Staro 14.07.2015., 11:22   #871
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,037
A polovno sa garom bi bio the way to go, ima i dobrih hladnjaka na placu ak nemaš neki bolji aftermarket pa bi se i taj phenom dao ižmikat još vjerojatno za neke performanse.
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 14.07.2015., 12:20   #872
Arendelle
Datum registracije: Jul 2015
Postovi: 113
Znači, taj bi procesor mogao gurati ovo? Je li to uopće jače od R7 260X? Eventualno bih se još mogla protegnuti za neko jeftinije napajanje.
Arendelle je offline   Reply With Quote
Staro 14.07.2015., 12:41   #873
Freddy
Freddy's Avatar
Datum registracije: May 2015
Postovi: 76
Autor Arendelle Pregled postova
je r7 265 je jača, al ja ti nebi preporučo ništa jače od r7 260x za taj tvoj procesor, ovako si uzmi:
MSI R7 260x 2GB GDDR5 128bit, 28nm, 2xDVI + HDMI + DP, OC V1
i napajanje:
Napajanje FORTRON 400W, HEXA Plus 400, 12cm ventilator
Freddy je offline   Reply With Quote
Staro 14.07.2015., 13:09   #874
Arendelle
Postovi: 113
I bi li onda ta kombinacija mogla vrtjeti igrice koje sam spomenula (prvenstveno GTA V da odigram, ali i novi FC, FIFA/PES, DiRT Rally koji bih tako rado odigrala, ali mi se sad FPS vrti oko 10) bez nekih problema na 1440×900 pri medium detaljima s nekom postavkom možda na low?
Staro 14.07.2015., 13:18   #875
Freddy
Freddy's Avatar
Postovi: 76
s tom grafičkom na toj rezoluciji ćeš večinu igrica igrat na high postavkama
Staro 14.07.2015., 14:44   #876
ravkan
ravkan's Avatar
Postovi: 753
Radit ce ti to sve, u svakom slucaju uzmi 260x grafu, a napajanje mozes uzet FORTRON 400 ili ANTECA, neces pogrijesit ni sa jednim.
Red Vishera Blue Devil
ravkan je offline   Reply With Quote
Staro 14.07.2015., 15:08   #877
Quorgyle
Postovi: 21
Na moju trenutnu konfiguraciju mi trebao upgrade grafičke kartice....tražio tražio pa na kraju naletio na forumaša koji je osvojio nagradnu igru tu na forumu i prodavao Sapphire R9 290x tri-x 8GB. Kupim to od njega i onda sam odlučio da bi i ostale kompomente mogao malo osvježiti. Odlučio sam se za ovu narudžbu pa recite svoja mišljenja.
CPU: Intel Core i5-4690K
MBO: ASRock Z97 Pro4
RAM: Kingston Technology HyperX Fury Memory Black 8GB 1600MHz DDR3
PSU: FSP/Fortron Aurum S 700
DISK: WD Blue 1 TB SATA
Kučište: Corsair Carbide Series® SPEC-01 Red LED
Sve iz Uzishopa, cijena ravno 5k kuna....+ grafa 2.5k.
Quorgyle je offline   Reply With Quote
Staro 14.07.2015., 15:13   #878
ravkan
ravkan's Avatar
Postovi: 753
Cisto super konfa, ako oces intela to je to. Ako oces imat full AMD build mozes uzet fx8300 te giga ili asus plocu. Uzet neki bolji cooler i stavit ga na 4.4 i vozi misko. Jedno i drugo ce ti radit bez greske.
Ja bi osobno promjenio disk i uzeo Toshiba tvrdi diks. Ali to je osobno, posto je ipak nesto brzi od tog WD blue.
Staro 14.07.2015., 15:20   #879
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
Malo bolja ploča, napajanje, malo prostranije kućište:
Seagate 1TB SATA HDD Barracuda, Serial ATA III, 1000 GB
Cooler Master V650S
Kingston Technology HyperX Fury Memory Blue 8GB 1866MHz DDR3
Gigabyte GA-Z97X-Gaming 3
Intel Core i5-4690K
Fractal Core 2300
S popustom nekih 5030kn.
