Povratak   PC Ekspert Forum > Računala > DIY i Tinkering
Staro 23.03.2015., 18:55   #91
spawn
spawn's Avatar
Postovi: 8,504
Za te pare ako nadjes ersu. Nisam je dugo vidio ali imao sam je prije 15 godina i bila je odlicna
Staro 23.03.2015., 21:48   #92
hobitxxx
hobitxxx's Avatar
Datum registracije: Jul 2009
Lokacija: Koprivnica
Postovi: 412
Hmm a nekaj ovak kaj morem kupiti u cipoteki recimo? mislim mogu izdvojiti i malo vise od 300 sl da onda imam stvar koja mi traje za povremeno koristenje al opet da si morem relativno kvalitetno napraviti posel
hobitxxx je offline   Reply With Quote
Staro 23.03.2015., 22:13   #93
Gonzo_stari
Gonzo_stari's Avatar
Postovi: 107
Gonzo_stari je offline   Reply With Quote
Staro 24.03.2015., 14:07   #94
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,083
Nisam turbo sitne stvari radio sa ZD99, ali se solidna glede preciznosti.
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 13.05.2015., 18:05   #95
piNheaD
piNheaD's Avatar
Lokacija: Senj
Postovi: 636
Poz kupio bih ovu lemilicu http://www.ebay.com/itm/Hakko-FX601-...item27fd49ef69 radi na 110v pa me zanima da li bi šljakalo preko adaptera http://www.kronos.hr/adapter-220110v-75w-p-7949.html
Hvala
Suck Satan's cock
piNheaD je offline   Reply With Quote
Staro 13.05.2015., 19:21   #96
mujica
črna jetra
mujica's Avatar
Postovi: 453
hakko 67W, pretvarac 75W, trebalo bi bit ok.
nisam bas u tome, slucajno naletih na temu, kaj se nemre za tih cca 470kn kupit nekaj u komadu?
Avoid hangovers: stay drunk.
mujica je offline   Reply With Quote
Staro 13.05.2015., 23:45   #97
piNheaD
piNheaD's Avatar
Lokacija: Senj
Postovi: 636
A čuj mogu se nabaviti Kineske stanice i onda stavit Hakko vrh.Ovo je oriđiđi Hakko i po specifikacijama je kao lemna stanica možeš lemit sve živo i kvalitetne je izrade.Na drugu stranu vrhovi su im dosta skupi ali i traju.
Suck Satan's cock
Staro 26.08.2015., 13:11   #98
chief_wolfinjo
Staro 26.08.2015., 20:35   #99
petar75
petar75's Avatar
Lokacija: slavonija
Postovi: 108
Jedna od kopija Hakko 936. Pogledaj ovaj video pa odluči.
Sve te kopije se rade u jednoj tvornici i samo lupaju druga imena.
Evo i ove sa videa dosta jeftinije.
petar75 je offline   Reply With Quote
Staro 27.08.2015., 09:41   #100
chief_wolfinjo
evo sada sam pogledao video. da, naravno da je lošiji ali realno gledajući niti se nemre baš očekivati da bude jednako kvalitetan.
samo da velim, da sam naručio s hobbyking. pa ćemo vidjeti kakav je
inače
dal za taj odgovaraju ovi nastavci:
http://www.ebay.com/itm/10-Pcs-Solde...08?&rmvSB=true
ili neki drugi ?
hvala
Staro 27.08.2015., 10:16   #101
petar75
petar75's Avatar
Lokacija: slavonija
Postovi: 108
Ti bi odgovarali, ali pripazi jer koliko vidim u napomeni da ne šalju kod nas.
Ako budeš zadovoljan uvijek možeš kupiti originalne Hakko vrhove koje budeš najviše koristio.
Staro 27.08.2015., 11:15   #102
chief_wolfinjo
a gdje mogu kupiti original, i koja je njihova uopće cijena ?
Staro 27.08.2015., 19:08   #103
petar75
petar75's Avatar
Lokacija: slavonija
Postovi: 108
Imaš npr. ovdje. Čisto da znaš, cijene su bez njhovog PDV-a (IVA) koji je 21%
Nije jeftino, ali kvalitet košta. Mislio sam uzet kod njih model 888 i kad sam skužio da su cijene bez poreza, kupio Ersu sa njihovog shopa.
Problem je što je Hakko teško nać u EU. Ovisi koliko ćeš je koristit pa u skladu s tim odluči dal su ti potrebni originalni vrhovi ili ne.
Staro 27.08.2015., 19:11   #104
c-shadow
c-shadow's Avatar
Postovi: 3,521
ZD-99
U Holexu više nema ovih ZD-99, eventualno kroz 2 tjedna kad im opet dolazi roba, ali ne primaju narudžbe unaprijed
Trenutno imaju samo neku ZD99/58 koja je slična, ali 58W i ima drugačije vrhove, koje naravno ne drže.
Ima li kakva alternativa u tom cjenovnom razredu ili možda kakav drugi izvor za nabaviti istu lemilicu?
Na ebayu mi sve ispadaju skuplje.
Staro 28.08.2015., 14:55   #105
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,296
imas ovdje. tu sam ja kupio.
Staro 28.08.2015., 15:18   #106
c-shadow
c-shadow's Avatar
Postovi: 3,521
Hvala, kako si ti zadovoljan tom lemilicom?
