Staro 22.07.2003., 12:36   #1
Sky
Datum registracije: Apr 2003
Postovi: 4,085
Question Što je što u svijetu ATI-ja?
Gledam zbunjeno sve ove ATI-jeve kartice. 9000, 9000pro, 9100, 9200, 9500, 9500 pro, 9600, 9600 pro, 9700, 9700 pro, 9800, 9800 pro...
Iam li negdje nekakva tablica da se vidi što koja ima i kakve su im perdormanse? Neki dan me pita frend da li da kupi 9700 pro ili 9800 ( da, frend mi radi preko ljeta samo da skupi lovu za novog grafikanera, frik, umjesto da ode na more ), a ja nemam pojma ni koliko koja okvirno košta ni kakva je razlika medju njima.
Staro 22.07.2003., 12:42   #2
Sunrise3500
Datum registracije: Jul 2003
Lokacija: Australia
Postovi: 6
Sunrise3500 je offline   Reply With Quote
Staro 22.07.2003., 12:46   #3
Sunrise3500
Lokacija: Australia
Postovi: 6
Staro 22.07.2003., 13:43   #4
Sky
Postovi: 4,085
Hvala, to sam i ja našao. Ali jel ima nešto detaljnije o ATIjevim čipovima, kao, proizvodni proces, nekakan usporedni benchmark... I još uvijek ne znam koja je razlika između 9700pro i 9800.
Staro 22.07.2003., 14:06   #5
Sunrise3500
Lokacija: Australia
Postovi: 6
9700 = r300
9800 = r350 (novije)
9700: (od http://mirror.ati.com/products/radeo...pro/specs.html )
"SMARTSHADER™ 2.0
Programmable pixel and vertex shaders
16 textures per pass
Pixel shaders up to 160 instructions with 128-bit floating point precision
Vertex shaders up to 1024 instructions with flow control
Multiple render target support
Shadow volume rendering acceleration
High precision 10-bit per channel frame buffer support
Supports DirectX® 9.0 and the latest version of OpenGL®
SMOOTHVISION™ 2.0
2x/4x/6x full scene anti-aliasing modes
Adaptive algorithm with programmable sample patterns
2x/4x/8x/16x anisotropic filtering modes
Adaptive algorithm with bi-linear (performance) and tri-linear (quality) options "
9800 (od http://mirror.ati.com/products/radeo...pro/specs.html )
"SMARTSHADER™ 2.1
Full support for Microsoft® DirectX® 9.0 programmable vertex and pixel shaders in hardware
2.0 Vertex Shaders support vertex programs up to 65,280 instructions with flow control
2.0 Pixel Shaders support up to 16 textures per rendering pass
New F-buffer technology supports pixel shader programs with unlimited instructions
128-bit, 64-bit & 32-bit per pixel floating point color formats
Multiple Render Target (MRT) support
Complete feature set also supported in OpenGL® via extensions
SMOOTHVISION™ 2.1
i "Z cache optimized for real-time shadow rendering"
Staro 22.07.2003., 14:39   #6
pinsla
Caught Somewhere In Time
pinsla's Avatar
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
Razlika između 9700 pro i 9800 pro je sasvim mala a s obzirom na sadašnje cijene reci frendu da uzme 9700 pro to mu je isplativije.
pinsla je offline   Reply With Quote
Staro 22.07.2003., 14:43   #7
pinsla
pinsla's Avatar
Postovi: 1,860
a moram priznat da je ati totalno usrao nomenklaturu i označavanje kartica a sve je počelo još sa 9000 i 9100. Sad više ni ja sam fakat ne znam te sve oznake sad se pojavljuju i 9200se 9600se bog te pitaj kaj sve ne tak da se čovjek lako može izgubit.
Još sam za r300 liniju 9500/9700 napamet i znao sve specifikacije i performanse pojedinih grafa ali sad?????'
Nema šanse više sve to popamtit a stvara i veliku zbrku kod ljudi.
Staro 22.07.2003., 14:46   #8
Sky
Postovi: 4,085
Ma pitao je za 9800 non pro... Zanima me kako stoje sa performansama. Ma zapravo i ja uskoro kupujem grafikanera, ali isto se ne mogu odlučiti kojeg Radeona. Zanima me kakve su to fore sa pro karticama, da je jedan 8500 jači od 9000, da je 9500 jači od 9600... Može neka tablica ili nešto tome slično?
Staro 22.07.2003., 15:07   #9
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
SVE to kaj pitaš možeš naći na ATI forumu u zadnjih pola godine.
Kaj se tiče 98oo-non-pro varijanta je po meni dobra kupnja...ak se ima para...
A kad buš TI kupovao grafu-samo navedi koliko novaca misliš potrošiti i to ti je to...
