#481 |
volveraš
Postovi: 386
Mislil sam na MP, vedro, i to na ove ostale opcije - i vidim da se igra lagano n00bovski. Nije mi namjera vrijeđat samo velim kak to izgleda sa moje strane. Ja to malo vremena kaj igram oću igrat kak Bog zapoveda. Il si luzer (a jesi na početku) il igraš dobro i to se vidi - a ne neki crashday u ljepšem celofanu. Ovo kaj sam spomenul težinu je čisto kak ja igram trenutno na SP-u.
"I will like to die in my sleep like grandpa and not screaming like his passengers..." |
#482 |
IT Consultant
Lokacija: Geneva, Petit-Lancy / Zagreb , Dubrava
Postovi: 323
izasao race driver grid patch 1.1: http://www.gamershell.com/download_27498.shtml Description: • Added support for Xinput wheel and Logitech Rumblepad 2, including default action map configurations. • Adding ability to use H-pattern shifter in custom configuration by allowing configuration of gears 1 to 6 and reverse. Same for boost. • Fix for missing Force feedback on Vista. • Added the ability to override the controller type, so that if the game fails to auto-detect it, users can specify it themselves. • Symptoms of the game failing to detect the appropriate controller type are: • On a pad, handling is too twitchy, appears to steer “lock-to-lock”. • On a wheel, the input lags and the linearity slider doesn’t appear to have an effect. This patch is only for the PC-DVD version of the game and is not compatible with versions bought through Direct2Drive, Metaboli & Steam. Patches for the downloaded versions should be available “within days”.
"All we have to decide is what to do with the time that is given us" J.R.R. Tolkien Zadnje izmijenjeno od: nathan. 13.06.2008. u 16:52. |
#483 |
Postovi: 8,507
#486 |
The mighty pirate
Lokacija: London
Postovi: 9,123
ne čitam do kraja. Očito te downloadane sa steama i ostalih servisa imaju neke dodatne fajlove koji valjda služe da se takva verzija odmah online prepozna, pa očito i patchevi moraju biti modificirani. Tko bi to znao kak su to zamislili u Codemastersu
#488 |
Bill Gates
Lokacija: Vukovar
Postovi: 1,983
#491 |
Postovi: 8,507
Lijepo, i moderatori su "kupili" igru ![]() Treba ti, jer ne možeš igrati s drugima ako imaš različitu verziju igre... Inače, ne znam čemu je pridonio ovaj patch... realnosti nije, grafici nije, bugova ima još i više, ponašanje auta kod upotrebe volana je smiješno ma koliko se trudili ubaždariti volan i settingse, itd. P.S. zaboravio sam jednu vrlo bitnu stvar. Naime, prije nisam mogao vidit druge igre, nikako, ali bi drugi mogli vidit moju igru kada hostam. To je ovim patchem riješeno... Zadnje izmijenjeno od: Neo-ST. 14.06.2008. u 14:39. |
#495 |
Lokacija: Zagabria
Postovi: 492
Fino smo nabacili danas Neo, demetrius i ja nekoliko utrka s novim 1.1 patchem! ![]() Iako je bilo početnih problema s hamachijem sve smo sredili! Ako vidite Fadolfa na hamachiju znači da hostam igru pa se slobodno konektirajte! ![]() |
#496 |
Postovi: 4,707
Ja se fakat zezam sa ovim Hamachijem... Igram sa frendom koji može naći bilo koji server, al treći frend može kreirat server i ovaj prvi ga vidi. Al treći nikako ne vidi mene ni ja ne vidim njega... Ne mogu isključit onaj testsigning, tj. ne pojave se u rubovima screena tekstovi. |
#497 |
Feeling Good (live&drunk)
Postovi: 5
jel on ima Vistu? http://community.codemasters.com/for...d.php?t=287793 e ovo je već opis patcha =D Reverse gear is now disabled for the first two seconds of a network race to stop players reversing off the start line. Fix for occasional excessive smoke coming from other players in network mode Fix for cars very occasionally flying into the air when hitting kerbs. E ovo sam majke mi doživio Nisam uopć ni bio u punoj brzini. Bilo je to na nekoj stazi, di je bija cik-cak zavoj po 90°prije U zavoja prije Finisha.Network chat text made less obtrusive. pohvaljujem
#498 | |
Mucki provokator
Postovi: 299
#500 |
Lokacija: Zagabria
Postovi: 492
Ja sam bez ikakvih oslobođenih portova s Vistom uspio biti host. Portove ne mogu osloboditi iz nebitnih razloga. Jedino kaj sam napravio je gašenje svih firewallova (Windows i Smart Security). Najnormalnije je sve šljakalo. Vjerujem da bi s još tweakanja bilo bolje jer je malo laggalo. |
#502 | |
Lokacija: Varaždin, Bronx
Postovi: 1,097
Kaj misliš zakaj je Neo-ST u oba dvije mreže? Em ima dobru konekciju, em ga svi vide dok hosta; i on je praktički host u obje mreže, i tako ljudi iz jedne mogu igrati s onima iz druge jer je on kao "poveznica" između mreža. Edit: napravljen purge danas, pcekspert_grid ( pass: pcekspert ) mreža je oslobođena spavalica, sutra čistim i 2. mrežu. |
#503 |
The mighty pirate
Lokacija: London
Postovi: 9,123
Ja imam opasnih problema s ovim patchem. Igra mi se, kad uđem u dio za biranje sponzora, totalno uspori i nemoguće mi je da izaberem sponzore. Kad krenem u vožnju, framerate mi se vrti oko 30 dok je prije sve radilo normalno i brzo na 50-60. Mislim da će bit reinstall igre.
