Staro 01.06.2012., 16:44   #1
Deyo238
Grazie Michael
Deyo238's Avatar
Lokacija: Ogulin
Postovi: 360
Catalyst 12.6 Beta
Win Vista/7 32-bit & 64-bit
Win XP 32-bit & 64-bit
With the release of the AMD Catalyst™ 12.6 Beta driver (“Catalyst”), AMD would also like to announce that we are moving away from our Monthly Catalyst release plan. Our goal is to ensure that every Catalyst release delivers a substantial benefit to our end users; as we have today with the release of the Catalyst 12.6a Beta. We will still continue with the Catalyst naming convention; Catalyst: Year.Month. You just won’t see a new driver every single month. We are confident that this will only benefit the end user; you’ll only need to upgrade to a new Catalyst driver, when it makes sense.
We would also like to announce the introduction of our new AMD Issue Reporting Form. We made a number of improvements to the older Catalyst Crew Feedback form, making it more comprehensive, ensuring high quality feedback. Feedback is very important in every product company’s life, especially in our fast paced environment. This is not just a check-box for us – we take these reports very seriously. We will review every report posted here and investigate every issue encountered. Please use this form whenever you encounter something worth mentioning.
Resolved issue highlights of the AMD Catalyst™ 12.6 Beta:
  • AMD Radeon™ HD 7900, AMD Radeon HD 7800 Tri-CrossFire™ configurations + Eyefinity BSOD when launching a DirectX application.
  • AMD Radeon HD 7900, AMD Radeon HD 7800 Eyefinity/Multiple Display configurations BSOD when using desktop applications.
  • AMD Radeon HD 7900, AMD Radeon HD 7800, and AMD Radeon HD 7700 cards hang when system goes to sleep.
  • Tearing on Eyefinity configurations when different display connector types are used.
  • Poor Elder Scrolls: Skyrim CrossFire scaling seen in AMD Catalyst 12.4 (back to CrossFire scaling found in AMD Catalyst 12.3).
  • AMD Catalyst Control Center – intermittently missing Overdrive page.
  • AMD Catalyst Control Center – missing GPU Activity gauge.
  • AMD Radeon HD 7900 CrossFire Configuration – system hang after cinematic in Call of Duty: Black Ops.
  • Crysis 2 -random system hangs when run in DirectX 9 mode.
  • Heroes and Generals: Blocky corruption in scenes with smoke effects when run in DirectX 11 mode.
  • Disabled HDMI audio when the connected HDTV is powered Off/On.
Feature highlights of the AMD Catalyst 12.6 Beta:
Dual Graphics enhancements – new application profiles
  • Supported Dual Graphics configurations:
    AMD Accelerated Processors for Desktop PCs
    • AMD Radeon HD 7660D (A10-5700)
    • AMD Radeon HD 7560D (A8-5500
    Notebooks with AMD Accelerated Processors
    • AMD Radeon HD 7660D (A10-4600)
    • AMD Radeon HD 7640G (A8-4500M)
    • AMD Radeon HD 7520G (A6-4400M)
  • New profiles have been added for the following game titles:
    • Diablo 3
    • Elder Scrolls: Skyrim
    • StarCraft 2
    • Portal 2
    • Call of Duty Modern Warfare
    • Call of Duty Black Ops
  • Future Catalyst releases will continue to add Dual Graphics support for additional titles
Build Info:
DriverVer=05/22/2012, 8.980.0.0000
8.98-120522a-139735E-ATI
Full Release Notes
CPU: Intel Core i7 3930k C2 Sandy Bridge E 3200MHz @ 4500MHz (100x45 @ 1.288V) HT enabled
CLR: Corsair H100x
MBO: ASUS RAMPAGE IV FORMULA
RAM: Crucial DDR3-1600 2x8GB + 2x4GB (24GB) @ 1600MHz - 10-11-10-24-1T @ 1.535V
VGA: KFA2 GeForce GTX1070 8GB EXOC
HDD: ADATA SUV800 256GB ++ WD BLUE WD30EZRZ 3TB ++ WD Blue WD6400AAKS 640GB
PSU: Corsair CS550M 550W 80+ Gold Modular
BOX: Jonsbo W2
LCD: DELL P2417H 24" LED @ 1920x1080
OS1: MICROSOFT Windows 10 Pro N x64
GSM: iPhone 11 black 4/64GB
ROM: latest iOS
Zadnje izmijenjeno od: Deyo238. 01.06.2012. u 16:54.
Deyo238 je offline   Reply With Quote
Staro 01.06.2012., 16:56   #2
2 die 4
2 die 4's Avatar
Postovi: 2,276
Konačno, ono čekam to ko kišu u pustinji!
Probam pa javim!
Radi ko podmazano.
Problem sa HDMI audiom je popravljen. Instalacija je prošla kao i inaće, samo sam zgazio stare i to je to.
