Staro 11.06.2006., 18:12   #1
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Vasi planovi za buducu nadogradnju konfi...
Znaci, kaj planirate u skoroj buducnosti kupit u vezi nadogradnje konfi? Ili u daljoj buducnosti.
Ja npr. planiram 2x1GB memorije, i hladenje koje sam vec poceo realizirat...
Dok za drugu konfu planiram kupit 3x256MB SD-RAM-a...
Jos sam planirao kupit neki volan, ali to samo ako ce bit viska novaca...
U daljoj buducnosti planiram neki D805 i Asus plocu ili mozda cak i Conroe ali to jos nije ziher...
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 11.06.2006., 18:39   #2
baterija
baterija's Avatar
Lokacija: ̣
Postovi: 1,019
Nista.
Salim se, grafu naravno...
Hardove sigurno....
baterija je offline   Reply With Quote
Staro 11.06.2006., 18:42   #3
Facelessone
Facelessone's Avatar
Postovi: 4,204
e ovak:
ovu grafu cu urat na reklamaciju poslije ljeta vjerojatno, kupit cu logi x-530,chieftec big tower kuciste, napunit ga sa tihim ventovima, i hdd 250gb.
sta se tice performansi, nist jace mi netreba od ovog
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 11.06.2006., 18:44   #4
csx
csx's Avatar
Datum registracije: May 2005
Lokacija: .
Postovi: 875
grafa, tipkovnica, i to je to za sljedecih godinu dana
csx je offline   Reply With Quote
Staro 11.06.2006., 18:46   #5
Router
Hejter
Postovi: 6,521
adsl , pa modem proci i umjesto njega creative zvucna , jos jedan hard od min. 80gb , i mozda neka grafa u rangu x1800gto/7600gt .
Router je online   Reply With Quote
Staro 11.06.2006., 18:47   #6
Razer
Razer's Avatar
Postovi: 11,642
Veći/više hard-ova, jaču grafu, novo napajanje, kućište i grafu...
Staro 11.06.2006., 18:52   #7
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
Veci HDD, LCD 17'', mozda zvucnici (2.1) i mozda TV karticu... to bi bilo to...
EDIT: i da 2x 120mm i modat kuciste
Zadnje izmijenjeno od: Tomo. 11.06.2006. u 19:27.
Tomo je offline   Reply With Quote
Staro 11.06.2006., 19:05   #8
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,507
Sutra stiže 6800LE 16,6, zatim kasnije nadam se: 160GB umjesto ovog, Logitech X530, stišati još komp, 19" CRT. Uglavnom, zadovoljan sam... Samo koliko će to dugo trajati... :-)
Staro 11.06.2006., 19:12   #9
John Creasy
Vocna iglica u mudante
John Creasy's Avatar
Lokacija: Beograd
Postovi: 2,837
Samo ram jer sam konfu kupio prije 2 mjeseca.
I mozda neki monitor.... ..
Staro 11.06.2006., 19:20   #10
Mr. M
Postovi: 718
novo kuciste i ventove, memu, hard mozda, a kasnije i grafu...
Mr. M je offline   Reply With Quote
Staro 11.06.2006., 19:22   #11
Roller
Lokacija: Sisak
Postovi: 1,127
Autor John Creasy
Još 2 wlan kartice na atheros čipsetu, serversko kučište sam već riješio u kojeg mogu ugurat miktorik i još jedno računalo, te neki p4/amd 1-2-1.8GHz da vrti game server.
Roller je offline   Reply With Quote
Staro 11.06.2006., 19:25   #12
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,463
NIŠTA.
Skupljam pare za novu konfu, radim vodeno, i nacrt za novu kantu
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 11.06.2006., 19:27   #13
frANZi
Dr. Gonzo
frANZi's Avatar
Postovi: 958
Matičnu za Socket A, neko kučište da mogu složit pristojno hlađenje + hlađenje, karticu za gledanje TV-a, hard 300+ gb za arhiviranje, možda grafu, i naravno novu tipkovnicu i miš te možda neki lcd (al' to ako bude para, a sad se trenutno nema para ni za šta ). I da, 512mb meme.
:clap:
frANZi je offline   Reply With Quote
Staro 11.06.2006., 19:34   #14
Roller
Lokacija: Sisak
Postovi: 1,127
Autor Renesis
NIŠTA.
Vidi se tko je zadovoljan svojim računalom
Ili jesi, ili nisi nikad, pa uvijek težiš nečem još boljem, a niti nemaš dobar razlog za kupnju jače kartice, proca ... ova kanta koju turpijam sad je čist ok za sve igre, premda igram samo 2 koje baš i nisu zahtjevne: cod:uo i tu i tam cod2.
Staro 11.06.2006., 19:39   #15
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,463
a i u planu je neki serverček za wifi, pa ono...
mislim da nema smisla stavljati ništa više u ovu konfu. vrti sve kako treba, meni dosta.... čak je i ova voda unutra privremeno, selit će se u novu konfu kad bude... a onda ova ide opet na zrak...
Staro 11.06.2006., 19:43   #16
John Creasy
Lokacija: Beograd
Postovi: 2,837
Sta je cudno s onim mojim postom? Imao sam ram, pa mi onda nije trebao, al sad vec pomalo pocinje falit.
A monitor spada u periferiju pa njega ni ne racunam, a i njega sam imao.... ..
Staro 11.06.2006., 20:00   #17
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Najvjerojatnije sutra idem po nx6125 (hehe ima Sempron64 mobilca unutra,tako da više neću biti Intelektualac, prelazim u drugi kamp ).
