Staro 01.01.2018., 12:33   #91
Night
Lokacija: Dbk
Postovi: 1,320
Ako imaš USB3 na laptopu svakako uzmi USB3 to SATA jer ćeš imati prijenos reda 100MB/s dok ćeš sa USB2 imati oko 20MB/s.
Ovaj mi se pokazao kao OK : Maiwo
Staro 02.01.2018., 17:40   #92
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,081
Da, to dela čist pristojno. Čak sam viđo iste takve koji sastrane imaju dodatni power konektor da mogu 3.5" upogonit. Doduše, kaj točno moš upiknut u to za dodatnu struju is anybodys guess.
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 06.01.2018., 16:17   #93
Night
Lokacija: Dbk
Postovi: 1,320
Imam i Logilinkov (Link)koji dođe sa adapterom pa ga možeš koristiti za 2.5" bez dodatnog napajanja ili za 3.5" sa dodatnim napajanjem. Adapter je 12V 2A, prilično čest adapter, većina STBova i routera ga koristi.
Staro 25.06.2019., 13:10   #94
hash
Postovi: 1,431
Dock za diskove svih velicina i tipova
Pozdrav.
Trebao bi mi dock za razne diskove. Imam doma nekoliko starih PATA i SATA diskova pa bi htio neki jednostavan nacin za pristupiti im preko laptopa.
Brzina mi nije vazna ali ako moze brze zasto ne.
Bitno mi je da mogu u njega ucitati sto vise raznih diskova:
* stari PATA - obavazno
* sata 3.5 - obavezno
* sata 2.5 - obavezno
* m.2 - pozeljno
* javite ako sam preskocio neki cesti format
Ima ih hrpu na aliexpressu ali bi zelio provjeriti da ne uzimam nesto sto mi nece raditi ili ce raditi polovicno.
Znaci:
fleksibilnost >>> brzina
Spajanje na USB. Po mogucnosti 3.0 ali 2.0 nije dealbreaker.
Prednost je ako dock moze hendlat dva ili vise diskova od jednom ali isto nije bitno.
Jesam zaboravio nesto?
Staro 27.06.2019., 23:27   #95
Max Rockatansky
Lokacija: Zg/Zd
Postovi: 727
Autor hash Pregled postova
Pozdrav.
Jesi 2.5" ATA, za njega trebaš ili konverter sa 3.5 na 2.5" (40/44 pina) ili da taj dock ima poseban 2.5" konektor. Za SATA su jednaki priključci (2.5/3.5") tako da uvijek imaš oboje.
Ja imam nešto ovakvo, ne sjećam se više da li je baš sa Alije ...
https://bit.ly/2KJDv20
U ovoj varijanti nema napajanja, pa za 3.5" diskove to moraš nekako drugačije riješiti.
M.2 u paketu nisam vidio, ali to mi se čini i bolje posebno jer ne treba napajanje ili nekakve konvertere.
Staro 28.06.2019., 09:42   #96
Postovi: 34,072
Nemoj uzeti to ako ništa drugo onda zbog toga što je USB 2.0 koji je vraški spor za prebacivanje veće količine podataka.
https://www.aliexpress.com/item/3291...chweb201603_52
https://www.aliexpress.com/item/3298...chweb201603_52
Staro 28.06.2019., 23:36   #97
hash
Postovi: 1,431
Autor Max Rockatansky Pregled postova
Jesi 2.5" ATA, za njega trebaš ili konverter sa 3.5 na 2.5" (40/44 pina) ..
Super, nemam takvih diskova ali ako je samo adapter onda to mogu valjda rijesiti i naknadno.
Nije mi bitno jel s alija nego mi je to prvi stop za takvu elektroniku. Moze i lokalni ducan, amazon, njuskalo, trznica, svejedno mi je.
Ali zaboravio sam nesto vaznije. Treba raditi na Ubutnu
Coconut, vidio sam ih, ima ih hrpu ali me zanimalo misljenje iz prve ruke. Osim ako nisi ovaj isprobao?
Poslao poruku jednom selleru, kazu da ne testiraju na Ubuntu, samo Windows. Poslat cu jos par poruka pa vidjet. Vjerojatno na kraju i naruciti na blef ako nista drugo.
Staro 29.06.2019., 12:13   #98
Postovi: 34,072
Imam sličan, i radi bez problema.
Staro 08.01.2020., 21:01   #99
domy_os
domy_os's Avatar
Postovi: 18,943
Valjalo bi zamijeniti poluispravnog dedu Sharkoon SATA QuickPort Pro za nešto brže pa me zanima ima li što bolje od ovoga za te novce? Mora imati i SD card reader i barem jedan USB 3.0 port naprijed.
