Staro 23.09.2019., 10:28   #481
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,038
meni se i elmatis pokazo dobrim za neke stvari pa pogle i njih
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 23.09.2019., 10:31   #482
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,130
Fala svima.
geronimo_2 je online   Reply With Quote
Staro 24.09.2019., 18:06   #483
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,545
Conrad.hr isto ima zanimljivih stvarcica.
Staro 30.09.2019., 13:55   #484
geronimo_2
geronimo_2's Avatar
Postovi: 4,130
samo da javim da je PSU popravljen. promjenili hrpu kondića, ali nije se nis promjenilo, cak se i produzilo potrebno vrijeme da ga se moze kresnut. nakon toga naletio stari na jedan sumnjivi otpornik. promjenjen i PSU radi ko novi :-).
na stampanoj plocici napojnog modula:
NTC otpornik 2,5ohm, 6.5v - banana
elektrolitski kond: 1000, 47, 4,7, 22, 3300 mikrofarada - vjerovatno bili ispravni
edit: mozda bi ovo trebalo negdje premjestit, neznam kako, sta...
Staro 08.11.2019., 20:03   #485
Postovi: 8,171
Staro 17.11.2019., 13:41   #486
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,260
Rjeseno,
Hvala kolegi forumasu "e1ectra_one" koji je nesebicno posudio cjeli komp koji ima plocu koja prihvaca E5 Xeone .
Hvala jos jednom dok se ne oduzim.
Staro 05.01.2020., 10:19   #487
Roso
Roso's Avatar
Postovi: 698
Ekipa,
Imam jedno uredsko računalo sa ovom matičnom (1151):
https://www.gigabyte.com/Motherboard...2-rev-10/sp#sp
i neki škart celeron na njoj.
Ima video izlaz u obliku VGA, ali mi je nejasno da li je to onboard grafika, ili ako bi stavio neki i5 procesor, koristio bi grafiku sa procesora? Zna li netko, da vidim koliko mi se isplati ulagat u to.
Celeron je očajan, a integrirana grafička ajme majko. igpu na i5-icama mi se pokazao do sada kao skroz ok solucija na uredskim konfiguracijama.
Roso je offline   Reply With Quote
Staro 05.01.2020., 10:42   #488
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Koristi GPU s procesora, ako stavis i5 onda ces koristiti GPU koji se nalazi na procesoru. Chipset i maticna nemaju nikakav GPU na sebi.
Staro 05.01.2020., 11:35   #489
Iliti ukratko, ako se ne varam, nema integrirane grafike u Intel pločama nakon socketa 775
1366 nije imao on-board GPU. Za s1156 se ne sjećam, ali sve dalje (1155, 1150, 1151...) nisu imale.
Staro 05.01.2020., 13:21   #490
Postovi: 23,505
@Roso
Zavisi šta ti je jednostavnije / jeftinije za nabaviti,
"neki" i5 sa support liste > https://www.gigabyte.com/Motherboard...rt#support-cpu
ili
neka add-on PCI-E x16 grafa (izvedba ovisno o kućištu).
Primjera radi i5-6600 ima HD Graphics 530, ali je ista i u Pentium G4500 CPU.
Ako možda imaš Celeron G3900, kod njega je HD Graphics 510.
Hoću reći, nebi bio značajan skok ako gledaš samo GPU karakteristike, za ostalo bi.
Staro 05.01.2020., 13:34   #491
Roso
Roso's Avatar
Postovi: 698
Ljudi, hvala vam na odgovorima!
Nisam imao mira pa sam išao provjerit šta se događa na tom računalu.
Nisu bili instalirani driveri za gpu, pa sam zato mislio da je nešto integrirano na matičnoj. Sad je povuklo Intel HD 610 i surfanje i youtube rade ipak bolje (1080p 60fps youtube ide glatko, to je valjda najzahtjevnije šta će to računalo radit). CPU je G3930 i nisam zadovoljan pa ću ubost nešto bolje čim nikne na tržnici.
Staro 05.01.2020., 13:51   #492
Postovi: 23,505
Eh, bez drajvera ... case slosed, neeext
Staro 15.03.2020., 12:26   #493
Smarty
Smarty's Avatar
Datum registracije: May 2005
Postovi: 1,283
Kako 100% ugasit pc kada se upre Shut Down (znači ne ištekat ga iz struje)
Pitam jer imam 2 problema, ploča je Gigabyte GA-B85M-DS3H.
