Staro 01.04.2017., 19:17   #1711
Amd_Shill
Datum registracije: Dec 2016
Lokacija: Sat
Postovi: 1,119
Autor Eladio Pregled postova
Manuel, ti pratis to dobro, kad se ocekuju ryzeni s integriranim grafama?
APU sa HBM će vjerojatno 2018.
Poslano sa mog E6653 koristeći Tapatalk
Amd_Shill je offline   Reply With Quote
Staro 01.04.2017., 19:24   #1712
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,576
Staro 01.04.2017., 19:27   #1713
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
Autor Amd_Shill Pregled postova
Ma ne gledam te jake ..mozda se zainatim fore radi pa uzmem nekog r3 , ako bude nešto jeftino ..naviklo me da intel ima i grafu i to sad vidim kao minus amdu
Jos uvjek se nadam nekom konkurentnom odgovoru od amda vezano za popularnig jeftinog pentiuma 2c4t, a onda se vracam na amd , bar jedan od 3 intel masine koje imam doma hehe ..nisam siguran da ce uskoro amd izbacit ryzene za mase tipa 500kn sto je steta i nije u njihovom stilu
..dosadno mi, nije da imam potrebu, cisto bi malo sarafao
MojSkuter
Zadnje izmijenjeno od: Eladio. 01.04.2017. u 19:33.
Staro 01.04.2017., 19:45   #1714
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Ovo je zadnje što znam da se spominjalo
AMD’s Raven Ridge Arriving in 2H 2017 Will Feature Enhanced Zen Cores and Vega GPU Architecture
The roadmap also showcased Raven Ridge which is AMD’s new APU based on the Zen core architecture. AMD has stated that while Raven Ridge is the family name, all SKUs will be branded as Ryzen chips and will be heading for launch in 2H 2017. The old roadmap showed Raven Ridge as a 2018 product but that has changed. The roadmap also claims the possibility of Raven Ridge featuring enhanced Zen cores which could leverage from some enhancements that would later be adopted by the Zen 2 cores in the Pinnacle Ridge family.
On the GPU side, Raven Ridge will feature the brand new Vega GPU architecture. These small Vega cores would help boost the performance of integrated graphics processing on such chips. We can expect prices for these chips under the sub-$250 US range. AMD has also confirmed that Raven Ridge SKUs will have a range of quad core variants with SMT enabled (4 core/ 8 threads). AMD looks very strong with the current product roadmap and they have some really cool stuff coming out in the next few years.
Staro 01.04.2017., 19:48   #1715
lobo64
lobo64's Avatar
Postovi: 1,346
Apropos APU, usrani vendori i dalje na ploče stavljaju HDMI 1.4 i DP 1.2, ako uopće.
Neshvatljivo...
Osim toga, zaboravite golgotu sa ddr4:
https://www.hardwareluxx.de/index.ph...18-kommen.html
Zadnje izmijenjeno od: lobo64. 01.04.2017. u 19:51. Razlog: dodavanje
Staro 01.04.2017., 19:52   #1716
warlock25
warlock25's Avatar
Postovi: 2,327
Autor zwer54 Pregled postova
Hebo ja taj ryzen i asus plocu i corsair kuciste i sve to skupa... Konfa je glasna... Nije to ne znam kakva buka ali od ovog svega ocekivao sam necujnu konfu a ne konstantan noise ko da je server...
Ak je netko zainteresiran prodam mu i ryzena s plocom i ovo usrano kuciste...
meni se cuje samo stock cooler kad je na 2000 rpm.
puknut cu ga na silent pa da vidim temp.
dignuo sam iz zajebancije na 3700 mhz al se srusio nakon 5 min prime 95 small testa.temp bila na 75 sto je mislim previse s obzirom na stock voltazu.stock cooler nije dovoljan za klokanje.sad ga drzim na 3.5 ghz pa cemo vidit dal bu se zrusilo.
Staro 01.04.2017., 20:16   #1717
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Yebiga, tolerancija korisnika na buku je oduvik bila subjektivna stvar...
Doduše kolegi zwer54 pod komp piše AIO vodenjara, pa malo sliježem ramenima jer sam mislija da priča isključivo o AMD stock kuleru.
A izgleda da mu ni kejs sad ne valja, hmm
Pomelo mi sig -.-
Staro 01.04.2017., 20:19   #1718
Manuel Calavera
Postovi: 14,589
warlock25 kolka ti je voltaža? Onaj bitwit bitanga je držao čak i preko 1.30v overclock sa wraith stealthom
Staro 01.04.2017., 20:47   #1719
warlock25
warlock25's Avatar
Postovi: 2,327
voltaza u biosu pise 1,180v a u cpuz kad ide prime 1.125v
Sent from my EVA-L09 using Tapatalk
Staro 01.04.2017., 21:11   #1720
Manuel Calavera
Postovi: 14,589
Srušio ti se zbog premale voltaže za 3.7ghz?
75C zvuči previše za tu voltažu, provjeri ti to
Staro 01.04.2017., 21:37   #1721
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
Dugo je i izdrzao s tom voltazom kad pogledas
Malo mu jos fali
MojSkuter
Staro 01.04.2017., 22:24   #1722
warlock25
warlock25's Avatar
Postovi: 2,327
Nekaj tu ne stima.
