Staro 08.11.2006., 18:52   #1
B3mt1
Chipokemon
B3mt1's Avatar
Postovi: 339
Uplink
Treba pomoc u vezi te igre (ako netko zna), zapeo sam na jednoj misiji.
Na gornjoj slici, crveno zaoukruzen tekst, kojom kombinacijom ga trebam upisati u one lijeve kucice (u koju kucicu ?, koja rijec ide u koju kucicu ?) da predjem misiju
Piracy helps stop global warming.Insted of driving to get CDs, buying pre-packaged software from megacorporations and wasting energy,you can help fight Global Warming by using P2P.Help save resources,fight pollution and save the enviroment.
-It`s what Jesus would do.
B3mt1 je offline   Reply With Quote
Staro 08.11.2006., 19:38   #2
horza
ono ispred konpjuktora
horza's Avatar
Datum registracije: Apr 2003
Postovi: 3,659
jaooooo pa neko josh igra uplink!!! genijalna stvar, šteta što je razvoj stao prije nego što je dovršena komponenta za halanje preko neta... ovo je negdje druga ili treća misija u prvom setu
kewl...
doh... ne sjećam se više... vjerojatno u college moraš upisati university degree , a u qualifications management. ... javim se s update-om ako iskopam negdje. btw, svaka čast što to igraš
Horza (death dwarf)
birthsign: rebel
character perks
major skills
greater powers
artifacts of choice
Staro 08.11.2006., 19:54   #3
horza
horza's Avatar
Postovi: 3,659
Class 3).
- Add an Other Qualification.
Commit the Update, disconnect. Reply the mission.
Mutiple of these mission can be done at once, because of the enormous trace.
http://db.gamefaqs.com/computer/dosw...e/uplink_b.txt
update: ovo bi moglo pomoći..
Hack the system. You'll have much time, sometimes about 900 seconds. Search
for the name. Now you either have to:
- Add a Graduate Qualification with Class (Mechanical Engineering, Class 1).
- Change Graduate Class (Class 1 --> Class 3).
Horza (death dwarf)
birthsign: rebel
character perks
major skills
greater powers
artifacts of choice
Staro 08.11.2006., 20:37   #4
OveRkiLL
Registered Abuser
OveRkiLL's Avatar
Postovi: 590
meni je isto zakon, al ne bi škodilo da je malo lakša
AMD Ryzen 7700X + Noctua NH-D15
Asus X670 Prime
2x8GB Kingston Fury Beast 6000MHz CL40
XFX RX6800 16GB Qick 319
Kingston NV2 250GB + Crucial P5+ 1TB + Seagate 2TB HDD
EVGA 650W SuperNOVA GQ, 80+ Gold
Fractal Design 7 Compact
23.8" AOC 24G2SPU 165Hz
Windows 10 x64
Logitech G402
Razer Cynosa V2
OveRkiLL je offline   Reply With Quote
Staro 08.11.2006., 22:11   #5
B3mt1
Chipokemon
B3mt1's Avatar
Postovi: 339
Autor horza Pregled postova
je, tak je, thx a lot
imas mozda neke hintove za mene pocetnika ?
i imam jos jedno pitanje, ako kupim novi gateway, da li moram kupovat novi proc, memoriju, modem ... ili mi preseli s starog ??
EDIT:
jos jedno pitanje, koliko sam skuzio kada se disconnectam on naparavi log, znaci uvijek ostane neki trag, ima li tome pomoci ?
Zadnje izmijenjeno od: B3mt1. 08.11.2006. u 22:28.
Staro 08.11.2006., 22:26   #6
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
Eeeee, vidis kako si me dobro podsjetio Mogao bi zaigrat malo to!
Tomo je offline   Reply With Quote
Staro 08.11.2006., 22:35   #7
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,463
mislim da imaš za kupit onaj log eraser... ali ako si preko više jumpova spojen nema zime...
mogo bi i ja opet počet to halat...
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 08.11.2006., 22:48   #8
B3mt1
Chipokemon
B3mt1's Avatar
Postovi: 339
Autor Renesis Pregled postova
imam log deleter v.4 i izbrisem ja sve logove na target serveru i onda se disconectam, a kada se disconectam on napravi log na target serveru da sam se disconecto (tj. ostavi trag s mojim IP-om)
Staro 08.11.2006., 22:54   #9
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,463
hmm, kako onda ono ide... vidi ako nema da se stavi da ostavis neki program na napadnutom kompu koji iza tebe počisti...
Staro 10.11.2006., 07:15   #10
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
Mislim da nesmijes nigdje ici vise nakon sta izbrises logove , ja ovako radim izmjenim IP adrese (uzmi od nekog privat lika), izbrisem sve logove i srusim server i nisam imao problema
Jedno pitanjce za sve vas dali itko igra ili je igro CRACKER , ja probo i nejde previse mi je tesko za snac se u igri
' alt='' border=0>
Vejita je offline   Reply With Quote
Staro 11.11.2006., 02:20   #11
B3mt1
Chipokemon
B3mt1's Avatar
Postovi: 339
moram se pohvaliti
kupio sam si napokon monitor bypass i htjeo sam ga malo testirat tako da ukradem nesto para, naravno napravio sam backup save (da nebi trebao opet ispocetka ako zaribam)
i tako ja idem po acc.-ovima i saljem si pare (sve neka sica) , na trecem acc.-u vidim pod transakcije da je lik nedavno jednom liku poslo 1,3 mil kredita (ja sam osto paf), brzo pisem IP banke i acc. no. na papiric, taman sto sam to napiso trace-ali su me (pasivno)
nista za to, stavljam backup, odem u tu banku prebacim si pare, brisem logove, disconnect i taman se spojio na svoj acc. da i tamo izbrisem log, kad ono ulovili me, vec sam pomislio da necu nikako doci do tih para
opet dizem backup, samo sada sve puno brze radim, i uspio sam, bogat sam
odmah sam si uzeo najjaci gateway (s 8 proceva) i sav moguci softver : goood :
hihi, kako sam happy
Staro 11.11.2006., 11:01   #12
horza
horza's Avatar
Postovi: 3,659
dada... igra fakat zna izbezumit čovjeka i onda si totalno hepi kad sjedne lova
fakat... malo je igara danas koje daju takav feeling postignuća. prezakon.
