Staro 08.10.2019., 01:36   #301
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,503
Autor calypso Pregled postova
Nabavi USB ladicu za ATA diskove na ebay/aliexpress i slicno... Jednostavnije nego se gombat sa adapterima ATA/SATA...
Koja je jeftinija verzija
Hala Madrid!
Staro 08.10.2019., 08:03   #302
Postovi: 34,080
Imaš i USB dockova u koje idu i SATA i IDE hardovi. Obično ti dockovi imaju i dugme za offline (bez kompa) kloniranje hardova. Idu po nekih 20-25$ na baji i aliji.
Staro 09.10.2019., 16:27   #303
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,082
alternativno ćopit PCI IDE Controller, znalo ih je bit po njuškalima ili mrknut online. Najjeftinije je vjerojatno kupit staru ploču/combo sa IDE kontrolerom
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 10.10.2019., 08:50   #304
tiki66
tiki
tiki66's Avatar
Postovi: 2,766
Najjeftiniji ti je šrot adapter sa aliexpressa i slično. Malo pogledaj koji provjereno radi. Ja ti ne bih preporučio ovakav izduženi:
Klik
jer imam dva i znaju gubiti kontakt ovisno o tome kako ih nagneš. OVAKO neka izvedba mi se čini puno zgodnija
Staro 11.10.2019., 03:46   #305
domy_os
domy_os's Avatar
Postovi: 18,955
Autor tiki66 Pregled postova
Sličan sam ja koristio, imam ga još negdje po ladicama, radio je bez problema.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 11.10.2019., 13:13   #306
Staromodan
Datum registracije: Nov 2012
Lokacija: .
Postovi: 184
Kartica ima smisla ako ces disk aktivno koristiti. Za povremeno pregledavanje je puno jednostavnije koristiti ata-usb. Spoji se vanjsko napajanje i adapter na disk, ukljuci se i spoji kabel na usb prikljucak racunala, kopiraju se podaci, odjavi se, iskopca usb kabel i onda ugasi vanjsko napajanje diska. Pri prebacivanju podataka pripazi da ne pomilujes disk, da ne zapnes za kabele i da disk ne odseta sa stola. Adapter ata-sata sto se stavlja na disk i spoji na sata prikljucak mbo se najbrze pokvario, ustvari mislim da nije ni bio potpuno ispravan, prc kvaliteta. Hm... sad kad razmislim, najbolje rjesenje je ono sto ti bude najjeftinije.
Staromodan je offline   Reply With Quote
Staro 10.12.2019., 20:33   #307
panoramix
driver
panoramix's Avatar
Postovi: 1,083
Molim za savjet.
Želio bih na Samsung laptopu zamijeniti postojeći hard disk sa SSD diskom.
Postojeći klasični disk je debljine 9,5 mm a vidim da se na netu uglavnom nude SSD debljine 7 mm.
Kako to tehnički riješiti ?
Uz to, koji software je najbolje koristiti za kloniranje postojećeg diska, te što mi treba od kablovinja za tu radnju.
Unaprijed hvala na odgovoru.
Staro 10.12.2019., 21:31   #308
Postovi: 34,080
Debljina ti nije toliko bitna stavka kod montaže. Eventualno staviš nešto ispod SSD-a kada ga montiraš u kavez. Osim toga, neki SSD-vi dolaze u retail pakovanju u kojima se nalazi i kit za montažu u laptope.
Staro 10.12.2019., 21:33   #309
Max Rockatansky
Lokacija: Zg/Zd
Postovi: 727
Autor panoramix Pregled postova
Molim za savjet.
Već je coconut odgovorio, pogledaj malo retail pakiranja SSD-a pa ćeš vidjeti mali okvir kao umetak na punu visinu iako je zbog male mase dovoljno i koliko se drži na SATA konektorima.
Softvera ima dosta, Macrium Reflect, Clonezilla, Acronis TrueImage ...
