Staro 05.09.2024., 16:21   #3151
snake29o3
snake29o3's Avatar
Lokacija: Croatia - Kutina
Postovi: 211
Autor Ivan357 Pregled postova
Bok, da li si uzeo samo MC889 ili kombinaciju sa ZTE T3000?
U kombinaciji piše da ide MC889, ako se uzima samostalno MC889A
Ima neke razlike?
Iza MC889(a) može se spojiti bilo koji vlastiti router?
Ima li neko drugo (bolje/jeftinije) rješenje za spojiti vlastiti router na 5G mrežu?
hvala
Uzeo sam samo MC889A... mislim da im je to A samo oznaka da ide bez WiFi routera....
Jeftinije riješenje ti je jedino ako nađeš neki WiFi router... ali to ti opet nije najbolje jer vidio si da moj stari router ne može prožvakati tu brzinu...
CPU: INTEL Xeon E5450 3.0 GHz 12 MB Cache
Cooler: Scythe Grand Kama Cross
Mainboard: Asrock P43DE3
RAM: 4 x 4 GB DDR3 1600MHz
GPU: XFX 8800 GT 512 MB DDR3 Alpha Dog XXX Edition
HDD: Kingston HyperX Fury 120 GB (OS) + ( 4 x Toshiba DT01ACA050 500 GB 32 MB (RAID 10) )
PSU: InterTech SL-500A
Case: Antec P180
OS: Proxmox VE
Cooler: Spire Kepler Rev.2
Mainboard: Gigabyte GA-965P-DS4
RAM: 4 x 2 GB DDR2 Kingmax 1066MHz
GPU: Palit GeForce 8400GS 512MB DDR2
HDD: Hitachi 160 GB (OS) + ( TOSHIBA 3 TB 64 MB DT01ACA300 + Toshiba 3 TB 64 MB HDWD130 (ZFS RAID1)
PSU: Xilence 420W
Case: Generic Midi Tower
OS: CentOS 7
Manufacturer: HP
Model: Z440
CPU: INTEL Xeon E5-1650 v4 3.6GHz ( 4GHz Turbo ) 15 MB Cache
RAM: 4 x 8 GB DDR4 ECC 2400MHz
GPU: nVIDIA Quadro P4000 8 GB
SSD: 2 x 240 GB RAID 1 + 256 GB
HDD: 2 x 3 TB RAID 1
Monitor: HP LA2405wg 24" 1920 x 1200
OS: openSUSE Tumbleweed MATE x64
BRAND: ASUS N705FD
CPU: Intel Core i7 8565U 1.8 GHz ( up to 4.6 GHz with TurboBoost)
RAM: 2 x 8 GB DDR4 2400 MHz
GPU: Intel® UHD Graphics 620 Integrated + nVidia GTX 1050 4GB DDR5
SSD: Crucial Micron 1100 256GB
HDD: Seagate ST1000LM035 1 TB 128 MB Cache
Screen: 17.3" 1920 x 1080
BRAND: HP Notebook 15-ba006nm
CPU: AMD Quad-Core A10-9600P (2.4 GHz, up to 3.3 GHz, 2 MB cache)
RAM: 4 GB DDR4 1866 MHz + 8 GB DDR4 1866 MHz
GPU: AMD Radeon R7 M440 Graphics 4 GB DDR3
HDD: 1 TB 5400 rpm
Screen: 15.6" 1920 x 1080 FullHD
OS: Windows 10 Pro x64
Poštene trgovine:
1, 2, 3, 4, 5, 6, 7
snake29o3 je online   Reply With Quote
Staro 05.09.2024., 17:08   #3152
johnsmith
Lokacija: vž
Postovi: 1,335
Niti jedna zte vanjska jedinica (mc7010, mc889, mc889a) koliko mi poznato (samo 7010 imam) nema wifi jer je vanjska jedinica. Stavis ju idealno na stup na balkonu ili krovu, na tom mjestu wifi nema smisla Meni osobno je i to ispravno. Ionako lan spojis na mrezu i unutra dalje slozis svoj wifi ili se uzme paket sa unutarnjim wifi ruterom s satshop.fi kome treba odmah sve...
