|  27.12.2022., 19:59 | #10083 |
| Premium Datum registracije: Apr 2017 Lokacija: Zadar
					Postovi: 343
				 | AMD Ryzen 7000 Non-X 65W CPUs Launching On 10th of January, Ryzen 9 7900 Up To 35% Faster In Gaming Vs 5900X Link: https://wccftech.com/amd-ryzen-7000-...ming-vs-5900x/ |
|  05.01.2023., 02:23 | #10084 |
| McG Datum registracije: Feb 2014 Lokacija: Varaždin
					Postovi: 8,375
				 | AMD Ryzen 7000X3D series coming February, 16-core Ryzen 9 7950X3D features 144MB cache  Citiraj:
				__________________ AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 |
|  05.01.2023., 04:38 | #10085 |
| Modder Datum registracije: Mar 2004 Lokacija: Waterford
					Postovi: 918
				 | Gledamooooo....   |
|  05.01.2023., 06:58 | #10086 |
| Prvoklasni Krkan Datum registracije: Jan 2006 Lokacija: Rijeka
					Postovi: 5,319
				 | OK, čitam malo što se piše. Ako sam dobro shvatio non X serija je doslovno ista ta X serija samo je po defaultu uključen onaj EKO (65W) mod, i piše da je AMD rekao da se preko PBO-a mogu dobiti veće performanse tj natjerat CPU-e da se ponašaju kao X serija(AMD claims that with PBO (precision boost overdrive), you can raise the power limits for the these chips, and improve their performance by as much as 35%. This is similar to Intel's 65 W "locked" processors getting a free performance uplift by relaxing power limits in the motherboard BIOS level.). Dakle snizili su cijene pod izlikom non X CPU-a što je super....osim za ekipu koja je već istresla novčiće. Vrhunski potez i još jedan dokaz da se nikako ali baš nikako ne isplati biti early adopter. A X3D serija je izgleda koncipirana kao i 5800X3D, tj 7800X3D ima zauzdan clock, ide ''samo' do 5ghz, dok 7900X3D i 7950X3D idu do 5,5 i 5,7 ili koliko već točno...nebitno, ALI nemaju izgleda cache za oba CCD-a, nego samo za 1 i taj je vjerojatno manjeg clocka, i 1 koji može dobro boostat ali nema dodatni cache. Vjerujem da će 7800X3D biti odličan i raditi kako treba, a sa ova druga dva ekipi želim svu sreću jer će ovisiti o win scheduleru da prebacuje npr igre na 3D CCD, a sve ostalo na boostajući CCD. A znamo da Ms slaže te schedulere bogovski.    I da nema 7950 non X i nema 7600X3D. EDIT: Zadnje izmijenjeno od: Disco. 05.01.2023. u 10:30. |
|  05.01.2023., 10:38 | #10087 |
| Premium Datum registracije: Sep 2006 Lokacija: Zagreb, Črnomerec
					Postovi: 2,580
				 | Da, ovaj 12core i 16core sa tim pola pola cacheom u biti nema nikakvog smisla ali i AMD je skužio da treba ponuditi bespotrebno skupe stvari jer hvala Bogu kupaca ima   Vjerojatno će i bit brži od 7800X3D tamo gdje ih scheduler ne potrga  . U biti ima smisla, velika je šansa da će i on sam bit brži od 13900K pa nema baš smisla sa novčane strane da ga pobijede samo sa procom za pola cijene, moraju i oni nešto staviti u kasicu prasicu. A ovi non X modeli, nisam baš siguran da će se moć klokati kao X jer će nam AMD vjerojatno uvaljivati najgore binane primjerke kao non X modele. No nije bitno previše jer par sto mhz ništa ne znači. Sad je samo pitanje dal nekom nešto znače one intelove baby jezgrice |
|  05.01.2023., 11:03 | #10088 |
| ¯\_(ツ)_/¯ Datum registracije: Feb 2008 Lokacija: Sibenik
					Postovi: 1,156
				 | Mislim da ste mao preoptimisticni, AMD-ov slide sa best case scenarijima (a to je 1080p i to high) pokazuje oko 20% napredak i jednu iznimku od 30%. Prosjek svih igara je vjerojatno niti 10%... Kad stavimo neku normalnu rezoluciju + ultra, prednost nad 5800x3d ce biti vrlo mala, sta opet znaci da ce biti tu negdje s Intelom.... |
|  05.01.2023., 11:11 | #10090 | |
					Postovi: 2,580
				 | Citiraj:
 To vrijedi za manje više sve proceve novije od 2-3 godine  Kad staviš normalnu rezu i ultra detalje, tak je svejedno koji proc imaš. Osim ako baš nisi na 4090 i igraš na high refresh na niskim rezama.... Zato i testiraju na 1080p sa 4090 što je komedija i priča za sebe, ali da, jasno je da žele postić da je CPU bottleneck. Ali ako zen4 4d bude bolji od zen4 koliko je 5800X3D bolji od 5800X, AMD će opet imat top cpu. | |
|  05.01.2023., 11:21 | #10091 | |
					Postovi: 8,375
				 | Ukoliko budu 3D cache modeli u prosjeku 15% bolji od standardnih, to je to, taman da se nadmudruju s Intelom u kojekakvim rezultatima.  Citiraj:
