Staro 23.09.2014., 21:43   #1711
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
Autor FRipper Pregled postova
DOA ide na servis na pregled, ako se utvrdi kvar ili nedostatak ide novi laptop. Znaci oce oni ili nece ti moraš dobiti novi laptop ako je tako kako je... Ali moraš sacekati da servis to pregleda...
Zbog?
Igor Batinic
Staro 23.09.2014., 22:09   #1712
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,084
jednostavno je tak ako je riječ o DOA proceduri, ak neš ne valja unutar 8 dana od kupnje nema servisiranja, odma drugi uređaj.
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 23.09.2014., 22:11   #1713
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
Autor Chuxonja Pregled postova
Zbog?
Igor Batinic
Staro 24.09.2014., 13:16   #1714
Digital.Ghost
Datum registracije: Sep 2014
Postovi: 4
Kontaktirao sam ih i pristali su mi dati novi laptop. Pohvale jako uslužnom i kvalitetnom osoblju bez obzira na sve.
Digital.Ghost je offline   Reply With Quote
Staro 25.09.2014., 00:33   #1715
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Autor Old Iggy Pregled postova
Zbog?
toga da ne moraju vracati pare
Zamisli...
Kupim monitor, ne radi odnesem nazad i čekam 15 dana popravak. Dobim popravljen monitor i on nakon 2 dana krepa, nosim opet i opet čekam 15 dana popravak...
nema smisla... čista logika i tko god misli drugačije i radi drugačije nije u redu
Staro 25.09.2014., 00:40   #1716
Don Kihoty
Datum registracije: Apr 2011
Lokacija: Sisak
Postovi: 1,373
Da, ide nov uređaj/povrat sredstava, ako je DOA, ali se DOA mora prvo i provjeriti.
Što ako nije DOA, nego tvoj zez (ne kažem da se tebi to mora desiti,
ali dešava se).
Baka kupi Canonov fotić, i već sutra "on ne radi". Nije stavila SD karticu
u njega, i naravno, fotić "ne radi". To nije DOA, to je "ja sam prepametan/na da čitam uputstva, tiskaju se eto da popune prazninu u kutiji" tip ljudi.
Ali da, ako ti nakon DOA dobiješ novi monitor i opet krepa u 2 dana - onda ili
nemoj izlaziti iz kuće jer si pehista, ili imaš velikih problema sa kućnom mrežom.
Don Kihoty je offline   Reply With Quote
Staro 25.09.2014., 11:01   #1717
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
Zamisli...
Jedno je logika, drugo zakon. Ako netko nešto mora to znači da je definirano ili zakonom ili specifičnim ugovorima.
Potpuna zamjena DOA proizvoda nije česta i predstavlja nestandardan postupak. Da ne govorim da je iz perspektive nabave u mnogim situacijama nemoguć.
Autor Don Kihoty Pregled postova
A kod koga ide nov uređaj po defaultu?
Igor Batinic
Staro 25.09.2014., 12:52   #1718
Don Kihoty
Lokacija: Sisak
Postovi: 1,373
Uvoznik odobrava i šalje novi uređaj. Trgovina može refundirati sredstva
u slučaju da uvoznik nema novi isti artikl.
Ta procedura traje u principu 24/48h, duže samo u slučaju da je problem
sa dostavom i/ili skladištenjem.
Staro 25.09.2014., 12:56   #1719
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
A to si čuo gdje?
Stvarnost ti je miljama daleko od te priče.
Igor Batinic
Staro 25.09.2014., 15:01   #1720
flare
mrzi zimu
flare's Avatar
Lokacija: behind blue eyes
Postovi: 318
Radim u IT veleprodaji već skoro 8 godina tako da imam puno iskustva vezano za cijelu ovu priču. Mogu vam samo reći da zamjena nije tako jednostavna kako se čini iz perspektive kupca, bez obzira na činjenicu što bi se, ponekad, uređaj trebao odmah zamijeniti jer je očito da je DOA ili da nije greška napravljena od strane kupca.
Mislim da nitko od uvoznika (radila sam s par brandova pa ne mogu generalno reći da li svi) ne može sam na svoju ruku mijenjati uređaj jer mora imati potvrdu od glavnog servisa dotičnog branda da je to zaista DOA/nepopravljivo i da može zamijeniti.
U protivnom ide na trošak uvozništva.
I da, tu kupac "ispašta" ali jednostavno nema druge. Ponekad trgovine odobre odmah na svoju ruku jer su već imali isti ili sličan slučaj pa znaju da će dobiti odobrenje no većinom se čeka.
