Staro 12.06.2008., 22:28   #481
mikey_rs
volveraš
mikey_rs's Avatar
Postovi: 386
Mislil sam na MP, vedro, i to na ove ostale opcije - i vidim da se igra lagano n00bovski. Nije mi namjera vrijeđat samo velim kak to izgleda sa moje strane. Ja to malo vremena kaj igram oću igrat kak Bog zapoveda. Il si luzer (a jesi na početku) il igraš dobro i to se vidi - a ne neki crashday u ljepšem celofanu.
Ovo kaj sam spomenul težinu je čisto kak ja igram trenutno na SP-u.
"I will like to die in my sleep like grandpa and not screaming like his passengers..."
mikey_rs je offline   Reply With Quote
Staro 13.06.2008., 15:40   #482
nathan
IT Consultant
nathan's Avatar
Lokacija: Geneva, Petit-Lancy / Zagreb , Dubrava
Postovi: 323
izasao race driver grid patch 1.1:
http://www.gamershell.com/download_27498.shtml
Description:
• Added support for Xinput wheel and Logitech Rumblepad 2, including default action map configurations.
• Adding ability to use H-pattern shifter in custom configuration by allowing configuration of gears 1 to 6 and reverse. Same for boost.
• Fix for missing Force feedback on Vista.
• Added the ability to override the controller type, so that if the game fails to auto-detect it, users can specify it themselves.
• Symptoms of the game failing to detect the appropriate controller type are:
• On a pad, handling is too twitchy, appears to steer “lock-to-lock”.
• On a wheel, the input lags and the linearity slider doesn’t appear to have an effect.
This patch is only for the PC-DVD version of the game and is not compatible with versions bought through Direct2Drive, Metaboli & Steam. Patches for the downloaded versions should be available “within days”.
"All we have to decide is what to do with the time that is given us" J.R.R. Tolkien
Zadnje izmijenjeno od: nathan. 13.06.2008. u 15:52.
nathan je offline   Reply With Quote
Staro 13.06.2008., 18:23   #483
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,312
Autor nathan Pregled postova
A pod koju verziju spada ova verzija koju smo svi mi "kupili"...
Staro 13.06.2008., 19:08   #484
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,060
Pa očito pod 1.0 ako je izašao patch na 1.1
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 13.06.2008., 19:26   #485
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,312
Autor 1v@n Pregled postova
daj pročitaj ponovo što sam napisao, a posebno ono quotano poviše mog teksta
Staro 13.06.2008., 19:35   #486
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,060
ne čitam do kraja. Očito te downloadane sa steama i ostalih servisa imaju neke dodatne fajlove koji valjda služe da se takva verzija odmah online prepozna, pa očito i patchevi moraju biti modificirani. Tko bi to znao kak su to zamislili u Codemastersu
LCD: BENQ PD3200Q
Staro 13.06.2008., 19:48   #487
Juggernaut
Lokacija: Varaždin, Bronx
Postovi: 1,097
Meni ne želi instalirati path, iako je igra kupljena ( da.. original ), nekaj je tu shebano...
Juggernaut je offline   Reply With Quote
Staro 13.06.2008., 20:01   #488
pipe
Bill Gates
pipe's Avatar
Lokacija: Vukovar
Postovi: 1,983
Autor Neo-ST Pregled postova
Neznam sta si ti kupio, ali vecina nas je "kupila" PC-DVD
I ja imam na ploci.
Staro 13.06.2008., 20:21   #489
mikey_rs
volveraš
mikey_rs's Avatar
Postovi: 386
Hmmm, kak sve ovo prolazi kod moderatora?!?
Staro 13.06.2008., 21:43   #490
Lazarus_Ledd
Feeling Good (live&drunk)
Lazarus_Ledd's Avatar
Postovi: 5
i šta će meni taj patch?
meni ne treba
Lazarus_Ledd je offline   Reply With Quote
Staro 13.06.2008., 22:13   #491
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,312
Autor mikey_rs Pregled postova
Lijepo, i moderatori su "kupili" igru
Autor Lazarus_Ledd Pregled postova
meni ne treba
Treba ti, jer ne možeš igrati s drugima ako imaš različitu verziju igre...
Inače, ne znam čemu je pridonio ovaj patch... realnosti nije, grafici nije, bugova ima još i više, ponašanje auta kod upotrebe volana je smiješno ma koliko se trudili ubaždariti volan i settingse, itd.
P.S. zaboravio sam jednu vrlo bitnu stvar. Naime, prije nisam mogao vidit druge igre, nikako, ali bi drugi mogli vidit moju igru kada hostam. To je ovim patchem riješeno...
