Zaključane teme
Staro 04.07.2006., 02:30   #121
Facelessone
Facelessone's Avatar
Postovi: 4,205
kod ostalih da....kod mene ne , popil sam 3 pive i to je to. nije mi se fora napit.....
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Facelessone je offline
Staro 04.07.2006., 02:31   #122
Razer
Razer's Avatar
Postovi: 11,642
Autor Facelessone
Nemoj tako ...uvijek je fora ''malo'' se napiti i ''malo'' otkačiti
Razer je offline
Staro 04.07.2006., 02:39   #123
Facelessone
Postovi: 4,205
Autor R@Z3R
naravno....al ne tak da 5 puta bljuješ i tolko si pijan da nemožeš hodat.
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 04.07.2006., 02:40   #124
Razer
Razer's Avatar
Postovi: 11,642
Autor Facelessone
E pa sad...ne mislim baš sad na to...to nikome nije bas zanimljivo...
Razer je offline
Staro 04.07.2006., 02:47   #125
Robi555
Robi555's Avatar
Lokacija: Pitomača(VT)
Postovi: 621
Kaj se vi stvarno nemožete otkačiti i opustiti bez alkohola?
Robi555 je offline
Staro 04.07.2006., 02:49   #126
Razer
Razer's Avatar
Postovi: 11,642
Autor Robi555
Možemo, ali vjerojatno nam to ne bude dovoljno...pa malo zalijemo i bude jos bolje...ja nisam zastupnik da se treba napiti da bude zabavno ...ali ne kazem da se ne volim opiti koji put...
Razer je offline
Staro 04.07.2006., 02:51   #127
Facelessone
Postovi: 4,205
naravno da mogu, al ipak su se "slavila" 2 rođendana
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 06.07.2006., 09:54   #128
mITZEK jr
R.I.P Mitzek
mITZEK jr's Avatar
Lokacija: Prigorje zelene..
Postovi: 354
komentar za rani ulazak u spolni zivot.....
nije to rano ja sam poceo rano tj dva mjeseca prije 14 rodendana....
cura je bila mlada godinu dana!ja nisam am bas nista forsiro niti rekao al jednostavno se dogodilo....sad sam si s njom na pas mater(bilo je nesuglasica pri prekidu.)sad imam curu koja ce na faks(ako bog da....da upadne)
ona me blagoreceno "silovala" jbga nisam se žalio....i eto to vam je dokaz da alkohol nije sve vec prividno sredstvo barenja.....slike drugom prilikom jerbo se nevoli slikat(makar neznam zasto al da je ulov e pa je i to pravi)!: nuts :
there's no replacement for cubic displacement...except turbocharger
mITZEK jr je offline
Staro 06.07.2006., 10:44   #129
Bran
nemam kaj napisati
Bran's Avatar
Datum registracije: May 2003
Lokacija: Međimurje
Postovi: 1,303
Čovječe koliko ljudi tu na forumu imaju godina? Ja uskoro imam 21 i osjećam se starim.
I da kaj znate s 14 godina o seksu? Nisam ni ja, ali nisam ni tak brzo to se isprobao. Ne kažem da sam ja s 21 neki ekspert, ali ipak znam više neke stvari od većine klinaca koji su pred nekoliko mjeseci golu žensku vidjeli sam na kompu, pogledali neki porno film i sad misle da su neki ljubavnici.
Ali stvarno ako se trebate napiti da biste zbarili pijanu žensku onda je to malo žalosno.
Baš sam nedavno bio u situaciji da se jedna ženskica (znam je dosta dobro i dugo) napila i onda se vesila po meni kao ono idemo malo dalje od moje ekipe u "šetnju", ali nije to fora. Još bi mi zaspala pa nek se ja "mučim", a i nisam imao opremu kod sebe. Lijepo smo je odveli doma, pa nek dojde k sebi. Onda se moremo "šetati".
