Staro 02.01.2008., 15:26   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Radeon Omega Drivers v4.8.442 for Windows XP/2k
Evo i najfriškijih (bazirani na 7.12)
Veli on vako:
Happy New Year!!!
Couldn't start the year without a bang, so here it is, this time for the ATI fans since I have made them wait since October, new Omega Drivers for Windows XP based on the official Catalyst 7.12 drivers.
What's New in Omega Drivers?
v4.8.442[*] Based on the Catalyst 7.12 Official drivers.[*] Major video card support rewrite from scratch. This time every Radeon card under the sun should be supported, if the divers don't install on your card you either have a freak of nature card or a card too new that not even the ATI has support for it. (Many thanks to all the people that sent their unsupported IDs)
[+] Added support for desktop HD3k Series and laptop HD2k Series.
[+] Experimental Gamma settings. Now whatever gamma setting you set on your desktop should pass on to your 3D applications. (tested with Adobe Gamma)
[+] The "temporary" fix for AGP cards still included. Waiting for ATI releases an official fix... *sigh*[*] Upgraded installer to reflect logo/site changes.[*] Upgraded drivers to v4 because of the previous details, plus thanks to a new install method I found, reduced the driver's size by a lot without loosing any features or options.
Known Issues:
1) After installing the drivers you will notice that they give you version number 3.8.442 instead or 4.8.442, no need to worry, is just a typo, sorry about that, I added the new version number when I was building the new installer and totally forgot about the driver build, since it was already compiled.
2) For the 2D->3D gamma trick to work properly you must NOT run CCC (if you have it installed); when CCC is open it forces it's own gamma settings overriding any gamma you have set using a 3rd party tool. If you happen to open CCC by mistake, in order to recover the gamma correction values, you only need to run whatever gamma program you use and gamma should be back to your settings again.
3) Since Overscan has been from the drivers, if you need to connect your PC to a regular TV that DOES need overscan in order to view it properly, you need to install the official CCC Control Panel from ATI after my drivers so you have access to the new "scaling" feature and scale the overscan to fit your needs.
4) From Cat 6.6 and up ATI removed driver-level support for the following series of cards (including Mobility models): Radeon 7k, 8k, 9k-9250 Series. Since the Omega Drivers use ATI drivers as a base, that means they will also not include support for these chipsets, they may install, but the PC may give you a BSOD or a black screen upon boot, install newer drivers at your own risk. People that need to install Omega Drivers on these cards should use v3.8.252 or older, you can get these on the Archive section of my site.
What's new for ATI Tray Tools?
1.3.6.1067 Beta
[F] Fixed localization for CrossFire dialog window
[*] Updated ini files handling procedures to be more compatible with Windows Vista
[*] Improved compatibility with IE7 under Vista with UAC enabled???
[+] Added new localizations
[+] Added option to change "Black and White level"
[F] Fixed OSD rendering problem with Overlord game. (Thanks to Unwinder)
[+] Updated Overlay color handling procedure to support new ATI Overlay color modes
[+] Implemented Save/Restore icon positions under WinXP 64 and Vista 64.
[+] Updated support for Adaptive AntiAliasing. Added support Multi-Samplinmg and Super-Sampling modes
[+] Monitoring Graphs window now can be sent to system tray.
[+] Added option to auto load Monitoring Graphs window at start up
[+] Added option to hide tray icon on load. You can restore icon to access settings by starting ATT again. This will not load second copy of ATT in memory, but will send command to show tray icon. Also created new hotkey to hide and show tray icon.
[+] Added configuration option hide_display to hide Displays menu.
http://www.omegadrivers.net
Uskoro izlaze i za Vistu
Staro 02.01.2008., 16:54   #2
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Nice, ubrzo stavljam pa javim dojmove. Valjda sad budu Tray Tools-i radili na HD3850.
Staro 02.01.2008., 17:02   #3
Jelc
Super Moderators
Postovi: 17,485
Autor SRV Pregled postova
Ako misliš na overclock-mislim da neće
Staro 02.01.2008., 17:19   #4
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Ma mislio sam na sve - oc, regulacija venta, profili i sl. Necu onda ni stavljat ako overclock nece radit, ne volim koristit vise utility-ja. A Riva kad postavi odredjeni takt, on ostane i u 2D modu. CCC ne stavljam ni za zivu glavu
Staro 02.01.2008., 18:09   #5
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
Evo vidis srv to sam i ja mislio. Onda sam stavio CCC. Mracno dobro radi. Mracno.