Staro 14.07.2015., 15:44   #880
Quorgyle
Postovi: 21
Ups, zaboravio sam napomenuti da sam već naručio
I imam spreman hladnjak za procesor, ARCTIC COOLING Freezer 13, s.
Samo ne znam koliko uopće ima potrebe na intelu, možda ga i ostavim na trenutnom računalu.
Staro 14.07.2015., 15:53   #881
ravkan
ravkan's Avatar
Postovi: 753
Taj cooler ti je banana, za intela Morat ces uzet nesto puno bolje Iskreno Extreme 4 je odlicna ploca tu nisi nista pogrijesio. Uzmi si neki cooler tipa hyper 212, razintek ili noctua. Probaj nac polovni negdje da usparas koju kunu.
Staro 14.07.2015., 15:56   #882
Quorgyle
Postovi: 21
Nisam imao plan još clockati intela, mislim da nema potrebe. Zar neće stock cooler biti dovoljan?
Staro 14.07.2015., 15:59   #883
ravkan
ravkan's Avatar
Postovi: 753
Svaki stock cooler je tu da komp radi, samo je pitanje dali ti se svida taj nacin rada. Meni osobno ne. Temp ako ces pokrenut nesto zahtjevnije ko render, bench itd ce ti skocit na 80 stupnjeva. Za 250 kn ili ako uspijes na njusci ulovit polovni za 150 hyper 212 ce ti rjesit te probleme i moci ces ga u buducnosti malo clockat, ne puno ali eto.
Edit: A i iskreno ne vidim poantu kupovine otkljucanog proca ako ga ne mislis clockat, onda si mogo ic na jeftinije rjesenje i5 4460 npr i vozi misko.
Staro 14.07.2015., 16:08   #884
Quorgyle
Postovi: 21
Rekao sam da ga neću još clockati. Vidit ćemo za koji mjesec. A K verziju sam uzeo zbog grafičke, doći će valjda i taj dan kad ova konfa bude "lošija" pa mi bude trebao jači procesor. Recimo trenutni AMD koji imam ima velikih problema sa jednom MMO igricom. FPS je oko 30-40....i odjednom padne na 0 u određenim situacijama
Staro 14.07.2015., 16:22   #885
ravkan
ravkan's Avatar
Postovi: 753
Taj problem sa MMO igricama je oduvijek tu, neovisno o procu. Ja imam FX8350 clockan na 4.7 Ghz a frend ima 4770k na 4.2 Ghz, igramo zajedno WOW i raidamo. Krajem prosle expanzije u SoO raidu, kada bi krenuli na startu figta AoE nas 25 svima bi stalo. Imali bi po par FPS-a. To nije do proca nego do lose optimizacije odredene igre. Necu ni pricat kolko bi bilo FPS-a na nekom world bosu gdje bi nas bilo 40+.
Edit: U buducnosti kada ti bude trebao jaci procesor, makar ja ATM ne vidim da ce to biti tako brzo, onda bude ionako bio neki drugi proc vani, drugi socket, sve drugacije i vjerovatno ce biti masu bolje. Ali ne vidim to bas tako uskoro.
Staro 14.07.2015., 16:27   #886
Quorgyle
Postovi: 21
Autor ravkan Pregled postova
WoW je još dobro i optimiziran, igrao sam ga nekad prije na Athlon XP 1.9GHz procu. Naravno da je low FPS utjecao na moj DPS, kasnije kad sam uzeo noviji komp i pokazao ljudima kako se DPS-a sa boljim računalom ostali su šokirani.
U svakom slučaju, koliko sam shvatio, intel ima puno bolje perfomanse kod radnji gdje se zahtjeva samo jedna jezgra.
