Staro 21.09.2005., 16:04   #1
Mailman
Mailman's Avatar
Postovi: 1,606
Firefox 1.0.7
Firefox 1.0.7 is a security and stability release. We strongly recommend that all users upgrade to this latest version.
This version includes several security and stability fixes, including a fix for a reported buffer overflow vulnerability and a fix for a Linux shell command vulnerability.
Specific changes in Firefox 1.0.7
* Fix for a potential buffer overflow vulnerability when loading a hostname with all soft-hyphens
* Fix to prevent URLs passed from external programs from being parsed by the shell (Linux only)
* Fix to prevent a crash when loading a Proxy Auto-Config (PAC) script that uses an "eval" statement
* Fix to restore InstallTrigger.getVersion() for Extension authors
http://www.mozilla.org/products/firefox
Mailman je offline   Reply With Quote
Staro 23.09.2005., 18:49   #2
Red Worm
Plasticni kirurg
Red Worm's Avatar
Postovi: 1,214
bumo probali.
Red Worm je offline   Reply With Quote
Staro 23.09.2005., 19:09   #3
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Evo, vrti se
Staro 23.09.2005., 19:48   #4
Costa
Costa's Avatar
Datum registracije: Aug 2003
Postovi: 3,193
Ja vrtim 1.5 beta 1
Ima nekih promjena u brzini "back" i "forward" tipki, tj. sad se stranice trenutno otvaraju, brze prebacuje izmedju tabova, po defaultu ne prikazuje prozor kad ne moze ucitati stranicu vec ispise gresku u obliku stranice...
Staro 23.09.2005., 20:11   #5
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
?Pa stranice se trenutno otvaraju s bac i fw na svim verzijama. Nisam skužio nikakvu razliku u brzini kod bilo koje verzije:confused:
Staro 23.09.2005., 21:06   #6
SniperWolf
SniperWolf's Avatar
Postovi: 4,193
Evo baš imam instalirano, malo me iritiralo kaj su mi se izbrisale extenzije ali sam ih ponovno instalirao (npr PCekspert.com meni must-have ) i to
Pošteni Trgovci: 1,2
Staro 23.09.2005., 23:41   #7
No123
Lokacija: Grad na Dravi
Postovi: 580
Originally posted by Costa
Ja vrtim 1.5 beta 1
I ja
No123 je offline   Reply With Quote
Staro 24.09.2005., 03:16   #8
Costa
Costa's Avatar
Postovi: 3,193
Ima razlike. Ne znam kako je to rijeseno u 1.0.7 ali sve prijasnje verzije su radile kratku pauzu kod pritiska na back, sad je to neprimjetno. Probaj
Staro 24.09.2005., 14:34   #9
No123
Postovi: 580
Meni npr na ovom forumu: http://p072.ezboard.com/bvudreni sa svim ranijim verzijama Firefoxa kada se učitava stranica lijevi side bar se prvo razvuče preko cijelog ekrana i to stoji koju sekundu i tek onda se učita stranica kako treba.
Sa verzijom 1.5 beta se to ne dešava nego se stranica učitava kako treba odmah, bez širenja lijevog side bara.
I definitivno mi je brže, imam ISDN.
Staro 24.09.2005., 15:40   #10
Bran
nemam kaj napisati
Bran's Avatar
Datum registracije: May 2003
Lokacija: Međimurje
Postovi: 1,303
Malo se primjeti razlika u tome. Ništ posebno. Glavno da radi.
Staro 25.09.2005., 10:15   #11
Red Worm
Plasticni kirurg
Red Worm's Avatar
Postovi: 1,214
Je, primjeti se brze radi sedmica.
Staro 25.09.2005., 10:17   #12
Red Worm
Plasticni kirurg
Red Worm's Avatar
Postovi: 1,214
Staro 25.09.2005., 11:48   #13
SniperWolf
SniperWolf's Avatar
Postovi: 4,193
A i ova 2 posta su dokaz kako je nova ver bolja je tak?
Staro 25.09.2005., 13:16   #14
Red Worm
Plasticni kirurg
Red Worm's Avatar
Postovi: 1,214
Naravno. Neznam kako radi beta verzija. Si ti probao... ?
Staro 25.09.2005., 14:19   #15
SniperWolf
SniperWolf's Avatar
Postovi: 4,193
Zezam se, vidio sam doublepost pa ono
nisam probao betu ili jesam ali se ne sjećam
Staro 25.09.2005., 14:31   #16
Red Worm
Plasticni kirurg
Red Worm's Avatar
Postovi: 1,214
A to.. ma to je nesto forum stekao. Valjda izbacio dva posta. Nisam primjetio.
Staro 26.09.2005., 15:31   #17
SniperWolf
SniperWolf's Avatar
Postovi: 4,193
meni je isto jučer i prekjučer ko lud štekao nisam na ST topicu mogao postati:confused:
Staro 13.11.2005., 17:25   #18
Red Worm
Plasticni kirurg
Red Worm's Avatar
Postovi: 1,214
Moze li mi netko znati reci, u cemu bi mogao biti problem. To se danas pojavilo dva puta. Zavitlao firefox ko lud.. i samo po "gasu" nece da stane. :confused:
A CPU na 96 %
Slika dolje
Zadnje izmijenjeno od: Red Worm. 30.03.2006. u 18:31.
Staro 14.11.2005., 16:10   #19
Red Worm
Plasticni kirurg
Red Worm's Avatar
Postovi: 1,214
Nema nitko iskustva o turbo firefoxu. :confused:
