Staro 31.10.2015., 12:02   #271
nub
PREMIUM
nub's Avatar
Datum registracije: Dec 2014
Postovi: 2,146
Nemreš uspoređivat multi četverojezgrenog proca s fx-om od 8 jezgri.. i7 je prije konkurent u multiju, ali i fajn više košta, tak da kom treba multi može slobodno uzet fx, a kom trebaju brže jezgre i5 je bolji izbor
A s druge strane, ovaj cpu-z benčmark i ne daje baš realne rezultate.
Staro 31.10.2015., 12:37   #272
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Moj se pojaca dobrano od zadnje verzije cpuz-a...
i5 2500K @ 4.0Ghz
Zadnje izmijenjeno od: Sn4k3. 17.11.2022. u 10:25.
Staro 31.10.2015., 12:40   #273
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,041
I moj se nasafto (4690K @4.5GHz)
Single: 2042
Multi: 6741
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 31.10.2015., 13:23   #274
nub
PREMIUM
nub's Avatar
Postovi: 2,146
Autor Chuxonja Pregled postova
Single: 2042
Multi: 6741
Kako? Moj je na istom taktu 2050 / 8002
Staro 31.10.2015., 14:07   #275
sakomako
Datum registracije: May 2013
Lokacija: nigdje
Postovi: 599
Xeon E5450 @ 3,0GHz
S: 863
M: 2513
E moj druže Brko tako ti je kada nabavljaš kod kineza i onda turpijaš po procesrou ili režeš po ploči i na kraju lijepiš naljepnice!
Da si bio gospon i platio 3 EUR više dobio bi pravi procesor! To ti je ko u Alan Fordu ako daš dolar više za kartu voziš se u autu sa sisatim komadima, a ako si cicija voze te u tačkama!
I nisam se puno hebao samo sam mijenjao clock ostalo je radila Asusica inače dalo bi se igrati sa time ali me overclokiranje ne zanima ali evo malo podataka pa usporedi koju si kantu nabavio!
XEON E5450 i to ona lošija verzija po stepingu!
Clock 3000 Mhz 3600 MHz 4050 MHz
Bus 333 MHz 400 MHz 450 MHz
FSB 1333 MHZ 1600 MHz 1800 MHz
CoreV norm 1.120/1.272/1.296 V
CoreV max 1.144/1.280/1.312 V
Temp norm 52/56/57 C
Temp max 61/69/72 C
A sada ide ono glavno zašto kažem da je ono čudo koje je piljeno, strugano i ljepljeno obična kanta!
CPU-Z Benchmark
Single 1031/1277/1393
Multi 3979/4771/5377
Prvi rezultati svega su za 3000MHz, drugi za 3600 MHz a treći za 4050 MHz!
Dalje nisam išo jer me ne zanima, samo pitam se kako to kod tebe tako mali?mislim na CPU-Z benchmark!
Svi benchmark su radeni 3 puta i uzeta srednja vrijednost.
Iako nije neki mjerodavni pokazatelj CPU-Z ipak daje neke odnose!
Ja sam mislio da je drug Brko neki hebač ali ono ispalo da i baš nije tako.
Evo vidiš ja volim pisati i dati podatke!
Inače nije ništa osobno samo mi nešto kod tebe mali rezultati za ovaj procesor, nisam mislio ništa loše!
Pola sata posla i evo hrpa rezultata, nije baja cicija!
Zadnje izmijenjeno od: sakomako. 31.10.2015. u 14:26. Razlog: ispravak
sakomako je offline   Reply With Quote
Staro 31.10.2015., 14:42   #276
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Zato što su procesori "malo ojačali" u novoj cpu-z verziji
Manuel Calavera je online   Reply With Quote
Staro 31.10.2015., 14:44   #277
sakomako
Lokacija: nigdje
Postovi: 599
Znači ubacili steroide u program i nabildali rezultate. Moram skinut istu verziju koju ima drug Brko pa da vidimo koliko je velik!taj CPU-Z benchmark!
Ali ima jedan problem drug Brko nije napisao svoju verziju CPU-Z Benchmarka koji je koristio kada je mjerio!
Evo skinuo staru verziju i gle čuda i moj se odjednom smanjio!
Ne da mi se sve ponovo ali evo podatak!
