Staro 09.11.2015., 03:18   #1
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,143
(pitanje) CPU nadogradnja STARE KANTE
rijec je o ovoj maticnoj (everest info)
CPU Socket Type 462(A)
Motherboard ID 11/21/2003-nVidia-nForce-6A61BA1BC-20
Motherboard Name Abit NF7(-S) v2.0
Front Side Bus Properties
Bus Type DEC Alpha EV6
Bus Width 64-bit
Real Clock 133 MHz (DDR)
Effective Clock 267 MHz
Bandwidth 2133 MB/s
Memory Bus Properties
Bus Type DDR SDRAM
Bus Width 64-bit
DRAM:FSB Ratio 1:1
Bandwidth 2133 MB/s
Chipset Bus Properties
Bus Type HyperTransport v1.0
Bus Width 8-bit
Motherboard Physical Info
CPU Sockets/Slots 1 Socket 462
Expansion Slots 5 PCI, 1 AGP
RAM Slots 3 DDR DIMM
Integrated Devices Audio, LAN
Form Factor ATX
Motherboard Size 240 mm x 300 mm
Motherboard Chipset nForce2-U400
Extra Features SoftMenu
e sad ta maticna ima "Athlon XP 2500+"
mene zanima, se moze na tu plocu dati (zbog utora)
neki bolji proc, preferirano dualcore, ili neki jaci single core ?
i koji ? :P
Why would you invite a mushroom to a Christmas party? He's a fun guy to be with.
Why do mummies like Christmas so much? Because of all the wrapping.
Why does Santa have three gardens? So he can "ho ho ho".
HumWeed je offline   Reply With Quote
Staro 09.11.2015., 03:56   #2
[GOW]Nec
[GOW]Nec's Avatar
Postovi: 1,215
Athlon XP 3200+ ti je najžešći CPU za Socket A, koliko je meni poznato.
Nikad nije postojao višejezgreni proc za taj socket.
[GOW]Nec je offline   Reply With Quote
Staro 09.11.2015., 09:53   #3
Postovi: 34,041
Šta god gore stavio, razliku vidjeti nećeš tj. bacio si novce.
Staro 09.11.2015., 11:25   #4
Rino
[ZA DOM]Rino
Rino's Avatar
Lokacija: Kutina
Postovi: 762
Autor HumWeed Pregled postova
Ako je Barton uz par klikova u BIOS-u mu digneš FSB na razinu 3200+.
Ali kao što je već napisano to je za današnje pojmove prejadan hardware i bacanje para.
Rino je offline   Reply With Quote
Staro 09.11.2015., 15:40   #5
Igor_Zg
Igor_Zg's Avatar
Postovi: 909
Ne isplati se upgrade-ati...
Igor_Zg je offline   Reply With Quote
Staro 09.11.2015., 17:12   #6
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,143
sto se tice tipa
ovo veli
Field Value
CPU Properties
CPU Type AMD Athlon XP, 2000 MHz (15 x 133) 2400+
CPU Alias Thoroughbred-B
CPU Stepping B0
Instruction Set x86, MMX, 3DNow!, SSE
L1 Code Cache 64 KB
L1 Data Cache 64 KB
L2 Cache 256 KB (On-Die, Full-Speed)
CPU Physical Info
Package Type 453 Pin PGA
Package Size 4.95 cm x 4.95 cm
Transistors 37.6 million
Process Technology 6Mi, 0.13 um, CMOS, Cu
Die Size 84 mm2
Core Voltage 1.50 - 1.65 V
I/O Voltage 1.6 V
Typical Power 44.0 - 64.0 W (depending on clock speed)
Maximum Power 48.5 - 74.3 W (depending on clock speed)
e sad, nije "beskoristno", za office stvari je sasvim ok
samo mi je namjera vise da youtube ne steka (tj flash)
posto gpu nije za to (gf 6600)
a morat cu dati win7 na tu masinu, eto zato pitam za "upgrade" cpu-a
dobro to su vise jeftine zakrpe
Staro 09.11.2015., 17:15   #7
syss
syss's Avatar
Postovi: 10,805
cpu ti je tu najmanji problem... uglavnom za w7 - baci to sve u savu.
Staro 09.11.2015., 17:19   #8
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,784
Autor syss Pregled postova
Bas suprotno, CPU mu i je najveci problem, jer nema SSE2, i de facto ga mozes baciti u smece za bilo kakvu desktop upotrebu danas.
Programer
Staro 09.11.2015., 17:21   #9
Nažalost, to je relikvija.
