Staro 22.02.2004., 16:50   #1
Veky
Veky's Avatar
Datum registracije: Nov 2002
Postovi: 1,950
mobilni 2500+ = oc do boli
neznam je li ovo vec postano al eto:
http://www.theinquirer.net/?article=14245
Mobile Athlon XP-M 2500+ overclocks like crazy
As it's a mobile device, the top operating voltage is low, at 1.45 volts. Also, because thermal performance has to be so much better than the standard desktop processor, mobile parts are generally selected from the cream of the crop. Additionally, the multiplier is apparently unlocked.
Overclocks on this chip up to 2.7GHz are not uncommon. When one considers that the frequency of this device is 1.87 GHz (266 FSB), that’s a 830MHz increase, which is a 44% overclock.
vidio sam da ga jedan tip vrti na AN7 i to na 2.5ghz
ima kandidata za probu?
Veky je offline   Reply With Quote
Staro 22.02.2004., 17:27   #2
>>>KUKY<<<
>>>KUKY<<<'s Avatar
Lokacija: Vinkovci
Postovi: 1,055
nice!!
Sig mi nije u skladu s pravilima.
>>>KUKY<<< je offline   Reply With Quote
Staro 22.02.2004., 17:28   #3
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
E ov je već nešto....Kulike para?
tor je online   Reply With Quote
Staro 22.02.2004., 17:56   #4
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,474
Treba vidjet ako se to može nabavit di, ako ne onda raskopat neki laptop
Ista fora je i sa mobilnim P4, samo šta intel ne da nikome da ugrađuje te procove u desktop kompove. Al bilo bi gušt nabavit jedan taj :burn:
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 22.02.2004., 17:58   #5
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Niš idemo skupit pare kupit par laptopa raskopat ih i furat u siggu Barton M@2,8Ghz@1,55V
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 22.02.2004., 19:22   #6
Veky
Veky's Avatar
Postovi: 1,950
nemrem ga nac kod nas da ga j...
Staro 22.02.2004., 20:22   #7
Isus
Headbangig Grunf!
Isus's Avatar
Postovi: 4,373
Kod nas ga 100% nema možda u Austriji, al sumnjam.
Grunf je moj idol!
Staro 22.02.2004., 20:40   #8
Bl@de
Bl@de's Avatar
Lokacija: Ispred kompa
Postovi: 2,004
eto sve ducane provjeril i jedino di ih se moze naci su u laptopu:mad: .
znaci treba probat negdje vani ili narucit prek weba.
kaj se tice OC. ono kaj pise je stvaro fuul ok. samo jel iono bilo sa vodenim ili zracnim jel ak je sa zracnim (sto sumnjam) s vodenim bi letio.
Intel i5 4670k
ASrock Z87 Extreme 3
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
OCZ SSD Vertex 4 - 128 GB
Samsung T166 500 GB 7200 okr/min 16 MB HD501LJ
Samsung F1 1 TB 7200 okr/min 32 MB HD103UJ
Dell S2522HG
Chieftec DX-01BD-V, Corsair 520W CMPSU-520HXEU
Bl@de je offline   Reply With Quote
Staro 22.02.2004., 21:26   #9
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,474
Vjerujem da je to sa zračnim, jer oni rade na 1.45V a i koncipirani su da zrače čim manje topline, tako da na nekih 1.8V zrače ko normalan na 1.6V...
Ajmo žicat dobre ljude iz Linksa da uvezu par komada
Staro 22.02.2004., 22:20   #10
Veky
Veky's Avatar
Postovi: 1,950
imas ovdje temu
http://www.ocforums.com/archive/thread/271103-1.html
ovaj ima dobar primjerak
http://www.ocforums.com/vb/vb/showth...hreadid=271012
2.6ghz sa zrakom
skoro 2.9 sa vodenim
izgleda da ce uskoro athloni xp na 3 gige
Staro 22.02.2004., 23:30   #11
no name
dim je pravi
no name's Avatar
Postovi: 99
U švabiji cijena 132 Eura sa MWS
Evo linksa
http://geizhals.net/eu/?google&o=4
no name je offline   Reply With Quote
Staro 22.02.2004., 23:49   #12
Bl@de
Bl@de's Avatar
Postovi: 2,004
e gle ludu ideju. koliko vidim sad je cijena 95€. ajmo se dogovoriti ko sve oce kupiti pa naruciti vise komada pa nek nam dostave sim!? ja sam definitivno in.
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
Staro 23.02.2004., 00:08   #13
tihomir
tihomir's Avatar
Datum registracije: Jan 2002
Lokacija: ?
Postovi: 2,274
imaš mobilni 2500+ u onom acerovom ferrari laptopu...
tihomir je offline   Reply With Quote
Staro 23.02.2004., 00:14   #14
Bl@de
Bl@de's Avatar
Postovi: 2,004
ok ja ti dam pare za 2500+ a ti plati ostatak laptopa!
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
Staro 23.02.2004., 01:24   #15
Bl@de
Bl@de's Avatar
Postovi: 2,004
Ovak nisam uopce iz prve skuzio. znaci oni delaju na 266 mhz dakle 14x133. to je odlicno. mislim ak su zakljucani bar n moras furati fsb 250 neg ide komptno na 200.