Imam USB zvučnike i kada ugasim komp oni ostaju upaljeni i ledica od zvučnika po noči obasjava cilu sobu što mi ide na živce.
a drugo pitanje je dali je moguče da monitor zrači? jer kad recimo scrollam, tipkam ili kada se nešto događa na monitoru zvučnici krče (i kada gledam film).
Zvučnici su ispravni i testirani na kompu na poslu i tamo rade savrženo, ne krče i gase se kada se gasi komp.
Thnx.
Smarty je offline   Reply With Quote
Staro 15.03.2020., 17:42   #494
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
Ne "zrači" ti monitor nego ti je loše uzemljenje, bilo na zvucnicima, maticnoj, kucistu, napajanju, produznom (ako ga koristis), uticnici...
Staro 15.03.2020., 17:56   #495
Mladenxy
Mladenxy's Avatar
Postovi: 4,321
Upali ERP u biosu, pa će ti se isključiti USB portovi/zvučnici nakon gašenja kompa.
Staro 15.03.2020., 18:32   #496
Smarty
Smarty's Avatar
Postovi: 1,283
Izvrsno, hvala najljepša. Več 5 dana razbiam glavu sa tim.
Zvučnici su se ugasili, a u stanu nemam uzemljenje nego je nulovano. Osposobit ću onda strai UPS.
Staro 03.11.2020., 15:30   #497
ne0mage
ne0mage's Avatar
Datum registracije: Nov 2020
Postovi: 3
LGA 2011-3 Procesor za probu dvi x99
Pozdrav ekipa.
Znači, prije 2 mjeseca mi je PC samo prestao reagirati... kada ga upalim, nakon 4-5 sekundi se ugasi bez prikaza BIOSa. Bio sam kod servisera i svi su mi rekli da je 90% matična, te da ne mogu izvršit točnu provjeru na takvom socketu . Naručio sam novu preko Ebaya, sve spojio i dogodi mi se isti problem, šta me dovelo do zaključka da je najvjerovatnije do procesora ( i7 5960x ).
Pa ako ima netko voljan u okolici Splita za provjerit, bio bih zahvalan.
ne0mage je offline   Reply With Quote
Staro 23.11.2020., 01:24   #498
ne0mage
ne0mage's Avatar
Postovi: 3
Novi procesor stiže ovaj tjedan . Možete zatvoriti temu. Hvala
Staro 04.12.2020., 22:07   #499
Zagorhac
Lokacija: Zagorje
Postovi: 421
Xeon?
Imam dilemu da li zamijeniti moj i5-4670k sa E3-1230 V3 (mislim da Z87 chipset podržava xeone - konkretno, ploča je Biostar Z87X 3D Hi-Fi)? Pripremam se za Cyberpunk 2077, a ne želim kupovati cijeli komp. Koriste li suvremene igre hyperthreading te ima li smisla nadogradnja?
P.S. nemam baš najbolje hlađenje te ne namjeravam tjerati postojeći procesor do 4,5 GHz.
Zagorhac je offline   Reply With Quote
Staro 05.12.2020., 09:35   #500
2XO
Lokacija: Osijek-Zagreb
Postovi: 325
Nije ti to baš nekakav upgrade, isto samo 4c 8t procesor sa praktički istim clockom. Više ćeš osjetiti u gamingu poboljšanje ako overclockaš taj CPU kojeg već imaš.
2XO je offline   Reply With Quote
Staro 05.12.2020., 10:49   #501
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Nema smisla.
Staro 05.12.2020., 12:32   #502
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,578
Pa HT mu može značit razliku između stuttera i bez istog (BF V MP npr.)
No najbolje pričekat igru da izađe
Staro 07.12.2020., 18:14   #503
Chuxonja
Pajcek
Chuxonja's Avatar
Postovi: 1,038
Ovisi o cijeni i kolko jako ganjaš trenutni i5. Potencijalnog benefita vjerojatno ima ak nijie i ne misliš klokat ak upgrade ne košta neke bijesne pare ko i7ice za isti socket.