Kloniranje u tvom slučaju onda moraš napraviti u 2 koraka jer ne možeš imati istovremeno spojen i hard i SSD.
Treba ti neki ext.disk ili dovoljno veliki USB stick (ovisno koliko je hard disk popunjen) a svaki od alata za kloniranje obično ima i opciju da napraviš bootabilni USB-stick (da imaš čime bootati kad kloniraš i izvadiš hard odnosno ubaciš novi SSD).
Što još imaš od dodatne opreme ? ext. ladicu, dock, USB-stick, dostupan neki file-server/NAS ... ?
Staro 10.12.2019., 21:41   #310
Postovi: 23,629
Šta se montaže tiče, ako je vijcima zavidan za kakav okvir onda ne treba ovaj adapter za debljinu.
Staro 11.12.2019., 03:14   #311
Emissary
ČLAN FKTa
Emissary's Avatar
Datum registracije: Jul 2004
Postovi: 2,264
Nedavno sam klonirao jedan stari 80 GB Seagate na Crucial MX500 250 GB, posudio sam ovu stvarčicu, jedan pritisak tipke i to je to (jedino što novi disk mora biti jednak ili veći od starog), pa ako bi uspio nabaviti, preporučam:
Docking station DELOCK, Dvostruka priključna stanica SATA HDD > USB 3.0 s funkcijom kloniranja, crni
Zadnje izmijenjeno od: domy_os. 31.12.2019. u 23:42. Razlog: obrisan višak
Staro 11.12.2019., 10:30   #312
Dottore
Dottore's Avatar
Postovi: 7,706
Najbolje je nanovo instalirati windowse nego klonirati odnosno povući smeća sa starog diska. Brzine mogu biti manje nego nova instalacija.
Отправлено через iPhone
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 27.01.2020., 20:42   #313
dabomba
dabomba's Avatar
Datum registracije: Jul 2010
Postovi: 538
Može li se na INTEL P35 ploču spojiti SSD i koji?
Hvala na odgovorima.
dabomba je offline   Reply With Quote
Staro 27.01.2020., 21:07   #314
nick praskaton
Asshole
nick praskaton's Avatar
Lokacija: RH
Postovi: 2,361
Autor dabomba Pregled postova
može, običan sata, s tim da će radit na pola propusnosti, zbog ogranicenja sata2, al svejedno je isplativa nadogradnja jer ces osjetit razliku u svakodnevnom radu
naravno ovisno o novcima i kapacitetu, gledaj... samsung, crucial, intel...
Staro 28.01.2020., 00:06   #315
Za takve ploče meni se najbolji pokazao Kingston A400 među najjeftinijima je, sasvim OK je za tu lovu i na toj propusnosti radi na svojih 60% recimo tako da od skupljih i bržih nemaš razlike osim u potrošenim novcima.
Osobno sam ih natovario 10+ komada na razne 11+ godina stare ploče od s775 pa čak FM1 socket i svi još uvijek rade bez greške već preko 2 godine.
240GB mislim da se nađe za 200tinjak kn.
Staro 28.01.2020., 00:07   #316
domy_os
domy_os's Avatar
Postovi: 18,955
Sve ovisi koji CPU ima, meni se recimo na laptopima te generacije nije osjetio neki značajniji pomak.
Staro 28.01.2020., 00:21   #317
Iz iskustva jako dobro radi sa E54x0 Xeon modovima.
Druga je stvar što ti procovi lagano postaju zaqrac.
Također sa E6x50 Conroe i E8x00 Wolfdaleovima rade dobro.
A opet ako i ima neki "slabiji" CPU na toj ploči, upgrade proca košta max 100 kn i to 100+% jači
Staro 14.02.2020., 19:23   #318
domy_os
domy_os's Avatar
Postovi: 18,955
Život moje Z68 ploče je upravo produžen! Uspješno ugrađen NVMe SSD iz Lenova T580 u PCI-E adapter, modificiran BIOS i bootana stara Windows 10-ka od Lenova. Brzine nisu neke jer je SSD sranje, a ne mogu naći ni drivere za njega...