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
Staro 23.02.2004., 01:35   #16
Isus
Headbangig Grunf!
Isus's Avatar
Postovi: 4,373
Evo linksa
Hm koliko ja tam vidim to je 2600+ Tbred jer ima 256K cachea, onda bi bilo bolje uzet 1700+,
A onaj po 132€ jr MP a ne M ( Muli Processor, a ne Mobile).
Ideja nije loša. Još dva i pol dana do dolaska DLT3C
Grunf je moj idol!
Staro 23.02.2004., 12:07   #17
tihomir
tihomir's Avatar
Lokacija: ?
Postovi: 2,274
zašto bi ga vadio,kad je laptop i tako mrak?
Staro 23.02.2004., 12:20   #18
Bl@de
Bl@de's Avatar
Postovi: 2,004
E isus nisi dobro vidio ima ih vise vrssta. eto ja sam nasao za 103€ak se ne varam 2500+ 266mhz 512 k i jako bino 42W!
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
Staro 23.02.2004., 12:57   #19
Isus
Headbangig Grunf!
Isus's Avatar
Postovi: 4,373
Al ima jedna kvaka ne dela na desktop Socket A platformama čak ima i napomena -
Mobile CPU, läuft nicht auf Desktop Sockel A Boards.
Ili ti u prijevodi
Mobilni CPU , ne radi na Desktop socket A pločama. Dakle niš od toga.
Grunf je moj idol!
Staro 23.02.2004., 13:49   #20
Paske
Ekspert iz sjene ...
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Ili ti u prijevodi
Ma ima da radi .... mamicu im
Staro 23.02.2004., 14:10   #21
Bl@de
Bl@de's Avatar
Postovi: 2,004
Decki ja mislim da je patka da ne radi . jel ak se sjetite one finte sa modanjem i Mp ili M da se moze oca u win ove nove jezgre!
Dakle vjerojatno je spika da ne radi na svim plocama ali vecini radi. tak bar ja mislim jer razlike u socketu nema pa je i logicno da mora raditi.
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
Staro 23.02.2004., 14:15   #22
Paske
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Problem je u voltaži proca ...
Ukoliko MB ne podržava toliko malene voltaže - postoji mogučnost da proc naprosto zgori.
Ipak - to je više teorija, vjerujem da je to sve vezano uz patke i nebulozne gluposti
Staro 23.02.2004., 14:32   #23
Elven
Elven's Avatar
Datum registracije: Sep 2002
Postovi: 2,722
Hm... meni baš i nije. Vidi se da je to Acer (tj da nije HP, IBM, Toshiba...) Završna obrada baš i nije na visini.
Staro 23.02.2004., 15:24   #24
Bl@de
Bl@de's Avatar
Postovi: 2,004
to je prakticki nemoguce jel onda ni 1700+ DLT3C nebi radio a on radi na 1.5V. cak i da radi min 1.5v stvaro mu nemoze biti nista.
ja osobno ak se ne varam na ploci mogu ici cak 1.2V bas budem provjero.
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
Staro 23.02.2004., 17:59   #25
Master Neo
Stane
Master Neo's Avatar
Datum registracije: Jul 2003
Lokacija: Nasice
Postovi: 657
kolika je minimalna voltaza na bartonu koji se moze kupiti kod nas (a da nije mobilni)? kod mene je voltaza 1.65, mislim da sam cuo da nekome radi na 1.55 ? taj bi bio zakon za oc!
Master Neo je offline   Reply With Quote
Staro 23.02.2004., 18:04   #26
Elven
Elven's Avatar
Postovi: 2,722
Ja sam odabrao 1.525V, ali svi senzori kažu da radi na 1.56 na default voltaži
Staro 23.02.2004., 18:15   #27
Master Neo
Stane
Master Neo's Avatar
Lokacija: Nasice
Postovi: 657
Joj da je meni takvi, kako bi ga kloko! no i moj ide dosta do 2470, da da mi je taj tek ! Ps. hoces se dorati?:clap:
Staro 23.02.2004., 18:44   #28
Denis@Links
Postovi: 40
Pozdrav!
Kad tražite AMD Mobile Procesore morate znati jednu sitnicu. Nije dovoljno da je procesor Mobile nego još dodatno ne smije biti "Mainstream" što je ovaj od 42W snage. Morate gledati onaj za stolna računala, a taj ima oznaku 72W. Ovaj prvi Vam nije ugradiv u stolna računala nego isključivo u prijenosnike.
Denis@Links je offline   Reply With Quote
Staro 23.02.2004., 19:00   #29
Isus
Headbangig Grunf!
Isus's Avatar
Postovi: 4,373
Originally posted by Denis@Links
Pozdrav!
Na vam skeptici. Ak ne vjerujete sinu božjemu, kome onda? HERETICI!!!
Grunf je moj idol!
Staro 23.02.2004., 19:21   #30
Bl@de
Bl@de's Avatar
Postovi: 2,004
Pozdrav!
Ok Denise jel postoji kakva mogucnost da ih vi nabavite.
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
