Staro 09.04.2006., 03:34   #1
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Silent PC (bez ventova na grafi i CPU)
Pozdrav!
Imam stariju konfu koja je malo bucna, htio bi maknut vent sa baze od CPU-a i s grafe... Na grafi sam vec skinuo staru zujalicu i stavio pasivnjak od Pentium 3...
Nego me vise zanima jel bi Colermaster Volcano 6 Cu+ mogao drzat P3 667MHz na normalnoj temperaturi bez venta? Jer vent radi na ~7000rpm, a to bas nije tiho... Ili ima kakva software-ska caka da se smanji turaža venta?
E da, grafa je GF2 Mx400.: goood :
Hvala
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 09.04.2006., 03:41   #2
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Speed Fan.
Ili kupi onaj potenciometar od 10kn i njega stavi.. I biraj dal želiš da ti komp leti ili da spava
žmnpp
Staro 09.04.2006., 03:46   #3
Panzer
Panzer's Avatar
Postovi: 1,814
Autor buljo
Kak to mislis?
Znaci bolje je da je vent gore? Onda cu probat nekaj iskemijat s poteciometrom...
UPGRADED...
Staro 09.04.2006., 03:54   #4
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Imao sam Vukana 6 +(k dB)
Ostavi vent ili ga promjeni, stavi neki tiši i kupi taj potenciometar.
žmnpp
Staro 09.04.2006., 19:57   #5
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,129
Ja sam pasivno hladio Celerona 633 samo sa aluminijskom bazom od nekog Socket A coolera... naravno, pasta Arctic Silver i proc nije prelazio 65° nikad. Ploca je bila Asus CUSL2-C, a kuciste neko govno koje nikad propuha vidlo nije Tako da vjerujem da bi se P3-ka mogla pasivno ohladiti sa nekim boljim bakrenim pasivnjakom Btw, razmisljam kako ohladiti proc, chipset i ram u jednoj HTPC konfi, pa sam si gruntao uzet 140mm vent iz Linksa i insalirat ga na plocu tako da pokriva i CPU pasivnjak i chipset i ram i MOSFET-e i sve zivo i mrtvo : cheers2 Mozda da probas tako nesto izvesti? :
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
Staro 10.04.2006., 01:39   #6
Panzer
Panzer's Avatar
Postovi: 1,814
Autor ^SuperUnknown^
Nije losa ideja... Samo mi se cini da je AGP na ploci otiso u k...
Ah, steta. Sutra moram istestat sve detaljno.
Ak nije, probat cu nekaj tak slozit, da ima propuh unutra.
UPGRADED...
Staro 10.04.2006., 02:48   #7
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Sa tog 6Cu+ makni 60mm cooler slobodno, taj dreci ko konj...
nadalje, makni i onaj crni pokrov s njega (na koji se sarafi 60mm vent)->tu ces mozda imat problema, al nekak ga makni
naljepi (ili necime priheftaj uz bazu) gore na bazu od 6Cu+ 80mm vent kojeg ces staviti na 5V (preko molexa ga spoji, naravno, moras onda kupit vent koji ima molex ili rezat zice i spajat ih, pa onda izolir trakom obljepit) - to ce ti biti jako tiho a ipak neces imat straha da ce nes pregorit od visoke temp.
S tako uredjenom bazom + 74mm vent (moj strgani vent sa freezera - ne pitajte kako ga je buraz stavio gore ) drzi palomina, koji ima Vcore na 1.75V na oko 40°C u idlu, load ide do 48°C
Ako drzi palomina, drzat ce i tog P3!