Staro 22.07.2003., 20:23   #10
Sky
Postovi: 4,085
Ok, na forumu nisan bigdje vidio da je netko uspoređivao performanse 9700pro i 9800 non pro. Frend mi ima oko dva i pol soma, a ja kupujem karticu tek kad izadje HL2 ili Doom3, tak da zasad samo izviđam situaciju.
Staro 22.07.2003., 20:55   #11
Jelc
Super Moderators
Postovi: 17,485
Ako je cijena tu negdje-bolje uzeti 9800.
Osim toga 9800 možeš flashati BIOS-om od 9800PRO
Staro 22.07.2003., 22:29   #12
Sky
Postovi: 4,085
Pa zato i trebam malo uvida što je što, da vidim koje su mi opcije za koju cijenu. Ne mogu vjerovati da se toga nije nitko sjetio...
PS. Ispričavam se zbog tiskarskih pogrešaka u prošlom reply-u i u budućim dok ne rješim problem sa tipkovnicom.
Staro 22.07.2003., 22:38   #13
Stipe
Head Of The Radio
Stipe's Avatar
Datum registracije: May 2003
Postovi: 672
Je čak je 9800np i jeftiniji od 9700Pro,ali mislim(samo mislim) da je sporiji jer je 9700Pro 325/620 a 9800np 325/580
Stipe je offline   Reply With Quote
Staro 22.07.2003., 23:55   #14
pinsla
pinsla's Avatar
Postovi: 1,860
Evo ja ću sad probat bit pametan pa poredat atijeve kartice po snazi a cjenjene kolege na forumu će me dopunit gde bude trebalo
Dakle:
9800 pro 256 mb nekaj najbolje ali preskupo i nikom potrebno
9800pro 128 mb
9700pro i 9800 128 perfromanse tu negde s tim da bi čak mogao 9800 bit mrvicu sporiji
9800 SE majko mila koje zbrke bit će varijanti sa 4 i 8 pajplajna te sa 128 i 256 bitnim busem pa se sad vi snađite ja bih izbjegavao
9500 pro 128 mb
9600pro 128 mb
9500 128 mb
9500 64 mb i 9600 128 mb trebale bi bit tu negde
9600 256 mb užas šteta spore memorije 5 ns elixir koja je na njoj
8500 i 8500 le ak je kvalitetan model dakle 250 250
9100 64 mb i 9000pro
9000 i 9100 128 mb 9200 i 9200pro
7500
7200
7000
7000ve i pci
Napomena bit će i 9600 i 9200 SE kartica namjenjenih strogo oem tržištu koje su jako okljaštrene pa bih rekao izbjegavat
Staro 23.07.2003., 00:24   #15
Jelc
Super Moderators
Postovi: 17,485
A treba i pripaziti pri kupnji i to jako...
Već sad ima bar 3-4 modela npr 9600 PRO...različitih taktova,brzine memorije i bla bla...
A npr. Sapphire 9500 128...ne bi čovjek vjerovao...od modela do modela različite memorije,različite brzine...
Hinyx 3.6,Infineon 3.0,pa EltronTech ili tak nekak...ko bog sam zaboravio koju...
Pa si ti misli...
Ja već davno ne idem u kupovinu bez povečala
...a i onda je koji put malo teže odgonetnuti...
Staro 23.07.2003., 16:34   #16
Sky
Postovi: 4,085
Znao sam da je zbrkano, ali ovo... :confused:
Ok, ako hiču kupiti 9700 pro sa 128 mb rama, koju?
Staro 23.07.2003., 17:44   #17
Jelc
Super Moderators
Postovi: 17,485
Pa-ak imaš lovice...najbolje ori-điđi BBA
Staro 23.07.2003., 20:24   #18
pinsla
pinsla's Avatar
Postovi: 1,860
Kaj se tiče 9700 pro nemreš fulat koju god da uzmeš, nazivno original ati ionako nećeš naći kod nas, ali sve 9700 pro izlaze iz iste tvornice tak da je kvaliteta ista. nemoj se s tim zamarat uzmi bilo koju naravno gledajuću cijenu.
iako kad baš moram reći ću ti- nemoj gigabyte a sve ostalo možeš.
Staro 23.07.2003., 20:26   #19
pinsla
pinsla's Avatar
Postovi: 1,860
baj d vej kad smo kod zbrkanosti nije ni kod nvidije situacija puno bolja a i na tržištu procova je slično tak da je to nekaj na kaj ćemo se očigledno morat naviknut
Staro 23.07.2003., 21:45   #20
Sky
Postovi: 4,085
Ček, sve 9700 pro kartice izlaze iz iste tvornice!? Pa nemoj mi reći da su ne znam, BBA i Manli nastale na istoj proizvodnoj traci...