Staro 14.07.2015., 17:17   #887
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,578
ma ti prvi phenomi nisu u rangu Q6600, dosta su slabi, em očajan singlethreading, em mali clock, te je bottleneck izvjesan (ovisno o igri). Ali opet nemaš što pametnije kupiti ispod 260X/750 ako ne želiš polovno, samo ako ne želiš mjenjati napajanje uzmi gtx 750 2gb i vozi
Quorgyle
Pukni ti ssd unutra za mmo
Zadnje izmijenjeno od: Manuel Calavera. 14.07.2015. u 17:24.
Staro 14.07.2015., 18:21   #888
tiki66
tiki
tiki66's Avatar
Postovi: 2,721
To napajanje nije Cooler Master već Thermal Master, šrot i jeftinija napajanja Cooler Mastera. Prilično lagano napajanje koje nije nešto kvalitetno, te vjerojatno ima koju godinu. Ja bih ga svakako mjenjao.
tiki66 je online   Reply With Quote
Staro 15.07.2015., 01:54   #889
Arendelle
Postovi: 113
Quorgyle
Velim, ne kužim kako neki vele da je to OK kad sam ja u mnogo izvora čitala kako je onaj najjeftiniji dvojezgreni Pentium nešto bolji od tog Phenoma kojeg život ionako nije mazio. Iako, nekad je dobro gurao 4850, sad su druga vremena. Ne znam, bilo bi mi drago kad bi Phenom vrtio igrice OK u talu s 260X, ali je loša situacija ako ne bude tako jer sam mogla ostaviti i ovo DDR2 smeće. Inače, od te 4650 su bolje valjda nekoliko godina starije kartice više klase, fakat je najgore govno uske sabirnice, spore memorije i nikakvih performansi.
Autor tiki66 Pregled postova
Da, Thermal Master... Ima koju godinu - 6-7 njih, točnije.
Staro 15.07.2015., 08:05   #890
tiki66
tiki
tiki66's Avatar
Postovi: 2,721
Definitivno mjenjati to napajanje prvo, vjerojatno je već izgubio pol snage
Staro 15.07.2015., 11:38   #891
Manuel Calavera
Postovi: 14,578
Normalno da je bolji pentium kad je nekoliko generacija noviji, brutalno učinkovitije jezgre pa je bolji i u multithreadingu iako je dual core. Ali ako kupuješ novo, jednostavno za taj budžet ne možeš ništa pametnije napraviti od već predloženog
Staro 15.07.2015., 14:00   #892
Arendelle
Postovi: 113
Ne osjećam još nikakve probleme u radu, ali OK. Sve je moguće.
Taj Pentium sad stoji tristo kuna, a ovaj moj Phenom, kad je bio nov, stajao je daleko više. Kad bih se odvažila na promjenu platforme, sigurno bih uzela tog Pentiuma, neku jeftinu matičnu i R7 260x. Ispada da bi to bilo bolje od ovoga što sad imam, a trošilo bi i manje struje. Iako, čujem da je X4 must-have za neke igre pa sam ipak u prednosti.
Staro 15.07.2015., 14:58   #893
Manuel Calavera
Postovi: 14,578
Imaš sad na tržnici recimo Seasonic S12II 430W 80+ (180kn), i gtx 560Ti twin frozr II (480kn), onda bi ostatak mogla štediti za novu platformu, ili athlona 840 + a68 mbo
http://www.centro.hr/amd-cpu-kaveri-...w-fm2-box.aspx
http://www.iqcentar.hr/product&product_id=51575
http://www.iqcentar.hr/product&product_id=47186
Staro 15.07.2015., 18:28   #894
domax
Postovi: 2
Pozdrav ekipa, nisam bio na ovom forumu no dosta ljudi mi je preporučilo da se raspitam ovdje...
ovako s prijateljem sam okvirno složio konfu za kantu u nastavku:
http://assemblio.hr/pc/FbOsfQ3JES/4
MSI A78M-E35 (FM2+) (418kn)
AMD Athlon x4 860k (600kn)
Gainward GeForce GTX 750, 1GB (897kn)
Kingston HyperX Fury Black 8GB (578kn)
Western Digital Green 1TB (500kn) -> uzet ću Blue cijena je skoro ista
Samsung 250GB 850 EVO (1039kn)
Corsair CX430 (438kn)
kako mi je ponudilo odabrao sam u istom shopu i:
http://www.futura-it.hr/katalog/komp...al-zm-t2-plus/ (180kn)
http://www.futura-it.hr/katalog/komp...vd-rw/0120441/ (130kn)
to je oko 4800 - plan je i bio potrošit do 5 pa lijepo molim za neki komentar oko kompatibilnosti ili sugestiju zamjene za slično
- vj. uzet bolju matičnu? koju?
