#91 | ||||
Postovi: 8,478
Scumbag Intel: Shady Practices, Terrible Responses, & Failure to Act
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 05.08.2024. u 13:09. |
#92 |
Postovi: 8,478
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX |
#93 |
Prvoklasni Krkan
Postovi: 5,349
Kad razmislim koliko su debelo bili ispred AMD-a....nevjerojatno na što su spali. I onda AMD krene laganim koracima naprijed sa zenom, a Intel uporno pokazuje svoje rekordne zarade, sada ostali lagano i bez toga. AMD uzima to mrvu po mrvu. Mislim da Intel nikada nije bio u ovako lošoj poziciji. Nadam se da se tu neće desiti jedna NOKIA, neprikosnoveni kralj mobitela koji je prvo ubijao Symbianom, a onda ih konkurencija samljela u papar. Nažalost, ako se tako nešto desi, AMD nema konkurenciju, a onda tek slijedi pravi problem. ![]() |
#94 |
Datum registracije: Feb 2021
Lokacija: Sveti Petar
Postovi: 305
Al ga dramite nepotrebno. U najgorem slučaju Intel prestane koristiti vlastite fabove za najnovije proizvode i prijeđe na TSMC. Naravno to bi popratila velika otpuštanja i pad cijene dionica i to je to. Krajnji korisnici bi u tom slučaju najviše izgubili jer bi tada i Intel i AMD morali dosta dići cijene jer bi se oboje borili za iste proizvodne kapacitete. |
#95 | |||
Postovi: 8,478
Intel već naveliko koristi TSMC i to godinama, dok su nVidia i AMD u prednosti po pitanju TSMC kapaciteta, cijena dionice je isto tak već godinama u padu zajedno s popriličnim otpuštanjima koja su sad već u trećoj godini zaredom, dok CEO sere kvake na financijskim izvješćima, tak da nije to nikakvo dramljenje, već čista realnost - sjebali su se na sve moguće načine i nemaju nikoga za okriviti osim sebe samih i bajnog vodstva koje si ne može priznati da su zajebali i da je konkurencija u vidu AMD-a, ARM-a, nVidije, Samsunga, TSMC-a, SK Hynixa, Microna, itd. već jedno dulje vrijeme u debeloj prednosti. Citiraj:
IMHO država neće dopustiti da Intel završi poput Nokie ili Nortela, ali sad su u goroj situaciji, nego AMD prije 15 godina, jer Intel je imal apsolutno sve prednosti uz nedostatak ikakve konkurencije.Citiraj:
#96 | ||
Postovi: 8,478
#98 |
Postovi: 1,698
Ma nema straja ![]() AMD7000 serija po pugetu i dalje ima veći failure rate nego Intel 13 i 14th gen, pa nikom ništa Bar tako kaze ovi: https://youtu.be/sxsvPdQ2aKk I ovi: "High-end computer maker Puget Systems released statistics, according to which Intel 13th and 14th generation processors have a failure rate of just over 2%, while AMD Ryzen 5000 and 7000 systems have a failure rate of over 4%" https://hi-tech.ua/en/amd-processors...%20over%204%25. Sent from my SM-S908B using Tapatalk Zadnje izmijenjeno od: jucca. 09.08.2024. u 12:53. |
#99 |
Prvoklasni Krkan
Postovi: 5,349
Hmmm, ali AMD nije u svim vjestima trenutno. I AMDovi CPU trenutno nemaju nikakvu grešku u proizvodnji koja će sam CPU degradirati s vremenom i nije pitanje hoće li, nego kada će. I AMD vj riješava svoje reklamacije jer bi ih netko već razapeo zbog toga. Eto, par sitnih razlika. ![]() U ovom trenu samo netko potpuno neupućen može uzet nešto od 13 i 14 Intela. Navodno istu grešku ima i slj koji izlazi (AL?)....NAVODNO...mislim da je MLID ili TechJesus to rekao jednom, ne sjećam se. Zadnje izmijenjeno od: Disco. 09.08.2024. u 13:27. |
#100 |
