Datum registracije: Oct 2010
Postovi: 3
Bnet thomson + airlive wl-5470ap (pptp)
/dev/ttyp0 0day 00:03:17 (none) kern.notice pptp[2597]: anon log[main ptp.c:292]: The synchronous pptp option is NOT activated 0day 00:03:18 (none) kern.notice pptp[2604]: anon log[ctrlp_rep ptp_ctrl.c:251]: Sent control packet type is 1 'Start-Control-Connection-Request' 0day 00:03:18 (none) kern.notice pptp[2604]: anon log[ctrlp_disp ptp_ctrl.c:738]: Received Start Control Connection Reply0day 00:03:18 (none) kern.notice pptp[2604]: anon log[ctrlp_disp ptp_ctrl.c:772]: Client connection established.0day 00:03:18 (none) kern.warn pppd[2590]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access 0day 00:03:19 (none) kern.notice pptp[2604]: anon log[ctrlp_rep ptp_ctrl.c:251]: Sent control packet type is 7 'Outgoing-Call-Request' 0day 00:03:28 (none) kern.warn pppd[2590]: LCP: timeout sending Config-Requests 0day 00:03:35 (none) kern.notice pptp[2604]: anon log[callmgr_main ptp_callmgr.c:231]: Closing connection (unhandled)0day 00:03:35 (none) kern.notice pptp[2604]: anon log[ctrlp_rep ptp_ctrl.c:251]: Sent control packet type is 12 'Call-Clear-Request' 0day 00:03:35 (none) kern.notice pptp[2604]: anon log[call_callback ptp_callmgr.c:78]: Closing connection (call state)0day 00:03:40 (none) kern.warn klogd: eth1 hy is 83050day 00:03:43 (none) kern.info udhcpc: udhcp client (v0.9.9-pre) started 0day 00:03:47 (none) kern.debug udhcpc: Sending select for 10.63.220.106... ... |
, pa eto stvarno ako bi mi netko mogao pomoć bio bih mu vječno zahvalan
0day 00:03:04 (none) kern.debug udhcpc: Sending select for 10.63.220.106... 0day 00:03:04 (none) kern.info udhcpc: Lease of 10.63.220.106 obtained, lease time 43200 0day 00:03:17 (none) kern.notice pppd[2590]: pppd 2.4.2b1 started by root, uid 0 0day 00:03:17 (none) kern.info pppd[2590]: Using interface ppp0 0day 00:03:17 (none) kern.notice pppd[2590]: Connect: ppp0 <--> /dev/ttyp0 0day 00:03:17 (none) kern.notice pptp[2597]: anon log[main ptp.c:292]: The synchronous pptp option is NOT activated 0day 00:03:18 (none) kern.notice pptp[2604]: anon log[ctrlp_rep ptp_ctrl.c:251]: Sent control packet type is 1 'Start-Control-Connection-Request' 0day 00:03:18 (none) kern.notice pptp[2604]: anon log[ctrlp_disp ptp_ctrl.c:738]: Received Start Control Connection Reply0day 00:03:18 (none) kern.notice pptp[2604]: anon log[ctrlp_disp ptp_ctrl.c:772]: Client connection established.0day 00:03:18 (none) kern.warn pppd[2590]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access 0day 00:03:19 (none) kern.notice pptp[2604]: anon log[ctrlp_rep ptp_ctrl.c:251]: Sent control packet type is 7 'Outgoing-Call-Request' 0day 00:03:28 (none) kern.warn pppd[2590]: LCP: timeout sending Config-Requests 0day 00:03:35 (none) kern.notice pptp[2604]: anon log[callmgr_main ptp_callmgr.c:231]: Closing connection (unhandled)0day 00:03:35 (none) kern.notice pptp[2604]: anon log[ctrlp_rep ptp_ctrl.c:251]: Sent control packet type is 12 'Call-Clear-Request' 0day 00:03:35 (none) kern.notice pptp[2604]: anon log[call_callback ptp_callmgr.c:78]: Closing connection (call state)0day 00:03:40 (none) kern.warn klogd: eth1 hy is 83050day 00:03:43 (none) kern.info udhcpc: udhcp client (v0.9.9-pre) started 0day 00:03:47 (none) kern.debug udhcpc: Sending select for 10.63.220.106... ... |
El Mattador
Lokacija: <->
Postovi: 1,946
Khm, sto se tice tvog problema stvarno ti ne bih znao pomoci ali dok se netko ne nadje da ti pomogne zasto jednostavno ne stavis da modem sam dize konekciju, das mu LAN adresu 192.168.100.1, dignes Airlive u cistom AP modu, ostavis adresu koja je i stavis IP adresu od modema kao gateway ? Stvar ce raditi sigurno. ![]() |
#3 | |
Postovi: 3
Postovi: 23,643
Bemu miša, šta nisi pogledao malo po forumu ? Carnet PPTP igrokaz jedva slućajno / namjerno radi samo sa WRT54GC (pazi: baš ta verzija sa origigi fw). Još je netko bio prijavio da je složio sa još jednim router - om, ne sjećam se kojim, evo našao TP-Link TL-WR340G ali vidim da ima više revizija pa opet nije siguro. Rješenja: - trampi / nabavi gore spomenuti router - nađeš neku kramu od kompa, staviš dvije mrežne i digneš neki linux u router funkciji - odustani od Carnet PPTP igrokaza |
#5 | |
Postovi: 3
pa zato pitam ovdje... možda se s ovim može a ja ne znam kako... |
Postovi: 23,643
Probaj, mada sumljam |
El Mattador
Lokacija: <->
Postovi: 1,946
Postovi: 23,643
@Matta Ovdje nije problem u uređajima nego u implementaciji PPTP u Carnet režiji, ista stvar / problem se pojavljuje i kod drugih ISP - ova u kombinaciji sa Carnet account - om. Mnogi uređaji imaju PPTP funkcionalnost ali samo par njih uredno radi u kombinaciji sa Carnet - om, nije moguće da svi proizvođači neznaju tu funkciju (način spajanja) napravit kako treba. Carnet je i htio otežati spajanje više kompjutera / kućne mreže preko osobnog account - a pravdajući se formulom "osobni account = jedno računalo" a dokaz tome je šta konekcija na kompu (Dial-Up) u Win i Linux os - u radi bez problema. |
Postovi: 23,643
Posudiš, probaš i javiš rezultat. Nije nitko prijavio jel radi - ne radi. |
Postovi: 78
evo da onda ja prijavim da bi trebalo raditi. Koristim Metro-Carnet koji isto treba pptp konekciju. u kombinaciji sa 5470AP-om stvar radi super. |
