Staro 08.07.2025., 11:41   #82081
Postovi: 17,143
Autor Daten Pregled postova
Čuo sam da u njemačkoj postoj kamere koje mjere distancu između vozila, možeš vozit na nekim dijelovima koliko hoćeš ali distancu moraš držati.
Postoje i u Austriji i SLO, nema toga kod nas.
Neće presretač nikoga zaustaviti jer prvo, nema ih dosta, drugo ne može se gurati u gužvu, treće, to su nam turisti koji pune proračun, četvrto, nema alternative, 2 su samo trake itd. Brdo problema. Kužim frustraciju, ali riješenje nema.
Staro 08.07.2025., 12:13   #82082
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
Kazne postoje, a policije nema jer sjede po uredima kopaju nos ili po benzinskima piju kavu. Uhljebi u plavom.
Hamm je online   Reply With Quote
Staro 08.07.2025., 12:16   #82083
Zeryx
Zeryx's Avatar
Lokacija: Velika Gorica
Postovi: 255
evo i misha je dao svoje misljenje o prometnoj izmedu porschea i bmwa
So about that big nasty Nürburgring crash... Full video you know where, but "in short":
I appreciate all your DMs asking whether I have seen it. Or any other NBR crash/incident/event. The locals see this stuff daily, but most of the times it stays within local WhatsApp groups or occassionally a picture gets posted on FB. Having said that: it's nothing special, this happens (almost) every day and crashes/incidents happen on almost every track day on every other track in the world. The "fireworks" of this one was of course quite big and massive thanks to today's safety standards for keeping everyone alive. In Porsche's case the driver had "just a few scratches", without helmet, HANS or any fire protective clothing.
Who is at fault? One more than the other. Public sessions are classified as public road and the rule is = slow traffic stays right, fast traffic passes on the left. As it is an unlimited speed section of "the road", everyone is required to check their mirrors for faster traffic. M2 clearly failed to do that, when the faster traffic was behind it first and shortly after next to it.
Rule Number 2: everyone is allowed to drive only as fast, as when they can make an immediate stop to avoid any accident. M2 turning in on you and you did not stop to avoid it? Own fault. Deer crossing the road and you hit it? Own fault. Asteroid fell out of the sky and hit you? Your own fault. Porsche driver COULD have anticipated that a foreign car is less experienced and may do silly things last moment. You can see the Porsche go off the gas earlier when M2 was on its line and started to accelerate when it moved out to the right. So there was no reckless behaviour from my point of view. Just very unfortunate split second wrong assumption and lack of awareness.
The other "interesting" question is who will pick up the bill. The barrier damage and other very expensive car. This is something for the authorities to decide - who is responsible for how much % of the accident and it may get nasty. The main reason I am mentioning this is a reminder that you are liable for yourself and others during the public sessions and some track days too. So be prepared and stay focused.
Zeryx je offline   Reply With Quote
Staro 08.07.2025., 13:24   #82084
medo
#erase startup-config
medo's Avatar
Postovi: 3,735
Automobili
Kako ti misliš da će netko dobiti kaznu kada je takva gužva?
Random?
Postoje kazne, naravno, samo prvo, nitko ih ne piše, drugo, policija mora ući u tu gužvu i krenuti pisati kazne, svima. Što je nemoguće.
Kamere koje do 30 puta sekundi mogu očitati tucet registracija i automatski logirati prebrzu vožnju ili tailgating kao u ovom slučaju.
Vidio sam demo toga na svoje oči kod nas u Zagrebu prije sedam godina. Stoga je pravo pitanje zašto to već nije implementirano.
Staro 08.07.2025., 13:37   #82085
Amdejac
Amdejac's Avatar
Datum registracije: Jun 2003
Lokacija: Kuća
Postovi: 5,419
Autor Hamm Pregled postova
Ljubljanska jutros smjer prema Samoboru. Kiša pada toliko da ne vidim ništa ispred sebe i isključim se za Bauhaus gdje sam pričekao da se malo smiri.
Ovim putem lijepi pozdravi za sve vlasnike novih automobila koji ne znaju da im na njihovim šrotovima ne radi stražnja pozicija iako je stavljeno na AUTOMACKI.
Kakvi prokleti krampovi.
Kad smo kod toga moram vidjeti kako je na mazdi i podesiti nekako da radi i stražnja pozicija kada rade DRL.