A što se tiče zbrke s nVidijom i procovima, ipak je malčice manja od ove s ATI-jem:burn:
Staro 23.07.2003., 23:02   #21
pinsla
pinsla's Avatar
Postovi: 1,860
Haj end atijeve kartice su sve iz iste tvronice. Manli nikad nije ni proizvodio 9700 ili 9700 pro, to su atijeve kartice koje manli prodaje. Imaš još hrpu firmi kao što su club 3d, hajtek i sl. koje samo prodaju kartice zapakirane u lijepe kutije. Kod manlija nema ni kutije zato je jeftinije.
Sve kartice radi PC partner a jedino saphirre i gigabyte kolko ja znam imaju neke posebnosti i različitosti ali i njihove su kartice proizašle iz iste tvornice. Dakle kad je haj end u pitanju nemaš beda zato i pljuneš tolku lovu
A kaj se tiče nvidije ne bih se složio s tobom jer tamo npr imaš dvije revizije 5600 ultra sa različitim taktovima pa sad dolazi 5700 tak da je situacija slična.
Staro 24.07.2003., 01:17   #22
Jelc
Super Moderators
Postovi: 17,485
Pa i 9600PRO imaš sa raznim taktovima i memorijama...
A koliko samo različitih memorija ima na Sapphire-u nećemo ni pričat...
Staro 24.07.2003., 18:06   #23
Sky
Postovi: 4,085
Zbilja, koje sve vrste memorija koriste, kojih proizvođača?
Jel netko pokušao to sve objediniti na jednom mjestu?
Staro 24.07.2003., 18:22   #24
Jelc
Super Moderators
Postovi: 17,485
Imaš "Retail" i OEM...e memorija na OEM ti je bog te pita....hinyx,infineon,eltron tech.../ovo pouzdano znam za 9500 128/
A 9600 PRO naprimjer ori-điđi ATI ima memoriju brzine 2.8ns...
Ko bog će neke 9600 PRO imati 3.0,a neke možda čak i 3.3ns...
Najbolje ti je tražiti da ti izvadi grafu,lijepo zemeš povečalo pa pogledaš
Staro 24.07.2003., 23:09   #25
pinsla
pinsla's Avatar
Postovi: 1,860
Čekaj malo kakve veze sad 9600 pro ima??????
Čovjek je pital za 9700 pro a tu neće pogrešit kaj god da uzme jer sve imaju memoriju koja šljaka na 320.
A ne znam ni da će 9600 pro imat memoriju u tolko različitih varijanti mislim da se to više odnosi na ne pro varijantu.
I saphirre nema baš tolko različitih memorija ne znam na koje kartice misliš ali najćešće se pojavljuju samsung, hynix i infineon
Staro 24.07.2003., 23:22   #26
Jelc
Super Moderators
Postovi: 17,485
Pa o tom ti i pričam da UVIJEK najebu bar 3-4 različite memorije,pogotovo na OEM-u je živi tulum...
Evo-ja sam jedno vrijeme mjerkao Sapphire 9500 128 np...Hinyx,Infineon,EltornTech...ko bog ih ima još
A u pravilu se i slabo proizvođači pridržavaju ATI-jeve referentne sheme kaj se tiče memorije,/brzine/-na stranicama proizvođača taj podatak nebuš nigdje našao...
Staro 24.07.2003., 23:24   #27
Sky
Postovi: 4,085
Samo me je zanimalo kako stvari stoje. Nisam još 100% zapeo za 9700 pro, zato se informiram. Ako itko ima link na neku zanimljivu usporedbu...
Staro 24.07.2003., 23:48   #28
pinsla
pinsla's Avatar
Postovi: 1,860
pa to je zato da ti nije dosadno kad kupuješ novu grafu
A ti bi sad u šoping grafe ko da cigare kupuješ a ne mre to tak
Staro 24.07.2003., 23:50   #29
pinsla
pinsla's Avatar
Postovi: 1,860
a ti si fakat čudan tip
Pa kakve linkove još hoćeš' jesam li ti naveo sve žive atijeve kartice od najjače di najslabije jedva sam sve napisal zabole me prsti
A ti sad lako pronjuškaš za cijene i onda vpikneš ono kaj ti najbolje leži
Staro 25.07.2003., 14:23   #30
Sky
Postovi: 4,085
Ma nisi me skužio, pitao sam ako ima negdje nešto što bi morao znati prije kupovine ( ono, uzmi ovu memoriju, onaj layout, taj-i-taj proizvođač ima s time-i-time problema) A da nisam čudan, ne bi sad tu bio na forumu nego bi bio na moru, kupao se , škicao komade...
Thanx, pinsla
PS. Ma znam da ti nije niš teško dok ima veze s ATI-jem
