Staro 13.09.2014., 12:14   #31
smirnoff
smirnoff's Avatar
Datum registracije: Dec 2009
Lokacija: nisam u ZG!!!!!!!!
Postovi: 1,211
Autor Valley7 Pregled postova
Može li se ikako namjestiti da se pojavi pitanje kada kliknem na shut down? Naime, lako je zabunom kliknuti i onda se odmah sve ugasi bez pardona. Malo mi je to glupo...
ček, misliš na ikonu kas stisneš start?? kak to moš zabunom stisnuti??
ili misliš na tipku "shut" na tipovnici??? to možeš isključiti u control panelu pod power options da ta tipka više ne reagira na pritisak.
Staro 13.09.2014., 14:13   #32
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,091
Pitanje mislim da ne, ali da se editirat da radi neš drugo (desni klik na njega samo pa moš mrdat). Ako baš patiš na onaj meni, gasi kantu sa alt+F4
CPU: i7-4790K @4.3 GHz + Scythe Ninja 3
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
CPU: i5-4690K @4.5 GHz + Raijintek Themis
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Dobar trgovac: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18
Živi bili pa umrli!
Staro 20.11.2014., 05:26   #33
Zé.
Samo polako
Zé.'s Avatar
Datum registracije: Oct 2014
Lokacija: Midwest Cro
Postovi: 301
Zasto meni na Win7 Windows Photo Viewer nece da otvara gif slike? Tj otvara ih ali kao jpg ili png, dakle neodvijaju se nego stoje.
kažu da sam lud, da je novo vrijeme...
Zé. je offline   Reply With Quote
Staro 20.11.2014., 05:41   #34
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,616
Moras preko browsera otvarat, nece u win7 vieweru
Staro 22.11.2014., 03:23   #35
Zé.
Samo polako
Zé.'s Avatar
Postovi: 301
Malo glupo...
Staro 19.03.2015., 22:11   #36
Zagorhac
Lokacija: Zagorje
Postovi: 421
Windows 7 - najjeftiniji key
pozz ljudi
posto sam vidio da windows 10 namjerava biti besplatan za korisnike sedmice i osmice, a i cijene key-eva, koliko vidim i nisu toliko visoke, zainteresirao sam se za kupnju istog.
gdje ih ima za kupiti (najjeftinije, a pouzdano)?
također, jel bolje home premium ili pro (koliko vidim, jedino bitno jest max podrzanost rama: 32 gb naspram 192 gb pro verzije)
hvala
Zagorhac je offline   Reply With Quote
Staro 20.03.2015., 11:38   #37
nub
PREMIUM
nub's Avatar
Datum registracije: Dec 2014
Postovi: 2,165
Možda da sačekaš dok se ne sazna više o ovom?
http://www.theverge.com/2015/3/18/82...ftware-pirates
Staro 20.03.2015., 12:07   #38
Zagorhac
Lokacija: Zagorje
Postovi: 421
nebitno. da li su ti kljucevi legit?
Staro 20.03.2015., 12:22   #39
zupy
zupy's Avatar
Lokacija: Priko Klisa
Postovi: 854
zupy je offline   Reply With Quote
Staro 20.03.2015., 12:26   #40
nino
nino's Avatar
Postovi: 12,613
Autor Zagorhac Pregled postova
...home premium ili pro (koliko vidim, jedino bitno jest max podrzanost rama: 32 gb naspram 192 gb pro verzije)
hvala
Mali ispravak za ram.
Home Premium: 16GB
Professional: 192GB
Staro 20.03.2015., 12:31   #41
Postovi: 34,139
To je povoljno obzirom da dobiješ i medij jer na ebayu za tu lovu dobiješ samo ključ mailom. Isto tako, ključevi za W8/8.1 su jeftiniji nego za W7.
EDIT: vidim na linku da je to verzija za Dell kompove pa ne znam koliko je to legalno.
Staro 22.03.2015., 10:13   #42
zupy
zupy's Avatar
Postovi: 854
The application is not bound by Dell
vako goggle translate kaže - neznam , možda je bolje uzest onda 8-icu pa ga dignuti na 10-tku kad se bude moglo.
