Staro 27.02.2007., 14:02   #1
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
Yakumo QuickWLAN USB 54 driver ( pomoc )
Dali itko od vas ima taj w-lan
evo slikica
Da mi da drivere ( jer u sebi imaju potreban program ), prijatelj mi je izgubio cd i nigdje ga nemre naci , probo je skinuti s glavne stranice drivere ali tamo su samo driveri a ne i program koji treba da vidi dali je koga naso ili ne
Vejita je offline   Reply With Quote
Staro 27.02.2007., 14:22   #2
Postovi: 33,989
Staro 27.02.2007., 15:37   #3
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
Da tu su samo driveri a meni treba i onaj program kaj ima u sebi
Staro 27.02.2007., 15:45   #4
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
ne treba ti program, možeš skenirat mreže i spojit se sa windowsowim programom. Ali ne možeš sa oba, ak radi sa jednim drugi neće radit.
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 27.02.2007., 15:49   #5
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
jer drivera nemam a ti driveri s glavne stranice kaj mi je dao i coconut te drivere nece instalirati jer govori da je to za drugi uređaj , tako da mi treba bas netko tko ima taj cd da mi ga zažaga ili da ga negdje stavi tipa rapid ili ...
Staro 27.02.2007., 16:25   #6
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
A si pokušao prilikom instalacije otić na search from internet, meni je jednom uspjelo kada nisam mogao nać drivere za zvuk na staroj intelovoj ploči.
Ryzen 7 2700X
2x 8gb Crucial
B450 Aurus Elite
GTX 1060
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
Harman Kardon
MX revolution
Battery grip
Sony: 18-70, 55-200
Staro 27.02.2007., 18:50   #7
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
ma jok nece kaze da nema drivera
Staro 27.02.2007., 23:29   #8
Postovi: 23,535
Sudeći po ovoj listi, a to su linux drajveri opet imamo onu priču isti hardware u xy proizvođača. Vjerojatno je samo razlika u USB ID, a kad njega otkriješ onda češ lakše pronači driver (+) software. Inaće se u originalu radi o firmi ZyDAS koju je Atheros preuzeo. Ako neuspiješ drugačije, uz pomoč ove gore liste nađi driver od drugog proizvođača i editiraj inf file. Naravno moraš izabrati onog koji ima isti RF Type:RF2959. Jedino sam na ovo naletia pri potrazi po ZyDAS firmi i zd1211 čipu:ZyDAS ZD1211 v4.13 drivers for Windows.
Staro 28.02.2007., 23:12   #9
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
Budem probao
