Staro 09.06.2008., 14:57   #1
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Ko je brži, AMD ili Intel - malo drugačiji pogled
http://weblog.infoworld.com/yager/ar...tml?source=rss
Ako imate volje čitati, članak je malo duži
"AMD counters the gearhead-level speeds and feeds derived from synthetic benchmarks with IT-relevant load metrics. In Web transactions, virtualization, and parallel workloads, Quad-Core Opteron outperforms quad-core Xeon by margins of 9 to 16 percent. But there's a point worth noting: AMD scored these wins with a 2.3GHz CPU and 2MB of Level 3 cache. Intel lost out to AMD with quad-core Xeon CPUs running at 2.83GHz with 12MB of cache. The configuration differences between the two architectures give AMD what you call headroom. AMD is holding manufacturing process shrink, CPU clock speed, bigger cache, and additional cores as cards to play on IT's behalf when the time is right."
Staro 09.06.2008., 15:50   #2
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,309
Segre se opet bori sa vjetrenjačama
Staro 09.06.2008., 15:55   #3
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Nisam ja majke mi, tip na slici uopće ne sliči na mene
Staro 09.06.2008., 19:11   #4
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
onaj tko imalo cjeni lovu ce znati za svaku namjenu uzeti proc...
.i.
Razer Blade 15
Staro 10.06.2008., 02:26   #5
maX
maX's Avatar
Postovi: 7,326
Autor Gilbert5 Pregled postova
jbg, neki se nikad nece pomirit s istinom
Staro 10.06.2008., 02:35   #6
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
Intel FTW
Staro 10.06.2008., 07:16   #7
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Autor maX Pregled postova
Pogotovo ako nije istinita
Staro 10.06.2008., 08:42   #8
Jerry
Jerry's Avatar
Postovi: 1,816
Autor Fleks Pregled postova
Intel FTW
1P - da
2P - mozda
4P - mos' mislit!
http://www.vmware.com/products/vmmark/results.html
Stupid is as stupid does
Jerry je offline   Reply With Quote
Staro 10.06.2008., 09:04   #9
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Autor Jerry Pregled postova
1P - da
2P - mozda
4P - mos' mislit!
To je upravo i poanta onog članka, Intel je uspio brute force pristupom (10 puta više cache-a, ogroman FSB, malo benchmarketinga...) postići prednost na desktop strojevima, ali kad se stroj pristojno optereti, AMD-ova superiorna arhitektura pobjeđuje (ok, možda bi bilo poštenije reći DEC-ova arhitektura )
Vidjet ćemo kako će ispast stvar sa Nehalem-om
Makar, kad se uzme u obzir clock, SPARC izgleda još uvijek rula