Staro 22.03.2015., 10:17   #43
partwish
Creeper
Datum registracije: May 2013
Postovi: 2,226
Ja sam vidio da ekipa ovdje prodaje MS softver, a čini mi se da su cijene fantastične.
Staro 22.03.2015., 18:13   #44
imaticx
Default
imaticx's Avatar
Lokacija: Požega
Postovi: 1,520
Jel tko probao? Da nije kao sa one stranice sto se prije par mjeseci kupovalo, pa onda kljucevi postali nevazeci
Staro 22.03.2015., 18:15   #45
Nick7
Lokacija: Velika Gorica
Postovi: 1,541
Ja jos prosle godine tamo uzeo kljuc za Win8.
Uredno radi
Nick7 je online   Reply With Quote
Staro 22.03.2015., 18:22   #46
dadoremix
dadoremix's Avatar
Postovi: 4,781
U čemu je sad caka? Office 30$ i windows 8.1 25$
Kupim odmah obje samo da je sve po ps-u.
Ili bude kreplao kroz par mjeseci?
Jedne windowse vec imam orginal putem ms akcije od 45$ al to je doslo drito od njih pa nije bilo straha
Staro 22.03.2015., 20:58   #47
windfucker
Da, ali kako u slučaju potrebe dokazati da je OS legalan?
To ne kužim.
Ovi ključevi direktno od microsofta, to O.K., imaš potvrdu od koga si i šta kupio, ali ovo...opet nije rješenje, imo.
To što oni neće 10-ku "braniti" ne znači da si legalan, u slučaju nedajBože, jel'...ako sam ja čitavu priču dobro shvatio.
ispravite me ako griješim
Staro 22.03.2015., 21:05   #48
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,818
Autor windfucker Pregled postova
Ako mislis to "dokazivati" Microsoftu, njima je to nebitno, jer je taj kljuc vec netko platio, ovako ili onako.
S druge strane, sto se tice pravnih osoba u RH, ovakva kupovina je potpuno promasena u smislu legalnosti pred DI ili tko se sada vec bavi pitanjima legitimiteta softverskih licenci.
Programer
Staro 22.03.2015., 21:11   #49
windfucker
Mislio sam na fizičke osobe, zapravo...znam da je šansa mala da te kao fizičku osobu ide netko provjeravati za OS, ali ipak postoji.
Predpostavljam da, ako se uvjet ispuni, nebitno jesi li fizička ili pravna osoba, izuzev koeficijenta kojim se množi min. kazna, izrecivo u kunićima...
Staro 22.03.2015., 21:19   #50
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,818
Zaboravi.
Eventualno ako bas ne skidas pedofiliju pa ti bane SWAT team za vrijeme nedeljnog rucka, gdje ces osim zatvora fasovati i dodatnu kaznu za neimanje racuna za Windowse. Ako...
Programer
Staro 22.03.2015., 21:42   #51
dadoremix
dadoremix's Avatar
Postovi: 4,781
Meni osobno bi bilo lijepo da znam, ako dadem tih 200 kn za MS win ili office da bude to radilo.. odmah bi osobno natjerao i sve koji kod mene "održavaju" računala, da izdvoje tih 200 kn za licencu i mirni su.
jer jedni čak uspiju dobiti na komp da win nije legalan, a koristim iste KMS metode i kod sebe na jednom računalu, svaki update skinem i sve radi ko da je orginal.
A jedni nisu zadovoljni, pokupe svašta ne netu, pa je onda kriv windows koji nije legalan (mada gruntam da bude onda cijena MS-a pre jeftina pa opet to nebude dobro)
Jer opče poznata je stvar, kada je ista stvar skuplja, narod to više cijeni.
Zato i jesam ja skeptičan 25$ za win i 20$ za office
Staro 22.03.2015., 22:00   #52
Goc 101
Goc 101's Avatar
Datum registracije: Aug 2011
Lokacija: Sesvete
Postovi: 129
Autor zupy Pregled postova
Izgleda primamljivo ali nema lijepe naše na popisu zemalja prema kojima šalju.