Postovi: 8,478
Puget Systems puno toga stavlja u eter otkad su Intelove financije u ponoru, a vlasnik Puget Systemsa sjedi u Intelovom odboru savjetnika i općenito su od samog početka Intel partner firma, dok im je FAIL procedura za Intel i AMD CPU, takva da se CPU mijenja za bilo kakav problem. Ne radi USB na ploči - CPU FAIL, ne boota se OS - CPU FAIL, jao, pa u realnom vremenu su zajedno s Tom's Hardware par sati nakon GN Intel dokumentarca, odmah imali članak za postotak AMD vs. Intel CPU problema, samo da se koliko-toliko skrene pažnja s Intelovih pizdarija, jer je ovima u Pugetu u direktnom interesu kad prema svojim riječima prodaju više Intel mašina. ![]() Jebote, ovo za Intel i Puget Systems makar je sve na ovoj stranici teme, kao u Don't Look Up filmu, ajmo se praviti da nije istina, pa nas neće udariti meteor.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 09.08.2024. u 13:13. |
#103 | |
Datum registracije: Mar 2011
Postovi: 57
![]() Updejtom biosa bi mogo i sebi (a i poslije nekom drugom) skratiti muke s potencijalnim mačkom u vreći. |
#105 | |
ODUZIMAM VAM RIJEČ
Postovi: 13,482
, zašto?zato jer smo zadrti plavci, ko HDZ glasači majkemi, samo intel, e pa nek krepa pa ćemo otić na 7800x3d il šta već tada bude
#106 |
Lokacija: Sv.Nedelja
Postovi: 5,826
Kolko sam citao nabrzinu najvise je i9 procesora pogodjeno 13/14 gen. Vozim 13500 on bi trebao bit alder lake, nadam se i dalje veselom radu, kolko sam vidio za moju plocu, noviji bios je vani, a ne sjecam se kad sam napravio vec updejt biosa. E intel intel, pored problema koje imas, jos ga zadesilo i problemi s naponima na serijama 13/14. |
#108 | |
Postovi: 8,478
Testing the intel 0x129 Microcode on the Gigabyte Z790 Aorus Master X with an i9 14900K
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 11.08.2024. u 14:10. |
#109 | ||
Postovi: 8,478
#110 |
mag.math.
Datum registracije: Dec 2021
Lokacija: Daruvar/Zagreb, Republika Hrvatska
Postovi: 366
Ovo nije porazno već je tragedija da se ovako nešto dogodilo takvom tehnološkom gigantu ali očito da su godine podmićivanja i krajnje neozbiljnog vođenja korporacije i ignoriranja konkurencije dovele do ovoga da na kraju takav gigant ne može odraditi najobičniji RMA. Planirao sam "nadogradnju" na 13700k ili 14600k no kako stvari stoje još će me 13400 neko vrijeme služiti. |
#111 | |
Lokacija: TRPI
Postovi: 456
![]() Sve ide kroz cikluse, probudit ce se i Intel samo nažalost sa gubitcima i dosta otkaza. |
#112 |
mag.math.
Postovi: 366
u državnim firmama nitko ne dobiva otkaze i novaca se ima koliko treba tako da bih prije rekao da se radi o privatnoj firmi čiji mladi vlasnik pijan od novaca ne zna voditi firmu koju su mu ostavili djed i otac na dobrim nogama a on ne vidi probleme dok mu govna nisu došla do grla. a kad mu su mu govna došla do grla onda brzo prodavaj pamet, dijelove firme i davaj otkaze, bez jasnog plana za bolje sutra. |
#113 |
Postovi: 8,478
Da, grdo bude kad država i službeno najavi da moraju spašavati Intel, po uzoru na auto-industriju, a sudeći po svim dosadašnjim poticijama i subvencijama, nisu daleko od toga. Koliko god je nadobudni direktor Pat "pun ideja za spas firme", poput ukidanja besplatnog voća diljem kampusa , oni prije njega su započeli ovu lavinu za koju se on pravi da će ih zaobići.
