#121 |
Datum registracije: Aug 2020
Postovi: 899
Neki Intelovi evangelisti bi rekli da je to naša krivica jer nismo odmah otišli u BIOS i mijenjali voltaže, jer eto, to moramo raditi s proizvodima out of the box, tvorničke postavke su vrlo nesigurne. ![]() |
#122 |
Postovi: 8,568
To, a i mogli bi se nadovezati da veći dio krivnje ipak spada na AMD, jer do 2017. je sve bilo OK. Iz godine u godine lijepo 350$ quad-core_high-end_gaming_crown CPU i nitko se nije žalil. I onda odjednom Intel mora nešto kemijati po inače provjerenom receptu samo da dodaju za gaming nebitne jezgre i eto problema di ga ne treba. ![]() ![]()
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX |
#123 | ||||
Postovi: 8,568
Intel has a problem part 2: Post Mortem: Revived. But the Aftermath? EDIT:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 05.10.2024. u 17:27. |
#124 | ||
Postovi: 8,568
#125 |
Postovi: 711
"Mobile processors are not affected" - my ass. Imao sam dva 14900HX koja su pokazivala simptome degradacije, i koliko vidim nisam jedini: https://rog-forum.asus.com/t5/gaming...s/td-p/1099947 |
#126 |
Postovi: 8,568
Da, nažalost takvi high-end mobilni modeli koriste iste jezgre kao i desktop verzije, tak da više ništa nije čudno, a s vremenom bude toga sve više. Intel je ionak cijelu stvar skrival i u više navrata prebacival na proizvođače i krajnje korisnike, a obzirom na aktualnu situaciju kompletne firme, imaju i većih problema.
#127 | |
music freak
Lokacija: Sibenik
Postovi: 3,317
kakvi su simptomi,upravo nabavio lap sa i7 14700hx procom
#128 |
Postovi: 711
Najlakše reproducirati sa unzipanjem raznih arhiva, npr. extract Nvidia drivera redovno baci CRC error: https://us.download.nvidia.com/Windo...l-dch-whql.exe ili famozni 0x800706BE kod Windows Update, kao ovdje: https://learn.microsoft.com/en-us/an...ror-0x800706be ili random STATUS_ACCESS_VIOLATION u Chromeu. A i generalna rušenja/BSOD/nestabilnost općenito... |
#129 | |
Postovi: 2,654
Znači raspakiravanje arhiva, generalni bsod pri opterećenju (s čim opteretit? Occt?) Još nešto? Plan je istestirat, pa ako radi sranja updateat bios na mbo pa onda opet testirat.
#130 |
Postovi: 8,568
Općenito bilo kakvo opterećenje diljem jezgri je dosta da se skrši, bilo određena aplikacija, igra, OS, kaj god. Jedna od zadnjih komedija je out-of-memory greška za vrijeme otvorenih web-browser tabova, tak da tu više nema nikakvog pravila. Zahvaćeni procesori u pozadini polako propadaju, dok se korisnici muče s pokušajem objašnjenja koji vrag se događa, a BIOS update samo donekle odgađa neizbježno, jer Intel je opral ruke od svega.
#132 |
Postovi: 8,568
Možeš probati, čisto, ako dućan u kojem je kupljen izađe u susret, jer Intel uredno pravi budale od ljudi, pa odbacuju direktne reklamacije kak i kad im paše.
#133 |
Lokacija: Zagreb, Črnomerec
Postovi: 2,682
Ako je riječ o laptopu nije mi jasno kako Intel može išta reć, reklamira se cijeli laptop koji baca bsode gdje god stigne, nek to ovlašteni servis popravi i riješi sa proizvođačem, ASUS-om, Lenovom, HP-om, kime god. Što mene u tom slučaju briga što Intel priznaje ili ne. Ako je riječ o samom CPU onda razumijem da može biti izmotavanja, iako ne razumijem na temelju čego Intel odbija reklamacije, možda korisnik sam izaziva BSOD-eve, samo kako, nepravilnom instalacijom CPU-a ![]() |
#134 |
Postovi: 8,568
Zato sam spomenul, ako je dućan voljan izaći u susret, jer neovisno o mobilnom ili desktop izdanju, netko bude se moral jebati s Intel RMA procedurom u kojoj te nakon AI chat veselja, između ostalog tjeraju da se odvrti Processor Diagnostic Tool uz popratno slikanje procesora, tak da lakše mogu odmahnuti rukom kak to nije njihov problem, jer batch number ne odgovora izmišljenom razlogu odbijanja reklamacije. Ionak su sve probleme uredno skrivali dok su aktivno prodavali sfušane procesore, pa kad je voda došla do grla, brže-bolje okrivili proizvođače matičnih ploča i krajnje korisnike. Kak god se okrene, Intelovom pederluku i ciganluku (1 - 2) nema kraja i sva sreća da ih je država spasila od propasti, tak da i dalje možemo imati konkurenciju koja se međusobno tjera naprijed. ![]()
#135 |
Postovi: 2,654
Nakon dva dana testiranja nisam ni mrvu pametniji ![]() OCCT testiranja prolazi bez beda, iako se zagrije jebački. Pri tom kopiranje i ekstrakcija radi, samo radi vrlo sporo. I igrat ponešto sam uspio. Jedino što sam ulovio je chrome tab lock up. Pri više otvorenih tabova chrome se random smrzne, tabovi se smrznu, otvoreni tab ne možeš clickat i skrolat do cca 20-30 sekundi i onda se odlocka. Ponovio isto nakon što sam flashao bios matične na najnoviji. Pa probao isto nakon što sam namjestio bios opcije po preporukama s nekoliko foruma/reddita. Isti rezultat bez obzira na sve. Čini se da je CPU "dobio po glavi" i ima problema, ali vjerojatno nedovoljno da bi to bilo priznato kao reklamacija. Eventualno bi još mogao probat posudit neku drugu ploču pa probat još jednom. Na kraju, kao što kažeš, sve ovisi o tome hoće li se dućan koji je prodao proc htjeti bosti s Intelom oko toga. @Exy, malo proguglaj po forumima i redditu, kako intel jebe ljude oko tih procesora. Od toga da uopće ignorira problem i svaljuje ga na probleme s matičnim pločama, do toga da optužuje ljude da su kupili remarked procesor i da će ga, ukoliko ga pošalju na reklamaciju, zaplijenit i ne vratit ![]()
#136 |
Postovi: 8,568
Možeš još i reda-radi odvrtjeti Intel Processor Diagnostic Tool, ali izgleda da taj procesor polako, ali sigurno ide u vječna lovišta.
#138 |
Postovi: 2,654
Hm, trenutno je CPU u zapećku i čeka da nađem vremena još se pozabavit time. Nemam isksutva s "prženjem" te vrste ![]() Jel to ziher radi i hoće li to sjebati garanciju? Ne želim na servisu čut, "znate vi ste ga spržili prevelikim naponom".