Xeon E5450 3.0 GHz
S 863
M 2522
Nego ako ovaj CPU-Z laže, međutim trebali bi ostati odnosi prema drugim novijim procesorima ako je rađeno sa istom verzijom CPU-Z Benchmarka, a tu sam onda zadovoljan ipak mi nije tako mali!mislim na Benchmark!
U tom se slučaju moram izviniti drugu Brki jer očito i njegovo turpijanje, rezanje i ljepljenje ipak daje neke rezultate, samo da mu se procesor u međuvremenu ne predomisli zbog takvog tretmana prema njemu.
Nego pitanje za duga Brku zašto je dao samo informaciju o stock frekvenciji, volio bih vidjeti kako kod njega ide overclock s obzirom da je ovo tema o overclokiranju! Dakle kako to izgleda kada se uzme Viagra, tj. mala plava pilula, kako onda procesor radi i koliko daje?
Evo nije mi dao vrag mira pa na brzaka uz samo jedno mjerenje evo rezulta:
Xeon E5450
S 863/1034/1164
M 2522/3033/3408
Naravno za
3000/3600/4050 MHz
i sve ostale podatke koji su isti i dani su ranije samo uz stari CPU-Z bez steroida.
Volio bih vidjeti rezultate za I-6700K na stock, turbo i max overclocku čisto radi komparacije da znam koliki mi je!
Zadnje izmijenjeno od: sakomako. 31.10.2015. u 15:22.
Staro 31.10.2015., 23:28   #278
Autor sakomako Pregled postova
Verzija 1.73. / 22.09.2015.
S: 863
M: 2513
http://forum.pcekspert.com/showpost....&postcount=127
Xeon E5450 3.0 GHz
S 863
M 2522
Dakle, isto. Koji herc imaš više, tako i koji bod.
Turpijanje procesora nema nikakve veze sa njegovim performansama, kao ni sa OC potencijalom.
Zato što je gorenavedeni rezultat validiran na usranoj ACER MG43M ploči koja nema OC mogućnosti, tj. procesori na njoj rade samo na stock taktu.
Xeon E5450
S 863/1034/1164
M 2522/3033/3408
Naravno za
3000/3600/4050 MHz
Postoji i rezultat na 3,6GHz kod mog ćaće na P5Q-E
http://forum.pcekspert.com/showpost....&postcount=137
Staro 01.11.2015., 00:51   #279
alengrosevic
alengrosevic's Avatar
Postovi: 3,775
Celeron G540
Single 941
Multi 1793
Staro 01.11.2015., 04:51   #280
sakomako
Lokacija: nigdje
Postovi: 599
Znam ja to, samo ima ljudi koji su rezuckali po socketu i sredili ploču pa će biti i onih koji će turpijat po procu dok im ne otkaže poslušnost. Zato bolje 3 EUR više i lipo takav procesor samo staviš tamo di mu je mjesto i voziš dalje!
Ali zato performanse imaju očito veze sa verzijom softwera na kojem se mjere, poznato sa grafičkih kartica, pa se pitam a čemu će mi isti slučaj sad i sa procevima? Ili autori programa neznaju delati svoj posel kak spada?
Staro 01.11.2015., 06:13   #281
kasko
kasko's Avatar
Lokacija: Ivanić_Grad
Postovi: 2,009
Ajde objasni kako je takav proc napravljen, posto tvornicki sigurno nije, il je s dremelom il je s turpijom, razlika je samo koliko brzo ces napraviti posao.
Staro 01.11.2015., 11:27   #282
Tvornički ga je obradio Xiu Ping Ling, Alibaba trgovac
Staro 01.11.2015., 12:00   #283
sakomako
Lokacija: nigdje
Postovi: 599
Pa taj Alibaba trgovac s obzirom na količinu obrađenih procesora koju prodaje morao bi mu dan trajat barem 100 sati ako bi to radio ručno s turpijom. Ima opremu pa je to brže, bolje i sigurnije i svi koji sumanjete pogledajte kako je izvedeno lemljenje na samom CPU, za to treba imati alat, većini se ljudi tresu ruke a ovo treba poprilično precizno prelemiti tako da taj trgovac ima opremu za to a tvrdi i daje svaki CPU još dodatno i testiran nakon radova tako da je njegova cijena sasvim u redu, a ja nisam gubio vrijeme na stvari kojima bih mogao napraviti više štete nego koristi.
