Staro 23.05.2005., 12:07   #1
Costa
Costa's Avatar
Datum registracije: Aug 2003
Postovi: 3,193
Thumbs up foobar2000 v0.9 BETA 3
Foobar nam se nastavio razvijati : goood :
Latest Changes:
  • * Improved playlist management: all playlists are editable without being active, multiple playlists with the same name, Autoplaylists
    * Field remappings in titleformat scripts: see Titleformat Introduction and Titleformat Reference for details
    * Tag merging: combines information from multiple tag formats on the same file
    * ID3v2 support with padding for fast tag updates
    * Cleaned-up preferences
    * On-line help system for preferences pages (uses the HA wiki)
    * Playback queue (contents are currently not viewable)
    * Instantaneuos volume changes
    * User interface selection: if a new user interface is detected at start-up, you can chose which one to use
    * File type associations editor in preferences
    * Ability to reset individual pages in preferences (if supported by the component that provides the page)
    * ...functionality
Na siteu pise i da ne radi s win 95, 98 ili ME. Instalirati u cisti dir jer stari pluginovi kao i postavke nece raditi!. Ovo je trenutno samo za testiranje.
http://www.foobar2000.com/beta.html
Ako ne koristite torrent onda skinite odavde:
http://fileforum.betanews.com/detail...l/1045605070/1
Staro 23.05.2005., 12:43   #2
Costa
Costa's Avatar
Postovi: 3,193
Ludilo, ova autoplaylist stvar je bas ono kaj mi trebalo.
Slozim si playlistu koju povezem s neki direktorijem i onda kad nesto promjenim u tom direktoriju (izbrisem/dodam stvari) napravim refresh i playlista se automatski obnovi
Cijeli Preferences prozor je totalno reorganiziran i sad se puno lakse snaci. Asociranje fileova se sad nalazi po preferences.
Podrzava i midije sto funkcionira OK samo dok ne probam premotavati, al glavno da su i to poceli.
Jos se samo treba strpiti do finalne verzije kad ce i pustiti SDK van pa ce ljudi moci updateati pluginove.
Staro 23.05.2005., 12:59   #3
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
E, ludilo.
Staro 27.05.2005., 14:08   #4
LordNitro
LordNitro's Avatar
Postovi: 1,610
Ne bih htio pljuvat po ničemu, ali WinAmp mi je bolji.No, o ukusima se ne raspravlja...
Kirk: "Spock, you want to know something? Everybody's Human."
Spock: "I find that remark... insulting."
LordNitro je offline   Reply With Quote
Staro 27.05.2005., 16:47   #5
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
Pa dobro, drži se onda njega i nikom ništa.
Staro 27.05.2005., 16:51   #6
Freek
Freek's Avatar
Lokacija: Zagreb/Dubrava
Postovi: 2,869
napokon mi search radi normalno sa cca 15k pjesama na playlisti.
Na prošloj verziji mi je stalno blokirao kod traženja i skrolanja po playlisti.
Staro 27.05.2005., 18:50   #7
miato
(°_°)
miato's Avatar
Postovi: 3,249
foobar je zakon
jedino s njim mogu slusati mp3ce u stereu emulirane na svih 6 zvucnika
Staro 27.05.2005., 19:02   #8
Costa
Costa's Avatar
Postovi: 3,193
@Freek: Jesi probao AMIP?
To je inace plugin za postanje onog sto ti svira (tekstualno, ono np.) na IRC i sl. ali ima i odlicni pretrazivac. Osim sto mozes upisivanjem isfiltrirati ono sto trazis mozes i vidjeti neke osnovne podatke. Kad nadjes stvar samo je oznacis sa dolje ili gore (ne trebas stiskati tab) i ENTER. Samo kaj bi ti mogao malo sporije raditi jer imas tako puno stvari u jednoj playlisti. Daj si to malo razvrstaj.
@LordNitro: Kad malo isprobas foobar vidjet ces da si u zabludi Jedina stvar u kojoj Winamp prednjaci su skinovi (za curice ) kojih foobar sluzbeno nikad nece imati jer nema apsolutno nikakvog smisla nepotrebno upropastavati odlican proizvod.
Staro 28.05.2005., 01:09   #9
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
E ja se odlucim da cu eto ... prec na foobar... i sipak... kvrci zvuk...a ja neuk...ljen...neda mi se trazit uzrok tome ... vracam se lijepom, dosadnom winampu
Staro 28.05.2005., 11:24   #10
Costa
Costa's Avatar
Postovi: 3,193
Jesi probao zadnju stabilnu verziju (0.8.3.) ili ovu betu?
Negdje sam citao da su ljudi imali problema sa zvukom kod ove bete.
Alright I'm getting some serious distortion when I try to play anything in 16bit. Changing to 24bit works fine.
XP service pack 2, Soundstorm 5.1 onboard sound.
Mozes ovo probati.
Staro 28.05.2005., 15:46   #11
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
E sad radi
Tnx. Ovu betu sam skinuo.