BFBC2 radi normalno, ne vidim nikakve pomake naprijed ni nazad ali malo je ipak stabilniji FPS!
Toliko za sada!
RedGreenBlue
Zadnje izmijenjeno od: 2 die 4. 01.06.2012. u 17:10.
Staro 01.06.2012., 21:24   #3
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Vidi ti to:
With the release of the Catalyst 12.6 Beta driver, AMD would also like to announce that we are moving away from our Monthly Catalyst release plan. Our goal is to ensure that every Catalyst release delivers a substantial benefit to our end users; as we have today with the release of the Catalyst 12.6a Beta. We will still continue with the Catalyst naming convention; Catalyst: Year.Month., You just won’t see a new driver every single month. We are confident that this will only benefit the end user; you’ll only need to upgrade to a new Catalyst driver, when it makes sense.
Staro 02.06.2012., 11:22   #4
Goranbm
Goranbm's Avatar
Postovi: 1,238
Mislim da je ovo odlična vijest za sve korisnike
Goranbm je offline   Reply With Quote
Staro 02.06.2012., 12:02   #5
2 die 4
2 die 4's Avatar
Postovi: 2,276
Ujedno i objašnjava kašnjenje ovih, ali eto zato su za sada dobri!
RedGreenBlue
Staro 02.06.2012., 14:37   #6
doky
doky's Avatar
Datum registracije: Nov 2010
Postovi: 1,942
Kolko im je trebalo da ovo srede.
EDIT: Meni se smrzavalo i kada se monitor ugasio, a ne samo kada je cijeli sistem otišao u sleep mode. Iako je to sad popravljeno opet nisam sav sretan jer dok mi je monitor izgašen vent cijelo vrijeme mijenja brzinu, ili ubrzava pa se vrati opet na min. (30%) ili se ventovi gase pa se sami opet pokreću, nisam ziher. Mora da to ima veze s tom tehnologijom ZeroCore Power koja software-ski nije još uvijek najbolje riješena.
Zadnje izmijenjeno od: doky. 02.06.2012. u 22:04.
doky je offline   Reply With Quote
Staro 05.06.2012., 12:16   #7
rockstar16
rockstar16's Avatar
Lokacija: Nova Gradiška
Postovi: 31
Baš zbog takvih stvari više se ne igram sa betama. Jednom sam gotovo ostao bez windowsa i rekao nikad više. Sad više niti ne pratim te drivere, on me sam obavijesti i to je to, ali da su driveri sve bolji i bolji to definitivno.
Lijepe riječi i oružje otvaraju sva vrata.
Pošteni trgovci: 1; 2; 3; 4; 5; 6; 7; 8; 9; 10; 11
rockstar16 je offline   Reply With Quote
Staro 20.06.2012., 16:46   #8
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,949
Autor rockstar16 Pregled postova
Odlično to radi moran priznat
2,3 drivera su prošla ok, a onda se pri updejtu na 12.4. nešto poremetilo i sad ne mogu ni gore ni dolje Stoji 12.3. koji kad "pregazim" s bilo čime i dalje ostane 12.3. i još se tu i tamo ruši. Jedino šta još nisan proba, je potpuni cleanup svega šta ima ATI naziv u sebi, sve osin toga je propalo bezuspješno, a to sam odgađa dok ne uvatin slobodno popodne, kao danas...
EDIT:
Evo nakon šta san uvatija malo vremena i pobrisa ATI totalno sa PCa čisteći sve iz safe moda, te nakon repaira boota Wina koji se prilikom toga sjeba, napokon na 12.6. beta driverima. Useren im se u posa...
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Zadnje izmijenjeno od: Mr.Ex.President. 21.06.2012. u 12:12. Razlog: tipfeler popravljen
Staro 21.06.2012., 02:24   #9
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
EDIT:
Evo nakon šta san uvatija malo vremena i pobrisa ATI totalno sa PCa čisteći sve iz safe moda, te nakon repaira boota Wina koji se prilikom toga sjeba, napokon na 10.6. beta driverima. Useren im se u posa...
A samo da si odvojio minut-dva na čitanje foruma, vidio bi da su u 12.4 imali sitan bug (zaboravili promijeniti oznaku verzije)
Staro 21.06.2012., 09:55   #10
alengrosevic
alengrosevic's Avatar
Postovi: 3,785
EDIT:
Mislio si na 12.6 ili si zaista stavio ove iz 2010 godine?
Staro 21.06.2012., 12:12   #11
Mr.Ex.President
Torrent freek
Postovi: 3,949
Nije to mene mučilo Nego se kompletno raspao sistem automatskog updejta nove verzije, a i kad bi to šta se nalazilo na disku išao pregazit s nečim ne bi dobio ništa, odnsno ostao bi na 12.3. i nakon updejta...
12.6
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 29.06.2012., 09:27   #12
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
Izašli su i finalna verzija, al mi se ne da raditi thread