Goc 101 je offline   Reply With Quote
Staro 22.03.2015., 22:05   #53
windfucker
Autor Bubba Pregled postova
Zaboravi.
Ma, mislio sam više na prijenosna računala, putovanja (inozemstvo?), ali nvm...jasno je kako stvari stoje sa kupovinom ovih ključeva.
A za onaj prvi dio, nema straha, konzumiram samo zrele plodove, trulež i zelenilo nisu na mome meniju (iako, kako matorim, trulež postaje sve rastezljiviji pojam)...
Staro 22.03.2015., 22:52   #54
partwish
Creeper
Postovi: 2,226
I šta, odeš s laptopom u Kanadu i na granici ti traže račun od laptopa, windowsa, mobitela i čarapa koje imaš na sebi?
Staro 22.03.2015., 23:15   #55
windfucker
Ha, ne znam, jbg...nikada nisam probao šetati se uokolo sa nelegalnim windowsima
Furam lap poradi posla preko grane, ali na njemu je ionako sve samo legala, tako da sam miran...i inače, prošla su me ta vremena krek@nja i sl., kupujem ono što mi treba, za manje bitne stvari koristim besplatne inačice, bitno da se posao obavi.
Postavio sam pitanje čisto da bacim bubu u uho neupućenima, da ne pomisle da takav key prolazi službene organe reda, ako se ikada poklopi, onako, više retorički... Jer imam dojam da je čitava priča kroz komentare o legalizaciji lagano naginjala na tu stranu, a tome ipak nije baš tako, izgleda...ugl. sve jasno.
Staro 23.03.2015., 12:29   #56
zupy
zupy's Avatar
Postovi: 854
150-200 kn se isplati dati samo radi ugrađenog antivirusa takorekuć.
Staro 23.03.2015., 12:58   #57
Postovi: 34,139
Čitao sam malo komentare ljudi koji su kupili baš te ključeve i nitko nije imao negativno iskustvo. Definitvno sam došao u napast da ih kupim, što ću vjerojatno i učiniti u slijedećih tjedan-dva.
Prozujao sam malo i po našim oglasnicima. Najbolji mi je bio lik koji mi je rekao "ključ je ok, ali ne smiješ skinuti određeni update". Alo!!?
Staro 23.03.2015., 13:11   #58
ukiy
ukiy's Avatar
Datum registracije: Apr 2008
Lokacija: ST
Postovi: 398
Oprezno sam ovim jeftinim kljucevima...
Ja sam prije jedno pola godine uzeo na G2A Win8.1 Pro retail kljuc za 20€, instaliram i aktiviram bez ikakvih problema...
A onda sipak... nekidan ih idem reinstalirati, kad ono aktivacija ne prolazi... odmah kontaktiram MS Support i kazu mi da je kljuc valid ali da ga je sistem blokira i da necu moci aktivirati...
Pitam u cemu je problem i zasto je blokiran, a agent mi veli da je kljuc flag-an ka piratski, i u fino mi kaze da se mogu je**ti... i odmah me upozori da pripazim di kupujem kljuceve.
Dobra stvar je sto mi je G2A odobrio refund... neznam da li bi ga dobio od sellera na redditu i slicnim stranicama.
Zadnje izmijenjeno od: ukiy. 23.03.2015. u 14:09.
ukiy je offline   Reply With Quote
Staro 23.03.2015., 13:16   #59
windfucker
Stoji, ali i dalje nisi legalan.
A ako je već tako, ima i drugih načina da dobiješ taj antivirus potpuno funkcionalno, jedino izbjegavaš "komplikacije" od dva reboot-a, što NE podržavam, da se odmah razumijemo, no istine radi zapravo dođeš na isto (glede legalnosti).
Tako da...jedino se zaobilaze programi "treće strane", i to je sve što dobiješ za tu lovu + još netko sa strane zaradi nešto (na tebi).
Staro 23.03.2015., 14:08   #60
ukiy
ukiy's Avatar
Lokacija: ST
Postovi: 398
*kriva tema
Zadnje izmijenjeno od: ukiy. 23.03.2015. u 14:09. Razlog: zaj**o se...