				__________________ AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 | |
|  05.01.2023., 11:38 | #10092 |
| All-rounder Datum registracije: Sep 2013 Lokacija: Zagreb
					Postovi: 1,338
				 | Nekako mi nema razloga da uplift ne bude jednako velik kao u prethodnoj generaciji. Čak i veći jer su frekvencije veće, a i veća bazna snaga procesora znači da će dodatnih 64mb cachea potencijalno biti bolje iskorišteno. Nagađam, naravno. Naravno, samo na 4090, ostale grafičke su maxane već i sada. No, vidjeli smo i da minimumi znaju biti bolji 5800x3D. |
|  05.01.2023., 11:43 | #10093 | |
					Postovi: 8,375
				 | Tijekom predstavljanja Lisa Su je naglasila kako je Zen 4 3D cache u prosjeku 15% bolji od običnih Zen 4 modela i da se to može očekivati, dok prezentacija tak jasno (uvijek) prikazuje najbolje slučajeve. IMHO od svega pokazanog i najavljenog, ovo je najzanimljiviji dio priče, gdje sve ove chiplet LEGO kockice fino sjedaju na svoje mjesto.  Citiraj:
|  05.01.2023., 12:15 | #10095 |
					Postovi: 1,338
				 | 145€ trenutno. Ovo će biti i više... Iako su zasrali Radeon, generalno su bili fer s procjenama koliko novi procesori donose. Da je Nvidia ili Intel, bilo bi odmah "up to 30%" ili bi cherry pickali još gore. |
|  05.01.2023., 12:28 | #10096 |
| Premium Datum registracije: Oct 2009 Lokacija: karlovac
					Postovi: 2,074
				 | A 7700x je 3000kn,7700x3d bude 4000-4500kn.Za to kupim 7900x. Ne znam, moje je mišljenje da je i jedan 7700x uvrh glave za bilo koji gaming stroj. Bio bi i 7600x,ali je trenutno razlika oko 800kn, pa se isplati dat više za dvije dodatne jezgre. Koliko god dobiš fpsa više sa x3d, rađe uzmeš bolju grafičku. Recimo xtx umjesto xt!
				__________________ Phil of the future! |
|  05.01.2023., 12:55 | #10097 | |
					Postovi: 5,319
				 | Citiraj:
|  05.01.2023., 13:11 | #10098 | |
					Postovi: 1,156
				 | Citiraj:
|  05.01.2023., 13:13 | #10099 | |
					Postovi: 1,156
				 | Citiraj:
|  05.01.2023., 13:18 | #10100 |
					Postovi: 2,074
				 | He, he! Dobro ja sam na 2k,a ako me zasvrbi i 4k. Ma koristio bi ja c1 kao primarni monitor, Al preferiram tipkovnicu i miš, pa mi raspored u sobi baš ne paše za tu kombinaciju. Inaće, nemam kaj dalje tražiti od c1.
|  05.01.2023., 13:18 | #10101 | |
					Postovi: 8,375
				 | Citiraj:
|  05.01.2023., 13:30 | #10103 |
					Postovi: 1,338
				 | Ili izbaciti B650 normalne cijene, ove sve osim onog gigabytea dsh3 su high end ploče. A koliko vidim, ovakvim pristupom se ništa neće na dual chiplet procevima s 3D cacheom izgubiti na produktivnosti. Samo da riješe scheduling. |
|  05.01.2023., 13:37 | #10104 |
					Postovi: 8,375
				 | IMHO DDR5 cijena je već sad OK, tj. lagano to ide sve niže, a uz non-X modele su rekli da stižu u kompletu s jeftinijim B650 pločama. Valjda bude nekaj od toga, sad kad su se svi MBO proizvođači namirili sa suludim B650(E) cijenama.
|  05.01.2023., 14:03 | #10105 | |
| Premium Datum registracije: Dec 2008 Lokacija: Zagreb
					Postovi: 375
				 | Citiraj:
|  05.01.2023., 14:14 | #10106 | |
					Postovi: 1,156
				 | Citiraj:
 Ok jos za 1080p, slazem se, al ono su esports naslovi i to ne na ultra. Cekamo review-e... | |
|  05.01.2023., 14:17 | #10107 | |
| Premium Datum registracije: Mar 2006 Lokacija: Sv.Nedelja
					Postovi: 5,824
				 | Citiraj:
 Jel to možda ono, dok je adm dućan, prodavao amd (mislim da je bio 5600x) proc, matičnu i ddr memoriju u kompletu? Ak je, to bi bilo dobro.. O kojim točno jeftinijm pločama? Ili trenutnim b560 sam sa nižom cijenom? | |
|  05.01.2023., 14:28 | #10108 |
					Postovi: 8,375
				 | Doslovno su rekli da uz ove non-X modele stižu i jeftinije B650 ploče (uz ovo kaj je već na tržištu), tako da baš bude budžet orijentirano.  E sad, da li bude to baš neki komplet CPU + MBO kak dućani znaju imati akcije ili budu samo stigli novi procesori i jeftinije ploče - ostaje za vidjeti.  Mislim, kak god se okrene, cijene se budu korigirale na ovaj ili onaj način sad kad je cijela Zen 4 ponuda otkrivena.
|  05.01.2023., 14:31 | #10109 | |
					Postovi: 1,156
				 | Citiraj:
|  05.01.2023., 14:33 | #10110 |
| Premium Datum registracije: Aug 2004 Lokacija: Zabok
					Postovi: 3,407