Staro 05.09.2024., 21:25   #3153
Nikox
Nikox's Avatar
Datum registracije: Aug 2017
Postovi: 1,230
Autor Avan7garde Pregled postova
EDIT: 750769 je na dobroj lokaciji toranj, Valbandon u pitanju
brzina 600/170
Znači ne treba premještati ništa
Staro 05.09.2024., 21:32   #3154
Nikox
Nikox's Avatar
Postovi: 1,230
snake29o3
Imaš pad napona pa se router restarta lan kabel nije dobar. Ili poe napajanje stavi bliže routeru ako imaš gdje utičnicu ili kvalitetan lan kabel. Imaš ovdje gotovih cat7 kablova samo uzmeš dužinu koja ti odgovara.
Staro 05.09.2024., 23:10   #3155
snake29o3
snake29o3's Avatar
Postovi: 211
Autor Nikox Pregled postova
snake29o3
Preko vikenda cu spojiti onaj kabal od 10m pa probati, ali vjerujem da je to.
Sent from my OnePlus 12 using Tapatalk
Case: Antec P180
OS: Proxmox VE
PSU: Xilence 420W
OS: CentOS 7
Manufacturer: HP
Model: Z440
BRAND: ASUS N705FD
HDD: 1 TB 5400 rpm
Poštene trgovine:
1, 2, 3, 4, 5, 6, 7
Staro 05.09.2024., 23:11   #3156
snake29o3
snake29o3's Avatar
Postovi: 211
Svi navedeni su samo 5G vanjske jedinice bez WiFia....
Ja sam tako htio jer imam router i htio sam koristiti openWRT...
Case: Antec P180
OS: Proxmox VE
PSU: Xilence 420W
OS: CentOS 7
Manufacturer: HP
Model: Z440
BRAND: ASUS N705FD
HDD: 1 TB 5400 rpm
Poštene trgovine:
1, 2, 3, 4, 5, 6, 7
Staro 06.09.2024., 08:52   #3157
Avan7garde
Avan7garde's Avatar
Postovi: 281
ja imam 889 spojen u switch 2.5gbit i dalje kombinacija sa M4 deco 4 komada i radi super.
Avan7garde je offline   Reply With Quote
Staro 06.09.2024., 09:13   #3158
Nikox
Nikox's Avatar
Postovi: 1,230
Autor snake29o3 Pregled postova
Pa šta nisi odmah spojio orginalni kabel? Prekratak ti je ili ?
Staro 06.09.2024., 09:24   #3159
snake29o3
snake29o3's Avatar
Postovi: 211
Premala mi rupa sa balkona u kuću za original kabal :-D
A na balkonu je montirano za testiranje....
Tak da ću onda malo otvoriti prozor da provedem original kabal pa da onda vidim jel sve ok :-)
Stavit ću na tavan vodonepropusnu kutiju i unutra staviti ovaj 10m original kabal i Poe napajanje i onda si samo kabal do WiFi routera spustim.
Tako da onda to bude sve oriđiđi.
Jer opet ni sa tavana ne mogu spustiti original kabal jer mi je kanalica premala i već imam antenski i mrežni kabal provučen... a još jedan mrežni kabal taman stane ;-)
Case: Antec P180
OS: Proxmox VE
PSU: Xilence 420W
OS: CentOS 7
Manufacturer: HP
Model: Z440
BRAND: ASUS N705FD
HDD: 1 TB 5400 rpm
Poštene trgovine:
1, 2, 3, 4, 5, 6, 7
Staro 06.09.2024., 10:05   #3160
Ivan357
Datum registracije: Jun 2020
Postovi: 161
hvala na odgovorima
ni ne treba mi wifi na LTE/5G jedinici, kao što sam napisao, imam vlastiti router
druga, jeftinija opcija mi je uzet gigabox+ i Xiaomi 5G CPE Pro za 120€
kako to da ste se vi odlučili na ovu skuplju opciju sa vanjskim prijemnikom? slab signal sa unutarnjim?
kakva su iskustva sa tim xioamijem?
Ivan357 je offline   Reply With Quote
Staro 06.09.2024., 11:24   #3161
lowrider
lowrider's Avatar
Lokacija: KR
Postovi: 1,167
Imam tomato, koji kao i A1 koriste jedini 700 MHz i 3700 MHz.
