Staro 13.11.2019., 15:22   #151
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,058
Ovisi, moš probat direkt clone pa pustit apdejt uštekan da si potegne sve što treba, eventualno ručno još neke drivere poinstaliravat ak se sami ne postave. U prošlosti sam imo uspjeha sa svakakvim kombinacijama pa i podvaljivanje diskova iz Intel u AMD konfe i većinu vremena nije bilo problema jer su se Windowsi sami popeglali. Nema garancije fkors i ja bi isto preporučio clean instalaciju kad već platformu mijenjaš.
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 14.11.2019., 10:01   #152
kiki86
Tehničar
Datum registracije: Dec 2011
Postovi: 1,085
windows 10 dobro radi te prijelaze sa platforme na platformu, win7 je već malo problematičniji. Možeš probat drivere od nove matične i sata/raid kontrolera instalirat prije zamjene pa su možda veće sanse da prođe...
Staro 31.01.2020., 15:15   #153
purger22
purger22's Avatar
Postovi: 181
Imam jednu Toshibu C650 na kojoj je hard disk pri kraju te bi ga trebao zamijeniti drugim.
Trenutni hard je 320gb, cca 250gb je popunjeno, stavio bi 500gb i klonirao čitav disk da nemoram instalirat opet windowse i kopirat sve podatke.
Koji je najlakši način za kloniranje pošto nemogu fizički uštekat novi disk jer imam samo jedan sata utor na koji je spojen trenutni disk.
purger22 je offline   Reply With Quote
Staro 31.01.2020., 15:23   #154
Chuxonja
Pajcek
Chuxonja's Avatar
Postovi: 1,058
USB ladice rade. Eventualno oba diska u neki PC spojit i preko njega clone napravit
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
ODD: LG GH24NS70
OS: Windows 10 Pro
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
ODD: LG CH10LS20
HDD1: WD Green 1TB
LINK
ODD: LG GH22LP20
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
PSU: Enlight 400W
OS: Windows XP SP3
LINK
HDD: WD 160GB
OS: Windows XP SP3
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 31.01.2020., 16:16   #155
Postovi: 33,994
Većina USB dockova za 2 diska može napraviti offline kloniranje (direkt s jednog diska na drugi, bez posredovanja PC-a) s jednog diska na drugi.
Staro 31.01.2020., 23:18   #156
RainZG
Postovi: 706
Instalacija/Restore/Kloniranje OS-a na HDD/SSD - how-to, info, problemi, savjeti
Autor coconut Pregled postova
Ne. Nova ploča (vjerojatno) ima drugačiji čipset, drugačiji audio, LAN,... Eventualno, ali s velikim upitnikom, bi moglo proraditi ako bi sa sadašnjeg kompa sve drivere deinstalirao i onda klonirao 'čiste' windowse na novi komp.
Moglo bi cak i raditi bez problema. Win10 su me puno puta ugodno iznenadili.
Ja sam mijenjao mbo kod sebe, sve se pokrenulo bez problema, stavio nakom bootanja nove drivere za mbo i to je bilo to.
Daleko je sve to otislo u odnosu na win 3.11
PS vjerovatno ce se morati napraviti reaktivacija windowsa doduse. Mene jednom cak trazilo da zovem njihov support
RainZG je online   Reply With Quote
Staro 31.05.2020., 11:10   #157
DSA
Lokacija: Sarajevo
Postovi: 290
Pitanje ljudi,
Imam SSD 256 GB u laptopu i na njemu na dvije različite particije Win 8.1 na jednoj i Win 10 na drugoj. Znači bootam po potrebi jedan ili drugi. Moze li Macrium ovo klonirati jedan na jedan identicno sa ovog na veci SSD? Trebam li nesto posebno podesavati ili obratiti paznju kod ovakvog kloniranja?
DSA je offline   Reply With Quote
Staro 27.06.2020., 19:36   #158
zig
zig's Avatar
Datum registracije: Jan 2010
Postovi: 389
Ne znam dal sam u pravoj temi, nadam se da jesam.
Našao sam se u problemu, vezanom uz frišku instalaciju windowsa.
U biosu sam namjestio da mi boota s cd-a, uredno mi prikaže da pritisnem bilo koju tipku za boot s cd-a i nakon toga ništa, jednistavno ne prihvaća komandu za ulazak u instalaciju windowsa.
Na drugom računalu sve uredno, što znači da nije problem u bootabilnom cd-u.