Probao sam sad na stocku odvrtit prime i temp se popela preko 75c.cooler je skroz stegnut i na standard u biosu.sad bum stavio na performance u biosu da vidim razliku.
Staro 01.04.2017., 22:37   #1723
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
Autor warlock25 Pregled postova
Nekaj tu ne stima.
Da li je vruć na prst metodu?
MojSkuter
Staro 01.04.2017., 22:41   #1724
warlock25
warlock25's Avatar
Postovi: 2,327
ok stavio na ful speed u biosu i cpu i case ventove i sad je na stocku prime small test oko 65 ak ja dobro gledam.koristim hwinfo i gledam najvecu temp na cpu.
Staro 01.04.2017., 22:44   #1725
warlock25
warlock25's Avatar
Postovi: 2,327
neznam.neda mi se sad case otvarat jer je ispod stola.kolko bi trebo stavit voltazu za 3,9 ghz?
Staro 01.04.2017., 22:45   #1726
Manuel Calavera
Postovi: 14,589
Ovisi od primjerka. Možda od 1.30v (ili čak i manje) pa sve do 1.35v
Prikladnije bi ti možda bilo kao jed2i nekih 3.8ghz i 1.20v ili koliko već ima
Zadnje izmijenjeno od: Manuel Calavera. 01.04.2017. u 22:54.
Staro 01.04.2017., 23:18   #1727
warlock25
warlock25's Avatar
Postovi: 2,327
evo 3.5 ghz max temp 76.3 Tdie temp, kaze hwinfo
stock voltaza
Staro 01.04.2017., 23:25   #1728
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
stock voltaza
Ako ti je cooler mlak na dodir nije dobro legao ili je krivo ocitanje, ako je vruc onda je jednostavno preslab ali ta druga opcija mi je malo sumnjiva
MojSkuter
Staro 01.04.2017., 23:29   #1729
Manuel Calavera
Postovi: 14,589
Kolko je stock ono? 1.25v? Probaj 3.8ghz s tim
Nije to možda ni loša temperatura za takav tortue test poput prime95 small fft, pogotovo ako sve uredno prolazi i ne throttla. Koliko C bude u gamingu?
Staro 01.04.2017., 23:37   #1730
warlock25
warlock25's Avatar
Postovi: 2,327
E sad tko laze od ova dva neznam.
Evo fotka
Edit: nije 1.25 nego 1.125v
Nekak vise vjerujem asrock tuning software.lol
Staro 02.04.2017., 00:07   #1731
Gigi1
Postovi: 2,138
probaj ryzen master, ali rekao bih da je ovih 77 stupnjeva realnije za torture test
Staro 02.04.2017., 00:09   #1732
Manuel Calavera
Postovi: 14,589
Skini i treći
hw info ti ne očitava ni voltažu kako treba. Ako je cooler dobro namontiran, onda više logike ima ovo as rockovo. 62C za 1.15v
Staro 02.04.2017., 00:25   #1733
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Ma ova c6h ploca je zakurac... Stavim sve na silent, to se sve dere previse za "silent" i prilikom igranja ovog novog PUBG temp proca je 50-60, strasno varira konstantno, grafa je oko 62 konstantno, ali chipset mi je na 68... I nadodir je bas vruc ovdje na hladnjaku gdje je ROG logo... No grafa je poprilicno vruca i tocno je kod njega... stavio ju u gornji ili donji slot, svejedno mu je preblizu i grije ga fino... A kuciste je stvarno glasno, cuje se taj protok zraka i ti corsair default ventovi se deru ko majmuni...
Staro 02.04.2017., 00:45   #1734
warlock25
warlock25's Avatar
Postovi: 2,327
@Jed2i
S cim ocitavas temp?
Staro 02.04.2017., 00:47   #1735
Overclock_freak
Datum registracije: Dec 2012
Lokacija: Rijeka-Zagreb
Postovi: 1,207
haha, zato meni sve tiho i hladno
Staro 02.04.2017., 09:50   #1736
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Da mozda nemas ovakav problem? https://youtu.be/nXcrfhquNJE
Koliko vidim ima i nova verzija tog kucista Obsidian 750D Airflow Edition
Staro 02.04.2017., 10:00   #1737
nick praskaton
Asshole
nick praskaton's Avatar
Lokacija: RH
Postovi: 2,361
pa sto ne namjestis, sam te krivulje ventova, jesi to pospajao na ploču ?
namjestis da se ventovi uopce ne pale do određene temperatuire proca, nakon toga neka rade do određenih okretaja, ja sam svoje sve stock ventove zamjenio za noctua redux i na idleu proc radi na 300 okretaja, a sve ostalo u kucistu je pasivno, nakon sto temp proca pređe 50 stupnjeva ukljucuju se ostali ventovi, al sve je to do 300-900 rpm max, tako da i u loadu ja ne cujem nista
Staro 02.04.2017., 11:32   #1738
Nybelung
Svaki solidan review na koji sam naletio uspoređuje Ryzen 7 sa Intel i7 i i5. Nikog ne zanima isplati li se prelaziti sa FX-8350 za 1080p?
Staro 02.04.2017., 11:42   #1739
To se podrazumjeva da treba
Sent from my SM-G930F using Tapatalk
Staro 02.04.2017., 11:45   #1740
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
Intelovci prelaze zbog multicorea, amdovci zbog singlecorea.. uglavnom svi trebaju
MojSkuter