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
ODD: LG GH24NS70
OS: Windows 10 Pro
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
ODD: LG CH10LS20
HDD1: WD Green 1TB
LINK
ODD: LG GH22LP20
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
PSU: Enlight 400W
OS: Windows XP SP3
LINK
HDD: WD 160GB
OS: Windows XP SP3
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 26.01.2021., 21:15   #504
Ninz
Datum registracije: May 2019
Postovi: 96
i5-4590 + geforce gtx1060
Ekipa kaj mislite jel i5-4590 dovoljan da nafila geforce gtx1060 sa 6GB rama. Sad imam Phenom II x6 1055T pa moram neki upgrade napraviti
Ninz je offline   Reply With Quote
Staro 26.01.2021., 21:34   #505
buljaka
Datum registracije: Aug 2014
Postovi: 2,927
Autor Ninz Pregled postova
Mislim da nije baš dovoljan da ju nafila do kraja ali bit će ok ugrade
Edit
Baš sam išao baciti u kalkulator
Za 1080 kaže ovo
Your processor is too weak for this graphic card on 1080p resolution
Intel Core i5-4590 (Clock speed at 100%) with NVIDIA GeForce GTX 1060 (Clock speed at 100%) x1 will produce 15.39% of CPU bottleneck on 1080p resolution. Everything over 10% is considered as bottleneck.
We recommend you to replace Intel Core i5-4590 with Intel Core i3-9100F
Za 1440kaze
Average bottleneck percentage: 8.88
Graphic card and processor will work great together on 1440p resolution.
A 2160
Average bottleneck percentage: 5.09% (CPU bottleneck)
https://pc-builds.com/calculator/Cor...0A20Velu/8/100
Sent from my Mi 9 Lite using Tapatalk
buljaka je online   Reply With Quote
Staro 26.01.2021., 21:39   #506
picajzla0707
Datum registracije: Sep 2018
Postovi: 309
Autor buljaka Pregled postova
Baš sam išao baciti u kalkulator...
picajzla0707 je offline   Reply With Quote
Staro 26.01.2021., 21:43   #507
Ninz
Postovi: 96
oh tnx
Za Core i3-9100F vec moram i ram kupovati uz ploču, mislio sam bar ddr3 iskoristiti od ovog setupa :X
Staro 27.01.2021., 00:28   #508
picajzla0707
Postovi: 309
oh tnx
Daj pusti te gluposti poput 'bn kalkulatora', bitno je koje igre igraš i na kojem monitoru. Ako igraš gpu zahtjevne sp igre eventualni bn nema nikakve veze jer će ti prije bn biti grafa nego cpu.
Ja igram sa gtx 1070 na 4590 i najčešće je bn grafa, ponekad bude i cpu bn, ali to je vrlo rijetko i često nebitno jer ionako igram na 60hz monitoru.
Druga je stvar ako igraš mp pucačine i ganjaš visoki fps, onda će bn biti češće problem. Meni sa 1070 ne bi bilo puno razlike niti s puno jačim procom od 4590, osim u rijetkim igrama i to tek povremeno, primjerice kad mi u ac origins fps padne sa 60 na 45 fps u gradu, ali to su rijetke i meni nebitne situacije jer pad fps nije drastičan da bi smetao
Druga je stvar isplativosti ulaganja u 4core
Staro 27.01.2021., 07:52   #509
tiki66
tiki
tiki66's Avatar
Postovi: 2,726
oh tnx
Stvarno nema smisla ići na stari socket zbog rama koji novi košta 200tinjak kn (keks od 8gb).
Ako hoćeš upgrade kako treba, neki Ryzen (npr. 1600 AF) ili i3/i5 nove generacije
Staro 27.01.2021., 09:30   #510
Ninz
Postovi: 96
Autor picajzla0707 Pregled postova
Da, ima smisla ovo što kazes, a ovo isplati li se ulagati u gen4 cpu..ono nađe se na njusci za 700-800kn mbo i cpu, nek izdrzi 2 godine za tu lovu super i opet ce otici bar za 300kn. Uglavnom bitno mi da može nafilati ovu graficku, a izgleda da može, dok ovaj phenom nemre ništa jebalomater.