Inače postoji jedan disko klub nedaleko od mene gdje curice koje su tek počele izlaziti samo čekaju da ih netko zbari jer nedaj bože da koja dođe u 2 razred srednje, pa da bude nevina ili da je bila s manje od 5 dečki. Fora je da se doma obuku kao da idu u crkvu (pošto ih roditelji voze), a zatim u torbicama imaju neku oskudnu odjeću koju nabace na sebe, napiju se i čekaju tko će im prići i odvesti u auto na "vožnju". Najviše mi se gadi da dečki mojeg godišta, pa i stariji oduzimaju nevinost tim curama koje imaju u prosjeku kojih 15-tak godina. Bljak. Gdje je smajli koji povraća??
U ratu i seksu krv uvijek prolijevaju nevini.
Toliko od mene.
Bran je offline
Staro 06.07.2006., 10:56   #130
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,472
bran, sve 5. same here. doduše ja jesam mlađi. ali bio sam u svim situacijama koje si naveo. a i ova fora sa presvlačenjem mi je poznata...
i onda one budu sve hepi, jer imaju dečka od 20+ godina (da sam ja to muško ja bi se sramio), iako on nju previše ne šljivi...
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Renesis je offline
Staro 06.07.2006., 11:06   #131
Ladybug
Ladybug's Avatar
Lokacija: n/a
Postovi: 900
Bili smo vani. Bilo je ODLIČNO
Ladybug je offline
Staro 06.07.2006., 11:26   #132
Robi555
Robi555's Avatar
Postovi: 621
Ja sam od sutra SAM doma,moji idu na more :burn:
Robi555 je offline
Staro 06.07.2006., 19:28   #133
mITZEK jr
R.I.P Mitzek
mITZEK jr's Avatar
Postovi: 354
ja imam 17 god i ja si ne brijem da sam neki lover boy (to cure same kazu...)
pa sad racunaj da sam 4 god aktivan....
Staro 06.07.2006., 19:37   #134
Thoroughbred B
Thoroughbred B's Avatar
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,918
Autor Ladybug
Ajme ja sam trebao ic,ali sam se kasno sjetio
Thoroughbred B je offline
Staro 07.07.2006., 03:24   #135
Chuby
Chuby's Avatar
Datum registracije: Feb 2004
Postovi: 1,309
ufff sad se bas pokusavam sjetit kad sam zadnji put bio vani........ obicno se zapijem s ekipom u nekoj viksi
dolzi ljeto pa ce bit vise aktivnosti na otvorenom
Chuby je offline
Staro 07.07.2006., 23:46   #136
kony
bacc. ing. comp.
Postovi: 310
joj meni kad prode prijamni svaki dan bu se pilo ,malo po malo ,pa na godisnji u rumunjsku jojjj kak bum se provodil.....
ak se sad napim onda nemrem rijesavat matematiku jedno 3-4 dana poslije pijanke,ode motivacija i volja u PM
kony je offline
Staro 07.07.2006., 23:54   #137
kony
bacc. ing. comp.
Postovi: 310
Autor Bran
Toliko od mene.
hmmm... di je taj disko????(nemam 21 imam manje,ali se osjecam ko da imam 16 hahahah)
pa nemres ic trijezan barit pijanu zensku kak bus to to nejde...
moras se i ti napit onda je to to,jednostavno nejde....
a cure su cudne jedan dan bi se maznule onda sljedecih 3 tjedna nebi....
treba bit na pravom mjestu u pravo vrijeme
kony je offline
Staro 08.07.2006., 00:36   #138
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
ajd da i ja nesto kazem...
uglavnom imam skoro pa 17, idu mi na kitu one zenske (tj. deca još) koja idu van samo da se napiju i da ih netko zbari...
inače bio sam u vezi sa jednom curom skoro dvije godine, no to je prošlost, jbga, inače što se tiče sex-a, ja nisam neki expert(kao za PC ) ali nije da nisam probao..
nije problem naci takvu koja "hoće", al jednostavno to mi je glupo, radit to sa nekime prema kome nista ne osječaš, zato sada imam curu i to mi je dosta bitniji su mi osječaji jedno prema drugome, nego tamo neki sex iza nekog kafića ili sl.
