Staro 07.12.2004., 21:34   #1
Costa
Costa's Avatar
Datum registracije: Aug 2003
Postovi: 3,193
Mozilla Thunderbird 1.0 NOVA VERZIJA
Evo jos jedan proizvod dogurao do jedinice
Homepage
http://www.mozilla.org/products/thunderbird/
Tek tolko da se zna:
When upgrading, all your Extensions and Themes will be disabled. This is not an issue, but it may appear to be one (hence its listing here). For rationale, see "Extension and Themes" above.
Latest Changes:
* Adaptive Junk Mail Controls
* RSS Integration
* Saved Search Folders
Saved Search Folders display messages based on previously set search criteria. For example, instead of filtering messages into a new folder, you can create a Saved Search Folder that lists all the messages received from a certain person over the past 30 days, even if those messages are stored in different folders and subfolders.
* Global Inbox Support
POP3 users can now combine all of their POP3 accounts into a single global inbox under local folders.
* Message Grouping
You can now group messages in a folder by attributes such as date, sender, priority or a custom label. For instance, a folder grouped by date will group messages from today, yesterday, last week, etc. into self-contained groups in the message list pane. (View > Sort By > Grouped By Sort)
* Privacy Protection
In order to help protect your privacy, Thunderbird now automatically blocks remote image requests in emails from senders you don't know.
* Comprehensive Mail Migration from other Mail Clients
Switching to Thunderbird has never been easier since Thunderbird can now migrate all of your email data including settings, mail folders and address book data from common mail applications such as the Mozilla 1.x Suite, Outlook Express, Outlook and Eudora.
Staro 07.12.2004., 21:42   #2
Overvide
Postovi: 540
nice sad pak treba i to skinuti a ja još nisam ni skinuo najnoviji firefox trebam nagovorit starce na napuštanje modema
Overvide je offline   Reply With Quote
Staro 08.12.2004., 11:08   #3
Veky
Veky's Avatar
Datum registracije: Nov 2002
Postovi: 1,950
jako dobro
Veky je offline   Reply With Quote
Staro 11.12.2004., 11:44   #4
miato
(°_°)
miato's Avatar
Postovi: 3,249
konacno i thunderbird da je 1.0.
sad mogu umrijet u miru
vec se skida
Staro 11.12.2004., 12:00   #5
Trek
Trek's Avatar
Postovi: 1,313
skinuo neki dan vrlo very nice je
samo jos sad idem ga natprat exstenzijama novim i pop gmail stavit
probo sam OE, obican outlock, poco, incredi, eudoru...
Ali thhunderbird mi je najbolji
Biti lud ima prednosti koje razumiju samo ludjaci
FKT meber jednog dana high priest...
Trek je offline   Reply With Quote
Staro 16.06.2009., 10:07   #6
karlito
sam svoj aka
karlito's Avatar
Postovi: 789
nisam otvarao novu temu, pa da tu pitam vezano uz Thunderbird
...zanima me kak bi napravio automatski forward, npr. jedan lik mi pošalje mail i da se svaki put automatski prosljedi jednom drugom ?, samo to, hvala
karlito je offline   Reply With Quote
Staro 16.06.2009., 10:27   #7
schetz
schetz's Avatar
Postovi: 1,570
imas opciju "create filter from message" .. naravno oznacis tu na koju si mislio i dalje ti je sve jednostavno..
izaberi onaj filter koji ti treba i to je to..
schetz je offline   Reply With Quote
Staro 16.06.2009., 10:28   #8
Buger
Postovi: 4,390
probaj
tools-message filters-i zdaja uvijet da ako ti je poruka od tog lika (match any of the following) - perform this action- forward message to...
Staro 16.06.2009., 10:50   #9
karlito
sam svoj aka
karlito's Avatar
Postovi: 789
e mislim da bi to ovak trebalo šljakati, daj mi samo odgovori na ovo pitanje sa slike
Staro 16.06.2009., 17:05   #10
Buger
Postovi: 4,390
stavi "contains"
Staro 16.06.2009., 18:24   #11
karlito
sam svoj aka
karlito's Avatar
Postovi: 789
Autor Buger Pregled postova
stavi "contains"
a i sa ovim "is" je radilo, fala ti
Staro 16.06.2009., 20:34   #12
denied
denied's Avatar
Postovi: 1,193
Kako napraviti u thunderbirdu account s aliasom (znači isti server i acc name - drugi mail) ili kako poslati mail s aliasa? Budući da ne dozvoljava dva accounta s istim serverom i loginom....
Sad sam prešao na win7 pa prelazak na neki mail client s OE/winmail je ko teški porođaj....
I jel se nekom desilo da kad napravi gmail acc odbija password (meni sad na mozilli, a to se prije i frendu na OE desilo)....
denied je offline   Reply With Quote