Adapter je skroz jednostavan, ne šarafi se na kućište nego samo ubode u slot i ujedno je hladnjak...
Sa stock BIOS-om se naravno nije vidio u boot izborniku...
Kad sam modificirao BIOS, device se pojavio pod imenom PATA i odmah je skužio EFI boot file sa SSD-a...
I evo ga konačno u Windowsima. Da, brzine nisu neke jer je SSD loš, ali temperatura je skroz OK...
Sad ću podignuti novu instalaciju 1909 jer ovo je tragedija koliko je Lenovo zatrpao OS sa svojim smećem.
Staro 16.02.2020., 18:59   #319
sinisa2
Lokacija: osijek
Postovi: 41
Molio bih pomoć oko kupovine novog SSD. Umjesto HDD od 1TB, 7200 RPM, SATA III želim ugraditi SSD od oko 500 GB. Matična ploča je ASRock H81M-DG4. Koji SSD kupiti i pošto ga mislim sam ugraditi molim savjete (treba mi li novi kabel za spajanje na matičnu i sl.). Svaki savjet je dobrodošao.
sinisa2 je offline   Reply With Quote
Staro 16.02.2020., 19:15   #320
domy_os
domy_os's Avatar
Postovi: 18,955
Imaš 2 x SATA3 6.0 Gb/s Connectors, support NCQ, AHCI and Hot Plug, to bi trebali biti sivi SATA_0 i SATA_1 konektori. Ako nemaš duple SATA i power kabele, onda napravi backup tog diska na neki vanjski USB device, ištekaj HDD i samo na njegovo mjesto ubodi SATA SSD.
Staro 16.02.2020., 19:23   #321
sinisa2
Lokacija: osijek
Postovi: 41
Znači bilo koji SSD?
Staro 16.02.2020., 19:26   #322
domy_os
domy_os's Avatar
Postovi: 18,955
Bilo koji SATA 2.5" SSD ti odgovara. Imaš ovdje hrpu preporuka.
http://forum.pcekspert.com/showthrea...23099&page=188
Iako ni 1 TB modeli više nisu skupi. Meni dođe muka kad vidim koliko sam svog platio prije 3 godine...
Staro 16.02.2020., 20:15   #323
silver_tip
silver_tip's Avatar
Lokacija: doma
Postovi: 2,919
Autor domy_os Pregled postova
A vid prije 5 godina, 3mj. 2015
Sad za te pare kupis 2TB + 1TB
trebaš seedbox?
silver_tip je online   Reply With Quote
Staro 18.02.2020., 13:16   #324
vedranzeman
Lokacija: Kloštar Podravski
Postovi: 1,019
Bome dobar je taj "PRO" porez.
Ovaj 1TB EVO sam 21.4.2015. platio 329,90 EUR.
Tko nije skršio Socket A procesor na bilo koji način, neka prvi baci kamen!
vedranzeman je offline   Reply With Quote
Staro 18.02.2020., 21:32   #325
gorkix
Postovi: 120
radi se o laptopu HP 6820s, Intel, Core Duo, T2370, 1,73 GHz, 2x 1024 MB, 17", 1440x900, SATA 160 GB, ATI Mobility Radeon X1350,win7
to je sporedni laptop i uglavnom je spojen na lcd te se gledaju filmovi preko njega i rijetko internet..
s obzirom da su video datoteke sve zahtjevnije počeo je imati problema kod reprodukcije pogotovo full hd ,odnosno datoteke sa veći bitrateom...npr 4,5,ili više mbS ,obično je tada procesor na 100%,pa pomalo "steka"
kad bi se stavio umjesto hd -a ,ssd disk neki manji 120gb (da ne ulažem previše u stariji laptop) da li bi se dobilo na poboljšanju ,odnosno da li bi bolje reproducirao video datoteke ,odnosno internet jer te dvije opcije su jednina svrha tog laptopa..