But it also breeds creation
RHCP
Staro 25.09.2014., 15:15   #1721
Da, i onda kontaktiram Kingston i objasnim problematiku i dobijem odgovor da je uvoznik dužan mi to zamjeniti jer je za to ovlašten. I onda nekoliko lud zbunjen normalan mailova, eto novog artikla.
Ne kažem da su svi muljatori, ali da se kupci probaju izveslat od strane IT veletrgovaca, da. I one fore "novi artikl nastavlja garanciju starog" i tako.
Svi imaju putra na glavi i to je začarani krug. Kupci su ljuti na uvoznike koji su ljuti na kupce koji muljaju sa garancijama. Zato nebi previše popasao priče o prepoštenim veletrgovcima. A i radio sam u jednom propalom pa znam kakve su direktive bile.
Staro 25.09.2014., 15:18   #1722
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
tebi je jasno da je u RH pravno Kingston "nitko i ništa"?
U takvim situacijama obično sam vendor izađe u susret i odobri financijski trošak uvozniku. Iliti, nema "pokazivanja prstom" i slično - uvoznika / distributera to interesira kao lanjski snijeg.
Igor Batinic
Staro 25.09.2014., 15:29   #1723
Ali ako je netko OVLAŠTENI ZASTUPNIK I DISTRIBUTER Kingstona, zašto se pravi grbav i pokušavao me smuljat? Pa je na kraju neki kolega bio kriv jer je novi i ne zna dobro sve...
Staro 25.09.2014., 15:31   #1724
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
Zato jer njegove obaveze prema tebi i obaveze Kingstona prema njemu nisu ni približno iste. Pitanje je samo koliko će se kome dati malo više "kruha preko pogače".
Igor Batinic
Staro 25.09.2014., 15:45   #1725
flare
mrzi zimu
flare's Avatar
Postovi: 318
Links nije distributer niti uvoznik za Kingston. Oni, kaj se memoriije tiče, imaju distru za PQI i G.Skill. Kingston ti ide preko Micorlinea, M- sana ili Asbisa.
RHCP
Staro 25.09.2014., 15:53   #1726
Skužio sam da smo u Links temi da, nije vezano za links drkarim preko tapatalka pa sam mislio da je raspava o rma i garancijama u općenitoj temi.
Staro 29.09.2014., 12:34   #1727
AFK
Datum registracije: Aug 2014
Postovi: 153
pitanje za links poklon bon :
http://www.links.hr/artikl-920.000.003
dolazi rođendan uskoro pa gledam bon da polonim 500kn poklon bon u links zanima me ako recimo uzme za 430 kn nešto ovih 70kn viška joj se vraća ili mora potrošiti sveukupnu sumu kod njih?Ili ako nešto npr košta 550 kn može se nadoplatiti 50 kn uz taj bon?
hvala
AFK je offline   Reply With Quote
Staro 29.09.2014., 18:24   #1728
flare
mrzi zimu
flare's Avatar
Postovi: 318
Brijem da je kao kod svih poklon bonova. Iznos koji ne potrošiš ti ostaje "za kasnije" (ne možeš dobiti novac nazad) a ako kupiš preko vrijednosti poklon bona onda nadoplatiš razliku.
RHCP
Staro 30.09.2014., 11:19   #1729
Postovi: 8,245
Autor AFK Pregled postova
hvala
Nedobiješ ništa nazad nit ostaje za kasnije, pa ti je bolje sve potrošit. Nadoplatit možeš.
Staro 30.09.2014., 11:23   #1730
virus1
virus1's Avatar
Postovi: 495
Ti poklon bonovi meni nikad nisu sjeli, ono WTF daj čovjeku pare za roćkas da vidiš veselja i nema komplikacija.
virus1 je offline   Reply With Quote
Staro 30.09.2014., 11:37   #1731
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Potpis, ovo s poklon bonovima rade samo nježnije indvidue
BMK oću li ispast ljakse ako za rođendan šiknem par novčanica drito u ruke slavljeniku, ako mu smeta neka ne stisne ruku
Pomelo mi sig -.-
Staro 30.09.2014., 13:32   #1732
X-Plosiv
X-Plosiv's Avatar
Postovi: 1,811
Autor Drvoje Pregled postova
Ja od svoje 15te više preferiram novac u ruke Samo što evo sada s 25 više nitko ne želi dati novac u ruke
Staro 30.09.2014., 14:19   #1733
Drvoje
Drvoje's Avatar
Postovi: 4,037
Pretpostavljam da ni ove Linksove bonove ne dobivaš na dar
Pomelo mi sig -.-
Staro 30.09.2014., 15:49   #1734
AFK
Postovi: 153
e hvala na odgovoru mislim da će onda u kovertu ići 500 kn pa neka radi sa njima što hoće [iako znam da će ih udariti u links ] ovo sa bonovima totalna gluposti..dakle 500 kn pretovriš u 500 kn bon od kojeg nemaš kusura a za nešto više nadoplatiš kao da tih 500 kn imaš i kod sebe...
