Staro 01.03.2008., 14:29   #1
Vido
[SW]'V^idO
Vido's Avatar
Postovi: 424
Hamachi i Red Alert 2
Network: http://nabaci.com/viewimage.php?file...s/4rw74359.jpg
Kako to treba konfigurirati? Je itko uspio pokrenuti RA2 preko Hamachia?
Probao sam tražiti na netu, ali nisam našao na nikakav konkretniji opis šta treba napraviti.
Poz,
Imam instaliran Hamachi i Red Alert 2. Htio bih sa frendom igrati u multiplayeru. Kada idem u Red Alertu na Options i Na Network hoće IPX. Išao sam na Hamachiev network i instalirao protokol IPX, ali RA opet neće da se spoji sa frendom koji je učinio isto.
Ovako izgleda u igri pod Options-->Network: http://nabaci.com/viewimage.php?file...s/4rw74359.jpg
Member of [SW]' CoD2 clan. Join us!
Moji DIY projekti i sl.: http://vidosprojects.freei.me/
Vido je offline   Reply With Quote
Staro 01.03.2008., 17:19   #2
Neo-ST
Neo-ST's Avatar
Postovi: 8,574
Ovako piše u mom readme fileu:
LAN PLAY
1.Install tcpcom included. You will use it to make virtual Com connections to play RA over a null modem (really a LAN)
2.Visit http://planetcnc.gamespy.com/View.ph...rs.Detail&id=2 for detailed directions with nice pictures.
3. If you would like to tweak some settings find Rules.ini for RA on the web and paste it in your RA folder. Anyone you play has to have the exact same copy.
You can also tone down the Comp in these settings, it hits fast and hard, unless you like the abuse.
4. Quick summary...make the host a TCP Server and the other a TCP Client. Both will use COM1 make sure Virtual is checked, Baud rate 115,200. Also the TCP client computer needs to enter the host IP address. Activate.
Launch Red Alert. Click Multiplayer, Settings on both computers. Com1, Baud rate 57,600, Save. Select Serial Game and Null Modem on both computers. Adjest the settings as desired and play
Samo moraš skinit ovaj tcpcom file...
Staro 01.03.2008., 21:24   #3
Vido
[SW]'V^idO
Vido's Avatar
Postovi: 424
Ako sam ja dobro skužio ovo nisu upute za RedAlert2.
Ali svejedno ću malo pronjuškati...
Staro 01.03.2008., 22:12   #4
Mar
Suit up!
Mar's Avatar
Postovi: 5,975
Instalirajte IPX protokol i zadajte si fixne adrese, također u opcijama igre morate zadati iste *neke* postavke, nisam siguran što točno, bilo je davno.
I da, koristite malo stariju verziju hamachija, jer najnovija ne radi najbolje s RA2.
Za detalje proguglaj.
- Barney Stinson
Staro 08.03.2008., 15:50   #5
Vido
[SW]'V^idO
Vido's Avatar
Postovi: 424
Odustali smo od RA2, igra je legendarna, ali neće i neće da se pokrene. Zato smo krenuli na C&C3 Tiberium Wars.
Kompovi se lijepo vide i igra se može stratati ali uvijek, nekad prije nekad kasnije dođe Connection timeout ili tako nešto. Firewalli, antivirusi i sl. su ugašeni, prije njihovog gašenja to se događalo i prije, nije se moglo niti pokrenuti igru. Ima li još šta što može uzrokovati takve probleme? Neke postavke, nešto u igri možda?