LC Power LC-DOCK-U3-CR
https://www.links.hr/hr/docking-stat...card-016008055
Uz to uzimam još 2 m USB 3.0 produžni kabel jer mi je priloženi od 1 m prekratak.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 08.01.2020., 21:15   #100
Postovi: 8,235
Vidi da li ima što od Orica na aliju što bi te zadovoljilo.
Staro 08.01.2020., 21:20   #101
domy_os
domy_os's Avatar
Postovi: 18,943
Njih sam prvo pogledao, ali nemaju tako nešto ni na Aliju, ni na svom siteu. Čak mi ni ne treba dual slot odnosno clone opcija, ali mora imati USB hub i SD card reader.
Staro 09.01.2020., 09:10   #102
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,418
mene interesira ovaj jer vidim da ima 2 slota i cjena je ok.
https://www.links.hr/hr/docking-stat...ssds-016008056
to vrti 2 diska odjednom?
ne mislim na te clone opcije i cudesa jer to mi ne treba. treba mi samo da 2 diska odjednom mogu koristit iako mi nije bas jasno, ako se kopira sa jednog na drugi brzina mora patit zar ne, obzirom da su na istom "kanalu" ?
a ovo mi se ne svida i nije mi jasno kako opet te price prolaze :
"Jamstvo 12 mjeseci"
trenutno imam 2 komada sharkoon sa jednim slotom i zadovoljan sam snjima, ali bi htio dock koji drzi 2 diska.
geronimo_2 je online   Reply With Quote
Staro 09.01.2020., 10:11   #103
Postovi: 34,072
Imam Orico iz Linksa sa 2 slota. Kopiranje s jednog na drugi disk je izvedivo, ali dosta sporo jer ne kopira podatke direktno nego s jednog diska u komp pa nazad naa drugi disk.
Staro 09.01.2020., 10:37   #104
Night
Lokacija: Dbk
Postovi: 1,320
Imam takav IcyBox, ali probao sam i Orico neki takav i radi to kopiranje s diska na disk putem PCa, a mogu se i oba diska na PCu koristiti u isto vrijeme. Kod hard diskova je brzina pisanja/čitanja puno manja nego brzina USB3 porta pa i dva harda neće zagušiti jedno USB3 sučelje.
Staro 09.01.2020., 21:57   #105
domy_os
domy_os's Avatar
Postovi: 18,943
Autor domy_os Pregled postova
Kupio sam ovo danas pa ćemo vidjeti kako radi. Priloženi kabel je 80 cm pa uzmite to u obzir.
Staro 09.01.2020., 23:07   #106
Postovi: 8,235
Autor coconut Pregled postova
Meni se cini da kad ides na onaj clone bas na ladici, da to radi i bez kompa, i da je bit by bit kopiranje.
Staro 09.01.2020., 23:18   #107
domy_os
domy_os's Avatar
Postovi: 18,943
Naravno, kad prebaciš switch na clone, onda kopira blok po blok i ne treba ti PC, samo ne znam kako to izgleda kada diskovi nisu jednake veličine.
Radio sam istu stvar sa SD karticama. Veća na manju nikako ne ide, a manja na veću ide s tim da poprimi veličinu manje i ne može se naknadno povećati.
Staro 10.01.2020., 07:44   #108
Postovi: 34,072
Kloniranje radi offline. Klonirao sam jedan disk i nije bio problem ako diskovi nisu istog kapaciteta. Ne znam da li ima veze, ali ja sam target disk formatirao prije kloniranja.
Staro 10.01.2020., 08:46   #109
Alister
Alister's Avatar
Datum registracije: Aug 2009
Postovi: 1,492
kloniranje rade samo ako je primarni disk veći ili istog kapaciteta kao i klon disk
Staro 11.01.2020., 19:46   #110
domy_os
domy_os's Avatar
Postovi: 18,943
Ovaj dock nema šanse upogoniti na Windows 7, cijelo popodne sam na ova dva PC-a u sigu isprobavao sve moguće kombinacije kabela, diskova i napajanja. U prvi mah sam pomislio da je dock neispravan dok nisam stavio sve kombinacije na papir.
Na laptopu s Windows 10 me zeza USB 3.0 charging port i dock se stalno odspaja iako svi drugi uređaji normalno rade. Na drugom USB 3.0 portu sve super radi, brzina do 450 MB/s, čak i preko produžnog kabela i fino se vidi da koristi UASP driver.