napomentuti ću i da iako ugradim ssd disk videa će ipak i dalje čitati sa vanjskog diska
obično je hdd usko grlo ,ali razmišljam da možda i sam procesor je slab (pa i star) za reprodukciju hd video datoteka ,pa da ugradnja ssd možda ne bi ni donjela neko poboljšanje..
uglavnom se radi o datotekama hd sa bitrateom max 5,6mbs,znači ne nekih večih rezolucija ili previsokg visokog bitratea
Pa me zanima Vaše mišljenje o tome...
gorkix je offline   Reply With Quote
Staro 18.02.2020., 21:38   #326
calypso
calypso's Avatar
Datum registracije: Oct 2002
Lokacija: Zagreb/Rijeka
Postovi: 2,050
Autor gorkix Pregled postova
CPU ponajvise... Sa SSDom ne bi nista postigao...
Za svaki slucaj probaj Potplayer pa vidi da li ce neki HW codec to odraditi preko graficke... Sumnjam, al mozes probat...
GMKTec K8Plus
2x EIZO EV2336WFS3-BK
23" 1920x1080 IPS
Dell Latitude 7390
32GB DDR4-2666
intel UHD 620
13.3" FullHD IPS Touchscreen
Staro 25.02.2020., 18:59   #327
r1_team
Datum registracije: Jan 2017
Lokacija: zlatar
Postovi: 2
HDD+SSD
Pozdrav,
Na HP laptopu sam imao samo HDD disk: C particija sa Windowsima 7 i D particija sa podacima. Sad sam kupio SSD, stavio ga na mjesto HDD-a i instalirao Windowse 10 na njega. HDD sam stavio u onu ladicu i spojio ga. Sad kad idem u Disk Managment HDD mi prikazuje kao Unknown i Not Initialized.
HDD bi htio koristiti i dalje za pohranu podataka, formatirati C paticiju sa starim Windowsima 7, ali bez da formatiram i D particiju na kojoj su mi svi podaci. Kako to izvesti?
r1_team je offline   Reply With Quote
Staro 25.02.2020., 19:30   #328
Postovi: 23,629
Koliko ima tih podataka na ex D particiji ?
Jeli može privremeno stati na ssd ?
Trebaš offline alate kao stari Hiren's ili Live Windows, boot sa USB stika.
Sve skupa ti je lakše odraditi na nekom pc - ju.
Sa nekim od partition managera treba odraditi:
- makniti Boot flag sa bivše boot particije
- obrisati boot particiju i particiju sa bivšim winsima
- ex D particiju "razvući" da uključuje cijeli hdd
Staro 07.06.2020., 01:03   #329
gorkix
Postovi: 120
planiram ugraditi na laptop lenovo 330 ikb17˝ ssd Mx500,500gb,a postojeći hdd prebaciti na mjesto dvd
imam neka iskustva za instalacijima windowsa,ali nisam dosad nikad instalirao na ssd pa ako ima kakav savjet na čega bi trebao pripaziti
-planiram instalirati na jednu particiju win 10 koji je legalan (nadam se da neće biti problema sa aktivacijom -dig.licenca)
vidio sam da je potrebno prebaciti na ahci ,ali toga u biosu nemam pod opcijama,pa pretpostavljam da se to kod ovog laptopa podrazumjeva jer je relativno nov
-da li uopće ima neke razlike oko uefi-legacy
znači ,neki savjet prije instalacije ili kasnije u radu oko održavanja (npr.pročitao sam da se ne treba defregmatirati)...
Staro 07.06.2020., 08:01   #330
Postovi: 34,080
A zašto moraš instalirati winse? Kloniraj ih s postojećeg HDD-a na SSD.
