Staro 18.07.2009., 17:06   #661
Facelessone
Facelessone's Avatar
Postovi: 4,204
Ja sam prošli mjesec dograbio 2900PRO i 4850 512mb pa sam napravio mali test ali samo u cod4 jer su grafe morale ići dalje... Nema rezultata sa klokanom 4670 i 4850 jer kad sam se sjetio da bi mogo ubacit i klokane rezultate je bilo već prekasno pa stigao odvrtit samo sa 2900pro.
Testni komp je bio:
CPU: AMD Phenom X3 720 Black Edition @ 3400MHz
MBO: Gigabyte MA770-DS3
RAM: 2x2GB Kingmax 800Mhz
GPU: Sapphire HD4670 GDDR4 512MB, Sapphire Radeon HD2900PRO 512/512 i Sapphire Radeon 4850 256/512
Mislim da su bili 9.5 driveri, Windows Vista x86 SP1.
Vrtio se demo od 4min sniman u multyplayeru sa 32 igrača.
Settings:
res 1280x1024 / 1680x1050 /1360x768
anti-alasing 2x
sync evry frm no
dual video no
shadows yes
spec map yes
dof yes
glow yes
no of dyn lights normal
soften smoke ed yes
ragdoll yes
bullet impacts yes
model det normal
water det normal
1360 min max avg
4670 49 124 68
2900 42 111 62
4850 71 194 106
2900oc 56 145 81
1280 min max avg
4670 40 103 58
2900 37 94 53
4850 62 173 91
2900oc 46 121 68
1680 min max avg
4670 32 86 47
2900 30 79 43
4850 52 148 77
2900oc 37 98 55
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 18.07.2009., 20:44   #662
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Očekivani rezultati. Nego gore si napisao pod testnim sistemom "770-ds3", a imaš "770-ud3", da nisi malo zeznuo?
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 18.07.2009., 20:52   #663
boris87
boris87's Avatar
Lokacija: Žepče
Postovi: 407
dai bi ocana 4670 prestigla ocanu 2900pro..??
boris87 je offline   Reply With Quote
Staro 18.07.2009., 20:53   #664
vedranzeman
Lokacija: Kloštar Podravski
Postovi: 1,019
Autor DraŽ Pregled postova
http://forum.pcekspert.com/showpost....&postcount=192
vedranzeman je online   Reply With Quote
Staro 18.07.2009., 21:03   #665
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Autor Omega Pregled postova
Sapphire HD4670 gDDR4 @ sobitza.com
mislim da nije bilo ove do sada po domacim testovima
Od početka sam mislio da će hd4670 popusit naveliko, i još vidim da se bori protiv blago overclockane xfx 9600gt, bio sam siguran u rezultat. No iznenadio sam se, hd4670 nju pobijedi u većini testova, makar su tu negdje unutar 5fps-a (isključivši hawx i last remanent).
Vrlo tiha u radu, i čudi me što se grije čak do 64C° u loadu??? Očekivao sam oko 50-55C, ali dobro.
Još jedan odličan review.
Autor boris87 Pregled postova
Bi sigurno. Probao sam malo HD4670 powercolor clockat, i išla je preko 800MHz(e neznam na koliko je stabilna bila), na 900MHz se sve freezalo.
TV: LG 7450
GAMEPAD: XBOX One
Staro 18.07.2009., 23:19   #666
Facelessone
Postovi: 4,204
Ova moja se neda baš clockat, oko 20mhz gpu i 50mhz memorija. Već je to sve nategnuto. Bolji score bi vjerojatno opet imala 2900 pro ockana, al računaj da je ovo kaj je bilo clockano išlo još malo gore.
Ali kad gledaš potrošnju energije i buku.... ufffff
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 18.07.2009., 23:56   #667
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
@Facelessone : možeš reći na kojim postavkama igraš Crysis, i od oka fps-a?
TV: LG 7450
GAMEPAD: XBOX One
Staro 19.07.2009., 00:11   #668
Facelessone
Postovi: 4,204
Ne igram Crysis
Jedino COD 4 tu i tamo kad imam vremena.
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 19.07.2009., 00:24   #669
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Ne igram Crysis
To sam i očekivao...
TV: LG 7450
GAMEPAD: XBOX One
Staro 19.07.2009., 13:40   #670
pingmachine
machine that goes ping!
