gore dok je mokro onda pomozibože    Ma da se sve proć. Najveći problem je zavoj desno, a pad terena lijevo (i obratno) pa treba iskombinirat kotrljanje i klizanje   Ala gušta ![]()  |
		#4589 |
			 Avocado
					Postovi: 7,856
		 Imam bolje gume od tebe al svejedno patim od istih problema, to mi je valjda najveći strah  ![]() Sutra će stvarno bit veselo, moram šparat zadnju kočnicu jer su pakne pri kraju, a blato je i spust je. ![]()
	Spoiler alert!  |
