Staro 06.05.2006., 15:05   #1
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Question Zaštita ventilatora?
Gdje ima za kupit neku zastitu za ventlator, u pitanju je 60mm thermaltake volcano 6 vent... Onaj bucni. Ono da ne upadaju stvari unutra i tak.
Skoro sam ostal bez prsta maloprije... : suicide
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 06.05.2006., 15:17   #2
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
pa mislim da toga ima i u linksu ako mislis na one "fan grilove"
Staro 06.05.2006., 15:24   #3
Panzer
Panzer's Avatar
Postovi: 1,814
Hm, mozda bi ti fan grilovi bili ok, jedino nisam nasao za 60mm vent. Inace, netreba bit nist fancy, znaci sto jednostavnoje to bolje...
Mislim da cu morat probat nesto sam smislit.
UPGRADED...
Staro 06.05.2006., 15:39   #4
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
cek mislim da imam jednog doma..cek pogledam pa ti javim
e da imam..bio je na jednom cooler za moj stari proc...oces se naci ili da ti saljem postom?
javi se na pm
Staro 06.05.2006., 15:41   #5
iveumag
zippo61_junior
iveumag's Avatar
Postovi: 1,296
Autor Panzer
U Majko Božja,onda bi trebao na vent stavit naljepnicu da piše Achtung Panzer
iveumag je offline   Reply With Quote
Staro 06.05.2006., 15:49   #6
Panzer
Panzer's Avatar
Postovi: 1,814
Exclamation Achtung Panzer
Autor iveumag
Da, trebao bi stavit...
Vent se vrti na ~7000rpm, tak da je prilicno ubojit za prste i slicno...
@Hamm - ak nades, super. Ak ne, nema beda, budem nekaj skemijao ja sa mrezicama i tak to...
UPGRADED...
Staro 06.05.2006., 15:53   #7
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
nasao sam..ispraznio sam inbox..ajde pa salji da se dogovorimo...
Staro 06.05.2006., 16:11   #8
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
panzer ja ti sada uskoro idem na kavu/pivu/sok kaj god...pa ti ostavi na pmu poruku ili na ICQu ja tebe preko icq borja nemrem pronaci
pozdrav pa se cujemo..imam jos nekaj za tebe uz zaj fan grill
Staro 06.05.2006., 18:16   #9
domy_os
domy_os's Avatar
Postovi: 19,040
U Chipoteci bi trebalo bit...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 07.05.2006., 00:09   #10
kiki89
kiki89's Avatar
Lokacija: n/a
Postovi: 228
ja sam spojio neki truli,enpoznatog proizvidjaca 120mm vent na 12v=7000rpm poceo mi je "letit" po stolu. ja se uspanicio i nekako sam gurnuo palac u vent. rezultat mojeg pothvata-palac desne ruke bez jabucice,zarezo mi ga je do mesa.sada imam oziljak. stoga budite oprezni.
@Panzer: probaj staviti neku mrezicu,onu sta se stavlja na prozore da ne idu muhe ili tako nesto
kiki89 je offline   Reply With Quote
Staro 07.05.2006., 00:14   #11
iveumag
zippo61_junior
iveumag's Avatar
Postovi: 1,296
Autor BiT-X
U jebote,treba počet nosit one željezne rukavice ko oni vitezovi u srednjem vijeku
EDIT:Oprostite na prostom izrazu
Staro 07.05.2006., 00:17   #12
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
pa ono bravo ekipa..kako samo uspjevate...stvarno mi se nije nikaj dogodilo NIKADA..a stvarno sam po svemu prckao..i zaustavljao rukama...
ali mislim da ipak rekord drzi netko tko je s ovog foruma isao mjeriti temperature grafe (9800 pro) s toplomjerom..sorry ali je fakat smijesno
p.s svima- ja i panzer smo sve dogovorili fan grill dobiva od mene kao i jos neke stvarcice
Staro 07.05.2006., 14:49   #13
Panzer
Panzer's Avatar
Postovi: 1,814
Evo, danas mi je Hamm poklonio fan grill, i jos mi je dao bazu i vent od Volcano 7...
Puno hvala Hamm...: cheers2
UPGRADED...
Staro 07.05.2006., 16:34   #14
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
i potenciometar i pivu
ma zezam se..evo ti si donirao za donatore plocu i proc od 500mhz...evo ja cu obavjestiti amda
Staro 07.05.2006., 17:19   #15
Panzer
Panzer's Avatar
Postovi: 1,814
hehe
Nadam se da radi ploca i proc. Radila je zadnji put kad sam popravljao taj komp, prije 5-6 mjeseci
UPGRADED...
Staro 07.05.2006., 17:39   #16
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
Ja sam takoder imao neugodno iskustvo sa vojim TT Volcano 12+ na cca 5000 dira..takoder slucajno sam isao nesto pogledat oko proca dok je radija i ono da cu rukom makint kabel ja zakacija kosilicu od venta sreca nije bilo strasno.... Stoga oprez momci...
G0RKI je offline   Reply With Quote
Staro 07.05.2006., 22:43   #17
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,477
i ja sam razrezao prst na TT, čini mi se baš na taj...
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 07.05.2006., 23:50   #18
TomG
TomG's Avatar
Lokacija: Munich
Postovi: 2,223
eee bash sam si i ja noktiche skratio na tu wrtilicu...bruji ko traktor ...hehee
TomG je online   Reply With Quote
Staro 08.05.2006., 00:24   #19
ZOKSY
ZOKSY's Avatar
Postovi: 278
Ja skoro poginuo mislim skoro ostao s trajnim posljedicama......
slago nekaj na kompu i nisam ga ugasio jer mi nije palo na pamet da mi se tak nekaj može desit.... genijalac..
Htio sam presložit žice/ malo reda napravit u neredu kad ono elisa ili kak se to zove od ZALMANA 7700Cu PUKLA!!!!!! Fiju meni pored glave...: sweating
Kabel od PS previše savinuo: bonker2
Više ne diram po kompu dok radi
GPU/CPU Freak
ZOKSY je offline   Reply With Quote
Staro 08.05.2006., 01:20   #20
Emissary
ČLAN FKTa
Emissary's Avatar
Datum registracije: Jul 2004
Postovi: 2,264
Autor BiT-X
E baš ovo, probiješ je sa vidama šta idu u ventilator. A u chipoteci afaik imaju grillove 80, 92 i 120 mm.
Staro 08.05.2006., 02:50   #21
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
Autor Tomy no.1
ma lako sta bruji nego kad dignes đire moze ti dobro zasic prst ili nokat puknit..svakako u najboljem slucaju ožiljak ti ne gine i obavezno stavljat grilove na takve zvijeri jer nikad ne znas kad se moze glupost desit..malo nepaznje i eto na..tako san i ja mislija ma nece me pazit cu....nikad dovoljno opreza! zato ove grilove najobicnije stavit oni ce najmanje gusenje imat a posluzit ce svrsi jeli (neces se ozljedit) : sweating !
Staro 08.05.2006., 14:37   #22
iveumag
zippo61_junior
iveumag's Avatar
Postovi: 1,296
Autor ZOKSY
Treba počet nosit oklope ko vitezovi u srednjem vijeku