Postovi: 478
Autor HollowAngel Pregled postova
imam dva dodatna ventilatora al neznam el cemi sta pomoc posto je kuciste otvoreno , a i ventilatori su smjesteni ( neznam kak bih opisao ) na straznjem djelu ( znaci pusu prema mjestu za floopy i hard ( a grafa je ispod njih ) el pomaze to sta
da su kućišta namijenjena tome da budu otvorena, onda bi iz tvornice izlazila otvorena, zamisli ti to.
zatvaraj prokleto kućište prije nego što ti nešto krepa od pregrijavanja.
pingmachine je offline   Reply With Quote
Staro 19.07.2009., 23:44   #671
Burko
Osobni opis - pitaj me
Burko's Avatar
Postovi: 2,317
napokon jedna od mojih tajnih zelja (ili HD4770): HIS AGP HD 4670
isti taktovi kao na pci x16 verziji, ali bolje hladenje od debele vecine vec dobro poznatih modela. uglavnom, trebala bi izgledati ovako:
cijena joj je vani 130 dolara, sto je i ok i nije. nije kad se usporedi sa pci x16 verzijom, ali takoder i jest jer je ipak rijec o danas najjacoj AGP kartici. no ajd, ako i nije jaca od HD3850, unutar su par posto po pefomansama. a kad je rijec o potrosnji, zagrijavanju, velicini i pocetnoj cijeni, HD4670 je apsolutni pobjednik.
mala razlika je potreba za strujom osim ploce, jer se spaja molex (kao na 9600XT seriji npr).
ovo sve kazu (nadam se ne lazu) na TechPowerUpu.
Staro 22.07.2009., 11:07   #672
Yoske
Yoske's Avatar
Lokacija: u kuci
Postovi: 38
AMD ATI Mobility Radeon HD 4670 1GB
nisam nasao informacija na netu. . zna li iko ista o njoj?
Yoske je offline   Reply With Quote
Staro 22.07.2009., 13:08   #673
Postovi: 7,568
Čip je slabiji od onog za desktop modele da kasnije ne bi bilo nismo znali, a 1GB memorije nije u stanju iskoristiti da je ne znam kakva. Jednostavno čisto pretjerivanje koje je garant popraćeno finom ukupnom cijenom laptopa koji udomljuje tu karticu. Ako ti ne treba za igre gledaj slabije kartice koje su tak i tak sposobne vrtiti multimediju ko i ta HD 4670, u suprotnome gledaj bolje kartice, tj. one koje bar imaju nekakav omjer "snage" i cijene.
Staro 22.07.2009., 16:51   #674
Yoske
Yoske's Avatar
Lokacija: u kuci
Postovi: 38
Autor McG Pregled postova
u sustini interesuje me da li je bolja od geforce 9600m gt. . da vidim dal sam se zaj****
Staro 22.07.2009., 18:54   #675
Nybelung
Autor Yoske Pregled postova
Trebala bi biti bolja..
9600M GT je dosta srezana u odnosu na svog desktop brata, dok bi ova trebala biti jača od desktop verzije HD4650 i samo malo slabija od HD4670.
Ako je lap 15" moći ćeš se pristojno igrati na default rezoluciji.
Staro 01.08.2009., 18:45   #676
Wuchko
Wuchko's Avatar
Postovi: 556
4670 i N68PV-GS
stavio sam temu, ali je admin pobrisao, ne znam gdje da uopće pitam jer ne znam gdje spada. znači, navedena grafa mi na navedenoj ploči radi x8 umjesto x16, koliko podržava i ploča i kartica... gdje je problem?
Wuchko je offline   Reply With Quote
Staro 01.08.2009., 18:46   #677
Postovi: 7,568
Pa tu ti je tema. Preseljena na odgovarajući podforum (jer s AMD-ovim nema nikakve veze kad imaš problem s pločom ili karticom).
Samo si trebal provjeriti vlastiti profil i zadnje postove da saznaš kud je tema prebačena.
