Staro 22.01.2015., 23:22   #991
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
@veve
Potpis doslovno od A do ŽNJ
Pomelo mi sig -.-
Zadnje izmijenjeno od: Drvoje. 23.01.2015. u 00:11.
Staro 22.01.2015., 23:56   #992
xGAME
xGAME's Avatar
Lokacija: Chernobyl NPP
Postovi: 4,778
Koji su tempovi tog procesora s deff coolerom? Bez OC-a. Da mjesec-dva izdrži s njim pa onda nešto konkretnog uzmem.
xGAME je offline   Reply With Quote
Staro 23.01.2015., 10:22   #993
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,084
Možeš i sa stockom izgurat za prvo vrijeme. Ja ga na box cooleru nisam nikad probo, ali mi je aftermarket u full loadu ispod 50 stupnjeva držo torture test na stock frekvama.
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 17.02.2015., 14:11   #994
Rino
[ZA DOM]Rino
Rino's Avatar
Lokacija: Kutina
Postovi: 762
Imam polirani TT Big Typhoon učvršćen vijcima + homemade backplate na 3570K!
Ukoliko je napon oko 1.25 (otprilike 4600MHz) temperature mi sa Intel Burn-om idu do 90 stupnjeva.
Kučište je dobro provjetreno.
Da li je moguće da je Big Typhoon nakon gotovo 8 godina korištenja otišao kvragu (heatpipe-ovi) ili toliko loše naliježe na procesor.
Zbog kučišta sam osuđen na top-down hladnjak pa sam gledao koji bi bio dostojna zamjena koja bi mi potrajala godinama i našao Noctua NH-C14, ali malo je skup i ne znam gdje ga kod nas nabaviti!
Rino je offline   Reply With Quote
Staro 17.02.2015., 15:26   #995
iggi
Lokacija: qǝɹƃɐz
Postovi: 442
Jesi skidao hladnjak pa su ti temperature skočile ili se to desilo samo od sebe?
Ako si dobro postavio hladnjak nema veze sto je backplate home made.
3570K se na 4600MHz fino grije, ali 90C je puno!
Kućište je Chieftec BA-02-B-B-B ili...?
iggi je offline   Reply With Quote
Staro 17.02.2015., 15:36   #996
Rino
[ZA DOM]Rino
Rino's Avatar
Lokacija: Kutina
Postovi: 762
Ne...držao sam ga na stocku otkad ga imam i tek nedavno ga odlučio overclockati.
Kučište je BA02-B-B-B, ali je moddano i na bočnoj i stražnjoj strani su 2x2 140mm Sharkoon ventilatori na 600rpm!
Staro 17.02.2015., 15:56   #997
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
Phanteks PH-TC14CS ili Cryorig C1. Kod nas ih nema ali cimaj Ninu da ti provjeri I da, moguce je da je jedna ili vise hitpajpova iscurilo.
Staro 17.02.2015., 16:37   #998
Rino
[ZA DOM]Rino
Rino's Avatar
Lokacija: Kutina
Postovi: 762
Autor xulos Pregled postova
Toga sam se i bojao!
Staro 17.02.2015., 18:36   #999
iggi
Lokacija: qǝɹƃɐz
Postovi: 442
Ja bi na tvom mjestu, prije kupnje novog coolera, svakako skinuo stari detaljno ga očistio, promjeno pastu i ponovo vidio temperature.
Prilikom skidanja hladnjaka po ostacima paste vidi kako ti cooler nalježe na procesor...
Imao sam Typhoon-a i nisam bio oduševljen završnom obradom baze hladnjaka.
Neispravnost heat pipe-ova bi uzeo pod zadnju opciju.
Zadnje izmijenjeno od: iggi. 17.02.2015. u 18:43.
Staro 17.02.2015., 19:18   #1000
Rino
[ZA DOM]Rino
Rino's Avatar
Lokacija: Kutina
Postovi: 762
Autor iggi Pregled postova
Znam zato sam ga i polirao i trenutno je savršeno ravan i baza je poput zrcala!
Možda je proc konkavan/konveksan!
Do sada je hladio 2500+ Bartona, Q6600, Q8200 i 2x 3570K pa mi ga je malo žao!
Staro 17.02.2015., 19:43   #1001
iggi
Lokacija: qǝɹƃɐz
Postovi: 442
Nemaš što izgubiti, provjeri prije kupnje novog!
A' možda jednostavno nije dorastao zadatku. Iako sumljam, moj je hladio Q6600 na 3400MHz.
Staro 18.02.2015., 02:35   #1002
Drift_King
Never Forgetti
Drift_King's Avatar
Lokacija: .