Staro 01.11.2015., 12:15   #284
Za ovu temu je to sasvim nebitno... kao i tvoje disertacije od 10000 znakova okini benč, postavi rezultate i okini koji komentar.
Ne trebaš lektiru prepisivati
Staro 01.11.2015., 17:02   #285
sakomako
Lokacija: nigdje
Postovi: 599
Ja sam ti uvijek imo 5 iz lektire!
Staro 01.11.2015., 17:52   #286
sakomako
Lokacija: nigdje
Postovi: 599
Autor dh41400 Pregled postova
Šteta, što se trenutno ne mogu iskoristiti prednosti ovakvog setup-a, pa da se u npr. 2D, multimediji i low loadu koristi iGPU (te isključuje dodatna PCIe grafika), a pri većem opterećenju koristi PCIe GPU (uz eventualnu dual graphics tehnologiju).
E to bi bila fora
Evo uslišali ti želju!
http://www.gigabyte.com/products/pro...px?pid=5482#ov
Možeš hardverski isključiti grafulju i ne moraš ju vaditi iz stroja i to pritiskom na gumbić!
Još da su to maknuli sa ploče i prebacili da dodatni panel koji se montira na prednju stranu PC kutije gdje bi im bio kraj?
Zadnje izmijenjeno od: sakomako. 01.11.2015. u 17:59.
Staro 07.11.2015., 22:52   #287
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,050
Dečki, pripremite se za kralja benchmarka:
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 08.11.2015., 00:28   #288
Funkie
Datum registracije: Sep 2014
Lokacija: Vukovar
Postovi: 12
6600K skajlejkusa (stock)
S:1986
M:7574
Funkie je offline   Reply With Quote
Staro 09.11.2015., 19:21   #289
Sardi
Sardi's Avatar
Postovi: 234
Pošto se svi nešto tu k****te sa mrcinama, imam i ja svog puža za utrku
Athlon 64 x2 5000+ Black Edition
S: 495
M: 878
Ko ima sporije?
Sardi je offline   Reply With Quote
Staro 09.11.2015., 19:46   #290
Postovi: 16,739
Mario92, 2 posta iznad
Staro 09.11.2015., 21:10   #291
rock00
Datum registracije: Feb 2011
Postovi: 324
evo malo sam prcko,sad mu malo smanjim napon jos ako ide
rock00 je offline   Reply With Quote
Staro 09.11.2015., 22:02   #292
aski
Je suis Schumi
aski's Avatar
Postovi: 1,524
Slabo je sve to ekipa
Nakon 7 godina još uvijek se držim u TOP 5
http://forum.pcekspert.com/showpost....47&postcount=1
Di sam stao?
Staro 09.11.2015., 22:12   #293
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
i7 6700@4,6ghz - 2200/8950
i5 6600@4,6ghz - 2350/9060
Na kolko ti je memorija rock00 ?
Bez potpisa.
Staro 12.11.2015., 11:42   #294
alengrosevic
Postovi: 3,775
Pentium G4400 3,3 Ghz H110 ploča
Single: 1666
Multi: 3187
Staro 12.11.2015., 11:56   #295
rock00
Postovi: 324
Autor RaneZ Pregled postova
2666... svaki put drugacije ga okine
Staro 12.11.2015., 12:12   #296
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
Autor rock00 Pregled postova
Da, meni je 2666@2880mhz xD
mozda to radi takav score
Bez potpisa.
Staro 19.11.2015., 23:52   #297
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Ram je na singl-čenl trenutno, ako to ima veze sa skorom...
Staro 20.11.2015., 19:20   #298
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Laptop ASUS G771JW, i7 4720HQ
Single: 1488
Multi: 6475
Staro 26.11.2015., 22:53   #299
scarzz
scarzz's Avatar
Lokacija: Stuttgart/Rijeka
Postovi: 414
i7 4770
scarzz je offline   Reply With Quote
Staro 27.11.2015., 09:28   #300
KillerLoop2807
motion graphics freak
KillerLoop2807's Avatar
Datum registracije: Jun 2010
Lokacija: Kutina
Postovi: 177
Single je blah, ali multi
KillerLoop2807 je offline   Reply With Quote