Nekakav savjet ?
zig je offline   Reply With Quote
Staro 27.06.2020., 20:17   #159
Postovi: 23,537
Ima tu dosta bisera / šta bi moglo biti, a nisi dao dovoljno informacija.
Uefi, secure boot, šta se hoće boot - at, ...
Staro 27.06.2020., 20:24   #160
zig
zig's Avatar
Postovi: 389
Autor Nikky Pregled postova
Radi se o starijoj ploči s biosom, a druge načine nisam isprobao.
Dvdrom uredno prepoznaje u biosu, sve uredno prođe, ali prilikom poruke "press any button to boot from cd" se ne događa ništa i uredno nastavi do trenutno instaliranog windowsa.
Cd je uredno bootabilan, jer sve uredno ide na drugom računalu.
Ne znam koje informacije još treba dat, recite pa ću vidjet ?
Staro 28.06.2020., 02:09   #161
domy_os
domy_os's Avatar
Postovi: 18,869
Starija ploča je relativan pojam. Ovako na prvu bih rekao da BIOS ne podržava USB tipkovnicu do ulaska u OS. Probaj u BIOS-u uključiti USB legacy support.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 28.06.2020., 03:07   #162
zig
zig's Avatar
Postovi: 389
Autor domy_os Pregled postova
Probat ću vidit šta je s tim, ali mi nije jasno kako onda prihvača navigaciju kroz sam bios.
Staro 28.06.2020., 03:40   #163
silver_tip
silver_tip's Avatar
Lokacija: doma
Postovi: 2,895
Autor zig Pregled postova
Al zbilja... kao da raspravljamo s ovim ne slici ti avatara skroz ljevo.
Nisi dao dovoljno informacija !
Koja ploca ? Koliko usb portova si probao uopce ? Jesi probao sa ps/2 tipkovnicom ili nisi ?
trebaš seedbox?
Staro 28.06.2020., 11:50   #164
zig
zig's Avatar
Postovi: 389
Sorry, jbg kad ne znam ni sam šta da napišem.
Ugl, riješio sam problem, USB keyboard mi je bio na disabled.
Nisam na to niti pomišljao, obzirom da mi je tipkovnica u BIOSu radila normalno.
Znaći, jedini period gdje nije radila, to je između biosa i os-a.
Ugl., Hhvala vam na pomoći i još jednom isprike na šturim informacijama s moje strane.
Staro 28.06.2020., 21:56   #165
silver_tip
silver_tip's Avatar
Lokacija: doma
Postovi: 2,895
To sto je u biosu namjesteno USB keyboard disabled ne znaci da ista ne radi normalno u biosu jer kako bi uopce dosao do opcije
da to promjenis ? Istina, ima ploca koje i tu zezaju i sve je stvar same podrske chipseta i usb kontrolera no sa opcijom usb disabled
a da si dizao windowse sa usb sticka/hdd-a ili da si sa Acronisom nesto radio oko diskova, u oba slucaja to boota samo u instalaciju
ili program i tek onda primjetis da ti ne radi tipkovnica ili mis u takvom okruzenju ako USB keyboard nije na Enabled.
trebaš seedbox?
Staro 29.06.2020., 11:18   #166
zig
zig's Avatar
Postovi: 389
Tipkovnica je radila uredno i u windowsima i u biosu, pa me to bunilo.
Hvala svejedno još jednom, bitno da je sve rješeno.
Staro 29.06.2020., 12:55   #167
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,118
Bok ekipa Ima li tko jednostavno i provjereno rjesenje za isklonirati Windows 10 sa mehanickog diska na SSD, a da se ne poremete boot loaderi i ta sranja?
Klonirao sam sa bootabilnim Acronisom i tak jasno da se sprcilo nesto, pa se Windowsi vise ne dizu. Doduse, ispocetka je radilo, no nakon dva-tri reboota vise ne.
Naravno, klonirani sistem sa SSD-a se prijavio kao F: i slicni uzasi. Nisam vec skoro 10 godina na Windowsima pa sam malo zahrdjao sto se tice toga
Konfa je neka Intel maticna, C2Q Q9400, u BIOS-u je ukljucen IDE mod diska i iskljucen je Boot UEFI os support.
Fala
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
Staro 29.06.2020., 13:16   #168
AdmiralST
Kapetan od beloladja
AdmiralST's Avatar
Postovi: 217
Fala
MACRIUM REFLECT bi ti to triba odradit
Certifikat je samo potvrda da si možda u stanju razumjeti razgovor između dva stručnjaka
Kad nepravda postane zakon, otpor postaje dužnost.
