Staro 30.03.2021., 15:13   #1
Postovi: 6,773
Intel "Rocket Lake" LGA-1200 Info Thread
Intel Core i9-11900K Review - World's Fastest Gaming Processor?
It seems Cypress Cove is sometimes able to make up a two-core deficit against Skylake, but not always. When comparing against AMD's recent Zen 3 releases the Core i9-11900K can't impress.
Even in the equal-matched duel against the 8-core Ryzen 7 5800X, the i9-11900K loses with 3%. Against the 5900X and 5950X the gaps are big: 18% and 28% respectively.
  • Very high price for what's offered
  • Lower gaming performance than AMD Zen 3 and Core i9-10900K
  • Only eight cores (vs ten on 10900K)
  • Application performance can't even match Ryzen 5800X
  • High power consumption
  • Lots of heat once power limit unlocked
  • Only minimal software support for AVX-512 & DLBoost
  • Gear 1 memory mode unable to run modern memory speeds
  • Many BIOS bugs
  • Only one PCIe 4.0 M.2 slot, others are PCIe 3.0
  • CPU cooler not included
Izvor: Interneti
Staro 30.03.2021., 15:21   #2
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 4,434
A što nebi ovo išlo u Intel dio, a ne AMD?
Slobodno me dodajte na PSN
Staro 30.03.2021., 15:27   #3
Postovi: 6,773
Ide, ali ovo je taman tema za novi Rocket Lake. Još kad Pat (Gelsinger) a Mat pređu na 7nm i počnu proizvodnju za druge - milina.
Staro 30.03.2021., 16:03   #4
Nick7
Lokacija: Velika Gorica
Postovi: 1,469
Ako koga zanima taj Intelov minimalni (inkrementalni) IPC pomak po generacijama:
Core i7 All Generations (From 1st to 10th) | RTX 3080 10GB PC Gameplay Tested
Problem je sto ovo ne usporedjuje IPC, nego procesore. I tu cak nema nekih bitnih skokova.
Naime, svaki proc je na stock settingu, tj. 2600K je na 3.4GHz/boost na 3.8GHz, dok je recimo 9700K na 3.8GHz/4.9GHz boost.
Trebalo je napraviti 3 grafa:
1) Sve na stock
2) Svi procovi na istom clocku (npr 4GHz), i tu se vidi IPC napredak ili manjak
3) Max overclock
1 i 3 su da se vidi koliko su procevi jaci/napredovali, a 2 je bas za IPC napredak.
Staro 30.03.2021., 16:23   #5
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,137
Slažem se u pravu si. Krivo sam napisao IPC pomak nego sam opcenito mislio ako koga zanima generacijska razlika među i7 -icma u FPS-u.
To što govoriš je napravio Gamers Nexus u ovom videu donekle:
10 Years of Intel CPUs Benchmarked: i7-930, 2600K, 4790K, & Everything Since (2020)
https://www.youtube.com/watch?v=KPWEdbfJ0oE
Pak bum dobio po prstima za Intel OFF-topic u ryzen temi
Blue Spirit: IMDB popis i preporuke filmova... 100 najboljih filmova 21. stoljeća!...IMDB Top 1,000 movies .... Find similar movies https://i.imgur.com/Y9m9Ove.png
COD 141.11.196.66:28960 || COD 141.11.196.66:28940 || COD 185.107.96.125:28977
Staro 30.03.2021., 20:01   #6
Protupožarac
Lokacija: Tamo gdje sunce vječno sja
Sapunator. Kad te TechPowerUp koji ti je inače naklonjen ovako ocjeni, ne znam, ne znam...
  • Many BIOS bugs
Staro 30.03.2021., 20:08   #7
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,728
ok,par fpsova u odnosu na 10600k,već ima 11600k za 2100 10600k je 1800 kuna,fino nije vrijedan 300 kuna više.
prodajem starije komponente.
Staro 30.03.2021., 20:17   #8
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,747
Razmišljao sam o prelasku na lga1200, u rasponu od h510+pentium sve do z590+ i9xxxxx. Ali sam odustao. Jer mi je h510 razočaranje (m2 nije pcie4), Pentiumi su ostali isti i nisu postali punokrvni quadovi, a sve ostalo mi je realno nepotrebno. Ostajemo na lga775 i u 2021
| AMD Ryzen 5 4500U @2,30 GHz |
| Lenovo IdeaPad Flex 5 14ARE05 | 8GB DDR4 @3200 MHz |
| AMD Radeon Vega 6, Shader cores: 384 @1500MHz |
| SKHynix NVMe 512GB SSD | Windows 10 Home x64 |
| 14" LED @1080p | Logitech M720 | Sony XB-22 |
| Sony PS4 Pro 1TB |
| Sony KD-55XG8096 |
| Intel Xeon E3-1535M v6 @3,1 GHz |
| Dell Precision 7520 | 32 GB DDR4-SDRAM @2400 MHz |
| nVidia Quadro M2200, 4 GB GDDR5 |
| Toshiba XG5 NVMe 512GB SSD | Windows 10 Pro x64 |
| UltraSharp IPS-Display, 15,6" @1080p |
Campeonato je offline   Reply With Quote
Staro 30.03.2021., 20:39   #9
Dr. Strange
Datum registracije: Aug 2020
Postovi: 813
Znači još jedan šipak od velikog Intela...
Staro 31.03.2021., 00:25   #10
Postovi: 6,773
Heavy Metal Steve za novi Core i9 povlači usporedbe s Bulldozerom.
Staro 31.03.2021., 05:46   #11
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 4,434
Meni nikako nije jasan potez izdavanja ovih procesora.
Jel to oni moraju zbog dioničara ili koji vrag?
Staro 31.03.2021., 06:47   #12
MegaSkot
Modder
MegaSkot's Avatar
Lokacija: Waterford
Postovi: 907
Da.
Staro 31.03.2021., 10:30   #13
Postovi: 6,773
Da, to je to, cijelo vrijeme su igre u pozadini, isto kao s ovim silnim najavama za nove tehnologije, proizvodne procese i popratne kapacitete - samo da cijena dionica bude visoka i da se oda dojam snažne firme s jasnom vizijom i ciljevima.
Umjesto da se koji puta malo zamisle, priznaju da više nisu najbolji (nisu čak ni treći najbolji: TSMC, Samsung, Apple, nVidia, itd.), pa onda krenu s konkretnim planovima i rješenjima - ne - bacaj sve što dobro zvuči u eter, pa nek mediji kokodaču.
Staro 31.03.2021., 10:42   #14
Gigi1
Postovi: 2,138
Nisam više tolko prisutan na forumu, ali gdje vam je Mladen?
Staro 31.03.2021., 11:02   #15
Mladenxy
Mladenxy's Avatar
Postovi: 3,970
Autor Gigi1 Pregled postova
Zbog čega me prozivaš? Fali ti rasprava, dosadno bez mene
Evo kad želiš. Stveo kaže kupite Intel, i i to i5 10600KF za 1500 kn jer je Ryzen 5 precijenjen. Ima na njegovom kanalu da ne linkam, ne bi ni spominjao da ne uzburkam neke osjetljive duhove koji će se sada masovno javiti, ali s obzirom da me vučeš za jezik
Staro 31.03.2021., 11:09   #16
Protupožarac
Patetika.
