Staro 11.09.2009., 16:06   #181
Postovi: 7,568
AMD's next-gen GPU powers Crysis on an iPhone
AMD unveiled its next-gen GPU, and secretive networked gaming company OTOY used it to power a demo of Crysis running on an iPhone. Believe it or not, it really worked. OTOY's demo of Crysis running on an iPhone was probably the most profoundly intriguing use of AMD's upcoming GPU that I saw all evening. First, the game is rendered like normal on the server machine, where frames from it are grabbed by the OTOY server-side software. Next, these frames are compressed and sent out over the network to the client, which decompresses them using a very small chunk of code (about 780K, hence the iPhone demo) and displays them in a window. User input is sent back to the server over UDP because it's tolerant of packet loss, so you don't add to latency by resending dropped packets.
The demos of Bioshock, Grand Theft Auto, and World of Warcraft were surprisingly responsive, despite the fact that the games were being served up by machines in Los Angeles. The iPhone's screen was small enough that I couldn't discern any compression artifacts, and the gameplay was smooth and responsive. Aside from the half-baked control scheme, which was apparently hacked together at the last minute, this really was Crysis running on an iPhone.
Staro 11.09.2009., 16:59   #182
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
A daj ajde
ovo je vec sprdnja, malo su se oni previše počeli sprdati
Ja samo cekam da to sve izađe, ak si necu za 1000 kn kupit i 4870 i gtx260(i 3870) tu na tržnici
Ali ono sa80fps-a, mislim da je to malo prevelko nabrijavanje. A slike grafe mi vuku kao da ih je netko mobitelom slikao...
Staro 11.09.2009., 17:01   #183
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
šta smo već u april ušli???
Staro 11.09.2009., 18:05   #184
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,746
Autor Halos Pregled postova
A daj ajde
Autor trouble Pregled postova
Kakva sprdnja, kakav april
Pa znam da je cudno, ali nije ovo vise doba pentiuma mmx, edo-rama itd...
Tehnologija ide naprid svakim danom
Staro 11.09.2009., 19:26   #185
Postovi: 7,568
Dal je ovo za Crysis na iPhoneu ili pak činjenica da vrte igre na nekolko 30" i sl. monitora sprdnja, prvi april ili nekaj treće procijenite sami, a do onda...
PCB ATi Radeon HD 5870 kartice
ATi Radeon HD 5770 i HD 5750 kartice
Juniper XT and LE will be officially named Radeon HD 5770 and Radeon HD 5750 respectively when launched. HD 5770 card is codenamed Countach while HD 5750 is codenamed Corvette and they both come with 1GB GDDR5 memories on 128-bit memory interface. Juniper will possess all the features of its higher end counterpart like 40nm, DX11, Eyefinity technology, ATI Stream, UVD2, GDDR5 and best of all, it is going to be very affordable.
Staro 11.09.2009., 20:05   #186
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,927
Ne pratim baš previše temu, pa ako nije bilo evo jedna zanimljiva stvar.
sinisa1989 je online   Reply With Quote
Staro 11.09.2009., 20:05   #187
Amepshi
Amepshi's Avatar
Lokacija: Bjelovar
Postovi: 739
A tek kada Edvard slozi full cover vodeni blok za 5870 graficku! Nadam se da ATi nece staviti u BIOS ogranicenje na max GPU clock :-)
Staro 11.09.2009., 20:10   #188
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Autor McG Pregled postova
_______________________________________________________________________________________
Evo nekih slika sa ATI foruma...
Radeon HD 5870 Eyefinity Edition Spotted
Izvor:techpowerup, ati-forum.de
Zadnje izmijenjeno od: Jelc. 15.09.2009. u 02:23. Razlog: mda...
Staro 11.09.2009., 21:47   #189
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,927
Autor bluefluid Pregled postova
Slike su awesome.
E da mi je ova grafa, odmah po 6 monitora, samo najprije moram auto prodat
Staro 12.09.2009., 23:31   #190
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Jel se to meni čini ili razmak između rupa bude bio isti/sličan kao i na hd4870/90, pa će se moći stavit musashi?
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 13.09.2009., 19:34   #191
jacbri
jacbri's Avatar
Datum registracije: Mar 2008
Lokacija: Kršan
Postovi: 28
Zadnje izmijenjeno od: tor. 13.09.2009. u 22:16.
jacbri je offline   Reply With Quote
Staro 13.09.2009., 22:20   #192
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,962
Autor jacbri Pregled postova
7 dana, prouči pravila.
Staro 13.09.2009., 22:28   #193
Razer
Razer's Avatar
Postovi: 11,642
Autor DraŽ Pregled postova
S obzirom koliko se isti mučio sa HD4870/4890 karticama, prilično sam siguran da ga možeš otpisati kao adekvatno aftermarket rješenje.
Staro 13.09.2009., 22:53   #194
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Ja sam fakat zabrio da grafe nece biti onakve, ali izgleda da ipak jesu...fora. Brutalno izgledaju, ali ono, više mi je muka od divljenja kako sve to izgleda...zanima me kako to ide
A i ovo vezano uz aftermarket kuler...hm!?