#504 | |
Postovi: 4,707
Imam i ja 1mbit upload. Nije bilo laga uopće. Al damn, nemoj mene hitat van iz mreža - premium sam kupljen i ne uzimam slotove. A ak ću hostat, što radim većinom kad igramo mi iz razreda onda nek se i drugi pridruže. |
#505 |
Postovi: 545
jel zna neko kolko otprilike troši po satu grid kad se igra prek neta?sorry ak je već bilo Zadnje izmijenjeno od: Speedbreaker. 14.06.2008. u 23:30. Razlog: nadopuna |
#506 |
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,918
prava je šteta uništit ovako dobru igru s nimalo realnosti u fizici,dugo nisam probao ovako tešku arkadnu vožnju...prestrašno,auto leti lijevo-desno na milimetarski dodir tipke i to na milisekundu...a zavoj možeš proć s 300km/h driftanjem ![]() uništavanje auta je pak posebna draž...kad sam ga namjerno zabijao u zid i u druge aute po 100x nije mu bilo ništa,da bi u zavoju slučajno zapeo za nešto i odmah generalka...totalno nerealno,do 149kmh ga možeš zabijat 100 dana u zid neće mu ništa bit,a zabij ga jednom s 151kmh gotovo,totalka... s grafikom sam totalno razočaran s obzirom na ono što sam vidio na slikama...totalno je blijeda,isprana...nimalo kontrasta,živost boja...osvjetljenja... možda sam previše očekivao,nadao sam se prvom Gran Turismo-u na PC-u,jer s obzirom na slike,aute...i mogao je bit samo da nije tako glupavo ponašanje u vožnji...
#508 | |
Lika u mom srcu
Lokacija: Canada, Toronto
Postovi: 9,887
generalno se slažem s tvojim dojmom, i sam sam sličnog razmišljanja.. no mene zanima kako podesiti da su tipoke na tipkovnici manje osjeljtive, jer i mene hebe ovo skakanje u zavojima i plesanje auta.. izludim, pogotovo kad treba krenuti s mjesta.. kao da svaki auto ima 5000ks pod haubom i da je led ispod nejga. |
#509 |
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
Ja sam totalno razocaran igrom i radije igram ponovo GT4 PAL verziju na PS2. Nuerburgring Nordschleife RULEZ! http://upload.wikimedia.org/wikipedi...rdschleife.png |
#510 | |||
Torrent freek
Postovi: 3,948
Ni ja nisan baš oduševljen igrom, što se vidi iz prošlih par postova, ali ovdje je ipak previše negativnosti napisano ![]() Citiraj:
![]() Ali za zavoj se ne slažem, istina je da neke možeš prodriftat, ali u koji god uđem 20% brže nego šta on dopušta završim u zoni izljetanja ili falijen putanju za 200 metara pa me 5 auta obiđe Citiraj:
Ali nije baš istina da do 149 radi, a preko 150 puca...iman SSova u kojima puca od 60-300 A slažem se da ima bugova, tipa da se auto razvali skroz pri udaru od 40 kmh, al to san doživija samo jednom u 100 krugova pa i ne bi uzea kao nekakav bug. Više me nerviraju otpadnuti djelovi koji se vrte po stazi![]() Citiraj:
