Lokacija: Sarajevo
Postovi: 474
RAM problem... Trgovac me prevario ili je do Winowsa?
Dakle prije koji dan sam konacno dobio computer kojega sam vec davno platio i narucio.... Trgovac me razvlacio ko placu... To je sad nebitno... Kada sam ga kupovao dogovor je bio da ide 2 x 2GB Apacer 800MHz DDR2... Sinoc gledam malo sa PC Wizard 2008 sta mi je to sve stavio u stroj... Kad vidim ovo: "Physical Memory : 4096 MB (2 x 2048 DDR2-SDRAM )" Sad, sta to znaci? Evo vam jos neki detalji: > General Information : A0 : Empty A1 : Empty A2 : Empty A3 : Empty A0 (Bank0/1 ) : 2048 MB - DIMM A2 (Bank4/5 ) : 2048 MB - DIMM > Information SPD EEPROM (A0) : Manufacturer : Kingston Part Number : 2G-UDIMM Serial Number : 0C08ADAD Type : DDR2-SDRAM PC2-5300 (333 MHz) - [DDR2-666] Format : Regular UDIMM (133,35 x 3) Size : 2048 MB (2 ranks, 8 banks) Module Buffered : No Module Registered : No Module SLi Ready (EPP) : No Width : 64-bit Error Correction Capability : No Max. Burst Length : 8 Refresh : Reduced (.5x)7.8 µs, Self Refresh Voltage : SSTL 1.8v Prefetch Buffer : 4-bit Manufacture : Week 13 of 2008 Supported Frequencies : 200 MHz, 266 MHz, 333 MHz CAS Latency (tCL) : 3 clocks @200 MHz, 4 clocks @266 MHz, 5 clocks @333 MHz RAS to CAS (tRCD) : 3 clocks @200 MHz, 4 clocks @266 MHz, 5 clocks @333 MHz RAS Precharge (tRP) : 3 clocks @200 MHz, 4 clocks @266 MHz, 5 clocks @333 MHz Cycle Time (tRAS) : 9 clocks @200 MHz, 12 clocks @266 MHz, 15 clocks @333 MHz Min TRC : 12 clocks @200 MHz, 16 clocks @266 MHz, 20 clocks @333 MHz > Information SPD EEPROM (A2) : Manufacturer : Apacer Technology Part Number : 78.A1GA0.9K4 Serial Number : 02008194 Type : DDR2-SDRAM PC2-6400 (399 MHz) - [DDR2-800] Format : Regular UDIMM (133,35 x 3) Size : 2048 MB (2 ranks, 8 banks) Module Buffered : No Module Registered : No Module SLi Ready (EPP) : No Width : 64-bit Error Correction Capability : No Max. Burst Length : 8 Refresh : Reduced (.5x)7.8 µs, Self Refresh Voltage : SSTL 1.8v Prefetch Buffer : 4-bit Manufacture : Week 19 of 2008 Supported Frequencies : 200 MHz, 266 MHz, 400 MHz CAS Latency (tCL) : 3 clocks @200 MHz, 4 clocks @266 MHz, 5 clocks @400 MHz RAS to CAS (tRCD) : 3 clocks @200 MHz, 4 clocks @266 MHz, 5 clocks @400 MHz RAS Precharge (tRP) : 3 clocks @200 MHz, 4 clocks @266 MHz, 5 clocks @400 MHz Cycle Time (tRAS) : 9 clocks @200 MHz, 12 clocks @266 MHz, 18 clocks @400 MHz Min TRC : 12 clocks @200 MHz, 16 clocks @266 MHz, 23 clocks @400 MHz > Memory Controller Information : Memory Controller : System Memory Location : Mainboard Error Correction Capability : No Number of connectors : 4 Max. Module Size : 4096 KB Izvinjavam se sto vas opterecujem sa ovim, ali ne mogu nikako da uploadam slike na imagesack... Sredit cu to kasnije... Sada da pitam: Sta sve ovo znaci? Je li to znaci da me trgovac prevario i stavio mi staru memoriju koja je OC-ana jedno 1000000 puta ili da je nesto drugo? Molim za pomoc jer se u ovo i ne razumijem bas mnogo... Zadnje izmijenjeno od: d^_^b. 23.06.2008. u 10:44. |
konjpjukter
Postovi: 934
pa kolko vidim jedan keks ti je kingston a ne apacer !?!?!? i to 667mhz |
Ex-Gastarbajter
Lokacija: Zagreb / Rijeka
Postovi: 5,472
imaš dva različita keksa memorije. jedan je ovaj koji si tražio, a drugi nije ![]() jeli novo ili ne, ne znam, valjda je novo (ipak su svježe, 13. i 18.tjedan 08.). čovjek vidio da se valjda ne razumiješ toliko, pa stavio što se našlo u trgovini... |
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Šta ti kaže cpuz? Na koliko radi RAM? Ako se spustio na 667,zeznuo te..ako radi na 800,onda pc wizard laže ko pas ..i sve radi na 800...makar ova dva različita naziva..hmmm..weird..apacer i king.. |
#6 | |
Lokacija: Sarajevo
Postovi: 474
Primjetio sam da su razliciti sada kada sam otvorio... A gle, razumijem se ja... Samo sto nisam bas neki strucnjak za memorije... Znam sta valja, uzmem to i gotovo... BTW: Sta znaci ovo boldirano? Je li to znaci da je to vec neko ranije clockao ili je to tvornicki? Da li da ja to malo OC-am? |
Postovi: 12,431
Ono boldano su SPD postavke deklarirane za pojedini radni takt ne kužim odakle ti idea da to znači da je netko klokirao ram
Can You Hear Me? 142.8 dB
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
Danas je teško biti budala, prevelika je konkurencija... Water cooled PC Moj najveci MOD Novi hobby: RC model + HD kamera ![]() |
#9 | |
Lokacija: Sarajevo
Postovi: 474
Sad sam na vikendici pa cu otici krajem mjeseca... Inace zvao sam ih i rekli su kako nisu imali 2 ista keksa pa su mi uvalili razlicite... I prodali mi ih po istoj cijeni kao i ona 2 sto sam narucio... Vidjet cemo sta bude, rekli su da ce zamjeniti... Samo dok nabave robu- to ce se optegnuti... Hvala na pomoci... I jos jedno pitanjce... Posto je jedna 800MHz, a druga 667 MHz to znaci da mi obje rade na 667 MHz??? To pitam zato sto znam da je tako dok me trgovac uvjerava da se ova druga automatski dize na visi radni takt i da obje rade na 800MHz... Trebam to snimiti Gdje sam ja kupio comp :| |
Postovi: 5,458
Lijepo sam ti napisao..trebali bi se spustiti na 667..a ne da se ovaj sam od sebe clockne na 800... ![]() ![]() ![]() |
#11 | |
Postovi: 2,073
ma negdje je (čini mi se Razer) napisao da većina mema radi na manjem taktu, 667, a da moraš podignuti sam na 800 ili 1066(iako kupiš tu bržu memu) kao i latencije, mahom su 5-5-5-15, iako mogu biti 4-4-4-12 na istom naponu ionako se u svakodnevnom radu u winsima ne kuže neke drastične razlike. edit: našao: Citiraj:
čini mi se da je bilo govora da crucial 667 bolje ide od istih 1066 modula, pošto gotovo svi 667 idu na 1200MHz (neki i više), a čini mi se da to nije bio slučaj sa svim 1066 modulima... uz to, 2gb stickovi se clockaju lošije koliko sam vidio po forumu samo jedan od topica: http://forum.pcekspert.com/showthread.php?t=107975 a i 4GB je upitan odabir, no vjerojatno znas to iskoristiti na XP32? (zaključio po sp3 koji imaš, a nije izašao za 64bit xp)
Danas je teško biti budala, prevelika je konkurencija... Water cooled PC Moj najveci MOD Novi hobby: RC model + HD kamera ![]() Zadnje izmijenjeno od: TomRi. 23.06.2008. u 12:03. |
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
Noviji chipseti, pa i P35 sami podese DDR2 na 800MHz ako je tako deklariran po SPD-u. Na starijim chipsetima je trebalo naklokavati PC2-6400 da bi radio na tom taktu, sto je danas slicna situacija sa PC2-8500 memorijama koje se mora nagruvati OC-om da rade na toj frekvenciji. |
#13 | |
Postovi: 5,458
A dobro.. ![]() |
Lokacija: Dubrovnik
Postovi: 1,287
Dakle kao što su priznali jedan modul su ti uvalili ali ok. Drugo kad se nađu dvije različite memorije pod pretpostavkom da se kako tako podnose konfa bi trebala radit s time da će se automatski namjestit i radit po onoj slabijoj. (I latencije i frekvencije) To je naravno u globalu a ima ti milijun caka kad će bit ovako kad onako. |
Beskorisna bitanga...
Lokacija: Sesvete (Zg)
Postovi: 6,956
Ako rade u DCu na 800 ja se recimo uopće nebi zamarao sa vraćanjem, ionako je IMHO kingston bolja marka od Apacera... ![]() Ako ne rade u DCu e onda je to već nešto drugo...
-- Have a nice day... |
#16 | ||
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
#17 | |
Lokacija: Dubrovnik
Postovi: 1,287
Btw doznat ćeš da li su ti u dual channelu po tome kolika ti piše da je bitna tj. ako s nekim programčićem vidiš 64 bit single je ako je 128 bit rade kao dual. |
#18 | |
Postovi: 5,458
...mislimo isto![]() ne znam ponekad kao da turski pričam..lijepo mu kažem upali si cpuz,program ima valjda 500kb..pogledaj ako rade na 667,onda su te preveslali i uvalili ti jedan 667+ jedan 800...ako ti cpuz izbaci fsb meme 400..odnosno 800...to je to..no big deal.. a kao da taj vražji turski pričam..pa 5x treba reći istu stvar na različiti način.. |
#20 | |
Postovi: 5,458
![]() ,lakše mi njih kresnut nego space..jbg.Glavno da se skužiamo..![]() |