bože dragi koja glupost :S
Staro 30.09.2014., 16:00   #1735
Burko
Osobni opis - pitaj me
Burko's Avatar
Postovi: 2,317
ja: dobar dan, ja sam xyz, evo osobne i clan sam links cluba, danas mi je rodendan.
netko: dobar dan, sretan rodendan.
ja: ja bi onaj poklon bon od 500 kuna.
netko: dobro, aktivirat cemo ga (ili sta vec).
ja: evo, ja bi kupio ovo jer eto bas se sada jebem sa dig receiverom i treba mi za null kabel da naguram transponder liste za 13, 16 i 19E.
netko: jos sta uz ovo?
ja: da, kusur .
pa nisi dobio 500 kuna, dobio si bon kojeg iskoristavas u linksu. ajd mi reci, sta mene sprecava (da je ovo za kusur, da se dobiva) da kupim ovakvo sranjce za 25 kuna i prosetam do bilo koje druge trgovine i potrosim preostalih 475 kuna?
uostalom, znas li koliko bi kostalo bilo koju trgovinu da za rodendan svim svojim clanovima doslovce daje 500 kuna, jer to spada pod kusur? za sve poslovnice??
common sense, dajte malo razmislite van svojih okvira...........
i daj, definitivno daj tome nekome 500 kuna. ili kupi nesto za tih 500 kuna, ne mora biti u punom iznosu. ja se nebi osjecao sretnim da mi dode netko za rodendan i kaze - evo ti bon, moras ga potrositi u konzumu.
a sta ako necu potrosit full iznos?
Staro 30.09.2014., 16:33   #1736
randic7
randic7's Avatar
Datum registracije: Oct 2011
Postovi: 115
Ovaj Links je u totalnoj banani, odnio sam dell monitor na reklamaciju 19.8 i jos uvjek mi nista ne javljaju.Svako tjedan pitam preko chata i stalno mi isto odgovore, uređaj je u ovlaštenom servisu i nikad neznaju koliko jos treba cekat..nikad vise ne kupujem kod tih specijalaca em nabijaju cijene u nebesa em su spori katastrofa!
I nevidim cemu im onda glupis servis u Rijeci ako sluzi za ukras, toj. sve moraju slat u ZG..
blazeni ostali servisi tipa microline posaljes i za 10 dana komponenta stigne doma.
randic7 je offline   Reply With Quote
Staro 30.09.2014., 16:34   #1737
silver_tip
silver_tip's Avatar
Lokacija: doma
Postovi: 2,924
Ne mogu vjerovati dokle ide pohlepa ljudske skrtosti i prokletosti.
Pa sta je Links ? CZSS ili HZMO ?
Umjesto da se svi koji mogu ovu mogucnost iskoristiti pokriju usima i budu sretni da su dobili 500kn pa i u bonovima i jos je i nadoplata moguca pa si covjek moze nesto fino uzet za rodjendan vi se bunite ?
KUSUR ?!?
Pa ja od sramote silne nebih napisao da mi nedaju kusur a kamoli kukao da eto ne daju KEŠ nego samo bonove....
Koliko god ne volio Links ovakve likove koji kukaju da nema i da nitko neda pare djabe i bez rada ne volim jos vise
Staro 30.09.2014., 16:39   #1738
AFK
Postovi: 153
čekaj kakav links klub..kak se to regirsitra što? može objašnjenje
Staro 30.09.2014., 16:40   #1739
Postovi: 34,092
Autor randic7 Pregled postova
Pogledaj ako slučajno imaš garantni list kod sebe. Možda ti tamo stoji ona odredba da će popraviti u roku od 45 dana. Ti si na 41 danu! Ako tamo stoji 45 dana, lijepo zatraži novog u ponedjeljak.
Staro 30.09.2014., 16:57   #1740
randic7
randic7's Avatar
Postovi: 115
Imam racun na kojem pisu opci uvjeti jamstva ali ne pise tih 45, niti po zakonu toga vise nema nego razumni rok..e sad sta njima predstavlja razumni rok to samo oni znaju..