Staro 02.08.2009., 19:43   #678
Omega
Omega's Avatar
Lokacija: Sibenik
Postovi: 1,226
evo i Sapphire HD4650 u drustvu slabijih HD4550, 9500GT i 9400GT. LINK
Casemodd logs : Dragon Storm, Kali, Entourage
Complete Case Painting Guide
Omega je offline   Reply With Quote
Staro 02.08.2009., 20:13   #679
Nybelung
Ovo ispravi u članku:
Sad je vrijeme da saznamo koja kartica u kategoriji ispod 500kn najbolje ispunjava zahtjeve low-budget gaming kartice.
HD4670 je odavno ispod 500kn.
Staro 02.08.2009., 20:17   #680
Omega
Omega's Avatar
Lokacija: Sibenik
Postovi: 1,226
hm... da, imas pravo.
kartice su testirane jos prije nekih 2-3 mjeseca kad je HD4650 bila taman oko 500kn
Staro 03.08.2009., 19:51   #681
>StarScream<
>StarScream<'s Avatar
Datum registracije: Aug 2009
Postovi: 5
Ja imam ati radeon hd 4650 1gb i meni je odlicna
>StarScream< je offline   Reply With Quote
Staro 03.08.2009., 19:56   #682
Nybelung
Autor >StarScream< Pregled postova
Dobra je kartica - al koliko si ju platio? 400kn? mogao si umjesto nove 4650 1GB tu na tržnici uzet skoro novu HD3870 ili 8800GS/GT.
Skoro novu
dobio ju s kompom...kupio sam komp u komadu nisam kupovo po djelovima...
A primjetio sam po komponentama da je jedna od gotovih konfiguracija.
Staro 03.08.2009., 19:58   #683
>StarScream<
Postovi: 5
Autor Nybelung Pregled postova
Skoro novu
Staro 03.08.2009., 20:00   #684
Apacer ft Bozja
Baja!
Apacer ft Bozja's Avatar
Lokacija: Sisak
Postovi: 761
Imas mozda cod4 (to me najvise i zanima ) da ga upalis i uzmes koji screenshot da vidimo koliko fpsa imas sa tom grafom
LP
Apacer ft Bozja je offline   Reply With Quote
Staro 03.08.2009., 20:51   #685
Apacer ft Bozja
Baja!
Lokacija: Sisak
Postovi: 761
Nezna covjek, ali sto je vaznije, trudi se
@starscream
Upisi /cg_drawfps 1 u konzolu (koji prije toga moras aktivirati u optionsu, ako vec nisi), te ce ti tada prikazivati koliko fpsa imas
@Nybelung
I meni je draza ta prva opcija
Staro 03.08.2009., 20:52   #686
>StarScream<
Postovi: 5
ne to mi se ne prikaztuje ni na slikama ni na videima
...evo upiso sam i vrti se između 90 i 120 fps
Staro 03.08.2009., 21:46   #687
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
COD4? Na kojoj rezi,800x600?
Staro 04.08.2009., 09:37   #688
>StarScream<
Postovi: 5
1280 x 1024
Staro 10.08.2009., 21:13   #689
bubbaloo
Postovi: 44
bok svima,evo hocu narucit gainward hd4670,dali je dovoljno napajanje od 350W?
napajanje je HEC.(Windmill 350 (Modell Name: HEC-350TP2WX)
iako na stranici gainwarda pise nda je potrebno minimalno 400w,al iz iskustva znam da ponekad pisu gloposti.
pa me zanima jel netko zna iz osobnog iskustva
e da procesor je amd 6000+
e da neznam jel bitno,i ovo pise na napajanju:
  • +3,3V / 20A
  • +5V / 12A
  • +12V V1 / 20A
  • +12V V2 / 20A
  • -12V / 0,3A
  • +5 VSB / 2,5A
Combined Power 130W / 276 W
zajedno: 350W (kako li ga dodjose na 350,to jos uvijek na shvatih)
bubbaloo je offline   Reply With Quote
Staro 11.08.2009., 02:13   #690
Nybelung
Bilo bi dovoljno i za jaču, ne troši HD4670 puno struje.
Nego, ako kod nas uzimaš Gainwardicu, koliko će te koštati? (mislim da idu za 650kn? to je malo puno, imaš Sapphire HD4670 (i Gigabyte) koja je odlična kartica, a <500kn košta!
Jedino što ta Gainwardica ima je Display Port konektor -> da li ti to vrijedi dodatnih 100+ kuna?