Na desktopu s Etron EJ168 kontrolerom UASP nije podržan, novijih drivera od 2013. nema i slikaj se, izgleda da je vrijeme za noviju MBO i konačan otpis Windows 7 smeća jer ništa novije ne radi na tome. Max brzina što dobijem je 45 MB/s i to nakon što uspije prepoznati dock jer svaki puta moram reinstalirati drivere da bi ga vidio. Na USB 2.0 kontroleru radi bez problema, ali to nije cilj.
Dock kao dock je smeće, mehanizam vrata je koma i 3.5" disk zapinje kod vađenja do te mjere da skoro pokidaš vrata koja su baš slaba. Nema nikakve vodilice za diskove pa je umetanje isto otežano, pogotovo malih 2.5" diskova, baš moraš gađati port i viriti unutra. Sharkoonov dock je bolji 10 puta što se toga tiče i vrata su puno čvršća, progutao je stotine diskova u 10-ak godina i još šljaka, samo je USB 2.0 usko grlo.
Zadnje izmijenjeno od: domy_os. 11.01.2020. u 19:51.
Staro 11.01.2020., 22:08   #111
Postovi: 23,617
Nije ti w7 kriv nego mobo sa lošim Ežblj kontrolerom.
Kako na h110 i Intel usb 3 kont. nema blema ?
Staro 11.01.2020., 22:16   #112
domy_os
domy_os's Avatar
Postovi: 18,943
Koja točno ploča? Jedino Asus ima neko svoje rješenje za Windows 7, inače nativno ne radi po ovome što ljudi pišu na internetima.
Staro 11.01.2020., 23:07   #113
Postovi: 23,617
Pitaš koja H110 ploča podržava W7 ?
Ako to pitaš onda skoro svaka u kombinaciji sa 6. generacijom Intel proceva.
Slično je i sa Z170 chipsetom, nakon toga više "nema / ne može".
Asus i Điđibajt su samo olakšali posao sa dodatnim alatima da integriraš drajvere šta fale (sata, NVMe, USB2/3) u W7 install.
Namjerno su "ubrzano" prešli na 7. pa 8. pa 9. generaciju kako bi napokon ubili W7 i W8.
Iz istog razloga slični proc iz 6. generacije je namjerno skuplji od onog iz 7. ili 8. generacije.
EDIT: Lani sam baš za nekog slagao Asus H110M-C2 + Intel 760p NVMe + W7 ... to radi ko zmaj.
Zadnje izmijenjeno od: Nikky. 11.01.2020. u 23:13.
Staro 11.01.2020., 23:13   #114
domy_os
domy_os's Avatar
Postovi: 18,943
A ma na kojoj ploči si testirao pa kažeš da nema problema? Intel je od 7x serije krenuo sa USB 3.0 i naravno da tu ima manje problema. Nemam ni ja ovdje problema s drugim USB 3.0 diskovima, zeza me UASP.
Staro 11.01.2020., 23:40   #115
Postovi: 23,617
A zo, onda se nismo razumjeli (šta radi a šta ne radi / zahebava)
Staro 12.01.2020., 01:48   #116
domy_os
domy_os's Avatar
Postovi: 18,943
Pa eto, sam si potvrdio ono što sam i rekao, Asus ima svoje drivere koji rade na Windows 7. Sve je do proizvođača, samo što se nitko više ne bavi starim OS-om.
Staro 12.01.2020., 02:50   #117
Postovi: 23,617
Nisu to nikakvi posebni drajveri ovog ili onog, to su službeni drajveri Intela i drugih ovisno čiji je hw.
Vidim da si pokleknuo sa namjenom mantrom obsolete os jer mora biti W10 smetje,
sve je jasno, dogovoreno, sve se zna.
Staro 12.01.2020., 17:20   #118
domy_os
domy_os's Avatar
Postovi: 18,943
Odustajem, kontroler je smeće i uz Windows 7 smeće () ne radi dobro. Na isto napajanje i USB 3.0 kabel spojim LC Power eksterno kućište i kopira 200 MB/s koliko je limit diska. Po svemu što vidim na netu, dobro mi to još i radi, sporije, ali stabilno. To mi je sad škola da pazim sljedeći puta i ne uzimam ploče s Etron smećem.
Staro 12.01.2020., 18:08   #119
Postovi: 23,617
Govorili smo u x tema, nabavi iz vani add-on kontroler baziran na NEC / Renesas chipsetu,
samo primjer > https://www.computeronline.com.au/pr...803&PROD=59110
Staro 12.01.2020., 18:42   #120
domy_os
domy_os's Avatar
Postovi: 18,943
A nešto na VIA ili Fresco chipsetu ne bi preporučio? Orico trpa ta dva na svoje kontrolere...