Horza (death dwarf)
birthsign: rebel
character perks
major skills
greater powers
artifacts of choice
Staro 11.11.2006., 13:37   #13
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
ima tko mozda kaku stranicu za uplink addons ,ja sam naso jednu ali sve je kodirano s binhex 4.0 a nigdje nemrem to naci , ili ako ima taj program ili link gdje da ga se najde
' alt='' border=0>
Staro 11.11.2006., 17:29   #14
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,463
evo i ja opet počeo igrat malo pomalo idem sada se igram sa voice recognitionom, firewall i proxy bypass v3.0 su već u garaži
Staro 12.11.2006., 01:12   #15
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,463
Da vidimo majstore... kako se ulogirat na LAN server i onda pobrisati fajle sa nekog kompa? imam lan scan, lan force, jel mi treba i spoof?
Staro 12.11.2006., 01:23   #16
hmmm
hmmm's Avatar
Lokacija: ???
Postovi: 370
ok moze mi netko objasnit zasto mi kada igram uplink CPU usage stoji na 100%
mislim na pravi cpu(athlon 3800+) ne onaj u igrici.
EDIT: ma daj bezi imam dojam da me ovo hakersko cudo skenira : paranoid
Zadnje izmijenjeno od: hmmm. 12.11.2006. u 03:42.
hmmm je offline   Reply With Quote
Staro 12.11.2006., 11:34   #17
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,463
nemam pojma, nisam išao za time... ako i piše 100%, nije sigurno, jer meni je temp oko 46, dok je full load oko 51... po tome znam najbolje
Staro 12.11.2006., 12:46   #18
B3mt1
Chipokemon
B3mt1's Avatar
Postovi: 339
Autor hmmm Pregled postova
meni isto radi na 100%, ali nema veze ionako je zima
Staro 12.11.2006., 12:49   #19
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,463
nego bemti, jel znas ti hakirat LAN sustav?
Staro 12.11.2006., 12:56   #20
B3mt1
Chipokemon
B3mt1's Avatar
Postovi: 339
nope, ne radim ja bas one obicne uplinkove misije, cekam mail od Arnomoura da nastavim special, ali nista zasada
Staro 12.11.2006., 13:41   #21
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,463
ah, vidiš, mogao bi i ja, koje su specijal misije, ja sam to sve bio odje...
a i šta napravit kad ti moraš prenest novce na drugi acc, a tip nema toliko novaca na accu?
Staro 12.11.2006., 15:02   #22
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,688
odlicna igra...makar malo preteska.
Problem je online   Reply With Quote
Staro 12.11.2006., 17:13   #23
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,463
ulovise me
bio sam drugi agent u firmi, i na jednom serveru, čim sam se spoji, odmah su me ulovili??? ništa, sada isponova, mogao bi probat i onu neku spcije misiju
Staro 12.11.2006., 21:11   #24
hmmm
hmmm's Avatar
Lokacija: ???
Postovi: 370
ma meni je to sumnjivo, jos neznam kako ali je. proc mi stalno radi na 100% a za jednu igru koja je najslicnija Ogameu to nije normalno.
googlao sam i jos se neki ljudi zale na istu stvar.
temp mi je bila na 35 u full hladnoj sobi jer sam taman dosao doma i upalio grijanje.
se mmoze u toj igri saveat ili se mora ponovno krenut kad te ulove?
Staro 12.11.2006., 21:42   #25
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,463
isponova...
Staro 12.11.2006., 23:11   #26
B3mt1
Chipokemon
B3mt1's Avatar
Postovi: 339
posalji mu para s svog racuna
backup-e save-ova radi
Staro 13.11.2006., 10:05   #27
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,688
Sorry na OT, ali jeli ko od vas igral Defcon?
Staro 14.11.2006., 06:18   #28
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
Dali itko je uspio provaliti lan imam samo 60 sec a nisam tako brz , a imam sve custom stvari ( ELD-16200 Server gatway)i odaberem 50+ linkova i nema pomoci
' alt='' border=0>
Staro 14.11.2006., 11:37   #29
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,463
ja se isto nisam uspio skužiti kako...
mislim da ti obavezno treba onaj LAN_spoof prije nego što bilo što pokušaš...
Staro 15.11.2006., 12:12   #30
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
Prvo skeniram i dobijem oko 30-40 novih stvari tipa modem , system security i onda pocnem gasiti 1 po 1 ostane mi oko 30 sec i puf naso me dobro ali ja provaljujem jedan lan kaj sam ja sam napravio tako da je sve high security. I dali je itko otkrio kako nekome unistiti zivot
' alt='' border=0>