Postovi: 1,640
Bi li sta pomoga H70i?
photo hosting
Ako ne, koji cooler uzet (ovog mogu dobit povoljno).
Drift_King je offline   Reply With Quote
Staro 18.02.2015., 09:30   #1003
Drvoje
Drvoje's Avatar
Postovi: 4,037
Autor Rino Pregled postova
..Noctua NH-C14[/URL][/B], ali malo je skup i ne znam gdje ga kod nas nabaviti!
Oprić Informatika za 540kn (cash), ali "božemesakloni" cijene
http://forum.pcekspert.com/showthread.php?t=190046
http://www.opric-informatika.hr/
Pomelo mi sig -.-
Staro 06.03.2015., 16:38   #1004
PR3DA70R
PR3DA70R's Avatar
Lokacija: Yautja Prime
Postovi: 1,229
Zna li netko možda gdje mogu nabavit ove ili slične držaće ventilatora za Xigmatek Aegir SD128264?
Edit: nvm našao sam nešto slično na ebayu.
http://www.ebay.com/itm/Lot-20pcs-1-...item3a962ed377
Zadnje izmijenjeno od: PR3DA70R. 07.03.2015. u 16:12.
Staro 13.03.2015., 18:05   #1005
Thiniad
Thiniad's Avatar
Datum registracije: Aug 2008
Postovi: 129
Tek tolko da pitam. Isplativo je uzet TRUE ultra rev.c za 200kn zar ne?
I recite koji su hladnjaci uopće bolji od tog trua danas?
Thiniad je offline   Reply With Quote
Staro 13.03.2015., 21:27   #1006
Cloker
Cloker's Avatar
Datum registracije: Oct 2014
Lokacija: Bojnik
Postovi: 235
Autor Thiniad Pregled postova
www.phanteks.com/ph-tc14pe.html
Cloker je offline   Reply With Quote
Staro 13.03.2015., 23:39   #1007
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
A jesi nas'o usporedbu Od TRUE je trenutno bolje bar 10 kulera ali za 200 kn naspram 500-600+ bolji kuler nemozes kupit naustrb par stupnjeva vise.
Staro 26.03.2015., 20:08   #1008
Thiniad
Thiniad's Avatar
Postovi: 129
Ljudi, našao sam kopiju LC-CC-120
http://www.techpowerup.com/reviews/S..._HE1224/1.html
Skroz je isti LC, samo što je ovaj silentium za poljsko tržište očito. Review dobro dođe za usporedbu sa ostalim brojnim coolerima pa pogledajte.
edit: evo još linkova lol
http://www.nikktech.com/main/article...-cooler-review
http://www.madshrimps.be/articles/ar...#axzz3VW7GTUWP
http://www.eteknix.com/silentiumpc-g...cooler-review/
I šećer na kraju, review sa PCeksperta XD
http://www.pcekspert.com/clanak/sile...c-fera-2-test/
Nisam ni znao da su imali review na ovog našeg LC-a, a nigdje nisam ni pročitao u ovom topicu ni slovo od silentiuma. :/
Zadnje izmijenjeno od: Thiniad. 26.03.2015. u 20:20.
Staro 26.03.2015., 21:05   #1009
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 895
Imam lc-cc-120 i mogu samo riječi pohvale reči za njega.i54690k @ 4800/1.275v max temperatura 72c .gažen sa OCCT 4.4.1.igranje wow-a 2-3 sata 53 do 57 kako koja jezgra
MSI B450M pro-m2 max-ryzen 7 5800xt-nvidia 5060 ti - Asus rog swift PG278Q
damir1 je offline   Reply With Quote
Staro 27.03.2015., 12:04   #1010
smak420
smak420's Avatar
Datum registracije: Jan 2015
Lokacija: mars
Postovi: 104
evo i mene zanima nesto jeftinije za core 2 quada tj xeona x5460 kojeg bi drzao na 4.0
sta je od ovog bolje...nazalost osuđen sam na polovni lopovluk sa PIK.ba jer su mi sredstva dobro ogranicena
http://www.olx.ba/artikal/16586747/h...-scythe-mugen/
http://www.olx.ba/artikal/16570268/c...cyte-katana-3/
http://www.olx.ba/artikal/16588586/c...ua-nh-u9b-se2/
uglavnom sve polovno u bih kosta blizu novog u hr, al jbg osuđen sam nažalost tako jer ovdje u mom mjestu imam 3 ducana sa pc opremom, a ni jedan nema termalne paste!
eto moze i preporuka za pastu dobru
smak420 je offline   Reply With Quote
Staro 30.03.2015., 16:35   #1011
Thermaltake
1
Thermaltake's Avatar
Postovi: 3,627
Ugrađivo već dosta katana 3 u kompove i pokazale su se fakat dobre i osobno ju imam i odlična je čak i za overklok.