Također ovaj tjedan ću nabaviti jedan disk, ciljam na Maxtor Diamondmax 10 od 160 Gb pa ako neće raditi, šaljem ga u tvornicu : cheers2
120 mm vent i modat kućište weee
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
Staro 11.06.2006., 20:15   #18
h3lld
Disturbed
h3lld's Avatar
Lokacija: Bogu Iza Nogu
Postovi: 1,420
17" LCD i drugo ama bas nista... jedino sutra idem po przilicu, ali to je visa sila na djelu...
-potpis-
h3lld je offline   Reply With Quote
Staro 11.06.2006., 20:30   #19
mat
Postovi: 2,105
ja si uskoro rezem stranicu na kucistu i bubam na nju ovo i zaslon sa kucista ovaj od naprijed
isto tako cu onu dolje rupu za zrak iskoristit za jos jedan vent od 92 ili 120mm, vidjeti cu
naprijed umjesto zaslona ide 120mm
imam jedno napajanje, 775 plocu, dolazi kuciste s aukcije a hardova fala bogu imam malih tako da kroz mjesec dana ce se ustolicit jos jedna slicna ovoj dolje konfi, samo ce bit s pci grafom, manje rama itd... kasnije uzmima conroe-a i stavljam ga u trenutnu konfu, a jedan od 2 630 će ić u tržnicu
eto
e da i kupujem novi hard svakih cca 1,5mjeseca
mat je offline   Reply With Quote
Staro 11.06.2006., 20:31   #20
mat
Postovi: 2,105
Autor h3lld
e da i to isto brijem, al na jesen tek...
Staro 11.06.2006., 20:55   #21
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
monitor neki 19" ili možda čak i veće (polovno ofkors)
512 rama
neki malo bolji volan da mogu LFS igrat kako treba na netu
možda neka pci-e grafa
Staro 11.06.2006., 21:12   #22
blozer
Doktor znanosti!
blozer's Avatar
Lokacija: Zg,Peščenica/borongaj
Postovi: 1,311
Kaj mislim kupiti?
MBO + PROC+ mema + grafa + hdd + kučiše + napajanje : D
ma skoro sve.. i to u roku mjesec dana
blozer je offline   Reply With Quote
Staro 11.06.2006., 21:33   #23
Overvide
Postovi: 540
Ili novi komp ili za stari još diskovlja, ram-a, dvd pržilicu, tv karticu, miš, možda kućište i možda još jedan monitor.
EDIT: I neki printer, skener... Nešto 3 u 1.
Zadnje izmijenjeno od: Overvide. 11.06.2006. u 22:02.
Overvide je offline   Reply With Quote
Staro 11.06.2006., 22:11   #24
h3lld
Disturbed
h3lld's Avatar
Postovi: 1,420
ja 17" lcd tek za bozic jer imam u 8 mjesecu maturalac u Prag, to mi treba jos oko 1.5k kn, taman za monitor...
-potpis-
Staro 11.06.2006., 22:18   #25
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Iskreno,ljeto ide i u gadnom sam škripcu sa cashom općenito..jesen bi trebala biti druga priča,tamo oko Infa na velesajmu negdje...2x1giga ddra500 ocz eventualno...i možda malkice veći hard,160,200gb sata150...i to bi bilo to..
E,i adsl...jasno..a iduće godine,ili krajem ove..eventualno ubodem neku malo jaču zvučnu i zamijenim iliti prodam svoj monitor..i uzmem lcd 19" LG...
No to su zasada puste želje..trebao bi najesen početi raditi pa eto..vidjeti ćemo..dosta je to nofca..ram je u dućanu skoro 2k kunića...: baad :
Staro 11.06.2006., 22:51   #26
Dawar
OMG, thats the funky shit
Dawar's Avatar
Lokacija: in The Republic of Peščenica
Postovi: 1,221
Ja sam uglavnom kupio sve kaj sam i mislio još novo kučište i ako bog da krajem ljeta prodam 2x512 i kupim 2x1gb sticka a krajem godine neki LCD
Dawar je offline   Reply With Quote
Staro 11.06.2006., 23:01   #27
LARN81
ghotic warrior
LARN81's Avatar
Lokacija: Jastrebarsko
Postovi: 398
Do jeseni cu realizirat :
2x1gb ddr memorije
a , volio bi :
Modularno napajanje...zbog kablova (iako mi nije neka hica)
i mozda Logitech G15 tipkovnica...
LARN81 je offline   Reply With Quote
Staro 11.06.2006., 23:09   #28
Željac
sto da napisem ?!
Željac's Avatar
Postovi: 880
kod mene polagano nova grafa, prije bih htio ubost poštenu TV karticu i miran sam neko vrijeme !
Staro 12.06.2006., 00:14   #29
TomG
TomG's Avatar
Lokacija: Munich
Postovi: 2,222
Planiram kupiti nowi proc,grafu,matičnu...kučište chuftek ,napajnje itd...swe nowo...
Staro 12.06.2006., 00:26   #30
speedy-3
speedy-3's Avatar
Postovi: 458
mene ofa konfka zadovoljava trebalo bi jedino vise rama ali nema mi smisla to sad uzimati kad ce za god, mozda dvije ionako bas MORAT cjela nofa konfka HDD je tini mini, grafa za 3Ds ni najmanje nie oke a ni CPU ni RAM za rendanje,,,,,,,
na ovo ce jos jedino wi-fi kartica i mislim da je to zadnji upgrade prije nove konfke
speedy-3 je offline   Reply With Quote