ajd uživajte
Crash009 je offline
Staro 08.07.2006., 02:42   #139
Thoroughbred B
Lokacija: RI
Postovi: 4,918
dajte molim vas svaka cura oce kurca svakog trenutka o cemu pricate,garantiram da je curama vise stalo do kurca nego nama muskima do picke,i da ga jace zele,da ne kazem cesce!nema cure koja moze 2 dana izdrzat bez seksa,ako jednostavno mora izdrzat-onda nema druge
Staro 08.07.2006., 02:59   #140
Robi555
Robi555's Avatar
Postovi: 621
Autor Thoroughbred B
Agree,samo se one prave fine...Mi smo bar iskreni : lol2 :
Robi555 je offline
Staro 08.07.2006., 03:40   #141
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,317
Amen : roller :
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
joolka je offline
Staro 08.07.2006., 04:13   #142
TomG
TomG's Avatar
Lokacija: Munich
Postovi: 2,222
Ewo ja sam sada došao kući,bio sam u društvu sa 4 cure..i bilo je coooll..onako sprdali se ...i tako to...hehe
Kao ono spike idemo spavati hahahhahaha....Ja mal navratio do njih,sad se ushuljao u kuću da neznaju starci i sve 5...
TomG je offline
Staro 08.07.2006., 04:25   #143
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,472
evo i ja doso kuci, bili smo u kinu pogledat Fast and Furious 3. Onda malo u pivnicu, pa malo pogradu i tako.... nema baš puno ljudi...
sutra lijepo na ljetni karneval u N.Vinodolski :burn:
Renesis je offline
Staro 08.07.2006., 04:45   #144
trpi
j aimam 16 i još nisam umočio, barijo jesam
jel kasnim, jel sad pravo vrijeme?
neznam po meni ide nekak ovak...
ispod 15.... u rano to brate...
15....kaj si fakat j?! o stari daj pričaj kak je to
16....pravo vrijeme....
17... daj trebaš neš umočit.....trebo bi se zabrinut već
18....100 eur i pravac kurva
19...: bonker2
: lol2 :
Staro 08.07.2006., 06:12   #145
Ladybug
Ladybug's Avatar
Lokacija: n/a
Postovi: 900
Kako mije bilo, kako mi je bilo? bilo mi je ***************eno da barem nikada više ne moram bvozit u životu
Ladybug je offline
Staro 08.07.2006., 10:07   #146
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
Krenuo sam jucer od jutra piti zavrsio sam navecer u 22h.
Ujutro sam se razbudio i eto malo bio na netu a zatim u samobor do drage..nako njeg..i par piva..u konzum po vodku/vino/pive i kod frenda na roštiljadu/rođendan
Skurio sam roštilja..fakat puno..i fakat je bio hebeno dobar...dostojan bilocijeg nepca...i eto cugao cijelo vrijeme gemište i pive..kasnije vodke i cistog vina...i to je rezultiralo jutrosnjim mamurlukom..e kako mi je muka..užas
Hamm je offline
Staro 08.07.2006., 10:29   #147
TomG
TomG's Avatar
Lokacija: Munich
Postovi: 2,222
Autor Renesis
Jel dobar film???
znam da je stigao kod vas ,a neznam jel u OSijeku došao??
TomG je offline
Staro 08.07.2006., 11:45   #148
baterija
baterija's Avatar
Lokacija: ̣
Postovi: 1,019
Autor Tomy no.1
Jel dobar film???
Auti su dobri,barem kakve sam na slikama vidio!
Znaci ovo je drugi film koojeg moram "posuditi"...
baterija je offline
Staro 08.07.2006., 12:59   #149
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,472
auti su dobri, koke još bolje, al film je ko crtić
Renesis je offline
Staro 08.07.2006., 14:31   #150
Hrvoje xyz
lepi
Postovi: 923
: lol2 : : lol2 : : lol2 :
hahaha
reci ti njima !
nebih se bas slozio s tobom , al smjesno je za procitat u svakom slucaju
OT sto se F&F3 tice : svi kazu da bas nije nesto , ja sam odlucio iskoristit flat akaunt od frenda da pogledam ... dal se isplati ic gledat u kino :-D
inace auti su svi neki neevropski , to me zivcira , koda kdo nas nema auta sa straznjim pogonom , i to duplo jacih od onih iz japana ..
Hrvoje xyz je offline
Zaključane teme