U međuvremenu zvao par dućana od kojih sam imao kontakte i nabavljao robu samo su cijene 30-40% veće:
Elmatis - 185 kn
Tevetron 170 kn
Gdje kupiti kod nas vrhove za tu lemilicu, trebao bi mi i jedan malo širi?
Tevetron ima samo onaj od 0.8mm kakav i dolazi gore, a Elmatis veli da pašu od ove lemilice koja barem na slici izgleda identično. Znači ovaj set.
Staro 28.08.2015., 15:37   #107
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,296
ok je. za ono sto mi treba (tu i tamo nesto prelemit je sasvim ok). regulacija uredno radi, nikakvih problema.
vrhove sam ja isto nabavljao u conradu, no koliko vidim i te sto si linkao bi trebali odgovarati.
Staro 28.08.2015., 16:46   #108
Chuxonja
Pajcek
Chuxonja's Avatar
Postovi: 1,083
Ja sam svoju isto prek conrada drpio. I dalje me služi okej, nije fantastična, al to kolko lemim u zadnje vrijeme, više neg okej. Vrhove mislim da i na jebayu imaš isto za sitne pare
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
ODD: LG GH24NS70
OS: Windows 10 Pro
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
ODD: LG CH10LS20
HDD1: WD Green 1TB
LINK
ODD: LG GH22LP20
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
PSU: Enlight 400W
OS: Windows XP SP3
LINK
HDD: WD 160GB
OS: Windows XP SP3
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 30.08.2015., 00:43   #109
.Delboy
.Delboy's Avatar
Lokacija: hr
Postovi: 755
Zar nisu vrhovi isti kao za onu zd-931, za nju je bilo vrhova prije u chipoteci set ili po komad, neznam sad kakvo je stanje.
Staro 30.08.2015., 00:59   #110
c-shadow
c-shadow's Avatar
Postovi: 3,521
Ista se lemilica rebrandira kao Velleman VTSS4, ZD-99, Fixpoint AP-2,... Elmatis ima na zalihi ove 2 zadnje i identične su osim boje. Za Fixpoint imaju set od 4 vrha koji sam linkao gore tako da sam naručio tu lemilicu i set vrhova. To će valjda potrajati neko vrijeme za moje amaterske potrebe
Staro 09.09.2015., 11:19   #111
chief_wolfinjo
jučer mi je stigla lemilica: http://www.hobbyking.com/hobbyking/s...rSearch=solder
ali paket je bio malo oštećen... sad iz kojeg razloga. to ne znam
uglavnom utičnica za struju je oštećena odnosno jedan pin je savinut.
pa sam se žalio i odobrili su mi djelomični refund što je ok
e sada ja moram taj kabel zamjeniti jer se ne može pojedinačno samo utičnica
pa me zanima dal bi pasao kabel od napajanja ? samo s druge strane skinem izolaciju i zalemim kabel..
to inače ovako izgleda kad se otvori:http://s69.photobucket.com/user/m249..._4425.jpg.html (slika s neta)
hvala
Staro 09.09.2015., 12:03   #112
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,296
Da. Kabel ko kabel
Staro 09.09.2015., 12:43   #113
Mac_F
Pauk mrežar
Mac_F's Avatar
Lokacija: Zagreb (Bjelovar)
Postovi: 278
A da jednostavno našarafiš šuko utikač? http://www.chipoteka.hr/artikl/35762...o-ravni-bijeli
PCAP or it didn't happen
Mac_F je offline   Reply With Quote
Staro 09.09.2015., 12:47   #114
Postovi: 23,634
Djelomični refund si dobio šta je uredu, al šta kompliciraš ?
Ako je oštećeni utikač ljepljen onda ga ocvikaš i montiraš novi > http://www.kronos.hr/utikac-220v-suk...li-p-7348.html
ili uzmi kabel od napajanja kojem ćeš ocvikati IEC konektor pa zalemiti na žice unutar lemilice.
Staro 09.09.2015., 14:47   #115
chief_wolfinjo
hvala svima na odgovorima
Nikky.... ne razumijem tko komplicira ? samo sam pitao za savjet
čak ova ideja s šuko utikačem uopće nije loša ideja
Staro 10.09.2015., 09:19   #116
chief_wolfinjo
update: montirao sam šuko utikač i sve fino radi
Staro 10.09.2015., 10:16   #117
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Prije bih rekao da je pitanje postavljeno od strane čovjeka koji je upravo kupio lemilicu, a sad pita kako riješiti banalan problem, prilično glupo
Kupovina lemilice po defaultu daje do znanja da se osnovno znanje o elektrici posjeduje.
Nikky se samo htio lijepo izraziti
Spoiler alert!
Staro 10.09.2015., 10:29   #118
chief_wolfinjo
lemilicu od prije imam
ali kao što velim samo sam tražio savjet da vidim što je pametnije. mjenjati samo utikač ili cijeli kabel...
Staro 10.09.2015., 10:43   #119
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Pa onda
Prema tome, nisi toliki zelenko u tim vodama
Samo pitaj, nemam ništa protiv.
Ako je kabel bio u neoštećenom stanju, naravno da je naj-jednostavnije, -isplativije i -brže samo utikač promijeniti
Spoiler alert!
Staro 10.09.2015., 11:27   #120
Mac_F
Pauk mrežar
Mac_F's Avatar
Postovi: 278
U lemilici su stopice, pa nije baš preporučljivo lemiti (tipa kod uzemljenja na trafou)
BTW u lidlu je krimpalica sa wire stripperom i nešto stopica za 111kn
