Staro 18.01.2016., 21:23   #751
osspaljeni
Silence
osspaljeni's Avatar
Datum registracije: Jul 2011
Postovi: 671
Ako je ploča nesposobna mjerit i ako ima Adaptive opciju uključenu BogaPitajKoliko napona zapravo daje van na CPU.
Možda ti je sakriveno negdje pod naponima ploče.
Ugl. koliko sam skužio ljudi uspjevaju povući 4,5 - 4,6 ispod 1,3 V a u rijetkim slučajima i 4,7 GHz (4690K).
Evo i tablice.
Pošteni trgovac: 1 2
771 to 775 for Dummies
Staro 18.01.2016., 23:11   #752
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,085
Fixed voltage je, tak da nevjerujem da puno previše odstupa od zadanog
CPU: i7-4790K @4.3 GHz + Scythe Ninja 3
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
CPU: i5-4690K @4.5 GHz + Raijintek Themis
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Dobar trgovac: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18
Živi bili pa umrli!
Staro 19.01.2016., 01:03   #753
nub
PREMIUM
nub's Avatar
Datum registracije: Dec 2014
Postovi: 2,165
Autor Chuxonja Pregled postova
nema veze. Generalno ne ide puno iznad zadanog, al tko zna, tempovi od 80c na sintetici pri 1.1v/4.5Ghz se čine visoki, ipak nije baš tak loš kuler.
Ak doista radi na 1.1v i jednostavno je kuler jako loš, onda imaš dijamantni čip
Staro 27.01.2016., 22:15   #754
Redline
Redline's Avatar
Lokacija: Vž-Mb
Postovi: 385
Zna ko pri kojoj se temperaturi gasi Turbo boost, odnosno procesor prebacuje na onaj nominalni clock 3,5GHz? i5 4690K na stock hladnjaku
Redline je offline   Reply With Quote
Staro 28.01.2016., 00:07   #755
Dottore
Dottore's Avatar
Postovi: 7,726
Autor Redline Pregled postova
Kad nema opterečenja onda gasi automatski turbo boost
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Dottore je online   Reply With Quote
Staro 28.01.2016., 00:48   #756
Redline
Redline's Avatar
Lokacija: Vž-Mb
Postovi: 385
Autor Dottore Pregled postova
Znači neki gornji limit (tipa visoka temperatura, power limit) kod opterećenjem nema?, kad nema opterećenja znam da se onaj Intelov SpeedStep pali, di mi varira množitelj od 8-39.
Staro 28.01.2016., 03:47   #757
osspaljeni
Silence
osspaljeni's Avatar
Postovi: 671
A gle, Haswell je deklariran do 90-100°C max (a spominje se i do 125°C), što su temperature koje NIKADA nećeš vidjeti kod stock postavki koliko god imao loš hladnjak.
Tek kod takvih extrema možeš očekivati da će CPU namjerno spustiti takt pod full opterećenjem.
Pod stock postavkama ili kontroliranim overclockom će uvijek raditi od 800Mhz - stock / zadanog overclocka dokle god temperature ne postanu toliko extremne.
Osobno ne bih forsirao čip iznad 80°C zbog degradacije čipa kao i matične ploče, a i to samo u sintetičkim testovima tipa IBT, Prime95 etc..
Ako te baš brinu visoke temperature ili pucaš na overclock, stavi si u BIOSu shutdown temperaturu na spomenutih 80°C.
Sve do 60°C ili malo iznad toga je prihvatljivo u svakodnevnom radu.
Zadnje izmijenjeno od: osspaljeni. 28.01.2016. u 03:58.