Za ovo što si nabrojao, minimum je kakav Core-based Celeron (430/450) kojih imaš po 20-30kn i neki jeftilen od s775 matx ploče i 4GB DDR2...
Ali ta matična je bila jedna od boljih socket A sa nForce2 čipsetom u to vrijeme, ako ne i najbolja.
Staro 09.11.2015., 17:21   #10
Chuxonja
Pajcek
Chuxonja's Avatar
Datum registracije: Jun 2012
Postovi: 1,069
Baš kak Rino veli, to u 2 poteza ide na 3200+, al badave ti je išta ulagat od vremena i para u tu platformu. Kolko je smeća natovareno online, to se mora vraški potrudit da i webpage otvori ovih dana.
MBO: ROG Maximus VII Ranger
ODD: Asus DRW-24B1ST
SSD: Intel 760p 256GB NVME
HDD: WD Purple 1TB
PSU: FSP Hyper 700W
CASE: Antec 1200
OS: Windows 10 Pro
MBO: ASRock Z87 Pro3
GPU: Intel HD Graphics 4600
ODD: LG GH24NS70
PSU: Corsair TX 650W
CASE: Zalman Z3 Plus
OS: Windows 10 Pro
MBO: Gigabyte GA-X58A-UD7
GPU: Gigabyte HD 5450 1024MB
SSD: Corsair Force GT 120GB
HDD1: Toshiba P300 2TB
HDD2: Hitachi DeskStar 2TB
HDD3: Hitachi DeskStar 2TB
HDD4: WD Green 2TB
HDD5: WD Red 2TB
HDD6: WD Purple 4TB
PSU: Corsair CX 600M
CASE: Chieftec Bravo
OS: Windows 10 Pro
MBO: Asus P5Q SE/R
FDD: Samsung SFD-321B 3.5"
ODD: LITEON iHAS124
CASE: Antec Sonata
LINK
MBO: Abit AB9 Pro
RAM: 6GB DDR2 800MHz
GPU: Asus R7 240 2GB
ODD: LG CH10LS20
SSD: LITE-ON LCS-256L9S 256GB
HDD1: WD Green 1TB
HDD2: Seeagate Baracuda 2TB
CASE: Lian Li PC-7FNB
LINK
MBO: Epox EP-AF550 Pro/G
GPU: Sapphire HD 4850 1024MB
FDD: Alps DF354H 3.5"
ODD: LG GH22LP20
PSU: Levicom VP450B.BL
CASE: Xilence X1
OS: Windows 7 Pro
LINK
MBO: Abit AI7
RAM: 4x1GB Kingston 400MHz
FDD1: TEAC FD-235HF 3.5"
FDD2: TEAC FD-55GFR 5.25"
ODD2: Pioneer DVR-112DBK
PSU: Enlight 400W
CASE: Chieftec Dragon
OS: Windows XP SP3
LINK
CPU: Athlon XP 3200+
MBO: Gigabyte GA-7N400
RAM: 2x1GB Kingston 400MHz
ODD2: Pioneer DVR-107D
HDD: WD 160GB
PSU: MS Platinum 400W
OS: Windows XP SP3
CPU: Pemtium MMX 233
MBO: Vtech VIB804DS
RAM: 2x32MB SDRAM
GPU1: ATi AIW 3D Rage Pro
SND: Sound Blaster 16
FDD1: Mitsumi D359T5 3.5"
FDD2: Mitsumi D509V2 5.25"
ZIP: Iomega Z100ATAPI
ODD: Mitsumi CRMC-FX400
HDD: Seagate U4 6.4GB
PSU: DTK PTP-2008 200W
CASE: ES-COM AT case
OS: Windows 98SE
LINK
Živi bili pa umrli!
Staro 09.11.2015., 17:21   #11
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,143
zato i ova tema
ako noviji za taj utor imaju sse2 onda je isplativ upgrade
naravno ak nekostaju ti proci neznam kolko.....
//edit
web radi kako treba jer koristim SSE1 pale moon za to
Staro 09.11.2015., 17:23   #12
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,784
Citas li ti sto pise u threadu? Nema, gotovo, ende, finito, šlus, konjec. Mozes malo ovrouklokirati (pitaj Jaska, on ti je mag AMD kloukanja!) ali niti s time neces dobiti nista spektakularno. Cak je i za server preglomazan i spor.
Slozi neki Linux + game emulatore gore i daj klincima u kvartu da se igraju ili nesto. Realno, ta masina nije ni za pokloniti, jer zaista nemas sto 2016. raditi na njoj...
Programer
Staro 09.11.2015., 17:31   #13
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,143
ok fala
