Staro 02.09.2014., 17:41   #1
nikve
nikve's Avatar
Datum registracije: Nov 2013
Postovi: 206
Nasumicno gasenje drugog monitora
Pozdrav, imam problem sa nasumicnim gasenjem drugog monitora. Znaci monitor se ugasi i upali sam od sebe u totalno nasumicno vrijeme, ali prosjecno 5-7 puta u sat vremena, nebi mi bio toliki problem da nisam gamer, jer kad dode do tog gasenja monitora, meni igra smrzne na dvije sec dok se drugi monitor upali, nadam se da ste shvatili problem, pisem preko moba pa isprike za greske pri pisanju.
nikve je offline   Reply With Quote
Staro 03.09.2014., 21:36   #2
nikve
nikve's Avatar
Postovi: 206
Bilo tko prije nego dobijem zivcani slom ?
Staro 04.09.2014., 01:19   #3
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,073
možda se grafička buni iz nekog razloga. ajd ih swapaj pa vidi dal će drugi radit isto to
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 11.09.2014., 21:14   #4
Talaba
Talaba's Avatar
Datum registracije: Jul 2014
Lokacija: Serbija
Postovi: 108
Da li ti je kabal ispravan i dobro nalegao na te izlaze ulaze od grafičke i monitora kako se već zvaše??
Talaba je offline   Reply With Quote
Staro 20.09.2014., 15:33   #5
nikve
nikve's Avatar
Postovi: 206
Jedan monitor je spojen na DVI, drug na HDMI. Nisam kod kuce vec tjedan dana pa ne mogu provjeriti jos jel sve u redu spojeno, ali trebalo bi biti sve spojeno kako spada. Svakako provjerim jos kako je spojeno, i moram probat zamjeniti monitore,.jer mi se gasi samo ovaj desni, tj sporedni.
Staro 06.12.2014., 13:41   #6
nikve
nikve's Avatar
Postovi: 206
Bump, problem se vratio. Isprobano sve moguce, ima li netko ideju do cega bi moglo jos biti ? Ili da zovem instar i saljem monitor na servis. Znaci jedan monitor (glavni) je spojen na DVI, drugi na HDMI. Ovaj koji je na HDMI spojen se gasi/pali sam od sebe i to najvise dok igram, zatim i igra trza i onda dobijem mali zivcani slom.
Staro 06.12.2014., 14:34   #7
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,835
Daj za probu provjeri da li se u igrama isključuje i kad imaš isključen screensaver i gašenje monitora u power saving opcijama.
Staro 10.12.2014., 13:26   #8
n E v E n
n E v E n's Avatar
Lokacija: At Home
Postovi: 208
Ja imam isti problem kao i ti samo sa 70+ racunala, ali umjesto HDMI, mi imamo DisplayPort i ista stvar se dogadja.
Znaci Windowsi se podignu, sve radi super i onda u nekih sat vremena monitor se zacrni i natrag vrati bar 5 puta.
Prvo sam mijenjao kablove, pa racunala, i na kraju se ispostavilo da su driveri, jer kolega na linux-u nema takih problem niti ja koji imam Windows 8.1.
Tako da sam zakljucio da je problem u driverima za Windows 7.
everybody lie!
n E v E n je offline   Reply With Quote