Staro 28.01.2016., 14:31   #758
sti
Lokacija: Lawl
Postovi: 1,381
Ekipa, da li se još uvijek isplati uzimati Haswell-4460 za gaming? Sve do nedavno sam mislio uzeti Skylake-6500, no vidim da imaju tendenciju savijanja pod težim hladnjacima, tako da ne želim biti pokusni kunić i radije bih išao na provjereni procesor, samo nisam siguran koliko je future-proof. Hvala
Staro 28.01.2016., 14:33   #759
ravkan
ravkan's Avatar
Postovi: 753
Ako zelis bas intel, slobodno uzmes 4460 jos uvijek to radi bez greske i radit ce jos dogledno vrijeme.
Red Vishera Blue Devil
ravkan je offline   Reply With Quote
Staro 28.01.2016., 14:38   #760
sti
Lokacija: Lawl
Postovi: 1,381
Potpuno mi je svejedno, ali vidim da se u malo skupljim konfama (7000 i više) gotovo uvijek preporučuje Intel. Nemam ništa protiv AMD-a, ako imaju nešto bolje za tu cijenu.
Staro 28.01.2016., 14:56   #761
nex
nex's Avatar
Lokacija: .
Postovi: 526
Autor sti Pregled postova
6500 je malo brzi i malo skuplji. Ono sto ce biti prezahtjevno za vrtiti na 4460 ce vjerojatno biti prezahtjevno i za 6500, mala je razlika medju njima.
nex je offline   Reply With Quote
Staro 28.01.2016., 18:10   #762
kurc
kurc's Avatar
Datum registracije: Aug 2008
Postovi: 237
Jedina prednost koju 6500 ima je blck overclock, ali za to treba z170 ploča i neki cooler. Uz to ide i dobra cijena. 4460 + h81/b85 < 2000kn, 6500 + z170 > 2800kn. Bez OC-a 4460 je isplativiji.
kurc je offline   Reply With Quote
Staro 28.01.2016., 18:27   #763
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
može i i5 6400 bclk
Staro 28.01.2016., 18:39   #764
kurc
kurc's Avatar
Postovi: 237
može i i5 6400 bclk
Može, možda je i bolji ako namjeravaš oc-at, digneš ga na recimo 4ghz, isto ko i 6500, a parsto kuna jeftiniji. Ako ne namjeravaš oc-at onda je 6500 bolji jer ipak ima 500mhz veći stock clock.
Staro 28.01.2016., 18:44   #765
scarzz
scarzz's Avatar
Lokacija: Stuttgart/Rijeka
Postovi: 414
za bclk oc je 6500 bolji jer ima bolji mnozitelj 32>27
scarzz je offline   Reply With Quote
Staro 28.01.2016., 19:34   #766
kurc
kurc's Avatar
Postovi: 237
Mislim da ćeš prije doći do termalnog limita hlađenja nego do maksimalnog base clocka na skylakeu. Vidio sam da neki mogu i preko 200mhz, sa smanjenim množiteljem na k-series i smanjenim množiteljem za RAM i cache.
Staro 31.01.2016., 01:32   #767
Glavas_ZG
Datum registracije: Feb 2015
Postovi: 218
Nije preporučljivo dirati BLCK.
Glavas_ZG je offline   Reply With Quote
Staro 31.01.2016., 02:15   #768
kurc
kurc's Avatar
Postovi: 237
Iako je ovo tema haswell, pričamo o skylakeu na kojem se može dizat blck. Na haswellu se baš i nemože.
Staro 31.01.2016., 11:33   #769
Glavas_ZG
Postovi: 218
Da, na Skylakeu je odvojen base clock cpu i rama od ostalih, tako da se može, ali na sb ib hsw je spojen pa nije preporučljivo jel
Staro 11.02.2016., 02:15   #770
MOTOR MARY
Pink Wraith driver
MOTOR MARY's Avatar
Datum registracije: Mar 2015
Postovi: 71
složio sam mami mini-ITX konfu s G3260, 120GB HyperX SSD i 2x4GB RAMa i prezadovoljna je. nazvala me nakon 4 dana da kaže da joj je to najbrži komp ikad i kak joj je sad baš užitak radit. radi prelamanje knjiga, izradu prezentacija i tutorijala (audacity, screen recording) i takve stvari.
inače joj je firma donedavno dala rentan HPov komp s Q6600 i nekom Quadro grafom (bez SSDa), a onda joj "podvalila" prastari laptop s T4300 pod Vistom.
uglavnom, super je mali pentiumić. i dosta znače te brze jezgre očito, jer sam osjetio razliku u odnosu na moj proc.
