Staro 18.01.2016., 12:42   #1
Doubleclickhere
Datum registracije: Jan 2016
Postovi: 11
Question Hp 4510s nema pozadinskog osvjetljenja
Pozdrav svima imam problem sa hp probook-om 4510s a sljedeci je da lcd radi prikazuje sliku i sve al nema nikakvog osvjetljenja, dal netko zna do čeg bi mogao bit problem?
Doubleclickhere je offline   Reply With Quote
Staro 18.01.2016., 14:26   #2
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,066
možda je prdnulo neš oko rasvjete, ali nebi ga bilo loše raskopat i pogledat kabel od ekrana, možda samo gubi kontakt negdje ili konektor ne sjeda kak treba na ploči.
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 18.01.2016., 14:30   #3
Doubleclickhere
Postovi: 11
Hmm nisam ga jos probao raskopat cijelog samo sam lcd izvadio i testirao na drugoj ploci i radi uredno tako da do njeg samog nije, probat cu ga raskopat popodne pa se javim dal je do flata ili konektora, jel ima na ploci nekakav osigurac ili nesto zbog kojeg se moze ovo dogoditi mozda dal znas?
Staro 18.01.2016., 14:42   #4
Chuxonja
Pajcek
Chuxonja's Avatar
Postovi: 1,066
rasturo sam mu srodne 4520 i 4525, ali nisam sa ekranima posebno petljo da bi znao dal je još neki fuse tamo ili ne. Ja satavljam pare na flat
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
ODD: LG GH24NS70
OS: Windows 10 Pro
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
ODD: LG CH10LS20
HDD1: WD Green 1TB
LINK
ODD: LG GH22LP20
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
PSU: Enlight 400W
OS: Windows XP SP3
LINK
HDD: WD 160GB
OS: Windows XP SP3
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 19.01.2016., 14:23   #5
Doubleclickhere
Postovi: 11
Nazalost nije ni flat rijesio problem promjenio sam ga i dalje ista stvar
Nesto je na ploci problem jel ima jos tko kakav savjet
Staro 19.01.2016., 16:06   #6
HardDiskDrive
Postovi: 26
Jesi probao ekran zamjeniti, probati sa drugim ekranom? Znaju te lampe na lcdu otici.
HardDiskDrive je offline   Reply With Quote
Staro 19.01.2016., 16:09   #7
Doubleclickhere
Postovi: 11
Da probao sam ubacit taj lcd u jedan drugi laptop i radi uredno. Na ovakav kvar jos nisam naletio na ovakvim modelima pa mi nije nista jasno
Staro 20.01.2016., 10:07   #8
HardDiskDrive
Postovi: 26
Da ni ja nisam to još vidio. Ali nema šta onda je matična sve drugo si eliminirao. Našao sam nešto na internetu pa ti mogu poslati u inbox.
Staro 20.01.2016., 10:08   #9
Doubleclickhere
Postovi: 11
Može pošalji i hvala ti.
Staro 20.01.2016., 15:20   #10
Mr.Black
Mr.Black's Avatar
Postovi: 1,679
Pozz, imam isto problem sa lenovo t520..ne radi osvjetljenje, ni nakon 2 zamijenjena displaya. Na vanjski monitor normalno daje slike. Jedino nisam još probao zamijeniti flat kabel, jer ga nemrem pronaći..
Mr.Black je offline   Reply With Quote
Staro 20.01.2016., 15:38   #11
Doubleclickhere
Postovi: 11
Jesi li probao promrdat konektor od flat kabela na ploci mozda je samo neki los spoj?
Staro 20.01.2016., 18:56   #12
huzo
Zvoni. Kucanje ne radi.
huzo's Avatar
Lokacija: ZAGREB DUBRAVA
Postovi: 711
jesi odstekavao i ustekavap ekran dok je laptop bio ustekan na bateriju ili na punjac?ako jesi spalio si smd osigurac ,a mozda i driver od osvjetljenja...
Those who believe in telekinetics, raise my hand!
huzo je offline   Reply With Quote
Staro 20.01.2016., 19:00   #13
Doubleclickhere
Postovi: 11
U pocetku nisam to je krepalo samo od sebe dok je laptop radio, taman sam surfao nesto netom i samo je osvjetljenje zatreperilo i ugasilo se, prvi put sam promjenio lcd sa istekanim napajanjem a sad to vec radim neko vrijeme sa ustekanim imam nekih razvaljenih lcd-a pa me nije puno ni bilo briga, taj smd osigurac jel to ovaj s 3 nozice kraj konektora od flata ili? Svi na netu prijcaju o fuse 1 fuso 8 itd na sony dell laptopima itd ali ja klasicni osigurac nigdje na ovom hp nemogu nac
Staro 21.01.2016., 18:06   #14
Chuxonja
Pajcek
Chuxonja's Avatar
Postovi: 1,066
vjerojatno nije klasičan, to su ova mikro govna koja se jedva vide. Best bet je gledat oznake na ploči ako ih ima F-nešto će se zvat. Krpo sam par takvih na monitorima, jedva našo smradove.
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
ODD: LG GH24NS70
OS: Windows 10 Pro
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
ODD: LG CH10LS20
HDD1: WD Green 1TB
LINK
ODD: LG GH22LP20
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
PSU: Enlight 400W
OS: Windows XP SP3
LINK
HDD: WD 160GB
OS: Windows XP SP3
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 26.01.2016., 00:20   #15
Doubleclickhere
Postovi: 11
Zaboravio sam javit trazio sam ta mikro smeca odmah taj dan nakon sto si mi rekao nisam mogao pronac, i evo danas nakon par dana uhvatim se tog posla opet i sad laptop daje sliku uredno samo na vga a na lcd/hdmi nema znakova zivota uopce. Probat cu update biosa ako ne proradi vjerojatno je grafa odradila svoje pa moze u smece..
Staro 26.01.2016., 13:07   #16
Overclock_freak
Datum registracije: Dec 2012
Lokacija: Rijeka-Zagreb
Postovi: 1,207
javi se forumašu Alvin ili njegovoj firmi IT elektronika.. čovjek koji će najbolje znat šta i kako.. al vjerovatno GPU na izdisaju.. tih probookova što 451x što što 452x bilo je mali milon.. svi kad tad završe kod njega ili na groblju