Ja sretan uglavnom.
naravno dok ne izace ATT sa podrskom
Staro 02.01.2008., 21:24   #6
Chosen
Banned; neopisivo
Postovi: 231
trenutno imam drivere za grafu iz siga koju sam dobio sa cd-a...jel bi dobio na perfomansama kad bi ovo stavio?
Chosen je offline   Reply With Quote
Staro 02.01.2008., 21:27   #7
Fleks
JDM
Fleks's Avatar
Postovi: 6,137
Dobio bi.
Staro 02.01.2008., 22:31   #8
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
steta sto neazuriraju nvidia drajvere inace kad sam imao atia samo omega je bila kod mene
.i.
Razer Blade 15
Staro 02.01.2008., 23:09   #9
Jelc
Super Moderators
Postovi: 17,485
Autor Codiac Pregled postova
Promjeni cvikere
Prije par dana su izašli novi i za nevidiu-samo kaj mi se nije dalo postat a poslje sam zaboravio...
Bazirani na službenim 169.21
Eh ti nevidiaši...sve im moraš nacrtat
Staro 02.01.2008., 23:36   #10
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
@Fleks: mozda na kraju i stavim CCC ako se umorim od cekanja postene verzije ATT-a. Ima li CCC regulaciju brzine venta, makar za 2D i 3D mod?
Staro 03.01.2008., 11:02   #11
The Satara
The Satara's Avatar
Postovi: 417
ccc nema nikakvu regulaciju brzine venta, ali je po meni trenutno najbolji za oc 3850 (samo za one kojima je 770mhz dovoljno, ofkors )
atitool mi smrzava komp, a riva (kako je već spomenuto) zakuca taktove na istu vrijednost u 2d/3d modu što dovodi do znatno većeg zagrijavanja u 2d.
on topic: jel netko isprobao ove drivere? jesu bolji šta od vulgaris 7.12?
The Satara je offline   Reply With Quote
Staro 03.01.2008., 11:51   #12
Fleks
JDM
Fleks's Avatar
Postovi: 6,137
Nisam probao cekam da proba neko drugi
@Stevo: Nema nazalost... Al sta nisi ti uzeo accelera??? A att cemo cekat jos neko vrijeme kako se cini. Lik na forumu tam zica da mu ekipa da pare za hd3850 da moze napisat podrsku za nju kad sam zadnji put gledao, naravno niko ga ne dozivljava
Staro 03.01.2008., 11:59   #13
Chosen
Banned; neopisivo
Postovi: 231
Jedino imam na kompu UT3 pa će mi to poslužiti kao za test
1280x1024 sve moguće opcije upaljene na max i aa..me sve
Ovo su sa driverima koje sam dobio uz grafičku.Piše na cdriver version 12-083
idem sada staviti omega drivere pa se strpite malo dok nebudu stavljeni
edit:
eto stavljeni su omega i osim što mi nakon svakog resetiranja kompa izbacuje neke erore[koristio sam driver cleaner pro 1.6[zadnji]] ali sam to riješio,u igrama je sve isto.Isti fps ista grafika...uopće nema razlike..tako da sam se opet vratio na starije drivere koje sam imao
Evo i slika sa omega:
Zadnje izmijenjeno od: Chosen. 03.01.2008. u 12:29.
Staro 03.01.2008., 13:27   #14
Codiac
bycod
Codiac's Avatar
Postovi: 6,699
Autor Jelc Pregled postova
Promjeni cvikere
essssssssssss a pazi ovo prije tjedan dana sam trazio drajvere sa omege jer sam stavio bio nove windowse i banana i onak ljut koji k i evo ih sad
.i.
Razer Blade 15
Staro 03.01.2008., 21:55   #15
Jelc
Super Moderators
Postovi: 17,485
Pa tak su negdje i izašli-prije 6-7 dana
I za XP i za Vistu.
Staro 03.01.2008., 22:14   #16
sipe
sipe's Avatar
Postovi: 993
Jer se isplati staviti na hd3870? Jer ako nema nikakvog napretka ne isplati se sve bristati itd...
sipe je offline   Reply With Quote
Staro 03.01.2008., 22:20   #17
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Autor Fleks Pregled postova
Kakav te Stevo spopao?
Accelero S1 nisam uzeo jer ga u tom trenutku nije bilo. Eno jos uvijek ga nema.
Staro 03.01.2008., 22:46   #18
Fleks
JDM
Fleks's Avatar
Postovi: 6,137
Od sad tebe zovem Stevo
Accelera ces se nacekat ako je suditi po linksovom forumu. onak cim dodje se razgrabi, a imaju opet male kolicine trazene robe... Ja sam svog kad sam ugrabio imao vise srece nego pameti. Isto tak i sa grafom...