Potorsnja i grijanje, to me istinski brine...jer u stanju recesije, to nams tvarno netreba.
Staro 14.09.2009., 08:10   #195
Mad_Duke
Čekaj da nestane plina sljedeće zime opet, pa ćeš biti zahvalan na ovom
Staro 14.09.2009., 16:01   #196
Omega
Omega's Avatar
Lokacija: Sibenik
Postovi: 1,226
sto se tice stock hladnjaka, iz prve ruke sam cuo da je "whisper quiet"... doduse neam pojma kakve su temperature u radu
edit: temperature su "iznenadujuce" niske s obzirom na potrosnju i tihi rad ventilatora... sto god to znacilo
Casemodd logs : Dragon Storm, Kali, Entourage
Complete Case Painting Guide
Zadnje izmijenjeno od: Omega. 14.09.2009. u 23:44.
Omega je offline   Reply With Quote
Staro 14.09.2009., 23:35   #197
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Staro 14.09.2009., 23:58   #198
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,541
Staro 15.09.2009., 00:55   #199
ivan77
by: tkpenalty;1551829
wow. That is FAST.
My 4870x2 is starting to feel inadequate already!
Jebote , odakle izlaze ovakva "racionaliziranja" Ja sam mislio da smo mi na balkanu malo ono...
Staro 15.09.2009., 01:30   #200
Lud76
Leteći medvjedić
Lud76's Avatar
Postovi: 1,204
Sve mi ovo izgleda kao kod izlaska HD4850 gdje po tim "testovima" valjda bila dvostruko brža od 3870 X2 ak se dobro sječam....al dobro vidjet ćemo uskoro na djelu sve to
Lud76 je offline   Reply With Quote
Staro 15.09.2009., 07:54   #201
Momir
Momir's Avatar
Postovi: 1,011
Gledam mal ove slikice i pasem oci
PCB ima 8 + 6 pinski prikljucak za struju, a na karticu su stavljeni 2 * 6, dali ce mozda verzija za vise monitora dolazit s 8 + 6, a ova za "obicne" smrtnike sa 2 * 6 ?
I prikljucak za ventilator koda ima 2 žice ?
Momir je offline   Reply With Quote
Staro 15.09.2009., 08:51   #202
Postovi: 33,917
Izem ti tu logiku 'ponekad je brži, a ponekad nije' (c/p: When compared to GeForce GTX 295, its performance ranges between -25 percent (25% slower) to 95 percent (almost 2x faster), another broad range.). Ili je ili nije brži. Ovo izgleda k'o da ga hrane malo Viagrom, a malo Apaurinima.
Staro 15.09.2009., 09:28   #203
V.I.P
Istrian Lifestyle
V.I.P's Avatar
Datum registracije: Jul 2009
Lokacija: Medulin
Postovi: 1,384
a cek..dali su oni objavili kad ce grafe siknuti u prodaju?
V.I.P je offline   Reply With Quote
Staro 15.09.2009., 09:54   #204
Postovi: 33,917
Do kraja mjeseca (čini mi se 24 ili 26.9.).
Staro 15.09.2009., 09:57   #205
Nybelung
Autor coconut Pregled postova
To i ja gledam i mislim si: "WTF?"
Mora da je do drivera.. Ne mogu vjerovat da mogu toliko velike oscilacije u rezultatima bit..?
qoute:
The Radeon HD 5850 on the other hand, can be -25 percent (25% slower) to 120% faster than GeForce GTX 285.
I šta sad? Koja je brža?
Ispada da trebaš za drugu igru i drugu grafu koristit?
Staro 15.09.2009., 13:07   #206
Gile
Postovi: 380
Gile je offline   Reply With Quote
Staro 15.09.2009., 13:10   #207
pinkskin
pinkskin's Avatar
Lokacija: Daruvar
Postovi: 1,743
Problem je kod drivera i kod optimizacije igri zbog Nvidine "The Way It's Meant To Be Played" politike.
Evo kako
"The Way It's Meant To Be Played" igrica izgleda na ATI-u u dx11
evo još testova
http://tweakimg.net/g/forum/template...com/oho6qa.png
http://tweakimg.net/g/forum/template...om/2gt16v5.png
http://tweakimg.net/g/forum/template....com/58it1.png
http://tweakimg.net/g/forum/template...com/sqt3yp.png
Staro 15.09.2009., 13:17   #208
Wolverine
Wolverine's Avatar
Postovi: 12,425
Autor Nybelung Pregled postova
qoute:I šta sad? Koja je brža?
Ne kužim zakaj se čudiš, pa to je odavno tako... ovisi o optimizaciji igre
nekim igrama bolje leži nVidia a nekima ATI
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 15.09.2009., 13:35   #209
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,746
Po tim testovima nova Radeonka se odlicno drzi vs GTX295.. Pogotovo u max rezi, di ima bolji fps..
Btw, nesto spominje po netu da ce izbaciti, osim standardnog x2 modela i 5870x4 model!
Evo neke specs:
Staro 15.09.2009., 13:53   #210
V.I.P
Istrian Lifestyle
V.I.P's Avatar
Lokacija: Medulin
Postovi: 1,384
x4 ?? mislim koje pretjerivanje...