Kupi si pošteni auto pa nečeš morati stajati sa strane dok kiša pada. ☝️😂
Asus N750JK (Upgrade)
MBO: Asus N750JK
RAM: 2x8 Gb PC3-12800 DDR3
PSU: Asus Li-ion 69486 mWh
OS: Windows 8.1
Monitor: 17,3 LCD (FHD)
Net: Intel AX210 NGW
Net: TP-Link Archer TX55E
PSU: Xilence, Bronze 550W
Monitor: Samsung
VGA: ATI RX570, 4 Gb
HDD: NVMe 1 Tb, Patriot
PSU: Inter-Tech SP750
Monitor: Samsung
Staro 08.07.2025., 13:40   #82086
Postovi: 17,143
Autor medo Pregled postova
Nitko ne kaže da to nije moguće, postoji u razvijenim zemaljama brdo riješenja, mi ga nemamo implementiranog.
Vienjete su jedna od tih.
Zašto? Zato jer smo mi govno od države gdje ližemo noge Česima, Poljacima i Bugarima jer nam plaćaju 4EUR za kuglicu sladoleda i 200EUR za noć u Tučepima negdje u špajzi.
Zato.
Staro 08.07.2025., 13:51   #82087
Postovi: 10,437
Ako imas srece ide preko dijagnostike. Ako nemas onda uvijek moze ici manualno
Na stranu sto je europski DRL osmislio netko jako retardiran, zapravo ne razumijem zasto senzori za svjetlo i kisu ne pale kratka svjetla kad pocne kisa? Ono, registrirao si promjenu u osvjetljenju, ali nedovoljno da se upale kratka svjetla, ajde oke! Ali onda pocne kisa i auto kaze "hej, upali brisace". Daj jbt upali im onda i svjetla. Ili ako su kojim slucajem rucno upalili pozicije i time overrideali automatiku, ugasi im rasvjetu table i ekrana, napisi im na ekranu "upali svjetla konju", forsaj ih da okrenu taj sugavi knob svojim prsticima.
Staro 08.07.2025., 14:26   #82088
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
Autor Amdejac Pregled postova
Nema to veze s autom nego je zdravo razumski ne voziti u takvim uslovima ako nije bađ nužno.
Autor xlr Pregled postova
Da, bilo bi korisno da se upale kratak + iza pozicije. Kak si napisao to nije radio nitko pametan.
Staro 08.07.2025., 14:56   #82089
zkljaja
Brat od Đon Vejna
zkljaja's Avatar
Lokacija: zg-vg
Postovi: 1,204
Na autima iz 2003. mozes napravit cornering light kodiranjem, a da novi ne dolaze s tim što si napisao iz tvornice je totalna glupost....Sivi asfalt, sivi nogostup, sivi stupovi rasvjete, more sivih automobila i još kiša...pozicija bi vrlo dobro došla u tom slučaju...
Staro 08.07.2025., 15:10   #82090
Postovi: 10,437
Ako brod na pucini mora imati pozicije, zasto auto ne mora imati sve 4 pozicije apsolutno uvijek upaljene dok radi motor? To ne razumijem...
I zasto skandinavci imaju svoj DRL mod koji uvijek pali sve 4 pozicije? Ako oni mogu, zasto ostatak EU ne moze? Mislim, promjene se dogadjaju, evo touch tipke odlaze u povijest. Tamo neki priuceni dizajneri auto interijera su se izdrkavali jedni po drugima sve ove godine dok se mi hebemo tapkajuci po ekranima.
Staro 08.07.2025., 17:00   #82091
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,197
Uzeo sam za probu nekakav paket za bezvodno pranje auta i jučer odradio pranje.
Stvar je na bazi carnauba voska. Pošpricaš, obrišeš krpom od mikrofibre i kad prođeš cijeli auto, prođeš čistom krpom i stvar gotova. Odvoji prljavštinu i navodno ne grebe lak.
Odradio sam to u garaži pod neonskim svjetlima pa nisam bio siguran kako će ispasti, ali zadovoljan sam.
Prvi minus je što nigdje ne kažu da ne treba manijakalno špricati i natopiti auto, tako da sam potrošio pola jedne boce (kaže da se s jednom bocom može odraditi 6-8 pranja).
Drugi minus je što nema šanse da operem tu krpu od mikrofibre .
Masna je kao da sam je provukao kroz friške čvarke. Vjerojatno je puno istih stvari pod različitim imenima na tržištu. Eto, mogu preporučitic, stvar funkcionira. Trebalo mi je oko 45 minuta da operem auto (vele 30).