MOTOR MARY je offline   Reply With Quote
Staro 11.02.2016., 09:25   #771
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Brze jezgre?!
Misliš superiorna Intel arhitektura u single threaded aplikacijama
Referiram se na to da ga tvoj A8 podere u smislu 4 jezgre, veća freq bikoz Turbo (3.8GHz), bolja integruša....zmaj na papiru, i tada qitica in real life, a košta više, više troši i grije se, a kad ga ideš clocknit da stigne mrski Intel noooooope - zaključan množitelj
Pomelo mi sig -.-
Staro 11.02.2016., 12:20   #772
MOTOR MARY
Pink Wraith driver
MOTOR MARY's Avatar
Postovi: 71
haha, okej, imaš pravo. nemrem reć brza jezgra ako radi na manjoj frekvenciji. na performanse sam mislio, dakle arhitektura, to je to.
uglavnom, prva liga je. a za ovo što si ostalo rekao, meni je moj super. :P
Staro 11.02.2016., 14:19   #773
Dottore
Dottore's Avatar
Postovi: 7,726
Autor MOTOR MARY Pregled postova
Koja ploča mini-ITX? Imam sličan procesor na poslu, samo mehanički disk 500gb i 4Gb memorije. Čudo radi dobro i ništa ne trza (outlook, exell, sap sa 6 tabova i browser) Najveći uppgrade za male novce.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 11.02.2016., 14:27   #774
MOTOR MARY
Pink Wraith driver
MOTOR MARY's Avatar
Postovi: 71
ASRock H81M-ITX
malo je štura sa SATA portovima, to trebaš pripazit. ima vjerojatno boljih opcija, meni je glavno bilo da ima dosta USB portova, da ima USB3 i da mogu spojit bilo kakav monitor.
Zadnje izmijenjeno od: MOTOR MARY. 11.02.2016. u 14:43.
Staro 11.02.2016., 15:15   #775
MikaHR
Postovi: 1,264
Jesemti, imam na poslu još uvijek C2D E 4500 s 2GB rama i niš ne trza, browser, ACad (+nadogradnje), excel, word.
Nisam vidio razliku izmedju toga, Phenoma x4, intela i5, FXa 83xx i i7.
Jedino što vam mogu poručiti je da se naučite održavati komp.
MikaHR je offline   Reply With Quote
Staro 11.02.2016., 18:56   #776
ssarik
Terror Absolut!
ssarik's Avatar
Datum registracije: May 2014
Lokacija: Earth
Postovi: 802
SSD kod tih stvari radi najveću razliku.
ssarik je offline   Reply With Quote
Staro 10.11.2016., 12:54   #777
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Nabavih 4670K, jel ok rezultat 4.4 @ 1,15V?
Staro 10.11.2016., 12:57   #778
domina
domina's Avatar
Lokacija: KC (HR)
Postovi: 917
Kakve temp? Mislim da je to odlično, probaj još izmust.
Staro 10.11.2016., 13:07   #779
nub
PREMIUM
nub's Avatar
Postovi: 2,165
Autor HCS Pregled postova
ako je to pravi vcore, a ne VID, onda je dobro, da.
Provjeri s hwinfo64 koji stvarni vcore očitava
Staro 10.11.2016., 13:44   #780
gil
Member
Lokacija: Kutina
Postovi: 979
Mislim da je to niski vcore za 4.4 GHz da bi bio istinit.
gil je offline   Reply With Quote