Zadnje izmijenjeno od: Neo-ST. 14.06.2008. u 13:39.
Staro 13.06.2008., 22:47   #492
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Eto, ja sam sad premium. Mogu bit u obje network.. Molim samo username i pass za prvu.
Staro 13.06.2008., 23:18   #493
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,060
Koliko sam ja uspio primijetiti, framerate mi je pao za 10 nakon stavljanja patcha.
LCD: BENQ PD3200Q
Staro 13.06.2008., 23:45   #494
Core2Duo22
Mucki provokator
Core2Duo22's Avatar
Postovi: 299
Meni su se znatno podignule performanse...sad je odlično!
Core2Duo22 je offline   Reply With Quote
Staro 13.06.2008., 23:45   #495
Fadolf
Fadolf's Avatar
Lokacija: Zagabria
Postovi: 492
Fino smo nabacili danas Neo, demetrius i ja nekoliko utrka s novim 1.1 patchem!
Iako je bilo početnih problema s hamachijem sve smo sredili! Ako vidite Fadolfa na hamachiju znači da hostam igru pa se slobodno konektirajte!
Fadolf je offline   Reply With Quote
Staro 14.06.2008., 00:46   #496
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Ja se fakat zezam sa ovim Hamachijem... Igram sa frendom koji može naći bilo koji server, al treći frend može kreirat server i ovaj prvi ga vidi. Al treći nikako ne vidi mene ni ja ne vidim njega...
Ne mogu isključit onaj testsigning, tj. ne pojave se u rubovima screena tekstovi.
Staro 14.06.2008., 06:06   #497
Lazarus_Ledd
Postovi: 5
jel on ima Vistu?
http://community.codemasters.com/for...d.php?t=287793
e ovo je već opis patcha =D
Reverse gear is now disabled for the first two seconds of a network race to stop players reversing off the start line.
Fix for occasional excessive smoke coming from other players in network mode
Fix for cars very occasionally flying into the air when hitting kerbs.
E ovo sam majke mi doživio Nisam uopć ni bio u punoj brzini. Bilo je to na nekoj stazi, di je bija cik-cak zavoj po 90°prije U zavoja prije Finisha.
Network chat text made less obtrusive.
pohvaljujem
Staro 14.06.2008., 12:10   #498
Core2Duo22
Mucki provokator
Core2Duo22's Avatar
Postovi: 299
Autor Ice Demon Pregled postova
I ja ponekad imam problema s hamachijem...neke vidim kad kreiraju server, a neke ne...
Staro 14.06.2008., 12:13   #499
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
jel on ima Vistu?
Obojica imaju XP... Ovaj jedan vidi sve, ama baš sve! Drugi vidi samo prvog. Strahota.
Oslobađao sam portove još za Hamachi... A sad. Hm.
Staro 14.06.2008., 12:58   #500
Fadolf
Fadolf's Avatar
Lokacija: Zagabria
Postovi: 492
Ja sam bez ikakvih oslobođenih portova s Vistom uspio biti host.
Portove ne mogu osloboditi iz nebitnih razloga. Jedino kaj sam napravio je gašenje svih firewallova (Windows i Smart Security). Najnormalnije je sve šljakalo. Vjerujem da bi s još tweakanja bilo bolje jer je malo laggalo.
Staro 14.06.2008., 15:34   #501
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Hehe, sad sam igrao private na drugom networku sa frendom, i došo mauro iz PCE, zanimljivo... Igrao je s nama makar nije bio u našem networku.
Predobro je bilo.
Staro 14.06.2008., 15:39   #502
Juggernaut
Postovi: 1,097
Predobro je bilo.
mislim... LOL, ako si ti hostao, i ako si u mreži u kojoj je Mauro, normalno da će vidjet igru.
Kaj misliš zakaj je Neo-ST u oba dvije mreže?
Em ima dobru konekciju, em ga svi vide dok hosta; i on je praktički host u obje mreže, i tako ljudi iz jedne mogu igrati s onima iz druge jer je on kao "poveznica" između mreža.
Edit: napravljen purge danas, pcekspert_grid ( pass: pcekspert ) mreža je oslobođena spavalica, sutra čistim i 2. mrežu.
Staro 14.06.2008., 16:48   #503
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,060
Ja imam opasnih problema s ovim patchem. Igra mi se, kad uđem u dio za biranje sponzora, totalno uspori i nemoguće mi je da izaberem sponzore. Kad krenem u vožnju, framerate mi se vrti oko 30 dok je prije sve radilo normalno i brzo na 50-60. Mislim da će bit reinstall igre.
