Postovi: 8,570
Problemi s Intelovim 13/14gen procesorima (oksidacija, degradacija, nestabilnost...)
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 26.04.2024. u 12:03. |
Postovi: 8,570
Ryzen 7 7800X3D vs. Core i9-14900K [Asus: Intel Baseline Profile] Gaming Benchmark
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX |
Postovi: 8,570
Ah, Arrow Lake se čini kao još jedna varijacija na temu s opet skroz novom platformom koja bude aktualna možda kakvih godinu i pol dana u najboljem slučaju. Da, gadno bude kad Steve odvrti dodatne testove s novim BIOS-ima koji još više ograničavaju CPU performanse kao odgovor na probleme s nestabilnošću.
¯\_(ツ)_/¯
Lokacija: Sibenik
Postovi: 1,156
Postovi: 8,570
Postovi: 8,570
Ryzen 7 7800X3D vs. Intel Core i9-14900K (Extreme/Performance Profiles) Updated Testing
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 19.06.2024. u 14:26. |
White Rabbit
Postovi: 5,409
Prvoklasni Krkan
Postovi: 5,414
Postovi: 8,570
Situacija je gadna, Intel i dalje konkretno šuti, dok se Raptor Lake high-end procesori krše, a svi zajedno su već odradili nekoliko krugova prebacivanje krivnje. ![]()
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 12.07.2024. u 10:53. |
Lokacija: Chakovec
Postovi: 475
AMD FTW! Nemam Raptor Lake, a bome ni u backup rigu nemam Intel. Ontopic: Na poslu na kompu na kojem sam trenutno mi je i5 14600k. Koristim ga za Autocad, Armcad i Allplan (BIM 3D software za projektiranje). Moram reći da komp super radi, ali taj proc nije high-end. |
Lokacija: zg westside
Postovi: 625
Imam Raptor Lake 13700f negdje već 9 mjeseci. Zalockan PL1/PL2 na 150W na Sonic B760M ploči, nemam problema - ni rušenja ni throttla. Nema problema niti na 180W. Nema problema niti defaultno uncapped, ali onda cpu termalno throttla. Hladi ga twin tower ID-Cooling u ne baš bajno provjetrenom Silverstone FT03 matx. Nisam skidao novi BIOS specifično da mi ne sprčka niš nakon što su ukrcali taj baseline profil. Kaj se mene tiče, kupil bi opet za tu lovu koju mi je cpu uletio ![]()
~Fury of the dwarves runs deep. |
Postovi: 8,570
Core i9-13900(XY) i 14900(XY) su najviše pogođeni, tu i tamo se nađe i pokoji 14700(XY), dok je sve ostalo OK, ali općenito su stvorili situaciju za ove high-end modele.
#16 | |
Postovi: 1,709
BTW, Cemu ove AMD FTW djecje pi#darije u Intel temi? Sent from my SM-S908B using Tapatalk |
#18 | ||
Postovi: 8,570
Core i5-14600K itekak valja, a kaj se ploče tiče, može biti bilo koja solidna, ne moraju se koristiti pretjerano skupe iz samog vrha ponude. Po pitanju aktualnih i sada već višemjesečnih problema koji se događaju s ovim Core i9 modelima, tu je ipak neki malo veći zajeb u pozadini priče, jer neovisno o potrošnji i radnom taktu, sporni procesori se nažalost krše čak i na pločama s W680 čipsetom, do te mjere da ne rade normalno kak god se okrene. EDIT:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 12.07.2024. u 19:04. |
#20 |
Postovi: 8,570
Core i9-13900 ili 14900 modeli se isto ko ovaj moj 7950X mogu iskoristiti za kojekakve čuda tehnike, sve ovisi kaj kome treba (izuzev striktno igranja), ali sad je ova problematika s nestabilnošću postala prevelika zajebancija za krajnje korisnike, jer više ne mogu ništa odraditi kak spada. I povrh toga, kolko imamo prilike vidjeti, Intel se cigani s reklamacijama, a i u trenucima kad ih čak i poštuju, pa daju zamjenske/nove procesore, ne treba dugo da i ti modeli ponovno odu nizbrdo.
#21 | |
Lokacija: Zg/Zd
Postovi: 728
#22 | ||
Postovi: 8,570
#23 |
Datum registracije: Aug 2020
Postovi: 900
Šta kaže najveći neutralac framechasers na te probleme? |
#24 |
Postovi: 8,570
#25 | |
Postovi: 900
#26 |
Postovi: 8,570
Čak su ga i oni razapeli, posebice u komentarima, jer lik uredno naplaćuje svoje specijalne postavke i opet sad gura "rješenje" za ove probleme, dok istovremeno spušta ljudima da ko im je kriv kaj su kupili CPU koji su kupili. Sve u svemu ~30min raznih kontradiktornih izjava od strane lokalnog stručLJaka. ![]()
#28 |
Dobro je sve.
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,528
Također Dize on/oni lovu na taj nacin sta si vise kontradiktorniji(ukratko klaun) to vise pogleda/$. Ko god ima zrno pameti zna i treba bi prepoznati gdje ne treba trosit dragocjeno vrijeme. Sent from my SM-S918B using Tapatalk |
#29 | |
Postovi: 8,570
#30 |
Prvoklasni Krkan
Postovi: 5,414
Nemoguće....sve za CB bench, CB bench za ništa ![]() |