Koji uopće to mobovi podržavaju?
Od t mobilea 5g ima svugdje gdje sam gledao.
Ne mijenja mi se Redmi note 12 pro 5g jer je odličan.
Daklem, preostaje mi samo bonbon.
Pošto na tomatu plaćam nešto što ne koristim
Lowrider
Staro 06.09.2024., 11:28   #3162
snake29o3
snake29o3's Avatar
Postovi: 211
hvala na odgovorima
Odlučio sam se za vanjsku jedinicu:
- imam Turističku SIM i ispadne me 24€ mjesečno pravi flat ( Gigabox - 29,95€ sa Magenta 1 ili 31,95€ bez) i ostale mobilne opcije imaju ograničenja na brzinu i promet pa moraš slat sms poruke i ostalo
- signal u kući mi je puno slabiji i uopće ne lovim 5G toranj, tako da sam imao u planu i Huawei B818 staviti na tavan radi boljeg signala, ali na kraju uzeo MC 889
Kaj se tiče Xiaomi pretraži tu malo.... imaš par postova gdje su ljudi napisali da je ok, ali da ima jako spor UI
Case: Antec P180
OS: Proxmox VE
PSU: Xilence 420W
OS: CentOS 7
Manufacturer: HP
Model: Z440
BRAND: ASUS N705FD
HDD: 1 TB 5400 rpm
Poštene trgovine:
1, 2, 3, 4, 5, 6, 7
Staro 06.09.2024., 14:19   #3163
Ivan357
Postovi: 161
udaljenost od tornja mi je nekih 500 metara, i unutra na mobitelu imam solidnih 500+ Mbps, evo našao sam neko staro mjerenje 750 Mbps
sad se još samo dvoumim oko uređaja, ako idem na xiaomi moram uzet gigabox+, ako idem na zte kombinirat ću sa turističkom
hvala još jednom
Staro 06.09.2024., 14:27   #3164
snake29o3
snake29o3's Avatar
Postovi: 211
hvala još jednom
Imaš u Iskonu samo uređaj za 229€, pa onda ne moraš uzimati Gigabox...
Ali po meni je onda bolje dodati još malo pa uzeti ZTE vanjsku jedinicu s kojom ćeš imati bolji signal, a i nema WiFi na sebi koji ti ne treba.
Case: Antec P180
OS: Proxmox VE
PSU: Xilence 420W
OS: CentOS 7
Manufacturer: HP
Model: Z440
BRAND: ASUS N705FD
HDD: 1 TB 5400 rpm
Poštene trgovine:
1, 2, 3, 4, 5, 6, 7
Staro 06.09.2024., 16:12   #3165
Nikox
Nikox's Avatar
Postovi: 1,230
hvala još jednom
Tebi ZTE MC801a idealan i bolji izbor nego vanjska jedinica bilo 7010 ili MC889. Pošto ti je toranj vrlo blizu imat ćeš veće brzine na 801a nego na ZTE vanjskoj jedinici jer si na HT. gigabox+ i Xiaomi 5G CPE Pro za 120€ da samo što si vezan dvije godine a u dvije godine svašta se može promijeniti. Bilo je dosta turbulencije na 4G pa zato oprez sa UO.
Staro 06.09.2024., 16:14   #3166
Nikox
Nikox's Avatar
Postovi: 1,230
Svi 5G mobiteli podržavaju n28(700Mhz) i n78(3480-3800Mhz). I svi operateri ne samo A1 koriste te frekvencije n28(700Mhz) i n78(3480-3800Mhz)
Zadnje izmijenjeno od: Nikox. 06.09.2024. u 16:30.
Staro 06.09.2024., 18:44   #3167
lowrider
lowrider's Avatar
Lokacija: KR
Postovi: 1,167
U tom mobu mi je kartica tomato, uvijek piše H+ i 40tak mb/s download, druga kartica bonbon, piše 5g i 500tinjak mb/s.
Zato pitam, nije mi jasno
Lowrider
Staro 06.09.2024., 20:37   #3168
Nikox
Nikox's Avatar
Postovi: 1,230
Koristiš dual sim? Tomato -pozivi ,a Bonbon-internet?