- AMD->Intel varijanta za skoro iste novce?
domax je offline   Reply With Quote
Staro 15.07.2015., 19:33   #895
tiki66
tiki
tiki66's Avatar
Postovi: 2,721
Konfa je za gaming između ostalog? Nije baš dobro izbalansirao assemblio, da se i malo bolje izvući iz te cifre. FM2 platforma je mrtva (nema više nadogradnji) pa je preporuka FX sa 6 jezgri:
Ukupno: 5029,34 kn
Malo se uštedilo na MBO, ali izgurat će FX-a sa hladnjakom.
Ukoliko vam baš ne treba pržilica slobodno je izbaci (Windowsi se stave sa USB sticka), SSD mu treba za što tako veliki? Preporuka je i veće kućište za nešto bolji protok zraka i više mjesta.
Staro 15.07.2015., 20:34   #896
Manuel Calavera
Postovi: 14,578
Bolje xfx R9 270, jeftinija i jača, bolji cooler
Staro 16.07.2015., 16:05   #897
domax
Postovi: 2
e pa fala puno za prijedlog i konfu
- pa bit će za povremen gaming pa da potraje neko vrijeme
- oko SSD-a sam kombinirao i skupljao dosadašnja iskustva prijatelja i mislim da ću ipak uzet 'samo' 120, ali malo bolji koji sam inicijalno planirao:
SSD Samsung 120GB 850 EVO Basic
- pržilicu ću ostavit jer mi treba tu i tamo pa da imam jednu
- kućište bum si ostavio ovo jer mi se i sviđa , a parama bi išao osjetno gore za minimalnu razliku (lako ga otvorim, stavim ventilator bla...)
- za grafu sad ni sam ne znam stavio mi Manuel bubu u uho
XFX RADEON R9 270 je samo 30ak kuna jeftiniji, ali da ima generalno bolje karakteristike... ova R7 370 je pak novija, ne razmem se dosta
- bi bolje možda bilo uzet neku matičnu za parstokuna više umjesto coolera na ovu?
Staro 16.07.2015., 16:28   #898
Manuel Calavera
Postovi: 14,578
- R7 370 je rebrand od R7 265, a sad su došli novi zajednički driveri za staru i "novu" generaciju, privremeni beta driveri za 3xx seriju su bili promotivne naravi da gpu što bolje izgledaju po launchu, ali su potpuno identične i podržavat će iste drivere u budućnosti
- cooler ti treba
- bolja mbo giga ds3p
Staro 03.08.2015., 20:43   #899
drupci15
je.ba.c na ba.te.ri.je
drupci15's Avatar
Lokacija: Zagreb-Jarun
Postovi: 304
pozz ekipa
došlo je vrijeme za novu konfu pa bih zatražio par sugestija od Vas
CPU - AMD X8 FX 8370 1565 kn
MBO - ASrock 990FX Extreme3 896 kn
DDR3 - Kingston HyperX Fury 1866mhz 4 x 4Gb 920 kn
GPU - MSI R7 370 gaming 4gb ddr5/256bit 1630 kn
PSU - ostavljam od stare konfe pošto mislim da mi je seasonic 600w čist dovoljan (star je 8 god)
eto ako netko misli da ima nešto bolje za value for money, slušam
drupci15 je offline   Reply With Quote
Staro 03.08.2015., 21:21   #900
Smartic
Smartic's Avatar
Postovi: 2,707
Namjena? Nije dobro složeno btw.