AdmiralST je offline   Reply With Quote
Staro 29.06.2020., 13:33   #169
prileee
laser
prileee's Avatar
Postovi: 2,347
+1 za macrium reflect. Evo moj kvot od prije par miseci iz pripadajuce teme za te alate.
Autor prileee Pregled postova
Sinoc uspjesno klonirao 1tb iz zeninog starog laptopa na a400 od 480gb (bilo je <480gb ukupno na starom hddu pa je uspjesno sve pribacia) sa macrium reflectom. Preporuke za alat, super jednostavan za koristenje.
Staro 29.06.2020., 13:39   #170
kiki86
Tehničar
Postovi: 1,085
ja sam preklonirao 20ak kompova hdd - ssd sa acronisom tako da neznam koji točno problem imaš s tim...treba bootat na acronis stick/cd a ne iz windowsa pokrenut kloniranje, iako sam i tako uspio 1 komp rjesit, i to ssd na nvme. Nakon kloniranja ugasis komp i izvuces disk kojeg si klonirao i ostavis ssd samo
Staro 29.06.2020., 14:21   #171
nino
nino's Avatar
Postovi: 12,613
Fala
Cupavi, Miray HDClone 9 je alat za tebe i takve kao ti.
Staro 10.10.2022., 13:36   #172
jean luc
jean luc's Avatar
Postovi: 589
Bok, molim pomoć. W10, ploča je Asrock A320M-HDV, upiknuo sam 256 GB NVME (Patriot), u system/storage sam podigao disk kao "prostor za pohranu". No winsi ga sad prepoznaju kao USB memoriju recimo - dobio sam ikonicu flash diska u taskbaru, koji kaže "PCI device", i mogu ga izbacit?
Macrium reflect mi ne da kloniranje sa HDD-a (1 TB), nešto sa nekompatibilnim sektorima, iako sam particionirao njegov dio na particiju koja može stati na ovaj NVME.
U Biosu se vidi NVME da je ukopčan, no u BOOT manageru mi ga ne daje trenutno kao opciju
Ima li tko savjet za kloniranjem ovak iz Windowsa? Tnx unaprijed.
jean luc je offline   Reply With Quote
Staro 10.10.2022., 17:21   #173
medo
#erase startup-config
medo's Avatar
Postovi: 3,714
Da. Nemoj klonirati iz Windowsa
Staro 11.10.2022., 10:50   #174
jean luc
jean luc's Avatar
Postovi: 589
Autor medo Pregled postova
Ha,ha, ok, tnx
Staro 14.11.2022., 21:03   #175
quazar912
quazar912's Avatar
Lokacija: north-northwest
Postovi: 1,979
evo ja sam upravio napravio clone W10 sa NVME na SSD pomoću ovog tuotrijala.
oba diska su istog kapaciteta mada mogu biti i različiti, jer je i ta opcija pojašnjena u videu
https://www.youtube.com/watch?v=CHCENfs87F4
sve je išlo ko podmazano, na kraju par puta restartao da provjerim dali boota kako treba.
dakle mogu reći da šljaka.
i na kraju imam pitanje: ostao mi taj NVME sa starim W 10 gore - kako ga formatirati a da ne moram vraćati na u PC jer je ispod grafe pa mi se to neda opet raskapati , ali ako baš mora - mora se.
mislio sam im ali kakav NVME to USB kabl da to tako formatiram
...and fly...
Thule nosač
Staro 15.11.2022., 06:34   #176
Postovi: 33,994
Ili nabaviš externo NVMe->USB kućište ili samo kabel. Alija i baja su puni takvih za 15-20$.
Staro 15.11.2022., 07:32   #177
SPLiFF
SPLiFF's Avatar
Postovi: 2,106
ubaciš ga u neki laptop i odradiš to
Staro 15.11.2022., 08:56   #178
quazar912
quazar912's Avatar
Postovi: 1,979
Autor SPLiFF Pregled postova
ma to mi treba samo jednom da obrišem stari OS sa njega. budem ga onda ponovo ubacio u MB i formatirao
ići će ovdje na tržnicu sa još nekim stvarima
...and fly...
Thule nosač
Staro 15.11.2022., 11:08   #179
Postovi: 33,994
Kolio M.2 utora imaš na mbo? Ako imaš 2, stavi ga u drugi u formatiraj.
Staro 15.11.2022., 11:17   #180
quazar912
quazar912's Avatar
Postovi: 1,979
ne. samo 1 .
...and fly...
Thule nosač