#114 |
mag.math.
Postovi: 366
Sjedinjene Američke Države imaju sustav da ne dozvoljavaju monopol jedne kompanije tako da Intel siguno neće propasi ali bi mogli životariti i svesti se na veličinu AMD-a kad rasprodaju srebrninu i raskomadaju korporaciju. Prvo će prodati fabove isto kako je i AMD prodao svoje a onda će vidjeti što i kako dalje. Sumnjam da će prije 2030. godine Intel napraviti išta relevantno. Pogledajte samo kako u server i enterprise segmentu poslovanja nižu fail za failom a to poslovanje nosi više kolača od desktop gaming segmenta i grafičkih arc kartica. |
#115 |
Postovi: 8,478
Nema sumnje da bude ih država i dalje držala za ruku, tak da ne odu u totalni bankrot, a fabrike bi već odavno rasprodali da nisu dobili sve one silne milijarde državnog nofca, pa sad moraju koliko god je još moguće, pričati o domaćoj proizvodnji, dok kod TSMC-a upućuju narudžbe. Kaj se AMD-a tiče, zajeb za Intel je da je ta šrot firma u međuvremenu postala veća i uspješnija, nego je ikad bila, a uz to oni više nisu jedina Intelova konkurencija. Tak da Intel sad ima puno više problema i konkurencije, nego u vrijeme kad su plaćali OEM ekipu da ne nude AMD proizvode.
#116 |
#erase startup-config
Postovi: 3,732
Već treća generacija serverski Intel procesora ne radi na VMWareu zbog sporih/brzih jezgri pa svejedno još uvijek čini se dominiraju tim tržištem. Intel je puno više od procesora za gejmere. Ali da, tužno. |
#117 |
Postovi: 8,478
Da, u puno toga su oni uključeni, a isto tak je puno toga bez pitanja s godinama automatizmom obnavljano po pitanju ugovora, dokle god nije udarilo u zid, počel je padati tršižni udio, a nekad rekordne zarade su postale nikad veći gubici uz sveopću rasprodaju divizija i infrastrukture. Trenutno pripremaju odvojene Xeon linije koje imaju samo P ili samo E jezgre. VMware se nakon Broadcom preuzimanja također dovel u podjednako nezavidnu situaciju, pa sad nekad vjerni VMware korisnici prelaze na Proxmox i sl. rješenja, dok Veeam priprema i svoju tranziciju.
#118 |
Postovi: 3,732
Problemi s Intelovim 13/14gen procesorima (oksidacija, degradacija, nestabilnost...)
Iz svojeg korporativnog iskustva mogu reći da nam je do3.14zdilo čupati kosu nad pomalo lihvarskim licenciranjima s kriptičnim featureima/paketima. Platim jači hardware i sve klapa na Proxmoxu ili Qemu za manje novaca. A onda ti pošalju BSA da ti pregledaju debelo crijevo. Ali ne može svatko tako. AMDu kronično fali podrška za developere i neke tehnologije koje Intel ima. Bar u serveraju. Sirove CPU performanse tu nisu dovoljne. |
#119 |
Postovi: 8,478
Je, bude i to postepeno sjelo na mjesto. Kod nas, a i kod klijenata je isto s godinama išla promjena sa Xeon na EPYC (posebice Rome, pa Milan), a nakon VMware pizdarija, lagano ide Proxmox ili XCP-ng. Nažalost, Intel je sve svoje nakadašnje utvrde uspjel dovesti u stanje opsade i sad na ovaj ili onaj način moraju obraniti i spasiti ono kaj se može.
#120 | ||
Postovi: 8,478
