Super Moderators
Datum registracije: May 2002
Postovi: 17,485
![]() Catalyst 8.1 Hotfix The information in this article applies to the following configuration(s): Radeon™ HD2900 series Radeon™ HD2600 series Radeon™ HD2400 series Radeon™ X1950 series Radeon™ X1900 series Radeon™ X1800 series Radeon™ X1650 series Radeon™ X1600 series Radeon™ X1550 series Radeon™ X1300 series Radeon™ X1050 series Radeon™ X850 series Radeon™ X800 series Radeon™ X700 series Radeon™ X600 series Radeon™ X550 series Radeon™ X300 series Windows Vista 32-bit Edition Windows Vista 64-bit Edition Windows XP Professional Windows XP Home Edition Windows XP Media Center Edition Windows XP Professional x64 Edition This hotfix resolves the following issues: Fix for problems with DirectX and Radeon AGP Graphics cards. Crysis: DirectX 10 Performance optimizations using Crossfire http://support.ati.com/ics/support/d...estionID=31625 Izgleda da su se konačno sjetili AGP-ovaca ![]()
Postovi: 323
meni driveri nisu bas ok...jer kada sam stavio te nove nakon 7,12...i pokrenuo crysis...stekala mi je igra na pocetku i pokazivali se artefakti...i onda me izbacilo iz igre. Sada sam vratio 7,12 i sve dobro radi |
Postovi: 12,613
A gdje vi tu vidite podrsku za seriju 38xx? ![]() Edit: Sad vidim da su izasli driveri 8.1, a ovo je samo hotfix. Starim jbga ![]()
Prodajem kucu na klizistu.. Nije puno presla..... Member Of PC Ekspert 100+kg Demolition Squad NAJNOVIJE = Povoljno RAM..http://www.downloadmoreram.com/... tor i AMD kupili.... NOVO! Prodajem visokokvalitetni tropleteni hardverski konac za fixiranje coolera Zadnje izmijenjeno od: nino. 17.01.2008. u 00:24. |
#4 | |
Lokacija: Velika / Osijek
Postovi: 1,442
Sry za ovaj ![]() No on topic el ovo sljedeca verzija drivera nakon 7.12 ili je to samo CCC u novoj verziji jer na temi vezanoj se nije spominjala nova verzija... |
#5 | |
Super Moderators
Postovi: 17,485
http://forum.pcekspert.com/showthread.php?t=95279
Super Moderators
Postovi: 17,485
No dobro, kaj nema ni jednog ponosnog vlasnika sa AGP grafaom da javi da li su konačno sredili drivere ili ne??? ![]()
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
...šefe ako oni driverima isprave kršionu koju su izazvali..svaka im čast..ja sve manje i manje nekako sumnjam da je do drivera..makar je to logično..daj Bože...prodao sam MSI-jevu vrhunsku X1950pro nakon 2 tjedna jer sam izludio na AGP-u... ![]() ![]() ![]() prije da je jednostavno 6pina 2much za AGP port..pa je narodno veselje pri igranju igara..odnosno full loadu...možda je u struji problem..tko to zna..pa se sve skrši..zbrejka.. neka netko javi..ja bi rado..al sam na 3870 ![]() ![]() ![]() |
Datum registracije: Jun 2004
Lokacija: home
Postovi: 2
nevalja ti link bar meni ne radi http://tinyurl.com/2zn9m9 ja sam puknul 8.1 obicne i naravno da D3D ne šljaka...sad bum puknul fix ba bumo vidli. 1950GT AGP na KT600 sa Bartekom 3.2K |
Lokacija: home
Postovi: 2
Meni ne radi taj fix...uredno sam instalirao...ista greška D3D invalid call...hrpa sranja i ne radi... Bar rade driveri sa CDa, jedini koji mi rade ![]() |
Spam Witch
Lokacija: Belišće
Postovi: 94
Ja imam x1950pro agp sa instaliranim 8.1 i nemam nikakvih problema, 3dmark06 radi ok kao i sve ostale igre koje sad do sada instalirao, WoW, Bioshock, Loki. Uredno radi i jako sam zadovoljan. Probat cu jos par igara poinstalirati da vidim. |
Postovi: 102
Kum ima Powercolor 1950pro AGP. Stroj se ne ruši ali povremeno je slika zbrčkana u igrama(oveći kvadratići, zazeleni se na tren, krugovi koji blješte itd.). I to sa bilo kojim driverima(6.11,7.1, 7.2, 7.6, 7.12, 8.1, 8.1fix). 3dmark06 prolazi ali na Canyon flight i Deep freezu isti slučaj kao i na igrama. Jel imaš ti iste probleme? To je nekakav Dell. Napajanje je 460W pa tu ne bi smjelo biti problema. Temperature: idle-42,3dmark-60. |
Spam Witch
Lokacija: Belišće
Postovi: 94
Ne nije mi se srusio od kad imam ovu karticu komp a i temperatura mi je puno manja, na 3dmark06 (prolazi cijeli test) mi ide o/cana na 43°, a ne o/c je u full loadu oko 38°, u windowsima (idle) mi je temperatura kartice izmedju 32-35°, nema nikakvih promjena boje ili bilo kakvih problema koje si naveo, a takodjer imam Powercolor x1950pro verziju, do sad sam je isprobao na slijedecim igrama: Loki, WoW, Overlord, Bioshock, Team Fortress 2 i sve radi za 5. Mozda da pogledas kakva je situacija sa pastom na hladnjaku? Znam da sam ja imao problem sa 6800gs kad sam je kupio, u idlu je bila oko 75° a full load skoro 100° pa kad sam skinio pasivac imao sam sta vidit, pasta lose razmazana i djelomicno kao razvodnjena, pa sam stavio novu i skino temp za 30 tak stupnjeva. |