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 08.07.2025., 17:06   #82092
medo
medo's Avatar
Postovi: 3,735
Skandinavci imaju stalno oblačno vrijeme pa tamo to dobro dođe i dobro se vidi. Mi imamo puno sunčanih dana pa se pozicije niti ne kuže kada su upaljene. Prije lampe nisu bile LED pa stalno upaljene ne bi dugo trajale.
Ja sam od malih nogu naučen da palim svjetla kada je oblačno ili kada vozim u sjeni npr. vijadukt, šuma…
Staro 08.07.2025., 17:15   #82093
Šole
Šole's Avatar
Datum registracije: Aug 2009
Lokacija: Zürich
Postovi: 711
Autor 1v@n Pregled postova
Ako ti je drag auto nemoj to vise nikad koristiti. Mozes i sam zakljuciti zasto, vidi se na petoj sekundi videa, iako nije to sad odmah od tebe, ali nemoj ga ti unistavati
Šole je offline   Reply With Quote
Staro 08.07.2025., 17:41   #82094
strikoo
strikoo's Avatar
Postovi: 1,060
Uvijek imam upaljena svjetla na autu. Ne vidim problem sa zaruljama.
strikoo je offline   Reply With Quote
Staro 08.07.2025., 18:04   #82095
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,197
Autor Šole Pregled postova
Ima tragova od automatske praonice. Gdje god da ga odvezem na ručno, ne mogu kontrolirati s kakvim krpama rade, a u garaži ga ne mogu/ne smijem sam prati.
Oprao sam ga normalno prije par dana i pao je pljusak od 10 minuta, skroz dovoljno da ga zasere, a da nije prljav. Ide prvo pod vodu ubuduće, pa onda lagano ovime. Ne planiram ga prati na suho samo ovime.
LCD: BENQ PD3200Q
Staro 08.07.2025., 18:37   #82096
Postovi: 10,437
Skandinavija je velika, ima suncanijih i oblacnijih regija pa i jednim i drugim prodaju iste aute - sa istim DRL-om. Ni kod nas nije bas isto zivis li na Korculi ili u Gorskom Kotaru, isti auto ti se nudi, a vremenski uvjeti kroz godinu budu dijametralno suprotni. Dvije male crvene ledice koje ce svijetliti valjda vjecno.
Pitam se imaju li Englezi skandinavski DRL? Ivane?
Staro 08.07.2025., 18:57   #82097
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,197
Kakav DRL, ovdje ni svjetla nisu obavezna po mraku
You must use headlights when visibility is seriously reduced", with ‘seriously reduced’ defined as when you are able to see less than 100m in front of you.
Šala naravno, ali količina auti bez upaljenih svjetala je ogromna. I s ugašenim svjetlima, rasvjeta je takva da ćeš vidjeti idiota. Magle nema, kiša nikad ne pada tako jako da ne vidiš, a brzine su male, tako da nije neki problem
LCD: BENQ PD3200Q
Staro 08.07.2025., 19:53   #82098
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,310
Svjetla su mi uvijek upaljena, ne gledam jel ljeto ili zima.
Znam samo da me se bolje vidi na cesti.
Ovo sa DRL-om je suludo. Mislio sam da je problem samo kod nas, al bit će u cijeloj Europi debosi voze tako.
Staro 08.07.2025., 20:35   #82099
medo
medo's Avatar
Postovi: 3,735
Autor Cuky Pregled postova
Tebe se možda bolje vidi na cesti ali zbog tvojih svjetala auto koji ti dolazi u susret slabije vidi pješaka koji po danu prelazi cestu između vas
Staro 08.07.2025., 20:42   #82100
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,625
Meni se na Megane-u automatski pale svijetla čim upalim auto. Žarulje ne prde često kako sam mislio (pogotovo jer francuzi navodno imaju lošu elektroniku). Jedino kad sam gunđao zbog cijene je kad mi je 3-e stop svjetlo krepalo pa je njega trebalo mijenjat (LED naravno).
Staro 08.07.2025., 20:52   #82101
Postovi: 10,437
Palio sam svjetla cijelu godinu na proslom pezou, kupovao nightbreakere i prdile su svako 6 mjeseci. Sa nalemljenim termistorom su durale malko duze, ali opet... Nisam imao DRL na njemu pa su kratka bila jedina opcija (ne racunam onu tinjalicu od pozicije).
Mase na konektorima straznjih lampi su bile blago otopljene, francuska klasika jel. Ne znas da je tako dok ne prdne cijeli kluster/lampa a onda imas mrtvu poziciju, stop i rikverc svjetlo.
