Staro 07.05.2015., 10:51   #1
DemiG
Datum registracije: May 2015
Postovi: 12
koju marku od r9 280 izabrati?
Sve se kreću u rasponu 150 kn, xfx, sapphire dual-x, msi gaming, gigabyte windforce x3.
Koja ima najbolje hlađenje? Čini mi se ko da dosta ljudi pljuje xfx, za msi sam čitao ako su imali nekih problema sa curenjem nekog ulja u početnoj proizvodnji ali da su to sredili.
Kakva su vaša mišljenja?
DemiG je offline   Reply With Quote
Staro 07.05.2015., 10:53   #2
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,083
Možda windforce ak ti stane u case :P
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 07.05.2015., 15:45   #3
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,296
imam 7950 dual-x od sapphirea (isti q) i da mogu birat opet bih je uzeo. eventualno bi prije jedino uzeo kakvog asusa direct cu.
hladenje je jako dobro, da se podesiti brzina venta da dok ne igras nis da je ni ne cujes.
Staro 07.05.2015., 15:58   #4
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,191
Imao sam Sapphirku i XFX i pohvale za obje. Zadnja verzija hladnjaka od XFX-a se ne može uspoređivati s onim limom bez heatpipe što su prije stavljali na 7970 i 7950. Sada je hladnjak zaista na razini.
Osim toga, imaš i review na ovdje na PCE pa baci oko:
http://www.pcekspert.com/clanak/xfx-...clockerov-san/
Staro 07.05.2015., 16:42   #5
noda
teh masta
noda's Avatar
Postovi: 216
Mogu potvrdit za XFX ovo kaj kaže Fischer, jer imam točno tu iz PCE reviewa.
U mirovanju hladna i jako tiha, skoro nečujna, a u igrama se čuje, ali ako si podesiš ventilator u msi afterburneru onda je i tada ok.
noda je offline   Reply With Quote
Staro 07.05.2015., 16:50   #6
DemiG
Postovi: 12
Da, naime čuo sam da je xfx u zadnjih par generacija na nivou.
Ima itko ovu gigabyteovu windforsicu? Izgleda da je najbrža od ponuđenih (950 hz core speed) a skuplja 100 kuna od najjeftinije 280-ke. Neka iskustva?
Staro 07.05.2015., 16:54   #7
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,296
Sve se to da oc-at tako da radije gledaj izradu, a ne taktove
Staro 07.05.2015., 19:17   #8
DemiG
Postovi: 12
Pa čini mi se kao da je ovaj windforce sistem dosta kvalitetan, em što je grafa jače klokana em dobiješ +1 vent na njoj za stoju više
Staro 07.05.2015., 19:45   #9
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,296
ti ventovi su 7.7/8 cm u odnosu na 9 cm kod sapphirea i asusa ako se ne varam, tako da ce biti i nesto glasniji.
Staro 07.05.2015., 19:55   #10
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Također gledaj da ima 3 god. gare i nema otraga naljepnice (dakle ASUS ili Gigabyte).
OC potencijal je ionako lutrija, a to šta npr. neka ima 5% veće tvorničke taktove ti zbilja neće pomoć.
Ja bi Gigabyte jer je ASUS tradicionalno među skupljima.
Usput se nadam da imaš koliko toliko provjetreno kučište, solidno napajanje i "normalan" monitor
Pomelo mi sig -.-
Staro 07.05.2015., 20:49   #11
DemiG
Postovi: 12
zalman z11 neo, Fortron Rider S 550w, a monitor još gledam šta ću.. trenutno je Benq GW2255 na listi. Ako imaš neki usputni prijedlog za cca 300 kn više rado ću ga razmotriti
Staro 08.05.2015., 01:19   #12
Drvoje
Drvoje's Avatar
Postovi: 4,037
Zalman kejs od cca 590kn - pljačka
Ja bi radije crni Fractal Core 3500 s plexijem od cca 600kn - sa skoro 9kg pregazi tu plastičnu Zalmanovu kantu ko plitki potok
Ali ne izgleda toliko sexy (više je srkazam nego stvar ukusa) ka Zalman, već skandinavski - monotono, oštro, čisto i ozbiljno.
BTW za dodatnih cca 100kn više (dakle i dalje ispod 300kn) imaš 12.3kg čistog sexualnog zadovoljstva zvanog Fractal Define R4 Black Pearl
Pomelo mi sig -.-
Staro 08.05.2015., 01:22   #13
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
gigabyte - malo bolje temperature, ali i malo glasnija, najveći plus 3 god. garancije
xfx - mrvicu toplija, ali i tiša
Jednu od te 2 bi gledao
Staro 08.05.2015., 08:45   #14
DemiG
Postovi: 12
Da, gigabyte i asus dolaze sa 3 god gare a i više preferiram hladniji gpu naspram glasnijeg. Posto je asus osjetno skuplja mislim da je gigabyte bolji izbor.
drvoje, nikako mi se ne sviđaju ta kucista sa prednjim stranicama, a koliko sam gledao reviewove z11 neo se čini kao dosta čvrsto kuciste :-)
Staro 08.05.2015., 11:18   #15
Chuxonja
Pajcek
Chuxonja's Avatar
Postovi: 1,083
Jel se na NEU da izvadit van disk bay u sredini ? Inaće bi ti mogo bit prekratak za Windforce.
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
ODD: LG GH24NS70
OS: Windows 10 Pro
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
ODD: LG CH10LS20
HDD1: WD Green 1TB
LINK
ODD: LG GH22LP20
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
PSU: Enlight 400W
OS: Windows XP SP3
LINK
HDD: WD 160GB
OS: Windows XP SP3
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 08.05.2015., 14:03   #16
DemiG
Postovi: 12
Da, od 270 - 400 mm grafe stanu u njega kada se ukloni hard drive cage
