Povratak   PC Ekspert Forum > Računala > Periferija > Ostalo
Staro 27.08.2024., 21:22   #1501
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,054
V-MODA BoomPro mi je oduvijek bilo elegantnije rješenje. Doduše ako su sluške sa proprietary kabelom, a ne klasičan odvojivi 3.5mm, onda nemoš drugačije
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 27.08.2024., 22:59   #1502
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,856
Staro 25.03.2025., 11:33   #1503
D.O.M.I.
D.O.M.I.'s Avatar
Datum registracije: Jul 2009
Postovi: 279
Trebam preporuku za novi headset, prek 10 godina koristim Speedlink Medusu kaj je bio best buy za ispod 200 kn tad, al nažalost izgleda da je otišao 3.5 mm priključak jer se počeo gubiti zvuk kak god probam uštekat. Nisam zahtjevan korisnik, treba mi 90% za peglanje L4D2, dakle ok zvuk i mikrofon, nekaj u rangu gore navedenih i po mogućnosti do 30 €.
D.O.M.I. je offline   Reply With Quote
Staro 25.03.2025., 13:58   #1504
Postovi: 16,820
A gledaj, za 30EUR su 2 zvučnika na ušima, realno, nemaš baš izbor.
50EUR već imaš Logitech G432, imaš Steelseries Nova 1, imaš Logitech G435 wireless itd.
Ako ti je već 50-60EUR van budžeta, onda jedino što bi ja kupio ispod toga je HyperX Cloud Stinger Core 2. Nekih 36EUR.
Staro 25.03.2025., 14:10   #1505
ruki31
ruki31's Avatar
Datum registracije: Mar 2018
Postovi: 155
Mislim da imam jedne g432 doma koje mi skupljaju prašinu. Radile svega 3-4 puta i ne koristim ih - mislio sam da ću ih koristiti kad sam dobio dijete ali je ispalo da ne koristim od tada ni slušalice ni laptop ni ps5 haha
Moram vidjeti dal imam kutiju.
Ako će te zanimati javi se
ruki31 je offline   Reply With Quote
Staro 24.06.2025., 10:10   #1506
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,357
ima netko audeze maxwell? napišite koju riječ, po rivjuima najbolji ali opet na redditu ima svega (ljudi koji pišu po netu većinom pišu jer imaju problem pa i to uzimam u obzir)
Staro 24.06.2025., 21:27   #1507
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,357
ok sam sam išo testirat i uvjerio se da je logitech za smeće naspram ovog
ovo je valjda jedini audiofilski gaming headset, wireless, nisam audiofil ali počeo sam skidat 700gb flac kolekciju glazbe
Staro 14.09.2025., 10:01   #1508
tomycrosound
Datum registracije: Jan 2010
Lokacija: Vinkovci
Postovi: 307
G733
Pozdrav,
kupim kcerki Zone Vibe 100, ne znajuć da preko BT kvaliteta ulaznog zvuka pada kada se aktivira mikrofon. Prodajem.
Kupim Corsair HS65, wireless. Sin ima Void Pro wireless, pa očekujem da rade slično. HS65 ima sidetone na papiru, ali zapravo ga uopće nema. Najprije sam mislio da sidetone uopće ne radi dok nisam mic stavio u usta. Tada radi i to samo p,s,b,p i puhanje se jedva čuje. Reinstalacije i testiranja na drugom PC nije pomoglo. Mikrofon radi uredno.
Povrat i kupim Logitech G733.
Sidetone na njima radi, ali čujan samo ako je mikrofon savijen kraj usta i tada radi vrlo tiho, kad postoji glazbena podloga, od nje se zapravo uopće ne čujem.
Postoji li rješenje tog problema?
(Zvuk je bez EQ bolji od Void Pro, baterija odlična, lakše su..)
tomycrosound je offline   Reply With Quote