Pastu ili Arctic Silver 5 ili MX-4 oboje koristim i oboje su dobre, jedino recimo AC5 ne stavljam na GPU čipove makar na par jesam i nije bilo problema no neki su rekli da iz nekog razloga je njima otišla tako grafička dok su micali staru i stavljali AC5 na GPU čip, šta su radili s njom nemam pojma uglavnom idem ziheraški pa stavim MX-4 da se nemoram brinut još i oko tog, plus MX-4 djeluje odmah dok AC5 ti ima cure time od 52h.
Zadnje izmijenjeno od: Thermaltake. 30.03.2015. u 16:41.
Staro 30.03.2015., 21:45   #1012
Drvoje
Drvoje's Avatar
Postovi: 4,037
Trenutno za iste nofce (136kn cash - Protis) imaš LC Power LC-CC-120, tako da ovi odroni s 90/92mm ventovima nemaju šta tražit pored njega (naravno ako ima mista u kejsu za 152mm visine).
A ovo za GPU čipove i AC Silver 5 pastu prvi put čujem
Pomelo mi sig -.-
Staro 18.04.2015., 20:20   #1013
zlikovski
Mutant Year Zero
zlikovski's Avatar
Postovi: 509
Ugradio sam Scythe Tatsumi na Intelov procesor i mogu reći da je hladnjak super.
Odlična obrada, baza ravna, hladan i nečujan.
Montaža je puno bolja od Katane, jer nema onih plastičnih puš pinova za Intel,
nego ima backplate i vijke na navoj.
Cijena je oko 180 kuna.
Mislim da je prava konkurencija ColerMaster 212 hladnjaku
Uglavnom svaka preporuka za Tatsumi.
http://www.quietpc.com/tatsumi
http://www.pcgameware.co.uk/reviews/...cooler-review/
zlikovski je offline   Reply With Quote
Staro 18.04.2015., 22:08   #1014
Drvoje
Drvoje's Avatar
Postovi: 4,037
Žali bože novaca - šta fali ovome za 150kn (za cash), a ima i 120mm vent (pa ga barem možemo usporedit s Hyperom 212)?
http://www.nabava.net/search.php?tp=0&q=lc-cc-120
Pomelo mi sig -.-
Staro 18.04.2015., 22:37   #1015
zlikovski
Mutant Year Zero
zlikovski's Avatar
Postovi: 509
Pa i nije tako velika razlika u cijeni:
http://www.nabava.net/search.php?tp=0&q=scythe+tatsumi
Kod LC-CC-120 mi se ne sviđa plastični backplate.
Scythe ima sve čvrsto, metalno i kromirano.. jednostavno bolja završna obrada.
Scythe ima sjajnu ravnu i ispoliranu bazu.
LC ima onaj sistem gdje heatpipe na bazi prianja direktno na procesor.
Znam da to pasta sve pokrije ali više volim sjajnu bazu.
Stvar odabira. Ne sviđa mi se LC.
Znam da je best buy
Staro 18.04.2015., 22:38   #1016
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,297
Taj sistem je cak i bolji od ovog koji ima "odvojenu" bazu.
Staro 18.04.2015., 22:44   #1017
zlikovski
Mutant Year Zero
zlikovski's Avatar
Postovi: 509
Ali ne možeš se pogleadati na bazi
Mislim da su temperature tu negdje približne.
Ništa spektakularno..
Staro 18.04.2015., 23:10   #1018
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,297
Mozes ako je obradis sa vodobrusnim kako treba
Staro 19.04.2015., 19:48   #1019
webstartm
Sandy!!!
webstartm's Avatar
Postovi: 1,695
imam ponudu za coolermaster tpc 800, bez ventova, za 160kn...
treba bi hladit i7 2600k na blagom oc , 4.2-4.4
radi se ovom ovom kuleru
link
ima par recenzija
link1
link2
link3
link4
cini se dosta dobar kuler, al nezz ni sam,sa jedan/dva venta ce me doc preko 200kn,a za te pare se mozda daa nac nest bolje
zanima me vase misljenje/iskustva/preporuke
Staro 19.04.2015., 22:10   #1020
iggi
Lokacija: qǝɹƃɐz
Postovi: 442
Nelos hladnjak. Pod zadnje Ultra 120 Extreme na trznici ide za cca 150kn, a on je bolji od tpc 800. Ako si u zurbi uzmi...