Mislim da sam jedno 10ak parova zarulja promjenio u 6 godina
Staro 08.07.2025., 22:34   #82102
strikoo
strikoo's Avatar
Postovi: 1,060
Najtbrejkeri, koja prevara. Dok su osram classic (original) jedine žarulje koje idu na moje aute
Staro 08.07.2025., 23:04   #82103
Ivan357
Datum registracije: Jun 2020
Postovi: 177
Autor strikoo Pregled postova
zašto prevara? počeo sam ih koristiti davno na fiat bravi koja je imala katastrofalne farove, nightbreaker su mi uz philips blue vision jedine kolko tolko osvjetljavale cestu
ostala mi je navika kupovati i kasnije iako su auti poslije imali ok farove
Ivan357 je offline   Reply With Quote
Staro 08.07.2025., 23:14   #82104
Postovi: 10,437
Meni su se pokazali isto kao najoptimalniji, osim po kisi al to sam i ocekivao i prihvacao. Takodjer, morao sam izvuci maks iz tog fara i ostale zarulje su mi jednostavno bile neuvjerljive.
Prevara su na francuzima ali vidim na drugim autima te H7 zarulje znaju duze durati.
Rezerva su mi bile neke osram obicne, ali svega par puta sam bio prisiljen koristiti ih (i bolje).
Staro 08.07.2025., 23:28   #82105
strikoo
strikoo's Avatar
Postovi: 1,060
Ako ste zadovoljni, ok.
Po meni uloženo dobiveno. Ispravni i dobri
Staro 08.07.2025., 23:30   #82106
strikoo
strikoo's Avatar
Postovi: 1,060
Po meni uloženo dobiveno. Jako su skupi bili i kratko trajali naspram classic osrama. Ispravni i dobri farovi rade pravu razliku.
Staro 08.07.2025., 23:35   #82107
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,310
Ma sumnjam da mu to toliko smeta. Pa nemam upaljena duga 😅
Staro 08.07.2025., 23:58   #82108
Psycho
Master Of Disaster
Psycho's Avatar
Datum registracije: Nov 2002
Postovi: 1,283
Jel kod nas postoje kazne za nedržanje sigurnosnog razmaka na autoputu?
Jučer popodne išao za jug, bila je gužva do Bosiljeva, svi se nagurali u lijevu traku koja je vozila od 100-130kmh.
Nevjerojatno mi je da se svi voze na guzici jedan drugome, vozi se 120 kmh, a drže razmak 20-30m, i manje.
Onda se nađe ekipa u bijesnim vozilima koji ne mogu tako voziti 120 kmh u lijevoj traci nego se nabijaju na guzicu da mu se makneš makar je ispred kolona u lijevoj traci.
Čim probam napraviti razmak 50m od auta ispred šta bi trebala biti nekakva distanca za sigurno zaustavljanje vozila kad se vozi 120kmh nabijaju se na guzicu na par metara.
nije bilo 100-130kmh, nego 90-100. mene osobno zivciraju ljudi koji voze do ogranicenja i onda misle da imaju pravo uzurpirati lijevu PRETICAJNU traku.
znam da svi vozimo po guzvama i da nam fali jedna, ako ne dvije trake od ZG do Bosiljeva. Ali ako ne pretices u tom trenutku i imas mogucnosti skrenuti u desnu traku nakon svog preticanja, bio bi jako zahvalan da prepustis mene da vozim kako ja ocu i sam odgovaram za posljedice toga. pogotovo kad mi na nekim dijelovima autoceste jos imaju znak 80kmh ogranicenja od prije 4 mjeseca kad je HAC radio neko odrzavanje i zaboravili maknuti znak
Staro 09.07.2025., 00:18   #82109
medo
medo's Avatar
Postovi: 3,735
Deset godina su bila tvornička svjetla u zadnjim farovima na Cliu. Kasnije su aftermarket pozicije/štopovi pregarali dva puta godišnje.
To mi je išlo na živce pa sam kupio Philips Ultinon P21/5 sa 12god garancije. Već sedam godina veselo svijetle u zadnjim farovima i prolaze tehnički iako strogo gledano ne bi trebali.
https://youtu.be/DWvIaY82Un8
Staro 09.07.2025., 00:29   #82110
zkljaja
Brat od Đon Vejna
zkljaja's Avatar
Lokacija: zg-vg
Postovi: 1,204
Ako postoje zadnji farovi jel postoje prednje stopke?
