Staro 19.07.2004., 13:47   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
RaBit 1.3
Ovaj program se bogme non-stop nadograđuje i poboljšava
Azarov Evgeny aka Jaz has updated his RaBit ATI Radeon BIOS editor. The archived date is July 12th, 2004. I have no idea about the actual changes, but better Windows XP integration is evident though. For advanced users only.
Unique ATI Radeon BIOS editor with a number of great features:
- Real adjusting of 17 (!) memory timings.
- Adjusting BIOS memory bus width (32/64/126/256 bit).
- BIOS description string editing.
- Toggling the type of memory (SDR/DDR).
- Adjusting BIOS memory size.
- Comprehensive BIOS info logging.
- Traditional BIOS Editor controls: Device ID, chip/memory clocks, TV-out options and checksum correction.
Adjusting memory timings allows user to gain "free" performance in 3D-games and applications and/or to gain better overclocking results.
http://mr-1677.v-mirror.spb.ru/bios/util/RaBiT-1.3.rar
Staro 20.07.2004., 12:19   #2
LorD ClockaN
od LemilicE
LorD ClockaN's Avatar
Lokacija: Veli Lošinj
Postovi: 4,712
Jel ima još netko ovdje osim mene koji je mijenjao latencije memorije pomoću ovog programa ili su ovakvi topici nepotrebni???
Nemam više lema!!!
Staro 20.07.2004., 14:00   #3
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,002
A napiši nešto o rezultatima, možda i nekog od nas ponukaš da probamo
segregator je online   Reply With Quote
Staro 20.07.2004., 14:12   #4
LorD ClockaN
od LemilicE
Postovi: 4,712
Da pogledaš prijašnja 2 topica sa Rabitom, onda bi možda i znao.
Nemam više lema!!!
Staro 20.07.2004., 14:17   #5
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
vidi vidi tak nekaj sam ja tražio sad kad mi se grafa vrne s reklamacije ćemo ić na štelanje latenicja.
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 20.07.2004., 15:24   #6
Jelc
Super Moderators
Postovi: 17,485
Mislim da je tek sad u trećoj inačici to TO
Dakle-i BIOS editor i ispravno prikazivanje tajminga i ispravno upisivanje u BIOS kad stavljaš nove postavke.
Meni je u stvari korisniji kao BIOS editor sa par dodatnih điđa.
Eventualno bih malo "zategnuo" memorijske postavke na default frekvi-čisto da vidim da li ima kakvog ubrzanja.
Imam 9800 non-pro flashanu u XT...ide do 430/365, svako kemijanje bez da obezbijedim dodatno hlađenje bi bilo čista perverzija
Kaj-živcira te soft
Ti bi rađe lemio:clap:
Staro 20.07.2004., 15:30   #7
LorD ClockaN
od LemilicE
Postovi: 4,712
Originally posted by Jelc
Kaj-živcira te soft
Skoro pai bi.
Kemijam nešto da stavim vodeni blok na grafu, pa će i hard-modovi doći na red
Nemam više lema!!!
Staro 20.07.2004., 16:43   #8
Mailman
Mailman's Avatar
Postovi: 1,606
Ja sam se nešto zahebavao s time ali kad imaš Infineona 3.3 ništa ti ne može pomoći...
(osim voltmoda naravno )
Mailman je offline   Reply With Quote
Staro 27.07.2004., 02:09   #9
Jelc
Super Moderators
Postovi: 17,485
Evo dečki-na linku je jedna mala gujda o RaBitu i kaj je zanimljivije jedan je benchao svaku stavku posebno i objesio rezultate.
Vrijedi pogledati.
http://www.rage3d.com/board/showthread.php?t=33770434
Staro 27.07.2004., 11:41   #10
Gile
Postovi: 380
Ja bi se malo igrao sa tim postavkama memorije, može li se kako vratiti stari bios bez PCI grafičke jer ju nemam, ako bude kakvih problema.
Gile je offline   Reply With Quote
Staro 27.07.2004., 12:00   #11
Jelc
Super Moderators
Postovi: 17,485
Samo prvo spremi stari BIOS na sigurno i zapamti proceduru flasha tako da možeš i "na sljepo" vratiti.
Ono-ako ti je kad piskaraš u DOS-u npr. točka pod đ na tipkovnici i slične stvari.
Staro 27.07.2004., 15:02   #12
miato
(°_°)
miato's Avatar
Postovi: 3,249
sudeci prema Jelcovom linku, tip dobije CAK 0.2 veci fps zbog promjene latencija. kakva je situacija kdo tebe?
Staro 27.07.2004., 20:05   #13
Gile
Postovi: 380
Nakon 5 sati zezanja sa tim postavkama, rezultati su sljedeći 3DMark03:4333 prije 4322, a Aquamark3
GFX:4.069 prije 4.056.
Staro 28.07.2004., 03:36   #14
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,463
:clap: a smanjit latencije, pa više clockat mem?
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 28.07.2004., 11:47   #15
Gile
Postovi: 380
Probano i nevalja, artifakti se pojavljaju odmah poslje restartanja.
Staro 28.07.2004., 13:15   #16
LorD ClockaN
od LemilicE
Postovi: 4,712
Ja sam si namjestio latencije PRO kartice i dobio nešto više od 200 novih Marka (ne DEM)
Nemam više lema!!!