Staro 07.09.2024., 09:52   #3169
sharkri
sharkri's Avatar
Postovi: 704
Mali OT, koja je Max duljina kabela za vanjske jedinice bez da utječe na performanse i stabilnost same vanjske jedinice, dali bi 20 metara bilo previše?
Sig-5 redova normalne veličine max
Staro 07.09.2024., 09:54   #3170
johnsmith
Lokacija: vž
Postovi: 1,335
Ne bi trebalo biti problem. Ja imam onaj produzivac za rj45 i ukupno ziher 15m kabla izmedju vanjske i poe adaptera.
Staro 07.09.2024., 12:39   #3171
lowrider
lowrider's Avatar
Lokacija: KR
Postovi: 1,167
Samo sam jedno vrijeme koristio bonbon samo za net, tomato pozive. I kad sam to prebacivao onda je bonbon bio 5g stalno, a kad vratim podatke na tomato, h+ je stalno
Lowrider
Staro 07.09.2024., 13:15   #3172
acmevagabundo
Datum registracije: Jul 2015
Postovi: 318
Probaj APN tomato (ako je nešto drugo) za tomato sim
acmevagabundo je offline   Reply With Quote
Staro 07.09.2024., 13:24   #3173
the chosen one
the chosen one's Avatar
Postovi: 755
Jel si probao možda solo karticu staviti u mob, u SIM1 utor? Ili zamijeniti pozicije kartica?
Jer meni na Samsungu ne može biti 5G na obje kartice nego samo na onoj koja je aktivna za net. A možda i fizički SIM utor ima ulogu kao što sam gore napisao...
PS. 5G na 700MHz ti ima dosta male brzine, više služi za veću pokrivenost terena, dok na 3700MHz su gigabitne brzine (naravno, u idealnim uvjetima)
Staro 07.09.2024., 13:49   #3174
lowrider
lowrider's Avatar
Lokacija: KR
Postovi: 1,167
Budem vidio APN, thanx.
Stavio sam tomato u sim1, bonbon sim 2 utor.
Očito sim 1 nije primaran, oba su istog "prioriteta" izgleda
Nije ni meni na oba uključen net, samo na jednom. Dakle isključim net na 092 i uključim na 098, piše 5g.
Isključim net na 098, uključim na 092, i h+ piše
Lowrider
Staro 07.09.2024., 20:33   #3175
sharkri
sharkri's Avatar
Postovi: 704
Koliko bi smetala temperatura vanjskoj jedinici ako je stavim na odušak, ne brine me bura ni vjetar već temperatura, jer sunce zađe iza dimnjaka oko 15:00
https://ibb.co/wwdDkXT
Staro 07.09.2024., 21:05   #3176
lowrider
lowrider's Avatar
Lokacija: KR
Postovi: 1,167
Autor acmevagabundo Pregled postova
Pod APN piše A1
Lowrider
Staro 07.09.2024., 21:18   #3177
Nikox
Nikox's Avatar
Postovi: 1,230
Da kad prebacuješ treba duže da ulovi 4G ili 5G jer tomato ima 5G tj svi operateri u HR imaju 5G.
Staro 07.09.2024., 21:48   #3178
acmevagabundo
Postovi: 318
Pod APN piše A1
Promjeni APN u tomato (kod mene je tomato i 5G mi je)
Staro 07.09.2024., 23:20   #3179
kasko
kasko's Avatar
Lokacija: Ivanić_Grad
Postovi: 2,012
Koji je best buy preporuka za 4g modem, neovisno dal ima los ili dobar wifi pošto imam backup AP koji bi lan kablom spojio ako je modemu los wifi.
Thanks ekipa i znalci.
kasko je online   Reply With Quote
Staro 08.09.2024., 08:18   #3180
rak21
COD2 expert
rak21's Avatar
Postovi: 1,919
Autor kasko Pregled postova
Rekao bih da je best buy ZTE mf297d, ako kupujes polovno. Nit jedan 4g ruter po meni nije best buy. Taj zte novi je oko 160 eur, dok 5g ruter novi kupis za 230.