LCD: BENQ PD3200Q
Staro 14.06.2008., 19:39   #504
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Autor Juggernaut Pregled postova
Da, to... Mislio sam da se uspostavljaju konekcije izneđu drugih igrača, a ispada da ide sve preko mene. Nisam znao.
Imam i ja 1mbit upload. Nije bilo laga uopće.
Al damn, nemoj mene hitat van iz mreža - premium sam kupljen i ne uzimam slotove. A ak ću hostat, što radim većinom kad igramo mi iz razreda onda nek se i drugi pridruže.
Staro 14.06.2008., 22:00   #505
Speedbreaker
Postovi: 545
jel zna neko kolko otprilike troši po satu grid kad se igra prek neta?sorry ak je već bilo
Zadnje izmijenjeno od: Speedbreaker. 14.06.2008. u 22:30. Razlog: nadopuna
Speedbreaker je offline   Reply With Quote
Staro 15.06.2008., 13:11   #506
Thoroughbred B
Thoroughbred B's Avatar
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,910
prava je šteta uništit ovako dobru igru s nimalo realnosti u fizici,dugo nisam probao ovako tešku arkadnu vožnju...prestrašno,auto leti lijevo-desno na milimetarski dodir tipke i to na milisekundu...a zavoj možeš proć s 300km/h driftanjem
uništavanje auta je pak posebna draž...kad sam ga namjerno zabijao u zid i u druge aute po 100x nije mu bilo ništa,da bi u zavoju slučajno zapeo za nešto i odmah generalka...totalno nerealno,do 149kmh ga možeš zabijat 100 dana u zid neće mu ništa bit,a zabij ga jednom s 151kmh gotovo,totalka...
s grafikom sam totalno razočaran s obzirom na ono što sam vidio na slikama...totalno je blijeda,isprana...nimalo kontrasta,živost boja...osvjetljenja...
možda sam previše očekivao,nadao sam se prvom Gran Turismo-u na PC-u,jer s obzirom na slike,aute...i mogao je bit samo da nije tako glupavo ponašanje u vožnji...
Staro 15.06.2008., 15:42   #507
mislav_os
freak
Postovi: 2,688
ja cu ga danas nabaviti,pa cu bas vidjeti kako ce mi ici...I kakva je,nadam se da se necu razocarat,iako me T-B sad razocarao s ovim svojim,sad je ni ne zelim vise
Staro 15.06.2008., 16:02   #508
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
Autor Thoroughbred B Pregled postova
generalno se slažem s tvojim dojmom, i sam sam sličnog razmišljanja..
no mene zanima kako podesiti da su tipoke na tipkovnici manje osjeljtive, jer i mene hebe ovo skakanje u zavojima i plesanje auta.. izludim, pogotovo kad treba krenuti s mjesta.. kao da svaki auto ima 5000ks pod haubom i da je led ispod nejga.
Staro 15.06.2008., 18:55   #509
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Ja sam totalno razocaran igrom i radije igram ponovo GT4 PAL verziju na PS2.
Nuerburgring Nordschleife RULEZ!
http://upload.wikimedia.org/wikipedi...rdschleife.png
Staro 15.06.2008., 19:04   #510
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,943
Ni ja nisan baš oduševljen igrom, što se vidi iz prošlih par postova, ali ovdje je ipak previše negativnosti napisano
za letanje se slažem i to ne pomaže nikakvo podešavanje tipki
Ali za zavoj se ne slažem, istina je da neke možeš prodriftat, ali u koji god uđem 20% brže nego šta on dopušta završim u zoni izljetanja ili falijen putanju za 200 metara pa me 5 auta obiđe
Nije baš istina, koliko san skužija bitan je kut udara, najgore je kad udaraš pod nekih 30 ili 330 i tad je skoro uvijek totalka jer stradaju gume, frontalni sudar je možda malo i otporniji nego šta bi trebao, dok bočni udar u ogradu ili zid podsjeća na NFS pošto to možeš napravit i pri 200,250 km/h
Ali nije baš istina da do 149 radi, a preko 150 puca...iman SSova u kojima puca od 60-300 A slažem se da ima bugova, tipa da se auto razvali skroz pri udaru od 40 kmh, al to san doživija samo jednom u 100 krugova pa i ne bi uzea kao nekakav bug. Više me nerviraju otpadnuti djelovi koji se vrte po stazi
Ja ne bi reka da san skroz razočaran, ali slažem se da fali kontrasta, jačine, svježine
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
